View Full Version : 3rd Gen Dakota
- 2005 Dakota transmission cooler fun
- Dakota owners manuals
- 08 Dakota Big Horn 4x4 brake drum seized
- Power roll on
- Receiver and CANBUS Question
- need help with dashboard plugs
- Headers
- heater control valve
- Installation of bushwacker fender flares
- rack and pinion best buy?
- New Rear Differential Cover
- 2007 3.7 Dodge nitro misfire
- Hit a curb, no slow acceleration
- weird radio issue
- Dakota Dragging front brakes
- Dome light/map light not working dodge dakota 2005
- T80 Recall for heated seats
- stalls when in reverse and drive
- 07 Dakota tranny
- overheating
- radiator core support (MOPAR 55359650AA)
- 4th gen Questions?? re post from wrong location...
- Another New Guy
- Crate N Go
- New clutch purchase advice
- outer tie rod end jam nut
- 15” rims
- 2005 Dakota Idle Issue
- 2005 Dakota IAC Code
- any one relocated their 4WD control knob 2005
- Where is the Shift Solenoid A located
- Here's a real weird one!
- Did i kill it?
- doubledodge99 transmission issue
- Added a Tailgate Spoiler
- No Dash lights, no crank
- 2006 3.7
- Cam/crank sensor Help
- '09 TRX4 replacement struts/shocks
- transmission ratcheting/clicking sound then clunk into reverse
- New here
- New to me 2005 Dakota - Questions
- Superchips 3845 on an '09 4.7?
- Electronic Throttle Control warning light
- Custom bumper for 2010 dakota bighorn
- Touch Screen Mods...WHat did you do to make it work?
- Transmission clunk 3rd Gen
- Coil spring comp. tool
- 2005 driver door panel repair
- A/T shift cable questions
- Yet another set of brake calipers
- Question about leveling kits
- "No Fuse" warning. '08 Dakota. IOD fuse?
- Towing question..2005 quad cab 4.7 RWD
- 2nd gen to 3rd gen front end swap.
- Transmission pan, gasket and fluid replace
- Oil Pressure Switch-3d Gen. Dakota
- Leveling kit help
- Capacity noise
- AWD or 2WD?
- Halp! Truck wrecked, need offroad bumper options!
- 05 Dakota rear end options?
- 06 Dakota 3.7 Rear Main Seal
- Trans cooling question
- 2008 v8 215k o2 sensor codes
- 2008 Dakota radio amp.
- Performance Mods for 3.7l
- 05 Dakota key fob?
- My "New" 2007 Dakota
- Help finding this part? 4WD conversion
- custom upper control arms
- Hey guys new to this forum!
- Help with tire choice
- Advice Needed on Aftermarket Transmission
- 08 Dakota Trans Shudder
- Anyone for a puzzle
- Engine Options
- Which Engine do I have?
- first front end problem
- 06 Dakota Transmission error codes
- Body Lift Kits on 06 TRX 4x4 dakota
- 06 Dakota Transmission Code
- LED Light Bar
- failing alternators
- Steering Box Adjustment
- Help after sensor swap
- Front CV assembly replacement alternative?
- Speedometer off tracking questions...
- Tapping/clicking from Oil filler neck??
- Half shafts
- Broken Valve Guide
- Driver window does not work.
- Lookin for a good fitting seat cover set
- Will this Tire Work??
- Adding a trailer brake controller to existing wiring?
- P0300, p0301, p0302, p0303, p0304
- Install Fuel Check Valve
- Probably already asked but searching has failed me. (Seats question)
- Disabling drls on 09 Dakota
- Does anyone have the shift point spread sheets?
- Torque Specs.
- Engine stumbling
- Issue after changing Water Pump and Thermostat
- Possibilities?
- TRX4 CV Axle questions
- Emissions
- 2005 Dodge Dakota 4.7 transmission interchange with 2006 Dakota
- 2007 Dakota Transmission Buzz or Vibration
- Leaf spring advice
- Same code, different problem (P0457, P0522)
- Main bearing endcap problem won't go away.
- Shackle bolt seized
- OBD fault
- Fender flares
- Only works in 4x4?
- Dakota History
- 2006 dakota lights, wipers, and horn not working
- 2006 dodge dakota transfer case control module location
- My 2005 Dakota has got me stumped
- 2005 4.7l timing cover gasket doesnt fit
- Towing a Ramcharger with my Dakota
- a Few issue
- Exhaust power gains
- Sway bar rubbing
- Good Cat-Back exhaust system
- I have a 2007 dodge dakota slt crew cab
- My "New" Truck
- Wheel bearing question
- Rim size
- engine replace - COOLANT??
- Oily stain on carpet by door steps.
- 2005 dodge Dakota
- 2005 dodge Dakota 3.7 4x4
- 2007 Dakota no power, solid red light(fixed)
- Dak or Kota?
- Power Steering Pump Reservoir Spacer
- 05' Dakota - Front Shock/Strut Assembly
- 2010 Dakota front parking light
- 545RFE Swap
- Leveling kit
- Trans Solutions
- Spring Is Almost Here - Anybody Have Plans
- Spark plugs
- 2005 dodge dakota door latch busted
- Manual shift into reverse 06 Dak
- Transmission problems
- Occasional misfire and rough idle
- Heater not working
- Transmission issues?
- Help rear passenger door inner panel removal instructions plz
- Loud grinding noise in front only when turning
- 2006 Dakota engine fit into the 2005
- Help! Dodge dakota down
- Starting problems
- 2011 Dakota fender removal
- Electric Cooling Fan
- Help!! Ball joint and bushing project failure
- Repair of Chrome Blisters
- Hose?
- 2008-2011 4.7 dual plug engine valve seats?
- Screaming Idle
- Hard/No start only when engine is at operating temp, it must cool down again to start
- Bring Back the Daktoa
- 60 year old rookie
- Can't get valve body out of transmission.
- Low temp on display
- So I decided to replace my solenoid pack today...
- 4x4 high not working?
- Rear tail light not working
- Need strong nerf bars.
- Will these tires work
- Whining transfer case
- 2006 4.7 low compression on 2 cylinders
- Tonneau Questions
- 06 Dakota Driver Side Airbag Light On
- Malfunction indicator on 2007 v6
- Overhead Console Battery Drain Issue on an 07 SLT
- heater/blower motor problem?
- 4.7 tapping
- Suspension Beef Up without Lifting?
- Shifting Cable
- Trans overheating problems
- Ball Joint replacement, Stock Upgrade
- Drive shaft issues
- Need Wiring Diagram 2010 Dakota Twilight Sentinel Auto Headlight On & Off
- 06 Dakota power steering fluid coming out
- Engine Light Flashing and Driving Rough
- Gear howl from transfer case after doing something stupid.
- Shopping for a 2008-2011 by VIN
- Power restart while driving
- Brake Caliper Keeps Seizing
- High pitch “whine”
- Driver side interior door panel.
- Battery Tie Down replacement
- Wheel bearing odd ball
- New to me '05 Dakota with issues...
- 2007 Dakota 3.7L No Crank
- 2006 Dakota 4.7, 4wd. Hesitation, shuddering
- 2019 Dodge Dakota
- Noise rear end
- Towing Capacity - What's too much? 4.7L V8 mag
- 2010 Dakota Bighorn wiring
- 2005 Dakota given to me due to transmission issue...
- 2010 Dodge Dakota Change To Twilight Automatic Headlights on And Off.
- Preferred Lower Ball Joint
- Another TCase issue, with a twist...
- How to fit 35s on a 4wd.
- Coil Pack Mounting Bolt
- 05 dakota abs light and no brake pressure
- Spark plug change
- Electrical Issue?
- 2006 Dodge Dakota won't go past 30 MPH
- Driving without front driveshaft
- Stuck in Park
- reset engine light
- 2005 Dodge Dakota power window
- 06 Dakota shocks/struts
- Well, now I know what I'm doing Friday afternoon
- Key/Ignition issue
- HVAC Panel Lights
- 2010 Sealed Ball joints is there a cross from another truck that will fit
- change tranny fluid and filter
- 2006 Dakota 3.7 performance and trans shifts
- Moog
- Fuel Vapor Leak Detection pump Location
- 08 laramie mpg worse than expected
- '08 Intake Manifold
- Engine ticking noise - help !!!
- Spare Tire Carrier
- Smoking Driver Wheel
- Front Bumper
- side mirrors control
- 06 Dodge Dakota P0340 code
- Service Manuals - Factory, Chilton or Haynes?
- Uneven Ride Height
- 2006 Dodge Dakota 3.7L o2 sensor1/1
- 2010 Dodge Dakota Looking To Add Heated Defrost Mirrors / Tow Mirrors
- Engine Knock
- Front coils
- 3rd gen dakota swap
- Funky Transmission
- Tires
- heated seats not working 2015 dodge journey
- Skid plate
- 06 Dakota 3.7 4X4 Park Brake Issue
- Coils
- Scrap yard find
- 2010 Dodge Dakota Big Horn 4.7 No Crank
