PDA
View Full Version : 3rd Gen Dakota
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54
  1. DIY Bull Bar Mock Up Opinions
  2. need some more wire diagrams
  3. 07 Dakota 3.7L V6 42RLE code P0749
  4. 2011 led tail light issues
  5. Transmission Pan/deep Filter
  6. A/C-heating fan not blowing strong
  7. Third gen facelift swap
  8. solid axel swap 3rd gen dakota (2005)
  9. Anyone relocate the OEM utility rails?
  10. Fabbed Skid Plate and OEM Tow Hooks Installed
  11. Fender flares
  12. where would I find the switch ignition wire
  13. Transmission cooler install DIY
  14. 2005 dodge dakota 3.7l 4x4
  15. 08 V6 4x4 Clunk Noise When Turning - CV ?
  16. Looking at Leveling an '05 4x4
  17. 2006 dakota v6 4wd trans stuck in 3rd
  18. Transmission Pan
  19. Hi 2006 Dakota Questions Help!
  20. Transmission issues
  21. P2096 code Idk wat it is
  22. Tow Capacity - 7,200 lbs *when properly equipped
  23. Tire for towing 265/70/17. Simple opinion
  24. Busted front drive shaft?
  25. Door locks, Radio, Overhead display stopper working
  26. 05 dakota random problems
  27. 07 Dakota slt exhaust
  28. 06 dakota 4.7l stalls at stop signs
  29. What to look for?
  30. Dakota problems... and specific front driveshaft question.
  31. HELP! Transmission Fluid Leak...
  32. 2005 Dodge dekota V8 4WD slt transmission won’t shift
  33. 545RFE transmission
  34. 2007 Dodge Dakota 4.7L Auto
  35. Switching back to conventional oil
  36. 2008 or later with 6 speed manual... Do they exist?
  37. 4x4 Leving Kit Question
  38. LED Light Bar
  39. 08 and up gas pedal
  40. No heat help
  41. 2005 Dakota Fuse Box
  42. Dakota shopping
  43. ball joint question
  44. 2007 dakota driver side leak
  45. Front end knocks
  46. dodge 2007 3.7l v6
  47. dragging hose under the front end
  48. 180° Thermostat During Cold Winter Months
  49. Radio Replacements
  50. RWD - Front Hub/Bearing - Is Replacement Required?
  51. why wont the headlights come on and the inside lights wont go off in my durango
  52. 2007 overhead console courtesy lights, glove box lights and ashtray lamp not working
  53. Brake issues 2005
  54. headlights
  55. Key Phobs Don't Work
  56. Starting issue in park
  57. v6 HEMI SWAP!
  58. 2005 Dodge Dakoa SLT
  59. 2008 Dodge Dakota only works at certain speeds
  60. check engine light
  61. Rear brake issue/parking brake actuator lever
  62. Programming new FOBs
  63. 2008 Dak - Possible to get an autostart?
  64. Soft Tops
  65. Exhaust parts
  66. Balky starting
  67. wipers not working except with washer
  68. 3rd gen 07 dodge Dakota 3.7 heater
  69. Exhaust question
  70. Turn signal issues 2007 dodge dakota
  71. Starts....runs 1 second...then dies.
  72. Question
  73. Hvac issues
  74. pro comp struts and shocks
  75. Strut bolt replacement
  76. P0300 - Random/Multiple Cylinder Misfire Detected
  77. Hemi ,trans swap
  78. New front springs from moog or not?
  79. 06 Dakota Frozen accumulator
  80. 2007 4X4 Laramie remote start wont work
  81. Want Some Fender Flares Without Getting a Mortgage…
  82. Hemi parts
  83. how to disarm 2007 dodge dakota security?
  84. fuel tank vent? can't fill at full flow from pump
  85. ?Experience with Eaton/Detroit True Trac?
  86. Installing Ranchos on all four corners
  87. 42RLE Dakota transmission hard shifting
  88. Turn Signal Issue
  89. How can i get the best results from my 3950 cortex tuner for my 08 4.7 ram
  90. Vibrating front end
  91. toppers
  92. Spark plugs.
  93. 2015 Dakota front parking lightbulb replacement
  94. coolant mixed with trans oil thanks to a bad radiator
  95. P0846 & p0700
  96. 08 dodge dakota
  97. Wiper fluid Motor and Fluid Level Sensor not working
  98. spark plugs on a dakota 2006 6 cyl
  99. do i need to the updated TRS CAM PLATE
  100. Headlights are turning my tail light off
  101. Tire
  102. Transmission Cooler Lines
  103. 2005 dakota wont stay in 4x4
  104. ECM Temperature
  105. 2006 dakota TCM
  106. ST vs TRX or Bighorn suspension
  107. Help with OEM tow hook grommets
  108. Turn signal sound
  109. 6-way power seat switch?
  110. AC 2005 dodge dakota
  111. 05 Dakota. Air bag light comes in with no passenger, and burning oil
  112. Front Control Module?????
  113. Alarm reset due to battery disconnect
  114. Light Bar on 08 Dodge Dakota
  115. 2010 Dodge Dakota SXT 4.7 Liter
  116. 08 Dak 3.7L - Replacing water pump
  117. rack and pinion in 3rd generation
  118. AfterMarket Headlights
  119. Doors Unlock but not lock
  120. gas guage and check engine light
  121. Should the TPMS sensors be replaced with tire change 09?
  122. Rear Axle Ratio (Upgrade 3.21 to 4.56): '08 V6 8.25" RWD | Rack, Pinion, Differential
  123. Suspension/tire upgrades
  124. 08 Gas Gauge Question...
  125. Transmission temperature sensor
  126. Axle swap info wanted
  127. trx4 lift?
  128. Help with 07 Dakota leveling kit
  129. Tailgate handle swap with RAM
  130. 05 dodge dakota rwd
  131. Silly starter problem
  132. Steeriing tight to turn
  133. 2008 radio removal
  134. shifting when coasting
  135. LED problem
  136. AC Line Leaking
  137. 06 Dakota Change Headlights
  138. Gumout Fuel additives
  139. ABS module
  140. 2005 Seat Belt and Air Bag warning lights
  141. Loss of acceleration and power
  142. Firewall hole for wire running?
  143. 42RLE Valve Body Connectors
  144. 05 dakota front bumper
  145. O5 dodge dakota v8
  146. Hard shift from park to drive and reverse
  147. Cannot find Factory Amp
  148. 2006 dakota tranny rebuild software update
  149. 33 x 11.50 x R17 on 2006 dodge Dakota
  150. Thermostat
  151. Can anyone tell me what these hoses are?
  152. Mystery Coolant Leak
  153. Bouncy steering around turns
  154. wheel bearing time again
  155. 2008 Dakota shocks
  156. Air conditioner snafu
  157. 2008 Dakota Airbag Module
  158. Dakota 2006 4.7 TCM?
  159. Will a rear step bumper from a 2nd gen fit my 3rd gen 05 Dakota??
  160. HELP PLEASE 2007 dakota low beam and wiper washer doesnt work
  161. 05 dakota suspension lift?
  162. 2006 overheating and electrical (?)
  163. Rear window defroster mystery
  164. 2006 Dakota P0700/P0750 Issue
  165. 3.7to4.7swap
  166. Upgrade Time!
  167. Fender flare help
  168. 2008 Dakota no compression cyl 5
  169. Stumbling at idle and at speed
  170. Exhaust dia change
  171. Topper Break Light
  172. Installing MyGIG RHR w/ auto-dim mirror
  173. 2006 Dodge Dakota rear bumper problem
  174. Dash switch panel
  175. Are there any exhaust headers for 11 dakota
  176. Whats the Biggest & Widest Tire/Rim for Stock Setup?
  177. rear driver side blinker not blinking when headlights are on.
  178. no heat
  179. Hemi swap Rear end also?
  180. 2008 Dodge Dakota 4x4 4.7L Throttle Position Sensor Location
  181. Well guys (and girls), it looks like my Dakota days are done
  182. Steering wheel clicking noise??
  183. 2007 Dakota 3.7 engine multi engine misfire
  184. Antitheft lock? Short?
  185. 2007 sxt extended cab rear door lock issue
  186. FYI to anyone with a wet/soaked front passenger-side floorboard after a rainshower...
  187. Lower shock bolts 06 Dakota
  188. 2010 Dakota 3.7 air/fuel sensor issues.......need help :(
  189. Rusted lower rad support
  190. Now we can go kayaking!
  191. 06 v6 dakota lost transmission
  192. OH NO! What's That Noise
  193. What happened? Did my caliper stick?
  194. 2005 4.7 exhaust cutout causing truck to go into limp mode
  195. 2006 Dodge Dakota 4.7 45RFE Trans stops pulling when it gets hot
  196. Dakota 2005 4.7 - reving when hot weather
  197. 2007 Dodge Dakota Surging Issue
  198. I finally left the Dak at a dealership and got....
  199. EcoDiesel in a 2005 Dakota??
  200. Tuners
  201. Rear leaf spring helpers???
  202. 2006 Dakota Transmission Issue. Truck started up in limp mode
  203. Dakota Towing 101
  204. 05 Dakota SLT quad cab 4.7 liter towing capacity
  205. Code PO159 - HELP
  206. suspension work
  207. running light problem
  208. missing fan shroud causing overheating?
  209. How To: Replace Cam Position Sensor 3.7l V6
  210. Gauge pod
  211. Dakota service manual link
  212. 4.7 running hot
  213. 2007 Dodge Dakota SLT Quad Cab 4WD
  214. hose broken near battery
  215. What brand of O2 sensor
  216. towing
  217. Rust/ zeibart.
  218. Bed liner
  219. Dakota 2006 ABS/Brake light issue
  220. 05 Dakota 42RLE Transmission stuck in 1st Gear?
  221. 2006 Dakota Nightrunner Quad Cab
  222. EGR / #7 coil melting
  223. Occasional key fob or security system problem.
  224. accessory switches
  225. location module ?
  226. Transission pan torque specs
  227. What Should I do
  228. Rancho re5757 Gone in less than 2 yrs - suggestions
  229. PCM or Transmission??
  230. Dodge brand tonneau cover
  231. 2005 Dakota Window Water Leaks into Cab Through Speaker
  232. Tackling the lower strut bolt
  233. confused
  234. 2010 Dakota Towing
  235. 2006 Dodge Dakota, SLT 4x4, 3.7 V6.....funny noise.
  236. Dash lights going nuts
  237. Abs systems 2009 dakota
  238. Chime immediately after ignition OFF
  239. 2005 Dakota 4.7
  240. Can I fix my key fob?
  241. Replacement molded carpet
  242. Trouble Code PO159
  243. Door Lock Wiring Diagram
  244. No crank 2011 ram dakota.
  245. Monroe quick struts + 2" leveling kit too much
  246. Steering rack bad. Any upgrades?
  247. 2006 Dakota Multiple lights out
  248. Body lift questions
  249. Battery Replacement
  250. Power Door Locks
