PDA
View Full Version : 3rd Gen Dakota
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54
  1. Lowering Gear Ratio help
  2. 2007 dodge dakota power steering leak
  3. seats
  4. PCV valve
  5. LED light bars
  6. 2007 Dakota, 4.7 L flex fuel
  7. P2096 + p0133
  8. Sputter/die issue, ever resolved?
  9. Squeak after struts
  10. 2005 Dakota 2wd 3.7l Trans Pan rusted
  11. BFG All Terrain KO2
  12. Interest in OEM Dakota wheels
  13. Frequent/repeated failure of power window switch cluster
  14. Suspension
  15. Dash lights out
  16. vibration
  17. Learned something new and may help others
  18. Has anyone ever noticed?
  19. Strange noise that I cannot find
  20. U1120
  21. Replacing motor in a 2005 Dakota 4.7l
  22. Can a trans blow out the rad?
  23. Lugs
  24. 255/70/18s with 3" PA Body Lift, No Leveling Kit?
  25. Front End
  26. 360 Magnum Swap
  27. Leveling Kit
  28. 3rd gen dakota help
  29. 2007 Dakota cruise control issue
  30. Grill and Tires, First truck responses appreciated.
  31. 2005 3.7 Dakota slt 2wd
  32. Can you rotate seats?
  33. 09 Dakota 4.7 Oil Consumption
  34. Shes breathin now
  35. To chip or not to chip ?
  36. 2007 Dakota 4wd starting issue
  37. Rear Main Seal
  38. Loss of power on slight inclines.
  39. multiple cylinder missfire and rough idle. 2005 dodge dakota 4.7L 4x4 QC
  40. Front end Moog parts help
  41. Rear light problem - night lights not working
  42. Intermittent nasty hard shift/lunge/buck
  43. lack or loss of power
  44. replacing knock sensor on 2007 dodge dakota im stuck
  45. Wouldn't start
  46. Bolt removal
  47. Occasional remote start problem
  48. should i buy this dakota
  49. how to remove front bumper cover 2007 dakota
  50. My Dakota is going downhill fast!!Need Some Advice
  51. HVAC question
  52. Jack My Ride????
  53. instument panel removal
  54. Longer Sway bar end links?
  55. Need suggestions
  56. Adding power seats and Windows and anything else I can
  57. Grinding in the diff or the tranny?
  58. Ignition Coils
  59. Sudden loss of power steering. Fluid res full
  60. 2006 dodge dakota P0452 code
  61. Air bag dash light
  62. Where to start???
  63. Seat belt buckle locked
  64. Transmission problem
  65. Paint code
  66. Need to know steel brake line dimensions asap
  67. 5.7 Hemi Swap!!!! 2005 DAK
  68. 09 v8 Evaporator Drain
  69. Auto transmission lugs motor at a stop
  70. fuel pump time
  71. New exhaust system
  72. getting to hot
  73. v8 to v6 with parts truck
  74. Shaky Truck
  75. 09 Dakota Rear Air Bag Suspension
  76. Amplifier hook up with aftermarket radio
  77. 285/75/16 tires rubbing on dakota frame.
  78. 2005 door wiring
  79. 2005 Dakota brakes
  80. 3rd gen diff drop kit
  81. 3.7 to a 4.7
  82. Turboing a 4.7
  83. Another round of "What sound is this?"
  84. Doing brake job, can't find caliper bracket torque specs
  85. OBD II Sensor Error Reading
  86. 2005 Dakota 4.7 to HO swap
  87. would like more power
  88. Lowering info/parts
  89. Tcm
  90. 2005 Dodge Dakota modelST, Replaced ECM
  91. got a P0452 code
  92. Tie-down hooks under spray-on liner
  93. Intermittent starting issue
  94. 4x2 to 4x4 Conversion
  95. Quick additive's & a general diagnosis quesion.
  96. Buying an 07 Dakota-What to look for
  97. cam positioning sensor
  98. Doing a fluid change and need bolt torque specs
  99. Engine problem DESPERATE FOR HELP
  100. Acceleration problems
  101. Transfer case issue
  102. 2008 Dodge Dakota 3.7 engine
  103. Key Fob Programming w/1 key
  104. Top strut nut quick question
  105. 2008 Dodge Dakota 3.7 water pump replacement
  106. Spark plug question
  107. Camber bushing squeak
  108. Fix my 42rle
  109. 42rle trans swap
  110. Bed mounted cargo basket
  111. Hate being the new guy but have a few quick questions
  112. Transmission temp light/solonoid pack replacement
  113. Brakes losing pressure in reverse only.
  114. Doing Struts Saturday
  115. 3rd Gen guys using torque app...
  116. Neutral Safety Switch Location
  117. Park lights
  118. 06 Transmission Temp Issue
  119. wheel bearing hub 2010 dodge dakota
  120. 2008 dakota
  121. P1776 And P0700
  122. Going through front brakes like crazy
  123. dual exhaust conversion
  124. Mopar Performance Cat-Back Exhaust System by Borla
  125. Are all 05 4.7s as gutless as mine?
  126. Air bag light
  127. possible t case issue? help
  128. Part compatibility
  129. Positive camber after 2"leveling kit
  130. Help with power window connector
  131. front end work question.
  132. Help finding the best lift
  133. Tire and Wheel Questions
  134. No power in 2005 dakota
  135. Blown Monroe Shock
  136. Just bought a new dakota! with transmission problems......
  137. A lot of Codes Bad PCM?
  138. DTC B1BA8, using other scan tools other than starscan
  139. Central PA Members with a 3rd gen?
  140. Adding power windows switch
  141. Line Out Converter install questions for amp
  142. to keep or not to keep? repairs are coming....
  143. Can anyone recommend any 2" lift blocks for the rear?
  144. Infinity Sound System CD Player
  145. Is there a spring in the lower rad hose?
  146. Had to have a little transmission work
  147. Why my keyless is not working?
  148. Tires tires and more tires
  149. Home built suspension lift
  150. Will not engage reverse
  151. 2005 Dakota 2dr Club Cab 131" WB SLT Transmission question.
  152. Squeaky Leaf Springs : Need Plastic Inserts
  153. ANybody know how to remove this electical connector??
  154. Air bag wiring
  155. Bumper Replacements
  156. Reset PCM
  157. leveling kit attempt #2
  158. dakota size with cummins grunt
  159. power steering transfer lines
  160. Poor fuel milage and losing speed on highway
  161. carrier caps
  162. 08 Dodge Dakota Lift Kits
  163. U-Joint Swap
  164. Manifold Bolts
  165. Synthetic Oil Issues
  166. Spark plugs
  167. Brake question
  168. '05 Dakota Master Power Window Controller Removal
  169. Dakota/Durango Parts
  170. So... about them mods...
  171. Center Console
  172. Ball joint and inner tierod
  173. Free, Immediate 2005 Dakota FSM and Dodge Build Sheet, and more...
  174. New Hubs & Rotors: Loose Fit...How to Make Tight?
  175. CD Problem-Truch does not recognize CD Player
  176. Difference in quality of Sensors
  177. 3.7 noise cold
  178. Getting new exhaust and a true Dyno Tune for HemiBlue
  179. Getting ready for e-fan
  180. Cat back straight pipe, codes?
  181. 4wd problem?
  182. Strange issue with dead battery
  183. 2011 Dakota Front Signals...
  184. Towing Question
  185. 2005 Dakota SLT 2WD Pulse while braking.
  186. Water in the fog light housing
  187. another trailer wiring discussion
  188. finally in the air
  189. we all have it?
  190. New Scanner
  191. 02 cap on a 010
  192. Trans coler line
  193. power stearing issues and how i think i fixed it
  194. Strange trans issue
  195. *Official* Projekt Dirt's Long Travel Build
  196. Led light bar wiring question.
  197. Bedliner on inner fender
  198. LED Light Bar
  199. Replaced LR Door
  200. 07 Dak, Starter motor ... Help- pics + youtube vid
  201. Time to say goodbye
  202. monroe 58650 -load adjusting rear shocks
  203. 2 in drop on 4x4 Dakota2005 ???
  204. wipers
  205. Cam postion sensor...
  206. 245/70/16 stock... what other size can i run?
  207. 2006 Dakota problems
  208. 2007 Dakota power for rear defroster
  209. Links to Service/Parts Manuals
  210. Leveling kit problems! Help!
  211. 05 dakota 4.7 threw some tanny codes
  212. Where to find door skins
  213. inlet/outlet size
  214. Levelling kit nightmare
  215. CEL - Plethora of codes barely runs
  216. 2 things
  217. head lamp switch
  218. Any help appreciated
  219. Bull bar install
  220. Yet Another Front End Noise Thread
  221. Adding Power Door Locks- New to forum
  222. Low idle, oil light flashes
  223. 2010 Dodge Dakota Big Horn
  224. 07 Dakota
  225. Hub Assembly PITA - It's Stuck Good...Ideas?
  226. Front end noise
  227. Emission Inspection Hell
  228. 2007 3.7L Issues
  229. Where to find Gear Ratio
  230. disc brake pad anti rattle clips
  231. Oil Light on Startup
  232. 2007 Dakota Does Not Crank
  233. operation rip and tear is in full effect
  234. Tire and rim question
  235. Wiring a utility winch
  236. front end work
  237. Another 3rd Gen Front Suspension Problem
  238. Free wheeling hub conversion kit for 05 Dakota?
  239. 2005 Dakota, 4 Wheel Drive Fuse?
  240. Cylinder 1 Misfire touble code p0301
  241. goodbye DF
  242. Rancho RS5757
  243. Duralast Ball Joint
  244. ran outta things to bitch about
  245. Force Key Fob Lock
  246. P vs LT tire preference
  247. Yellow Fuse
  248. Pulley Noise When Cold
  249. 05 Dakota front driveline
  250. Keyless Entry and CTM
