PDA
View Full Version : 3rd Gen Dakota
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54
  1. Airaid Modular intake tube
  2. Truck meet
  3. :( :( sigh :( :(
  4. How do they get away with it?
  5. 3" lift leveling kit
  6. $5 Dollar Wiper Blades
  7. Power Stop rotor and PADS DEAL
  8. New Dakota owner with questions
  9. justa wonderig why?
  10. 2008 Grille
  11. My new 2011 should be built!
  12. frt brake removal
  13. Aftermarket shock & strut question
  14. Sweet deal on Monroe shocks and struts
  15. Lift Spring
  16. what would you pay for a lift, ect?
  17. What A Pleasant Surprise!!!
  18. HHR Fan Connector
  19. Rear Disc Brake Conversion
  20. gas mileage question
  21. Backspacing??
  22. Spare Rim replacement with a 5th Dakota Rim - Now have underbed tire holder problem
  23. Dimpled/slotted rotors
  24. 265/75/16" tires ???
  25. 265/75/16" tires ???
  26. wow... i hope this works
  27. Dont use your truck in place of a rifle for deer hunting!
  28. Dealer Maintenance Services.
  29. Need help asap!!!!
  30. Just ordered 245/75/16 will that be a difference to 245/70/R16
  31. body lift
  32. New, Really NEW, tires
  33. Dodge Truck Builders Guide
  34. New Dakota owner, few questions
  35. wow i'm shocked
  36. Transmission Whine
  37. CAD file
  38. New pics !
  39. Remember those who fought for our Freedom.
  40. Here it is, my baby
  41. maintaince and fluids questions
  42. 2009 Trailer Hitch Setup
  43. Rear Drum Brakes
  44. exhaust question
  45. Scan gauge II Vs. Turbo gauge III vs. Ultra Gauge vs. interceptor
  46. Need foglight help
  47. idle problems
  48. Rough shift between Park, Neutral and Reverse...
  49. Brake Job
  50. Installing a stock sat radio question.
  51. 2 inch daystar kit cv axles binding.
  52. 2006 PCV valve location
  53. Need your opinion!
  54. need someone to do a quick expirement
  55. What do you all make of this?
  56. Questin about leveling kit
  57. Another use for the Dakota...
  58. Factory speedo tire height value...vs actual
  59. Costco tires compared to actual name brand tires
  60. p265/75r16's to replace p245/70r16?
  61. no power in reverse
  62. High res calendar pics [UPDATE: Please read post#32]
  63. Weird clunking gone when window fuse is busted
  64. 2005 parts
  65. New Seats, New Problem
  66. Does cold weather = squeaky front end??
  67. pcv for 06
  68. DAMN!! Idle problems
  69. Spark plug?
  70. Thermostat???
  71. Sound Clip Resonator off?
  72. factory wheel offset
  73. 07 strut question
  74. bolts for manifold
  75. Audio Upgrade
  76. 3.7L owners, dont hold your breath but...
  77. 05 Overhead Console Wiring, CAN Bus B connection, etc
  78. Havent been on for awhile, anything new?
  79. true suspension lift interest up to date list?
  80. Fuel Filter on '07 Dakota
  81. Changing 4X4
  82. 2011 Dakotas?
  83. Max RPM in Park Position?
  84. 2.5 vs 3" exhaust
  85. Needing good tire in wet/slush/snow
  86. 4-pin Trailer Harness
  87. Best H 13/9008 Replacements
  88. Amsoil or Royal Purple
  89. Check those air filters
  90. Pinion Seal at 54K?
  91. Turbo Kit
  92. 08+ 4.7l spark plugs
  93. Hats off to Extang! got my cover today.
  94. random question
  95. how does one remove the air intake resonator?
  96. Exhaust
  97. Rats!!!!
  98. Exhaust tips
  99. 06 dakota 9.25 gear swap
  100. Serious Idling Issues
  101. Oxygen Sensors
  102. diameter of axle
  103. Brake Squeal
  104. bed stripes
  105. HID Help Please
  106. stock headlights
  107. Clock not available
  108. My Borla Exhaust Videos
  109. Ready for Winter
  110. New tires, level kit install
  111. front bumper lip?
  112. Why I chose the Dak...
  113. t-case skid plate
  114. My 08 with new Definity Dakota tires
  115. question about exhaust
  116. 100w headlight bulbs
  117. Calendar Vote! FINAL 12 Countdown! (Thread 2)
  118. Calendar Vote! FINAL 12 Countdown! (Thread 1)
  119. 08 intake manifold swap
  120. Struts ? Which ones? DIY???
  121. meets
  122. The 4.7l Power Curve
  123. Black Bezel headlamps
  124. Anyone Running 285-75-16?
  125. Larger tire size causes front-end shaking
  126. my Build Sheet question
  127. New tire questions!
  128. 4.7 oem air hat needed
  129. got lift blocks for my truck
  130. trans fluid change question
  131. This is ridicuolous!!!!
  132. Keyless entry strangeness
  133. What is new on the CB front?
  134. Tire/Rim questions (drag racing)
  135. New Tire
  136. I need a new Key, but have some Questions...
  137. Who has flipped their tie rods?
  138. my Idea for Hood Decal
  139. creaking when doing tight turn
  140. One bid a$$ mailbox
  141. New Tires, Crappy Pictures!
  142. Forward-facing Lighting Set-up
  143. Help P0508 CODE
  144. its a sad day
  145. What size lug nuts?
  146. 4" lift idea
  147. Question! help!
  148. help quick
  149. Chevy guy looking at getting a dodge. time to school me!
  150. plasic vs steel lol
  151. where are you all at?
  152. Rear %$# Lowering Shackles
  153. 2008 tire size
  154. Soon to be cammin!!
  155. Sonnax Has arrived
  156. Ram gauge pod
  157. HELP! squeaking front end
  158. Engine Codes
  159. Will these fit with out a lift?
  160. Yet another CAI...the way it should have been!
  161. clean truck!!
  162. JET Accu-Speed SPEEDOMETER CALIBRATOR
  163. 2006 dakota v8 shaking at 65 mph & up
  164. Rack & Pinion, AGAIN!!!!!!!!!
  165. Truck overheating..
  166. 2005 Dakota
  167. Calendar voting thread 3
  168. Calendar voting thread 2
  169. Calendar voting thread 1
  170. Keyless entry freq problems
  171. Happy thanksgiving from CANADA
  172. No Cold AC?
  173. Odd Tranny hiss
  174. 2005 Dakota Dash Lights Inop
  175. Efan help!! Asap!
  176. Syn motor oil
  177. How many 6 speeds here?
  178. Yet another 05 Vibration issue
  179. My home built canopy
  180. Tire Size?
  181. Hard Reset
  182. HUBCENTRIC RINGS not SPACERS
  183. tires for 18" wheels
  184. What does the heads up say after '0'?
  185. A few more Zeros in my future...
  186. 20" Rims and Lowering Shackles?
  187. cv half axle question
  188. Need to replace the plugs in the 2008
  189. sc programmer
  190. Amp Install Help!
  191. New Grille
  192. Dodge Dakota HELP!!!!
  193. Looking back on this morning...
  194. 08+ intake manifold
  195. P0700 Transmission Code
  196. Gas Needle at E, Temp guage no Temp (05 Dakota Quad)
  197. Oil Leak!
  198. New Tonneau Cover Pics
  199. Tell me what you think (Pics)
  200. dakota seat belt alarm
  201. which tires for fireston or bfg?
  202. 3G Dakota Calendar Submission thread
  203. Rancho strut failing?
  204. Finally got enough to start the project
  205. EGR Valve Diag.
  206. EVERYONE LOOK PLEASE. thanks
  207. brake performance package
  208. Nitrous
  209. powersteering cap missing!!
  210. G3 Dakota October TOTM
  211. Just got back from PA, no power windows now?
  212. Installing lowering shackles
  213. Solid Motor Mounts
  214. MAP sensor mounting bolts..1 or 2?
  215. Rear Limited Slip Differential Chatter
  216. 05 struts
  217. Grill Removal HELP
  218. Pictures
  219. another diy cold air intake.. well sort of. this ones a little different
  220. Power Wire How-To
  221. Yet ANOTHER cold air intake.........
  222. Steering Fixed!
  223. Hmmm...might have to consider ditching the Dakota...
  224. Halo HID Headlights
  225. Lund 90087 Genesis Snap Soft Tonneau Cover
  226. Got in an accident :(
  227. 2005 dakota spark plugs
  228. Trucking driving sideways?
  229. Pictures
  230. New Toys
  231. CAI oh so sexy
  232. Instrument cluster back light
  233. 2005 Dakota FCM
  234. October G3 Dakota TOTM Noms
  235. Alternator is dying
  236. '06 needs shocks?
  237. You won't believe where water is leaking through
  238. Wheel bearing assembly Bolt - HELP
  239. 2007 Dodge Dakota radio/speaker questions
  240. Front brakes clicking???
  241. New Rims-N-Tires (WITH pics, of course!!)
  242. DOOR OPEN on dash
  243. Future owner questions...
  244. A Rose is a Rose...What's in a Name??
  245. Middle "Third" front Seat
  246. HELP - Adding new Remote Central Locking Keys to 2005 Dodge Dakota ?
  247. First Time Poster
  248. It NEVER did this before???
  249. Hum noise
  250. Brake Pads???
