PDA
View Full Version : 3rd Gen Dakota
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54
  1. 05 4.7L to be tricked out need help
  2. 05 dakota transmission
  3. Truck dying when i let of gas
  4. Error Codes
  5. Seat Cover Removal
  6. Should I replace the Rack n Pinion boots
  7. 2007 4.7 5spd auto downshifting issues
  8. Plasti-dipped my grill and headlight bezel
  9. $100 tire pressure check
  10. In-dash GPS
  11. lights mods?
  12. lights on dash board
  13. Rear Drum
  14. Where exactly is the A/C drain tube?
  15. HO Cams?
  16. Ford SVT injectors...
  17. Center Console
  18. anyone have 33s with a leveling lift?
  19. Cruise control
  20. Trouble codes, Grrrrr
  21. Tinted my tailights
  22. throttle body
  23. 2005 SLT questions
  24. squeak in front driver side
  25. Blinking Check engine light
  26. Changing Gear Ratio
  27. Throwing the white flag (sort of)
  28. Rear diff leak at the Driveshaft
  29. Need parking light assembly
  30. Squeek / Rattle / Vibration drivers side under the dash
  31. $12.00 air raid Jr.... Kind of...
  32. truck died and wont idle
  33. repainted my tail lights
  34. Reseting engine light?
  35. bed rail for 2007 dakota?
  36. Knock sensors
  37. Turn signal multifuntion switch erratic 2008+ writeup
  38. 20 inch Ram Wheels
  39. 2006 dakota 4x4 Rancho strut/moog springs
  40. 2011 Dakota premature tire wear (bald)
  41. another performance site
  42. Finaly excited about my Dakota.
  43. two ?'s for you 3rd gen dak guys
  44. replacement mirror glass
  45. Squeakyness on my 2005 Dakota
  46. hesitation 4.7L
  47. question on rims folks
  48. Newbie needs help
  49. Pics and attemt at fix of rear wheel rust.
  50. whirling noise
  51. Superchips 3865
  52. Help!!!!! Truck will not start.
  53. Ball joint boot replacement?
  54. Front Sway Bar End Links
  55. Good experience with detailing?
  56. Recognize this receiver?
  57. About to drive it off a cliff
  58. Traction Control
  59. i need a cheap rear bumper for my 05 dakota
  60. LED Replacement fog lights
  61. check engine light running rough
  62. What to look for before buying used 2006 Dakota SLT
  63. delta 40 exhaust
  64. Monroe Struts installed
  65. 2006 Dakota Dirt Bike Hauler...
  66. Possible product to help with rust prevention in rear wheel area.
  67. Side Window Stopped
  68. Grey Cloth seats
  69. Wheel fitment
  70. Shimmy, Shake...
  71. Noise when putting into gear...
  72. Cluster Dies!!!
  73. Looking to buy 05/06 Dakota
  74. wheel bearing/superchips tuner
  75. Does this trick work on a Dakota?
  76. ac problem
  77. Moog problem solver ball joint possible issue?
  78. Gauges
  79. Finally bit the bullet and bought some ranchos...
  80. p2317 "Ignition Coil 6 Secondary Circuit-Insufficient Ionization"
  81. I Just Bought A 2011 Dakota and my wife and daughter hate it!!
  82. Hit again
  83. Interesting morning, need new bumper!
  84. strut
  85. Dead RT Headlight on 2005 V8 Dakota
  86. What the f*&%!!
  87. Parking/running light problems
  88. tire pressure sensors
  89. Only running lights work through trailer harness
  90. Red security light on and truck wont start?
  91. wierd noises coming from dash
  92. Spec-D headlights?
  93. Jack My Ride Lift Kit
  94. 3.21 gears??? wtf?
  95. 2008 4.7L Gear Swap! A must!
  96. 04 Dakota club cab 2dr to 4dr
  97. 2005 4wd Question
  98. Headlight Lens 09 Dakota
  99. by by junkmaster
  100. 2006 Dakota 4.7l fuel economy
  101. Help! Rain in Passenger Floorboard
  102. Who uses synthetic?
  103. Play in steering wheel finally fixed.
  104. Unidentified rubbing/vibration
  105. Another eFan question
  106. Trans code po218
  107. Looking for a 4door dakota with a blown motor/trans
  108. I hate key fobs
  109. Double Din Installed
  110. When do I need new shocks?
  111. Power steering Issues/questions:
  112. running rich?
  113. High Idle in Park
  114. Bull bar and stupid bolts
  115. 3rd brake light
  116. 06 Dodge Dakota Quad Cab 2wd
  117. LED Tail lights
  118. any body lift an 07 Dakota
  119. clock spring??????????
  120. 2005 dakota rack and pinion...
  121. Project Flatbed - Truck Evo, Build, Pics, etc
  122. Drive shaft
  123. motor mounts
  124. PO300 - Random misfire detected...
  125. Luckin fug nuts
  126. Opinion on selling price?
  127. Roll Pan Hitch?
  128. Stroker Kit
  129. Am I overheating while towing?
  130. Help with power steering/rack hose
  131. 2005 dodge dakota 4x4 squeak
  132. Lift Kit Installation Help
  133. Advice on fender flares
  134. Maybe hitting some junk yards in my area
  135. Random Temp light??
  136. What things should I do first?
  137. FOB door remote programming question?
  138. still stalling...
  139. quad cab rear seat
  140. Need a TRX4 favor
  141. Rattle Can Clear Coat Technique
  142. Quad cab rear interior door handle issue
  143. 06-08 ram tail lights
  144. fuel door
  145. 2007 4.7 V8 Error code p1128 & p1129
  146. jet chip
  147. odometer error
  148. Tires... Opinions and Questions.
  149. Rear block questions before install
  150. Rear Differential
  151. no tail lights
  152. Transmission problem
  153. loud fan clutch
  154. Ugh!!!!!!!!!!!!
  155. gift from my wife
  156. Super chip really worth it??
  157. Question About LMC Truck Catalog
  158. Need a point of contact
  159. Home on R&R - Transfer Case Problem
  160. Roll Pan?
  161. replacing front axle seal
  162. Cough Cough
  163. Transmision Oil Temperature
  164. Too hot?
  165. Tire size
  166. Oil Pressure Light Came on Then Off
  167. front end rattle
  168. stabilizer bar/steering stablizer question and more shocks
  169. shaking
  170. all this strut talk
  171. need front strut info
  172. Time To Replace...
  173. Anyone running a Trans Temp Gauge?
  174. A little warm for my comfort
  175. ECT Sensor
  176. No 2 or 4 wheel drive seems to be in neutral
  177. Help me spend my money
  178. Engine hiccup and high RPM
  179. Cruise control??
  180. Official weight of my 2wd
  181. day two
  182. Electric Turbo ... Total crap or a decent buy?
  183. SuperChips questions
  184. Questions about wheels for my truck.
  185. it wont stop spinning
  186. Lift kit
  187. Paint Job Recommendation
  188. 2 inch lift and 18 inch wheel
  189. High Definition light Bulbs
  190. front res
  191. has anyone??
  192. Spyder Bull Bar Installation
  193. Fender Flares?
  194. Monroe Quickstrut
  195. after putting in new struts
  196. 05 Dakota SLT 3.7L 4X4 Transmission fail.
  197. Two'fer thread: Bed Cap and SC 3865 tuner
  198. power steering questions
  199. Don't tell me I have to remove the bedliner
  200. I thought we took 6qts?
  201. Long Night and Early Morning
  202. Broken front diff
  203. How To Install Parking Sensors on our trucks
  204. Transmission solenoid pack
  205. A/C Compressor help!
  206. Rear lift Block quick question
  207. New plugs
  208. Anyone have the TSB for the software upgrade for transmission
  209. Manual Trans Help (I broke it)
  210. Ford Injectors
  211. Help the Newbie Build his 06
  212. July ROTM voting is open
  213. Evap Leak / Gas Cap Loose -- Can't find fix?
  214. Thinking of upgrading to K&N filter
  215. Did I make a good purchase on my oil?
  216. Intermittent Transmission Temp Light
  217. Mark 8 Efan
  218. Changing out the Reading/Map Lights?
  219. Jack My Ride/Available Suspension Upgrades: Update
  220. seatbelt issue
  221. Full Synthetic Oil
  222. 2'' lift level kit
  223. rancho quicklift??-does it work
  224. Performance/addons
  225. Dumb Battery Question - Maintenance Free Battery
  226. Help cupping tires with leveling kit
  227. Superchips?
  228. spark plugs?
  229. Fuel Filler Tube
  230. Problems?
  231. Trans problems?
  232. New to me truck, allready got problems!
  233. Ait
  234. Moog uppers always "Wet"
  235. Drilling Steel Bumper, need recommendations for a bi-metal Hole saw
  236. Steering Shaft Problem
  237. Custom Rear Bumper?
  238. ABS warning lamp & DTC codes
  239. Tire Size Heads up
  240. having trouble with stalling...
  241. Opinions...
  242. Plasti-dip'ing my grill
  243. cam swap
  244. Dakota overheating
  245. Shocks and lift question
  246. HIDExtra question
  247. The OFFICIAL Lift and Tire Size Thread
  248. "custom exhaust"
  249. Spyder Halo Projector Headlights vs. HID's
  250. Tonneau cover - Folding hard vs retractable
