PDA
View Full Version : 3rd Gen Dakota
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54
  1. 2010 Dodge Dakota Big Horn 4.7 No Crank
  2. Gen 3 Dakota Blend Door Actuator replacement help?
  3. 2005 Dodge Dakota Key Sentry problem
  4. Thermostat Change and Coolent Burp Steps??
  5. Shorten steering column?
  6. Interior lighting
  7. 2008 Dakota quad cab 4x4 leaf springs.
  8. how to replace 2005 front half shaft
  9. 2006 rack and pinion
  10. Aftermarket speakers
  11. Where is the fuse to turn off four-wheel-drive Transfer case motor is switching from
  12. Truck dies at random, 05 laramie
  13. 2008 no heat on drivers side
  14. 06 Dakota transmission issue
  15. High Rmps
  16. Brake pedal
  17. Top Speed
  18. 2005 Dodge Dakota rims
  19. Gas cap?
  20. Bleeding brakes
  21. Caster camber bolts
  22. 05 Dakota mega cab lift kit 4x4
  23. Power steering fluid
  24. Timing cover gasket
  25. seat belt light
  26. Rough Idle with no start.
  27. 2010 Dodge Dakota Low Beams Doesn’t Work
  28. 05 Dakota Key Fob Looses Programming
  29. Radio/Power connection
  30. Brake lights
  31. Beating a dead horse (another thread about lift)
  32. Tire size difference
  33. Fender Flares
  34. Rear Axle Oil / Limited slip? / Leak
  35. Nebraska Dakota: Rims & Tires
  36. 2005 Dakota: Single Beam Headlights?
  37. No start/transmission issue - 1 or 2 separate issues?
  38. Need Help with 2005 3.7L electrical issues
  39. 05 Tranny gone....now what
  40. Batter Draw CCN Fuse
  41. 2005 dodge dakata heating and air flow
  42. Bank 2 sensor 2 p0157/p0158
  43. Rims and tires
  44. 2006 Dakota Ign Key Programming..
  45. wheels will not turn when jacked up
  46. blame it on the rain?
  47. Dodge engine swap
  48. 2006 Dodge Dakota , none of the windows work?
  49. Code P0344 - Throttle Position Sensor or Camshaft Position Sensor??
  50. Exhaust Power
  51. Back Passenger Window will not roll up
  52. 2007 Dakota what rear seats will fit
  53. Wheel bearings?
  54. New dakota owner with a Trans question
  55. Radiator
  56. Flasher unit
  57. 03 dakota rear axle assembly
  58. Dodge dakota
  59. Differential drop bracket
  60. Adjusting Camber
  61. Picked up an '06
  62. Engine swap
  63. Leaking at the B pillar
  64. Chasing ticks, missing chicks ....
  65. 3.7 vapor leak detection pump?
  66. Dakota control arms and other suspension
  67. New wheels and tires?
  68. Intermitent Shutdown 2007 Dakota
  69. It does not start and everything seems to be fine, with energy OK.
  70. Switch beds on quad cab
  71. wheel
  72. Shift Linkage issue and WTH is this part?!?
  73. 2012 challenger P0731, P2784 codes
  74. Transmission I.D
  75. Touch Screen Radio
  76. Towing Capacity
  77. 545rfe in limp mode, tried everything
  78. 2008 SLT tire replacement question
  79. wheel
  80. lots of codes u0100 p0884 ect
  81. Remote Start ?
  82. 2005 dakota transmission not talking to computer?
  83. Drive shaft vibration
  84. Glad to be apart of the forum! This is my first Dodge truck and need guidance/advice
  85. TPS questions
  86. Plugged connector under hood question
  87. 05 dakota limp mode
  88. 2006 dakota ambient sensor location
  89. Plasti dip
  90. 2009 dakota st wheels
  91. Cosmetics
  92. p0740 and p0700
  93. wheels
  94. Abs and Brake Light
  95. 2006 Dodge Dakota electrical problem
  96. P0456, p0457
  97. 2006 Dakota Parking Brake Cable Connectors
  98. Locking the Rear Diff
  99. Help with heater hoses - discontinued?
  100. Water in drivers side floor board
  101. How do i get gear ratio
  102. 52" Curved Light Bar Mounting on a 2010 Dodge Dakota Bighorn
  103. Sway Bar Sizing
  104. 4.7l flex fuel
  105. 06 slt 4.7 towing
  106. P0172 and P0132 + Engine Hesitation
  107. Cruise Control Fuse
  108. 2017 Dodge Durango Citadel
  109. '08 4.7L V8 Dakota Symptoms (jerking, lock up)
  110. Hose Mystery
  111. bullet proof 545RFE suggested aftermarket parts for rebuild?
  112. Transmission feels like it's stuck in gear
  113. I have 2 questions
  114. Sorry! Ive lost the link
  115. Truck won't start after its been running
  116. 05 dakota electrical problems
  117. 2010 Dodge Journey Caliper bracket torque specs
  118. Bought a new headlight assembly for 2006 dakota
  119. Not sure if im in right place but I want a throttle body spacerr
  120. 06 dakota r/t new pcm
  121. 07 sway bar end link problem
  122. 2007 Front Axle Drop
  123. Matte black spray paint removal
  124. 07 Dakota Misfire/rough idle
  125. Junkyard Parts
  126. Transmission Temperature Sensor
  127. AC refrigerant capacity and AC condensor replacement
  128. Brake light Install
  129. help me decide
  130. 07 Dodge Dakota Misfire(???)
  131. Front wheel hub 4x4 stuck
  132. Slight High Pitched Humming during Idle
  133. clutch noise. rhythmic chirping/squeaking on lift throttle
  134. Fuel Pressure Loss
  135. airbag light on instrument cluster
  136. replaced lower and upper need torque specification
  137. 2006 dodge dakota, no start when you turn the key, makes no noise
  138. New 4.7 Owner
  139. Coil Pack Exploded!!
  140. Finally, I can do a lift
  141. a/c freezing up
  142. Clicking noise 05 dakota
  143. 2006 Dodge Dakota 4.7 L (running but bogging down)
  144. Upper control arm bolts size/length/grade
  145. 06 Dakota R/T limp mode.
  146. 285/75r16 - yes you can!
  147. 2005 Dakota - Need help
  148. 2005 Dakota Starting Problem
  149. Key Fobs Lost Programming...again
  150. 2005 Dodge Dakota Wiring harness
  151. Too soon for a problem
  152. Looking for advice
  153. Dim radio time and other info
  154. 2006 Dakota O2 Sensor issues
  155. 2005 Dakota ECM, TCM or PCM
  156. Water pump replacement questions
  157. Newly used 2008 Dakota Laramie, no Uconnect
  158. U0100 U0101 U1414 U1415 Lost Communication PCM ECU
  159. Broke Igntion Coil Mounting Bolt.
  160. A/C issues
  161. 2008 Dakota 4.7 4x4 front driveshaft removal
  162. Rear differential?
  163. '05 Dakota Misfire
  164. 2005 patch panels
  165. New guy with a question
  166. General or Cooper
  167. Oil Leak Help
  168. I'm beginning to hate this truck...
  169. New Owner, Minor Help?
  170. Steering help
  171. 42rle transmission need help
  172. Passenger side water leak
  173. Where is the Orifice tube on a 2005 Dakota with the 4.7 engine
  174. Apple CarPlay
  175. Will a box and doors off a 20011 Dakota fit on my 07 Dakota?
  176. Vin trace for Pennsylvania
  177. Steering rattle
  178. How to fit 33's with 3" Supreme suspensions lift?
  179. Just wanted to say thanks to all who offered advice
  180. my 2012 Dodge Avenger Idles a1 1 in park and up to 2 when in town driving
  181. Help Does anyone know if there is wiring for front seats?
  182. More lower control arm issues
  183. Leaf spring center pin w/lift blocks
  184. Body lift instructions?
  185. Overthinking my lower control arms?
  186. transmission solenoid faulty again?
  187. ABS or no ABS?
  188. over heat
  189. Factory Remote Start FOB for 2006 Dodge Dakota
  190. Rough idle no check engine light
  191. Tires question
  192. by pass trans cooler to use after market trans cooler
  193. 2011 trac lok in my 2006 carrier?
  194. gauge cluster swap or home build new cluster?
  195. Central Timer Module
  196. I finally broke her
  197. need help with a stuck window 08 dakota
  198. Need 2008 Dakota help
  199. Motor oil in bulk
  200. Attempting A 3.7 To 4.7 Swap
  201. Air Filter
  202. Help
  203. 07 dakota 4.7 misfires and shutters
  204. 2006 Dodge Dakota Air Filter Housing
  205. Mix of ATF+3 and +4
  206. 07 dakota headlight
  207. dodge dakota
  208. Ball Joint? 2006 Dakota 3.7
  209. 2007 Dakota 4X4 rack & pinion.. How to get the hoses off?
  210. Under Seat Air Bag Connections Passenger Side
  211. No crank No start
  212. 2006 Dakota Park Brake Release Handle Broken
  213. 2005 dodge Dakota problems. NEED HELP!!!
  214. my2006 dodge dakota running off gear oil in tranny
  215. alarm turns on when i use my key
  216. Rough running and white smoke.
  217. Hey guys (and gals). Long time no talk
  218. spare tire
  219. oil pan bolt
  220. Vibration
  221. Another victim of the runaway transfer case motor
  222. Park lights won’t work unless parkbrake is on.... How do I fix it?
  223. 2006 Night runner mod recommendations
  224. Security Alarm going off with FOB & Door
  225. Info for those with P0344 code
  226. my 05's radio ony plays thought the rear speackers
  227. Help! Im so Stupid! I cant find my low a/c valve!
  228. A/C prob and it's getting hot soon!
  229. 2005 Dodge Dakota Acceleration Issues
  230. My DIY Bull Bar
  231. 2006 Dodge Durango. no crank or start. HEMO Limited
  232. location of a dodge dakota 2011 horns
  233. 06 SLT 4x4 Fuel Mileage
  234. Trouble Starting when Warm
  235. Bumper and Lights
  236. Audio System
  237. Help mileage check
  238. Steering wheel lock
  239. 08 HID projector kit? Lowering kit?
  240. Amp installation help!!
  241. Got some problems
  242. Console question
  243. Kill door chime by cutting wire to chime
  244. Heater control stuck on high
  245. New brush guard and black front bumper
  246. P0463 code
  247. throttle and cruise control cable replacement
  248. 2006 Dodge Dakota Fuel Filter Location
  249. Help! 2005 Drum Brake Service
  250. 2008 dodge dakota slt
