- rear differential issues
- help
- What are opinions on swapping rack and pinion for a gear box
- locking tire in bed
- Mud Flap suggestions
- anybody used oreillys Masterpro parts? looking for tie rods
- Wet front passenger carpet
- replace cv boot? or replace entire axle?
- 5.7 swap help
- 2007 Dakota Signals & 4 way flashers not working
- install a new trans temp gauge
- trouble cranking 05 dakota
- Steering Locked Up When Stopped in Reverse
- superchips+68.5mm TB upgrade
- question;
- TIP: always double check ujoints before install to save headache
- Tranny solenoid pack replacement
- Exhaust manifold leak
- rear differential on 2005 4x4
- Front bearing and axle question
- Please help!! Fuel and or intake issues
- Water
- Lower radiator support tie bar replacement??
- 2005 Dodge Dakota 4wd problem
- anti seize on spark plugs. Yes or no?
- Stumbles from idle
- Truck turned off by itself
- Key / Remote 2007 Dakota
- Double din install into 2008 Dakota
- Oil pressure
- Slamming steering wheel all the way to left/right?
- Is the GF Performance Chip any good?
- Anybody ever painted the stock steel 16x7 wheels?
- add a leaf spring 05 dodge dakota
- suspension drivetrain noises after leveling/lift kit
- key fob wont work after battery replacement
- What's the sensor thing on the bottom of the overflow res? And how do you drain it?
- A remarkable MPG
- Superchips Issues?
- 9.25" Differential clutch pack retainer broke need advice
- 2007 Dakota Wiper issue
- E-fan contoller
- daystar 2inch leveling kit
- Night runner headlights with chrome trim?
- Speaker size?
- 2010 Dodge Dakota SXT 4WD 4.7 L
- 2005 Dakota will not stay running
- front sway bar
- Power steering help
- Which type of levelling kit?
- Strange sound
- Tune Up Time!!!
- 06 dakota transfercase temp
- Replaced my spintech with a borla.
- rugged tarrain or grabber at2
- LED lights and part #s
- Front stut design change?
- Clicking after 35mph and clunking from dead stop in 4wd
- high pitch ringing until i hit breaks
- Paint code
- I broke my slider. Where to buy a new one?
- 06 Wiper arm and possibly bracket
- what do you use for fog lights
- Needy help..
- Engine sounds like a jet engine
- So I put my sway bar back on.
- 2009 dakota transmission fluid change Intervals
- Swapping out parts
- Common problems
- Need help !!
- front end still shaking
- Tow Mirrors
- Need longer Shocks
- p0300 code
- bedrail-, bulkhead- and tailgate caps
- Dodge Dakota Rust Warranty
- 21.7 mpg!
- 08 headlights suck
- 06 dodge dakota 4x4
- Fuel Consumption V8 4.7 Crew Cab
- 3.7L Exhaust
- Leaf Spring Cracked off! ( foot and half ) pics *+ discuss
- erase check engine light code
- 2005 dakota slt tire fitment
- A/C Evaporator Coil leaking bad
- Tranny just went out and I have a question.
- Sounds like Manifold leak?
- buying my third dodge.
- High Idle
- Squeaking high and low...
- new lug nut help
- Custom Bumper Build- Info Hub -
- Question about front seat replacement ..
- top and bottom control arm shot????????
- u-bolts
- Jack My Ride
- Programming Only Remote Fob (no sentry)
- Hate factory bed anchors. What to do?
- Digital Gauges
- 3.7 Exhaust systems
- Pulling to the right???
- Will these Headers fit?
- Intermediate Steering Shaft Lube
- Double Din Stereo in 2011 Dodge Dakota
- Seat Creaking
- 2011 Dakota Navigation Interchangeability
- Help: City light not working
- 2005 Dakota 3.7 Transmission Issues
- E-brake
- 2009 4.7 EGR Valve
- Make it look nasty!
- Correct Air Suspension Pressure?
- Warning lights flash on and off
- E-Fan Issue
- Lifting 3rd GEN dakota
- throttle cable tension
- 2009 Dakota, DTCs
- Fuel Injector Wire Harness Replacement
- rear brake line leak ( need help thread )
- Is this not a good idea?
- Anyone bought a cargo net?
- exhaust before axle
- New to outfitting
- E-FAN Taurus Fan and other 2 speed fan setup
- Is it this hard to replace front rotors?
- Code P0740 Torque Converter Clutch Solenoid Circuit
- Stumbling idle/stalling
- Lift springs!!!!
- whats it worth?
- Slight overheating after new A/C compressor
- transfer case
- My recent project-FINALLY
- auto trans filter kit and recommended fluid
- Noise While Driving
- add a leaf "?"
- cut departure angles in the bed.
- Muffler and resonator
- Tired of the grouper lip.
- 9ASCAP and P0457
- RPM and Oil Pressure
- Aftermarket Radio and another Qs
- new idea for high angle front axle shafts
- Front end vibration after Rack & Pinion replacement
- Amsoil!!!!!
- 4x4 gear swap
- Trying to burnout
- no gears not even park
- Transmission line booster
- A/C issues
- clutch petal height
- rough idle
- wipers won't park
- wipers won't park
- need to replace my front wheel hubs looking for suggestions
- emergency- Just replaced water pump- now engine shaking and ticking
- Heated mirror upgrade
- 06 Dakota 4.7L V8mag 4x4 slt Help.
- Where to find a new bumper? Victim of hit and run :(
- front end squeaking need advice!!!
- Vibration when accelerating
- Electrical issue 4.7 05Dakota
- Can a 2nd gen Dakota Canopy fit my 3rd gen?
- Questions about 2005 Dakota Quad Cab 4WD I just bought
- cd's stuck
- headers, are they worth it?
- Best upgrades for the money
- Who has an aftermarket dual core radiator?
- 05 Dakota leaking passenger side & frozen ac lines Help please!
- damn radiator trapped!
- 2008 Dakota Laramie UConnect Question
- steering box leak.
- rancho with monroe????
- Volant 16947
- Exhaust
- Parked Dakota hit hard. Transmission OK?
- air/fuel problemos.
- Disappointed in 05 V6
- alternator
- Error code P0404 EGR
- Lowering
- New Project... In Bed Power Outlet
- Glaring 3rd Generation Dakota Problems?
- Dodge Dakota Hard Shift When Outside Temperature is Hot
- wheel noise issue.
- 2010 front level lift
- Need front U joint + help please
- Project: 305/65r17 with no lift
- 5.2 vs 4.7 Seat of pants dyno
- P0420 After Dual Exhaust Install
- 2005 dakota slow forward movement, hard reverse shift
- replacing my transmission tomorrow at shop few questions
- Shave OEM Air Intake like a CAI Tube?
- 2007, front passenger window will not go down.
- Billet Intake Manifold Adapters... Any input?
- Heat Shield for Intake Manifold? Yay or Nay
- Time For Struts
- Spark gap way off
- Switched Octanes, wanna switch tunes
- Sticky Suggestion: Paint/DIY/Mods- Before & After
- True Dual Exhaust
- '08+ Intake Manifold
- Sway Bar Bushing 2005 Dodge Dakota Can't Find
- Prep Ex. Manifold for Re-Install ???
- 05 Dakota SLT 3.7L ABS Wheel Speed Sensor Not Connected!!!!
- How to install headers - DIY
- 2006 Dodge Dakota - Broken Ring Bolts
- 2006 dakota 4x4 trying to engage but won't
- Can't Find New Hardware for Valve Cover.....
- Wire loom for engine bay
- Front struts...
- NAPA Sway Bar Link Rusted n Replacing Tie Rod End
- Evaporator drain 2006 Dakota
- 2006 Dakota A/C evap drain location????
- Quick Question about Pads
- '08 engine swap
- Got bored with the welder...
- fuel pump
- HHR Fan Install
- O2 sensor connector
- Tips on disconnecting power steering rack lines
- P0456 p0457
- mpg readout margin of error
- Superchips
- PO300 Engine Code 2007 Dakota 4.7 Magnum V8
- Steering Wheel 06 Dakota
- Newbee with two questions .....
- 06 Dak keeps throwing codes
- 2008 Dodge Dakota SXT 2WD Ext Cab - Gas Mileage Issues
- 4wd Grinding Noise
- new radiator + switched to synthetic HM oil
- Vader get's a lift..
- Trans problems?
- Rubbing / Vibration when applying brakes
- IAT sensor
- issues
- Trans cooler
- Yay or Nay?
- replacing my radiator
- Passenger Side Coils
- cv half shaft assembly
- Can't figure it out
- Runs hot sometimes
- Headlight replacement parts
- Power Steering
- truck wont start..
- TB whistle?
- 08+ Dakota, Leather steering wheel
- trans shifting too early while cruising
- Lift Blocks
- full float rear axle options
