- Music
- 2007 dakota transfer case shift motor diagnosis
- Dash lights flashing 2005 Dakota
- lower bank spark plugs 2008 dodge dakota
- How to remove Idle air control valve 2005 Dodge Dakota 3.7
- Transfer case swap
- 4.7 HO/ 4x4/ Y Pipe
- Aftermarket Bluetooth 2007 Dakota
- What's the "Engine VIN Number"
- Code P0128
- My stupid tailgate.
- Wierd upshifting problem
- 2006 dodge Dakota will not start after transmission fluid change
- Grinding noise in 2wd, goes away in 4wd
- Advice on Dakota Purchase
- Service Manual
- 2005 Dakota Quirks?
- daytime running lamps
- CV axle/driveshaft rebuild
- dodge dakota (2009)
- P0139 Questions
- Replacing chrome trim bumper with solid
- 2007 dakota laramie plugs question
- Rides like a brick... Advice on ride quality?
- Makin my little Dak work
- superchip
- Another water leak/wet floor
- Is it the Wheel bearing or the brakes?
- All three brake lights are out. Must be wire?
- '07 Dakota headlights won't stay on high beam
- I have 04 ram slt and suddenly would not go into 4th or 5th gear.
- 08 Dakota Dashboard Resetting/Reinitializing Over and Over
- Need new starter?
- looking for new shock/strut assembly. suggestions?
- Help! - New Radio and FM/AM radio signal is no good
- Dodge Dakota slipping around turns
- 05 Dakota severe misfire
- Slight hesitation
- code
- Tonneau covers what are you using on yours?
- Lifting my 2wd 09 v6 dakota
- help”” 2005 dodge dakota 3.7 v6 dakota 2008 gearbox?
- Puzzled
- Space Between Bull Bar & Fender
- John C.
- Let Us Not Dwell On The Tragedies of Yesterday
- Dodge Dakota 2005 after market alarm
- New to me 2006, what should I watch for?
- Wiper woes
- dodge dakota front control module
- Fog Lights Help on 07
- 2007 Dakota Lift Help!!
- 2005 Dodge Dakota wiper problem
- Bank 1 Sensor 1 upstream 02 sensor
- Bad Fuel MPG Problem
- Shifting problem on '05 QC 4.7L 4X4, 5-45RFE
- Ignition Key Cylinder replacement
- 2013 Durango Trans Cooler Lines
- 305/70/16 BFG KO2s installed
- PSA: Don't neglect your tie rod ends
- Source for Longer Sway Bar End Links?
- No Washer Fluid In PA!
- Help!! Possible ecm replacement?
- black lug nuts
- Please help; Center counsel 06 Dakota
- Front end screech
- Scanner Live Data Help
- Can't find suspension lift kits
- 2005 4.7L 6sp Dakota Front End Pop/Click
- No Pictures, so it didin't happen
- looking for (2) 2008-2011 16X8
- Transmission Gasket Replacement Help
- Odometer codes?
- 05 dakota 4.7 rwd Brake Problem
- Light bar mounts
- Code P0706
- possible pcm problem?
- 05 dakota guages keep dropping out please help
- 1600 lb payload with aal
- 4x4 not disengaging
- 2009 Dakota Wheel Specs
- Finding the Mic Plug, UConnect Mirror
- does cruise control have fuse / relay or modual
- Code P0706
- finally replaced fuel pump
- Impressed with how the Dak handled
- Left Outer Tie Rod/Battery
- DS708 scanner Transmission question
- switch to synthetic
- Hard to locate battery draw
- Fender flares "psi"
- 545rfe gear searching when I should be in overdrive
- 06 4.7 clutch replacement
- Headlamp Retainer to Body
- Radio
- Security system armed
- No crank /fire up/ engine start after heavy rain
- Disabled CEL !@#$%
- Steering won't return to center
- To change tranny fluid or to not?
- seat cover-tuner-bull bar
- Battery Splice
- Error code P0700/ P0750
- Inside Rearview Mirror
- New 2009 Dakota lone star. 37000 miles
- backup alarm switch
- Blower won't change.
- Chrome Bumper Moulding
- Column Shift Knob
- Axle nut
- What muff is tuff?
- Hi!
- Quick question?
- Newbie with suspension issues
- Dakota in Snow, Need New Tires?
- Good-bye dodgeforum
- new member
- My Dakota
- My livestock hauling Dakota
- 06 dodge dakota codes
- havent been on in a while...new look :)...and dealing with cooling issue
- Alert tone with no apparent reason
- P0706
- 45RFE / 545RFE - No Reverse
- Help choosing right year/model
- 08 Dakota 4.7 Spark Plug coil on boot stuck
- rear drum brake adjustment
- Want to upgrade the head unit.
- Shaking while braking
- 2009 Dakota Turn Signals
- Transmission concerns
- need new shocks
- lower gears and LSD for 2007 4.7 dakota
- Front bad bearing like sound????
- Check engine light/stumble off idle
- Sport vs TRX
- Cat removal or replacing?
- Dakota Coil Packs
- rims
- Hey yall!!! Fenders.
- Update on previous post for performance problems. Need help
- wheels
- Lowering a 05 4wd Dakota
- Tow Hooks
- Trans Cooler Lines leaking @ Radiator
- Front & Rear Differential Gaskets
- 2005 Dakota 3.7 Shuttering
- 05 Dakota Passenger Window won't go up.
- PCM or FCM? Chasing the random stall.
- Rear drum hardware kit?
- The classic "Bad MPG, Loss of power" !
- New Dakota owner
- Is this wheel bearing noise?
- Of Dakota lost power suddenly
- New Purchase 2005 Quad Cab
- Lift kit issues
- just bought a 05 Dakota Quad Cab
- Brake controller question
- Backup Camera: Comes on when applying brakes
- 2008 4.7L exhaust leak
- Performance problems
- Tranny fluid temp lifht
- Steering problem
- Blinking check engine light means stop
- Light bar on top of 2008 Dodge Dakota
- Power Distribution
- Looking for Service Manual
- shocks and struts??????
- P0037 & P0057 O2 Codes
- Front propeller shaft (drive-shaft)
- Tow Package Transmission Cooler?
- Looking to purchase a passenger airbag occupancy sensor light
- Broken leaf spring.
- Transmission shift problems.
- Steering or suspension issue
- Double Din Installation Kit
- psi fender flares
- Changing wheel cylinder
- Trying to figure out which o2 sensor I need p0430
- Leaf Springs may be bad
- PCM swap
- Front end noise/vibration 07 Dakota 4x4 3.7 c205
- 2005 Dakota Rack & Pinion
- 2006 Dodge Dakota 4.7 V8 RWD Quad cab
- Front end ALMOST grinding noise
- 3rd brake light connection?
- Shaking when braking with new wheels?
- power window failure
- 6x9 replacement mirrors?
- 2011 4.7 Top & Side Plug Replacement
- PS Problems
- Wipers
- 2009 4.7 4x4 programmer.
- topper install issues...need answers
- Unable to pump gas
- which mud/splash guards?
- 2008 4.7 HO Super poor gas mileage
- T bar?? 2006 dodge dakota
- crew cab topper size???
- Throttle Position Sensor
- power steering whine??
- 4.7L Valve cover removal trouble (driver side)
- Truck part unknown.
- Leaf block install
- Dakota Braking at 55 mph
- Rust
- Katani trail hog
- Service 4wd
- Upper Ball Joint MOD??
- Homemade Tools..Anyone Else
- Longer shocks
- p1776 ABOUT TO START MY OWN REVOLUTION
- Transmission problem Need Help!!!
- Front end clunk fixed
- Something very strange for you gurus!
- Strange Codes P0700
- Destroyed my crank
- Need a little input
- 3" body lift
- Programming
- exhaust question
- troubleshooting hesitation problem
- Weird Ding after start up
- Temp gauge issue?
- Changed axle fluid today
- 2005 dodge dakota fuel problem
- Anyone have these new fender flares?
- Definitely Found My Problem
- Free Access To Chilton Manual For Any Vehicle
- 05 Dakota 4.7 miss fire
- snapped 4wd spindle
- 3rd Gen Dakota Headlight Switch
- Rear main
- 2008 Dakota 4.7 Overheating
- Back to oem air intake.
- ECU Relearn?
- Questions Needed! 4x2 to 4×4 SAS
- Cold starting problems
- tranmission cooler lines
- Still have LED headlights
- More electrical problems (I think) on 05 4.7
- Hub bearing again or something else?
- Did the dimensions of the standard bed change throughout the years?
- grilles
- accessories???
- Possible Accelerator Pedal Position Sensor or Eletric Throttle Body Problem?
- Humming noise in the front end, only in 4 wheel drive
- 2008 Dodge Dakota lower ball joint replacement
- Please forgive me, but I almost traded my dakota
