View Full Version : 3rd Gen Dakota
- Think I killed my rear diff
- Air bag light
- 2007 Dakota Rims - Rusty?
- 2007 Dakota ABS Light/Rear Axle Speed Sensor
- Rattling noise
- Brake recomendations?
- 2006 Dakota Question
- Bed rail caps
- New to Dakota
- New Driver, New Truck! - What can I do to customize it??
- '07 3.7 V6 Throwout bearing
- windshield washer problem
- Yet another leveling thread...
- Introduction and Crank Seal Question
- seized engine HELP
- 05, Transmission? or sensors? Help!
- SAS interest
- Thinking of Buying An 06 Dakota Quad Cab 2wd......
- Transmission need help!!
- Transmission Oil Line Leak!
- Re-gearing my 2005 Dakota "Help"!
- hood safety catch stuck
- TPMS questions
- Loose drivers window when rolled down.
- Brake and ABS idiot Lights
- Remote Start in OEM Keyfob on a 2006?
- external trans cooler...
- Wheel Hub Replacement Question
- What to do next..
- 2 questions. ..
- Power windows slow.....
- Garfield Joe
- DRLs??? Help me.
- Rear Brakes
- Exhaust Question.
- Transmission problems
- new headlights fit on an 05 dakota
- egr valve
- Exhaust manifold repair tip
- Dash Frozen
- newb with 06
- How Easy to Replace Outside Right Rear Window Seal
- Anyone have a Dee-Zee narrow toolbox?
- EGR code P0406
- 2007 Dakota Remote Start ADD ONs...whats available
- Airbag Recall: 2005 - 2008 Dodge Dakota
- o2 sensor help
- 2007 shop manual
- turn signals both flash
- Custom suspension (mid/long travel) happening.
- Trans Temp Light
- Please help with front end noise
- Hood alignment 2008 dakota
- Possible manual trans swap
- 275-70-18s???
- Best mod ever...
- 2006 Dakota Ignition Switch Diagram
- Added on Wiring
- Two problems.
- Do I have 4 wheel or 2 wheel ABS?
- Daytime Running lights issue
- Need Help -- 2006 Dakota with P300 Miss-Fire Error
- Replacing pads on front of 2008 Dakota rear wheel drive
- Need confirmation on something please
- What engine
- '06 Dakota QC - Need direction on seats that will work
- Rear Diff.....
- brake bleed wrench
- power steering pump
- Remote start not working
- Water and oil leaks
- Buying a 2006 Dakota, Need Opinions and Help
- 08 V8 4.7 - Slow then get's a nitro boost?
- chek engine light
- 4.7 swap
- 07 Dakota Blinker
- 4.7 swap
- biggest tire for stock 05 dakota?
- My 2005 Dakota Thinks It Is a Durango!
- electrical problems
- I have a PROBLEM!
- difference in 2wd and 4wd front struts
- Questions before buying a 2011 Dakota Big Horn
- Rear Disc Brakes - From a Ram?
- Fob!
- transmission test port...
- sticky speedometer :(
- Shuddering at higher speeds
- Ram 20" wheels on a dakota
- Shaking on highway that intensifies when decelerating
- My first Check Engine Light
- Fog lights with brights mod question???
- windshield washer pump....
- loud noise from drivetrain
- HELP windows are stuck
- Air/Fuel Ratio Gauge / Shocks
- Got a little wet...
- Tonneau cover, roll up vs tri-fold
- Removing Passenger Side Inner Fender
- 07 dak manifold stud/bolt - help
- Side mirror possessed?
- Passenger Air Bag Bulb Replace
- Bang for the Buck Mod...
- How to shift into 4 low with a standard?
- K & M filter
- 05 dakota slt 4x4 passenger side window doesn't come down, power locks don't work
- When do you change transmission fluid?
- how do I know if my dakota has the infinity system?
- 05 dakota 4x4 seat belt indicator in dash won't turn off
- 05 dakota slt 4x4 power outlet not working ALSO seat belt light on dash stays on
- 2006 RWD wheel bearing
- Click click, no start...
- Changed Spark Plugs
- Has anyone replaced their intermediate shaft yet?
- trailer brake controller
- Rear sway bar for 2010 Dak
- Ride Comfort... Tires, shocks, etc
- Chirp from front wheels. 2005 SLT 2wd
- Daytimes Brighter Than Nighttimes
- trailer wieght
- So I need some confirmation
- Watch my in-dash navigation
- HELP! Rust on the inside bottom of all 4 doors
- another fan removal trial run
- code C2500??
- *squeaky* front driver's side
- Poor power and milage
- ABS light comes on for a moment
- superchips question
- retune superchip to factory tune
- Horrible MPG
- 4.7 Auxiliary fan location??
- Help
- Bumper build ideas
- Leveling kit and new tires
- Torn seat
- wierd clunk
- Need Help w/ Wiring for Canopy 3rd Brake Light?
- Skis replacment
- Bumper Question (or is God telling me to upgrade?)
- More power
- 2008 Dakota 3.7 V6 P0305 Cylinder 5 Misfire
- 2005 dakota with procomps
- 05 dakota 3.7 exhaust ideas
- Feel like I should know what's wrong...HELP!!
- Blower Motor
- 06 dakota v6 3.7 hollowed cats?
- fuel pump module for 06 dakota
- 06 dakota 3.7 lit v 6
- '06 wiper motor
- Passenger Air bag issue
- well.... need some opinions and options
- Rough Idle and at low rpm it felt like miss fire
- 07 Dak - parasitic Drain Fuse #24
- multiple electrical problems - All at once
- Truck cap wiring?
- cannot connect obd-II
- should I? 05 for a 03
- Which running boards are best for you?
- Camshaft bearing caps
- air bag light-seat belt alarm
- No Power Steering at Idle/Low RPM
- PVC hiding?
- New Dakota Owner
- Fixing two codes
- Dos and Donts for Getting the Most Out of Your Visit
- Engine sometimes spudders while stopped
- 05 transfer case
- Want to make sure I'm buying the right rim...
- [Radio] I Just Can't Win!
- Changed water pump, now problems
- 2005 4.7 fuel injector
- 2007 dakota wiring diagram
- Brake and shake
- '05 Dakota Electrical Questions
- weird steering feeling
- Carlisle Mopar nationals.
- getting new keys from an online source!
- Rear Suspension Rattles, Squeaks, Etc.
- IAC problem?
- No more brake pressure
- The SQUEAK is driving me insane!
- Strange Power Steering Feeling
- Grinding noise in front end
- pressure transducer
- truck vibration coming from bed
- Will a 2nd Gen Dakota Roof Rack fit on a 3rd Gen?
- 2006 dodge dakota slt engine problem
- sway bar delete
- Different timing on cams
- Intermittent Trans Temp Light
- 3"BL and 2 " leveling kit will I fit 305/70/16 33s
- gas tank airlocked?
- Idling strange on start up
- New guy with terrible bad noise comming from the drive train I think.
- Having Signal Problems
- Monroe Struts
- .. What is this? P1128 no solution?
- Rear Brakes 2005 Dakota
- Replace the rear brake 2006 Dakota
- Best struts for 08 dakota
- 2005 Dakota issues
- Reverse not engaging immediately.
- another front end noise thread
- Truck won't go forward
- Shocking
- rear drums on a 2009 dodge Dakota 4x4
- Side Mirror swap
- Transmission or electrical problem?
- 08 with vibration around 55-65mph
- Plasti dipped my grill
- Anyone with chrome grill?
- Dakota Hesitates during acceleration from a Stop
- Front end popping noise
- Wheel Offset
- programmers and my questions...
- Looking for FSM's
- Drop down kit
- Misfire on Cylinder 7
- Happy to see mailman today
- Window Motor or Regulator?
- Front end maintenance
- Headers for a 3.7L dakota
- 2005 dakota lowering shackle questions
- P1128 & p1129
- 05 dakota tire pressure
- Relocating the spare
- Ethanol Free Gas
- Brake Light Stuck on
- Front end parts worn after 50,000 miles?
- ATTN crankshaft positon sensor(p0335) - 07, 4x4 ,4.7- dakota REPLACEMENT
- P0403 2009 4.7l
- Transmission Won't Go In Gear: P0700/876/944
- 4.6 injectors on 3.7
- New Tires Rims
- Wheel Bearing question
- 2008 Winch Install
- Broken Audio Auxiliary Port
- my 05 slt ext cab audio build up
- Wheel Spacers
- 05 quad cab engine swap
- 2005 TCCM location
- need to replace rear bumper
- DIY air intake question
- Just bought an 05 slt extended cab
- Seat Covers?
- Strut Bushings
- Any one know the name of this piece of trim?????
- vibration in steering wheel
- Hub Bearing
