View Full Version : 3rd Gen Dakota
- 07 4.7 p0123/p0068 extended crank
- Help!! 06 dakota not so 4x4
- Front end question
- 2011 dakota trx4 parts question
- Oil Fill Cap Question
- String Alignment/rebuild front end
- Fuse number 14 iod #2
- Ram1500knuckle swap
- New 10' Dakota - what to check?
- Leak in rear of 05 dakota cab
- Injectors have you replaced? How many miles?
- 2005 Dakota Clutch Fluid Change
- New to me Dakota issues
- 2005 Dodge Dakota 4.7 L Missing
- how to actuate ASD relay?
- Fog lights on 06 Dakota ST
- radio power, no sound
- Not sure where we messed up calculating
- Bleed ABS brakes on a 2007 Dakota.
- Biggest 20's on 06 dakota
- Bed Mat
- Sometimes it's the simple things...
- Help; Truck shut off after hitting hard bumps in the road.
- coil voltage
- Rusty Shackles
- change 2007 Dakota grille/lights for 2008-2010?
- 5.7 Hemi Swap
- program a new computer with out dealer?
- 2005 Dodge Dakota steering issues
- Need Leaf spring info
- no bus code
- noob
- No crank no start 05 dakota 4.7 4x4 auto
- Anyone else have this problem?
- Leaf spring hanger help
- 2005 #3 coil split
- Help!!!!
- Looking to buy
- Buyer's Guide for 3rd Gen Dakota?
- Hard exhaust manifold bolts?
- rubber boots/feet on radiator?
- Truck sounds like a Semi
- Yet another question about bleeding an overheating 4.7
- My truck keeps blowing coil#1
- Bought a PCM
- code P0203 AGAIN!
- Tires
- Quick question
- Lower fuel tank on 2011 Dakota
- Electric how worried?
- 05 Dakota security
- Looking for A/C Clutch and Pulley replacement parts?
- Shift from park with no key?
- 2006 Dakota ignition switch
- Vacuum line needing a home, is this by chance related to my air vents not working?
- 06 RWD Rack & Pinion vs Steering Shaft vs Jam Nuts vs Tie Rod Ends
- Any information on the Neutral Safety Switch on a 2006 Dodge Dakota 4.7 Automatic?
- which coil is p2302 code talking about?
- Lost my only key
- Wondering if I have a stock tune ... ?
- smoke test on the 4.7?
- tube coming off of PCV valve, leading back to engine, where the hell does it hook up?
- 08 Dakota 4.7 V8 Power steering issue. stumped, please help
- Rear Disc Brake Conversion
- 2007 3.7 Engine Oil Pan Replacement (4X4)
- SVC 4WD.....bad case motor or computer issue?
- Another Brake Issue Question(s)
- Crankcase breather, or... ?
- How to remove driver's side pillar
- 2011 Ram Dakota Head Blown Gasket 3.7 v6
- Grounds FYI
- 06 4.7 cam swap questions
- Factory shocks on 2009
- single chime upon startup
- Power steering super stiff
- Lift kit and tire size help please
- V6 Exhaust, what'r you running?
- Feed wire from inside of cabin to truck bed?
- Rancho, KYB, Monroe, ???
- Oxygen Sensors
- Reference: Bench Seat Construction
- Added leveling kit need HELP
- Paint - Dupli-Color or Rust-Oleum
- Bleed air from 4.7 in dakota
- Hate this truck.....
- Problem Installing New Brake Master Cylinder
- Installed wireless backup camera buuuut. 05 dakota slt
- How to find information about my Dodge Dakota
- Super tricky to SMOG cert?
- 8.25" Limited slip parts?
- Rear Differential Drain and fill service
- Floor Jack/Jack Stand Position
- 06 Dakota wheel cyclinders
- Silver Door Trim
- Compatability questions (and a silly issue)
- Serpentine bolt rounded and seized
- Rack and Pinion question.
- Dumb question because I'm kinda dumb
- just nuts
- seat belt chime won't shut off...help!
- Scratching my head
- I put 02-08 Dodge Ram flares on my Dakota !
- Add a leaf... or 3
- Roll Pan
- Where to buy 1.5" trailmaster kit
- Lowering a 2005 dodge Dakota 2wd
- 2005 Dakota Headlight Adjustment
- Dakota Headlight Switch
- 2008 Camshaft
- Steering Rack Replacement Brands
- Good Muffler for 4.7?
- Code p0203
- Speedbump Clunk . . . 2005 Dak
- O2 Sensors Interchangeable? Denso 4756 & 4744
- 2008+ Replacement drivers seat
- Where to get the red clips on the Computer connectors
- Just wondering.
- Do the struts for an 05-09 Dakota fit a 2011?
- Rear Shock torque spec
- Tire woes
- 2005 Dodge Dakota 4.7L Performance
- Need some help with an 06 Dakota 4x4 4.7L HO v8
- Stuck in second gear
- Transfer case stuck in neutral
- Holly Terminator X Max for HEMI swap??
- New guy Mikenice
- Dodge Dakota 2007 3.7L TPS/PPS code reporting
- I Increased Gas Milage from 17.9mpg to 22.3mpg
- '08 Dakota Exhaust Recommendations
- Stuck in limp mode
- Diff gear ratio
- 12.5 MPG What Gives? What's Next?
- 4WD noise 2007 dakota
- Spare Tire tool
- Seat Recliner
- New Magnaflow Catback Drone
- 06 Dakota v8 motor options
- Dead Battery
- Order a 2" strut lift, but found out after install that I was sent a 3"
- 2005+ bed caps/toppers
- Seat Cushion Repair/Replacement
- 2005 Dakota 4X4 Tire Pressure Decal
- 05 Dakota Oil Pressure Switch Installation
- 4WD Issues
- '05 Dakota 2WD wheel bearing and hub torque specs.
- Are the Mopar online retailers trustworthy?
- 2008 Dodge Dakota Turn Signal Issue
- Error on odometer
- Error
- Strange Noise
- Tail Light pigtails
- 2005 v8 4.7L SLT Smells like burnt plastic from exhaust occasional white smoke
- Power Steering Fluid Leak 05 Dakota
- 05 Dakota fan clutches
- PCM location 2005 Dakota 3.7l
- P0734
- Which cv axles?
- Connector identification help needed!
- Storage Cubby Replacement/Spare Wire
- 15.4 V Charging ?
- Best 07 Dakota 4.7L Quad Cab Mods??
- 2005 no start/no ecm communication
- 2005 Dakota Electric Fans
- Bad 02 sensor out of the box
- 3rd gen lift kit or SAS
- 07 4.7ho pesky check engine light.
- super locked out!
- Thank you
- Help!!!! Transmission swap.
- 2005 Dakota codes
- Broke extractor when removing bolt
- Need some help
- 9.25 axle shaft 2nd to 3rd gen?
- No brake fluid,rear wheels
- Acceleration + Turn Vibration
- Ram CV's???
- 3rd gen bumpers
- Rear shoe brakes
- 2008 4X4 power steering lines
- Torque converter keeps locking and unlocking.
- 2008 Rack and Pinion
- 3.7 Upstream Drivers Side O2 Sensor Removal
- Installed Ram Rebel Wheels & New Rubber.
- 2008 Dakota My headlights seem reversed.
- How can I buy new or used Tail light assembly for 2010 dodge dakota?
- fix for Dakota shifting into 4wd on its own
- LED Headlights
- No speedo/odom.
- New muffler for '06 4.7
- missfire on my 2010 dakota 6 cyclinder
- New PCM New crank sensor New cam sensor no fire
- Wipers and windows are slooooow, humming noise
- Lightning strikes!
- Stereo install
- need advice
- 05 Dakota Tranny Dead x2
- Reattaching Fender Wells
- 2007 dodge Dakota SLT
- Are all 4.7 engines swap and drop
- Intermediate Steering Shaft
- Installed Dana Spicer
- 4.7 intake manifold popping?
- 05 Dakota temperatures
- Temperature issues
- P0841 and P0700
- 06 4.7L V8 Magnum Auto 545RFE TRANS FAIL? No DTCs
- New engine job
- Amount of Brake Fluid for Full Flush
- 05 Dakota & Torque app question
- Stalling
- Towing with a Dakota without factory towing harness
- Reduce wear on driver side wiper arm?
- Installing fender flares
- 2006 Dakota AC warm when stooped, cols when moving
- Getrag 238
- 2005 Dakota rear door latches
- 2007 rear flange... SNAPPED
- 2002 trans into 2006?
- 2006 Dakota 2wd 2-piece driveshaft vibration
- New Member with Questions
- Installing aftermarket tailgate lock
- heated mirrors
- Strut replacement questions
- Crank no start
- Engine Misfire and Rough Idling
- 2005 Dodge Dakota 4WD - 4.7L V8
- lights on lamp coming on
- After TUNE UP STARTER IS DEAD
- Ball joints
- Driver seat
- Multiple misfire and low fuel pressure
- 3rd gen First Gen Swap, any help in the right direction.
- Intake manifold
- Given free truck tons of questions
- 2006 Dakota 4x4 with 2.5” supreme suspension level issue
- strangness with the alarm system!!??
- Fender Flares for 2006 Dodge Dakota
- guage issues
- Performance Acc/Daystar 2" Front lift help
- Intermittent Cruise Control
- TRX4 Tail Pipe
- 3rd gen dakota lift
- Where to find R/T hood
- Another cruise control problem
- Need answers
- 08 4.7 4x4 exhaust options
- Newbie to Dodge
- 2007 dodge Dakota idle drop
- Brake Light Fuse
- Seat/belt light and alarm
