PDA
View Full Version : 3rd Gen Dakota
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54
  1. 2008 4.7L vs 4.7HO
  2. Drone Eliminating and Branch Resonators
  3. HO Cams Availability
  4. OH NOOES, "9ASCAP" error message!
  5. what do you guys think?
  6. Which uppers?
  7. Deer accident repairs.
  8. Dynomax mufflers.
  9. Is it odd that my 3.7 dakota tacks out at only 4,000 rpm?
  10. new pair
  11. 3.7 Dakota Upgrade
  12. New Rims
  13. 4.7L High Output spark plugs
  14. Which kind of power steering fluid?
  15. 05 dodge dakota stereo help
  16. metal IFS diff???
  17. Any jmr kit installed yet?
  18. Anyone ever use this stuff? Any good?
  19. How does the digital shift indicator work?
  20. Hey Guys ....selling my truck :(
  21. Battery Terminal Corrosion
  22. 2" leveling kit fine?
  23. rust proofing
  24. New Struts, Shocks, Blocks, and Leveling Kit
  25. Superchips vivid
  26. Exhaust Kit
  27. What does "looking rice" mean to you?
  28. Efan
  29. ?s about dual exhaust
  30. Transmission Line Disconnect
  31. prioritizing modifications
  32. 265/75R16s on stock 2008 SLT
  33. CSRS Passenger Assist Handles?
  34. Shock replacment and leveling kit
  35. Struts
  36. Strut/Leveling Kit Problem
  37. My Gig Lockpick- anyone install one?
  38. Trying to add mirrow defrosters?
  39. Don't like this one bit.
  40. Trailer wiring- 12V and brake controller
  41. Aux. tranny cooler
  42. Can we program TPMS ourselves
  43. 2005 4.7HO 4X4... which Header & exhaust
  44. Need help (Transmission codes)
  45. Truck bucking while in reverse??
  46. Door panels with a new look
  47. Tuning
  48. Installing Rear Blocks
  49. just thought you would want to read it
  50. Finally got rid of the truck :(
  51. cat question
  52. superchip for 4.7HO
  53. Sway bar....
  54. 05 Rear tail lights
  55. Tranny leaks already
  56. Headlights
  57. 3rd Generation 5th Wheel
  58. Led lights
  59. Narrowing down on rims
  60. Superchips Vivid
  61. Springs
  62. need some new bedstripe ideas
  63. Edge tuners
  64. Need everyones help!!!!
  65. Upgrade suggestions
  66. Closeout on headers!!
  67. really cold
  68. Stock muffler in/out diameter?
  69. Need advice on wheel spacers
  70. ABS Brakes
  71. Air horn
  72. Need a new windshield
  73. There is grinding and wailing of teeth
  74. My new tires
  75. Rims
  76. Led taillights
  77. New pics and old pics (slow work in progress)
  78. How bad were your upper ball joints?
  79. Painting stock rims
  80. Jmr
  81. Lockable center console
  82. Decided to keep my 2005 Dak 4.7HO
  83. Thoughts about painting interior?
  84. steering problem..
  85. Rear axle is offset, one wheels sticks out more..
  86. headrest tv?
  87. Do we have to replace upper control arm?
  88. queston about brakes
  89. 10' dakota
  90. Chrome fender trim.
  91. Rear Blocks Confusion...
  92. show me your headlights
  93. Anybody here tow with the 3.7 automatic??
  94. Yep, I did it too
  95. Some pics of the rockers
  96. Driver's seat
  97. jmr lift
  98. Rear end noise.. I think?
  99. 3rd gen dakota hood scoop for sale
  100. Engine/tranny Cooling - towing
  101. HIDs and they work well!
  102. Double din help me pleaseeeeee
  103. Dakota r/t stripes
  104. Toneau covers
  105. About to buy Dodge Dakota
  106. 3.7l tuners
  107. Roll Pan
  108. Shocks Installation - DIY or Shop
  109. Tie rod end came apart...
  110. reset computer
  111. Factory stereo I-pod wire
  112. Strobes/Aux Lights
  113. Rear disc brakes??
  114. New to the forum 05 Dakota
  115. SCT fail
  116. Dynamat Installation
  117. bad shift, 6 speed manual
  118. Help with P0304
  119. magnaflow y versus flowmaster y
  120. Transmission Fluid Success
  121. Sand Paddles+ 5.5'' lift dakota + snow???
  122. Wow jack my ride pictures!!!!
  123. 2011 and Superchips
  124. well i had a good run but its time to move on
  125. new member, helping a friend.
  126. Need a transfer case plug
  127. clunking sound
  128. Locked my keys in the truck this afternoon!
  129. Check out my Christmas present!
  130. Getting hung up on 2 - 3 shift
  131. gas cap light
  132. '05 Dakota Burning under the hood
  133. 2008 4.7L Dakota SLT won't crank
  134. body lift question
  135. HELP! '05 4WD Not working
  136. 2005 Dakota Body Lift
  137. transmission ??
  138. 05 Dakota Laramie 4.7L 4X4 hard disengage from 4H to 2H
  139. Look ma no spark plug wires... WTF
  140. Wiring a new Stereo.. oh god, need a hand
  141. Would these fit?
  142. windshield washer issue
  143. Funky Dakota Issues
  144. New Guy, 2 "hopefully" simple questions
  145. Odd Brake Defects...
  146. Dealer actually fixed something the first time....
  147. Help odd noise
  148. got my doner radio
  149. supercharged on rt70
  150. found out leveling kits are bad if not done right?
  151. Exhaust Question
  152. Whats this part called / Quote from garage sound legit?
  153. Bye Bye Dakota
  154. Front end squeak
  155. 2012 Durango RT
  156. Ball joint advice
  157. "Lights-on" Light...Interesting Day
  158. Sway bar links broke...
  159. Prep work
  160. Want both tires to spin!!!
  161. Rear Brake Noise 2006 Dakota
  162. Drivers side tail light bulb keeps going out
  163. Gear change
  164. Gun Rack
  165. ShurTrax Experience?
  166. lookin for 4.7L flex fuel shorty headers!!!!
  167. 2005 dakota leveling kit problem
  168. mysterious random shudder around 45mph
  169. Front Leveller kit question
  170. Seatbelt stuck out
  171. More transmission fluid change questions
  172. amp hook up high/low
  173. My Dak got pissed
  174. Offroading/mud spots near Phoenix, east valley?
  175. Wanted to say good bye
  176. Rear seat belt buckle bolt size.
  177. cheap Cold air intakes, suck? good deal?
  178. 2005 6 disk in dash $50
  179. Front reciever hitch? with winch?
  180. 3.7L - 6 Speed Ticks and Rattles
  181. Failed emission inspection
  182. Towing with Electric fan
  183. Will they fit
  184. Lowering Shackles direction?
  185. Lug nuts
  186. 05 spare tire troubles
  187. Rims for Dakota Quad 2007
  188. Wanted: Tailgate net for hauling studs
  189. adding key fob to 2005 dakota...
  190. tuning problem:pcm or injectors
  191. truck started on its own
  192. Lumber yard guy: "I've never seen anyone do that before..."
  193. 3" body lift
  194. New(er) Member
  195. A minor inconvenience....
  196. Codes P0700 & P0750
  197. shift kit vs programmer
  198. Upper Ball Joints
  199. Rear Brakes
  200. tow hitch
  201. Heavy duty tire inflator
  202. New Tires, Leveling Kit & Lift Kit Are Fully Installed
  203. New OEM headlight pods
  204. Do RAM shocks bolt up?
  205. doing the front end of the truck ( DONT BUT MEVOTECH)
  206. Throttle body upgrade
  207. towing upgrades
  208. Not enjoying large puddles..
  209. New in quebec canada??? emission+ mecanical inspection???
  210. Temp. roof rack
  211. Center Bore
  212. Ride of The Month - ROTM!
  213. Fuel Gauge OHMS
  214. 2005 v6, which transmission?
  215. RockAuto discount code
  216. tire size question!!
  217. Happy 2008 3.7L Dakota owners?
  218. Sorta of sound clip
  219. Does this sound like a tire balancing issue?
  220. Struts & Shocks
  221. Problem when truck is cold
  222. 4.7L to 5.7L hemi swap oil pan available?
  223. A bad day
  224. Best performance for 1,600
  225. Replacement Rear Bumper?
  226. 4.7 to a 5.7
  227. Malfunction indication light
  228. New Member, Lots of Questions.
  229. Help with wheels, please.
  230. Personalizing/mods. Finally making it MY truck.
  231. first 3rd gen with fiberglass fenders!
  232. Dual Exhausts
  233. Tire selection help (another one!?)
  234. Leaking water pls help
  235. Just put the 4s on the 08 dakota!!
  236. Snowplowing with a dak
  237. droppin my 05 er
  238. Shift linkage cable
  239. Transmission/differential fluid change question
  240. Installing power locks
  241. Goodyear Wranglers are on
  242. Leveling Kit Questions
  243. Too poor for a borla, getting a Magnaflow
  244. Door speakers mats/baffles
  245. DYI Bedliner
  246. Adding auxiliary input
  247. 4.7 Performance Mods
  248. Rancho's
  249. Vibration in rear end
  250. New passenger caliper?
