View Full Version : 3rd Gen Dakota
- Use 4x4 as light switch?
- Tailgate cap/cover - trouble finding a way to fasten it / bolt it
- Weird "whup, whup, whup" from tires when driving?!
- 2005 Dodge Dakota 4.9L V8 poor gas mileage solved
- Big WTF after my nerf bar install. (PICS) Help Please.
- bull bar install HELP
- Yep...I'm a DumbA**...too many ft lbs
- new door - LOCKING MECHANISM not triggering lock...PICTURES
- North Dakota
- Dakota's Parted Out: Best National Data Base?
- little shimy
- header exhaust leak
- Steering Wheel Squeaking?
- My 2006 3.7 Project
- rear mainseal
- New strut and leveling kit issue
- 2005 clutch pedal problem(Need help please)
- So I replaced my gauge cluster to clear ERROR message.
- Replaced Tie Rods: Safe to drive at all before Alignment?
- Front Driveshaft, CV Joint
- 2005 Dakota output mileage sensor location help
- LED Reverse Light
- sold axle swap
- I need help
- Wheel stuck on hub
- new tires and shocks
- Fitch Catalysts, Worth spending money on??
- Those with leveling kits: 1.5" or 2"? Help me out.
- Got Grease-able Suspension parts now, soooo
- Truck Getting Fixed: Need Advice
- o7dakQC gettin shocks-then struts - first wanna try an fix a squeek
- Shocks and tire wear
- NEED QUICK help if possible: Steering Shaft
- question strut/shock with level kit
- 2013/14 Dodge Dakota?
- Fog light bulb upgrade for pa46-gf40
- Strange braking behavior
- So i got an oil change at a garage
- truck is WOBBLING when hitting breaks at 50+
- Hard downshift coming to a stop
- Head light - tail light problem
- Spark Plug Wires ?
- Dash Bezel / Trim
- weird smell, hot wheel, lots of break dust, pulsating stop..
- Needed to upgrade my center console
- What other OEM wiring harnesses do I need for these heated seats?
- Going to look at camper top
- Window stuck up....
- Shortie headers that fit a HemiDak!
- 3.7 engine governor
- Dakota, Valve cover Oil Leak...
- OEM Skid Paperplates
- cargo lamp wiring
- hey all! Checking in with my DAKOTA WORK - new door - bumper - paint job
- Ram rear bumper
- pothole trouble f****
- Aftermarket Stereo Installation Issues
- pro's & cons lift blocks or helper springs?
- Speakers
- clear coat touch up
- After Market Parts ? Best place to buy?
- yellow foam in oil change
- Need help wit hstereo install
- Cargo Lamp, Illuminated entry Question
- **fixing up exterior on my 07dakota need help identifyng/locating parts please :)
- replacement radio for 2011 dakota
- The Phantom Backseat Driver
- adding a leaf
- Lots of clicking but motor won't turn over
- Truck started running hot...again
- I need some help, please.
- 06 dakota intake question
- Problem Towing / Shifting
- swaybar removal?
- PCM code
- 08 Radio problem
- Another Tire Question
- Satellite Radio?
- Getting the Shaft?!
- I need to turn off the alarm on my dodge dakota 2008
- transmission problem under light acceleration
- 2011 dakota auto dimming rear view mirror
- Another tow button question...
- 05 Dakota Taillight problem
- bad ball joint?
- So I got this rattle ( leveing kit issues)
- IPCW L.E.D. Door Handles
- Long time! No see!!
- Questions about tires/wheels
- clicking under dash
- drivetrain??
- 2006 Dakota. Whole Lotta Problems! U0101, P1603, ect...
- 08 4X4 standard trans VIN # needed
- 2009 Dakota Sat Radio Issue
- Performance igniton coils?
- Power Steering Pump: How can I tell if it's bad?
- Right Tail Light is Dark!
- Front end rebuild - what would you do?
- Low range light blinking while driving
- Shortening the shifter
- Anyone near ATL, can I borrow your gen3?
- 2009 Dakota!
- Is Moore performance products still around? Is the srt hood still available?
- Recomendations on Cold Air Intake??
- temp gauge issue
- Ooo NO!!!!
- Backup/Reverse lights
- Another Y pipe thread
- ding-dang idiot lights !
- Whine at WOT
- 3 inch coil spacer
- Clunk or ping in drive train when first accelerating
- removal of door moldings
- Power Steering Issues
- nerf bars
- Need Help: Headlights are out both High and Low
- Ride height
- In dash temperature question
- Fuel Pump questions for yalls
- I am down to 13 mpg!
- exhaust for 3.7l
- new tires needed
- Rear slide glass gasket
- tow haul issues
- Tail light keeps blowing fuses & only works as turn signal WTF?
- Truck running hot
- vibration at idle or at a stop
- Pleased about superchips
- Dealer cant fix my stalling
- Flashpaq 3.7L V6?
- tailgate lock
- Leak behind center console?? HVAC??
- New 05 Club Cab
- leveling kit installed
- Seatbelt warning won't stop going off
- Quietest Exhaust for 3.7 L (2011)
- HELP! Tranny downshifting HARD....
- Start up whine 4.7 dakota
- Microfishe. Power steering line
- Spark Plugs
- Tonneau advice
- 2008+ intake manifold on 04-07 4.7?
- 2008-up shorty headers?
- Factory service manual
- whining/humming
- Receiving 2005 as a gift
- Low tire pressure alarm
- Blinker / Wiper Switch
- Center consol help
- New member and need help please.
- quarter pannel DENT (Q&A?)
- HIPOTEK! Another happy member!
- Next Generation Controller (NGC) fyi
- Official Recall for Dakota TRucks
- Fog Lights on with brights
- Dangerous Potential Brake Issue.
- ThrottleBody mod? DYI?
- Looking forward to some front end work
- 07 dakota DRIVER WINDOW STUCK DOWN
- Another fan thread....
- Bouncing front end
- 2005 Dakota 4.7L HO Superchips Tunes
- Any body know???
- 2007 Dakota 4.7
- Full-sized double din in my 2006 Dakota
- 2005 4x2 Steering issue
- ATTN help: noob needs help with dakota(heat+exhaust leak+ ABS)
- Auto rear view dimming mirror installed
- need remote start/alarm help
- Build sheet
- Couple exhaust questions...
- GASCAP mystery
- ABS sensor stuck to connector
- Manual to Auto transmission swap?
- No Vent Heat
- Getrag 238
- Differential
- E0 gas
- Ignition key will not turn
- Overhead console will not reset
- finally free
- Helper springs
- Will Ram 1500 brake booster fit 2010 Dakota
- Curious if there are any pics
- gear swap project, need info
- Need help: auto trans leak on 07 dakota 3.7 V6
- Transmission Pan Replacement
- Wiring Through the Firewall
- 2007 Quad Cab Subwoofer Box
- Broken Spider Gears... F***
- synthetic oil changes
- Stock to halo help
- This stupid, monsterous Key!
- Hydrogen anyone?
- Bumper removal for light replacement?
- 05 Dakota 4.7l auto quad cab transmission issues
- That time of the year again: remote starters
- 4.7L soot out of tailpipe?
- 2008 V8 hot mess underhood..
- Transmission Issue
- Bumper swap?????
- Does anyone else have this problem?
- Tie Rods and Sway Bar Bushings
- Club cab rear seat conversion
- Mevotech control arms?
- Skid Plates installed
- Suspension Lift Kit?
- Speedo sticking
- Wiper fluid pump fuse
- Power driver seat panel
- Dodge Dakota Center Console Plate Removal
- MyGig question
- 3.7l v6: Has stripped out spark plug hole
- Sloppy steering shaft. Dangerous?
- Hard tonneau that works with Cargo Rails?
- 2005 dakota service manuals in classifieds
- Block heater
- Dakota Utlity Rails
- Looking at a 08 dakota, new to dodge, help!
- DVD/CD Player 2006 Dodge Dakota
- HID projectors installed - very happy
- Off Road Lights
- need help
- Anyone know ?
- 2006 Dakota 4.7: Oxygen Sensor
- Heavy duty cooling
- Prothane swaybar mounts, DONT BOTHER
- 2005 Dak 4.7 lliter Misfire Cylinder 3
- Keyless Entry Module
- Engine noise like clicking and whirring
- HELP Dodge DAKOTA seatbelt NOT REGISTERING
- Transmission Scrap Price
- Roof Rails from a Durango
- Aftermarket Radio
- New Member.
- CEL but no code stored
- Rear end parts
- New spark plugs
- 4.7 horsepower at rear wheels
- getting all air out of cooling sys
- Aftermarket grilles, not inserts
- 2005 Dakota Bumper Fixup
- is there hope for my 2010 dakota
- Injen Cold Air Intake
- where is fuel filter for 2007 dakota
- 2007 dakota laramie
- bed liner the whole truck
- Stereo Question
- Question about aftermarket grille inserts
- Lower Control Arm Install Question?
