View Full Version : Dodge/Ram Diesel Tech
- 2015 2500 Cummins
- Dpf
- Dpf 2010
- Lost prime in my diesel
- tymark
- New L.E.D lights installed now flashing too fast
- speed sensor driver side
- New Sinister Diesel Website!
- would you buy a 2500 , cummins , 2015
- map sensor
- info on Dodge
- Replacing Pinion and Carrier Bearings
- Aiming Headlights
- 2500 from 2012 to 2015 disel
- Just Bought a 1990 Cummins
- Introduction
- truck won't go forward until you drive in reverse first
- ? about kerosene
- Used Cummins, 2003 only?
- stacking minimaxx and smarty
- Need help!
- Sinister Diesel has the parts you need!
- Newbie..Oil leak help
- Trouble Codes
- Accessory Key Position Not Working
- full deletes are more then awsome
- who makes the best front end components
- Leaking brake fluid
- Lift pump help
- CNG help/suggestions
- Cruise control not working
- 2003 ram 3500 5.9 cummins
- Need help
- ? About lift pumps
- 05' 2500 Cummins A/C Probs...
- ? About programmers
- new to the site. newbie questions
- Fuel saving mod suggestions?
- Talk me out of pulling the triger on a 2015 Factery order...2500 CTD...
- A/C clutch '07 2500 diesel
- 2007 Ram 2500 turbo wastegate issues? 5.9L
- Stereo mods
- 94 cummins
- 5.9 cummins upgrade
- Advice: swapping a 1998 12v with a 1999 24v
- Building from the ground up...
- Need Drv. side interior front "A_PILLAR" trim
- Start Up Issues 99 Cummins???
- 01, ram 2500 cummins..front seat electric diagram
- need help with this
- 2001 cummins 4x4 Front seat electric connector
- Need help please!
- looking at a 07 5.9
- 99 3500 dually 2x4
- Help with programmer that will work with my truck
- Pulling RV problems, in a 06 2500 ctd
- Bilstein shocks
- questions for new ctd owners with manual transmissions
- need help on programmers
- Can anyone help me???
- 2011.5 full deletes, with H&S xrt pro what level are you running?
- best mods?????
- 2000 brakes 2500
- Clutch Issue
- 2002 Dodge cummins one ton auto tranmission can't decide what gear to stay in?
- Transmissions
- Clear codes? P2609
- 3500 drw vers 3500 srw need facts
- 97 12 valve won't start.
- Factory Order Mileage
- 03 2500 5.9l stalling out at half a tank
- 1990 350 auto to manual swap
- 2013 Dodge 2500 diesel
- 99 cummins acceleration questions
- No vacuum
- overhead console perform service problem??
- 99 2wd spindle wheel bearing and grease seal
- Coolant
- 98.5 24V Tuner Questions
- dashboard
- Other Cummins Forums??
- cat or muffler
- Reliability Q?
- WTB Cummins Parts
- Ram 3500 turbo
- Should I trade my 02 Ram 1500 for a 95 Cummins dually 5spd
- Ughhh 47RE issues
- 04' 3500 Ram Diesel stumbling on hills
- Trans and turbo help
- Fuel gauge Retrofit
- 03 CTD exhaust questions
- 2007 5.9L cummins any good?
- Wiring help
- After market manual trans for 3500?
- Advice with buying a new truck
- 1993 W250 Cummins - Fuel injector line
- 2000 24 Valve Cummins problem
- Software updates to pcm
- PCM problems. Need help.
- "different" exhaust ideas... lets hear them!
- 2014 Ram Diesel Fuel Cap and Door
- p2271 code on 2011 6.7
- So I guess 3rd Gen is the way to go
- two questions. .
- Problems with 4th gen hid install
- Engine light came on
- Well, I'm back and ready for my 2nd RAM
- p2149 and p2146
- fuel dilution
- Question on a 95 Cummins
- which tuner is best for Cummins engines?
- Boost on 03 mostly stock 5.9
- Cruise control problem
- 04.5 slips around 15-22mph
- Wants recommendations torque converter
- 2009 dodge ram mega cab 6.7l upgrades
- Cold Won't start
- Just looking for some info on a 1st gen
- gauge cluster help.
- cummings 6.7 diesel engine
- 1996 2500 5.9 Cummins starter stays engaged
- 05 Cummins won't start
- 97 12valve voltage issues
- WANTED: 1st Gen CUMMINS
- Need some help
- Engine cutting out at 1500RPM- VP44 or ECM?
- i really need help
- 2003 4x4 Ram H/O Turbo Diesel ~ FCA or Lift Pump
- 2003 Dodge Ram TD HO quit!
- Why is diesel more expensive than gas?
- 03 dodge 3500 with cummings desiel
- new to the family
- 03 5.9 air intake heater relay question
- engine swap: 2nd gen to 3rd gen, cummins
- 03 5.9 starting problems
- Looking at a 99 Cummins, comments and questions.
- Which tuner?
- Replacing Headlights for 1998 Ram 2500...
- DexCool in 2013 Ram Diesel
- starting problem
- Leaf Swap
- Need wiring help on a Dodge ram 2003 Cummins
- 2000 24v voltage spiking
- How much Engine oil does a Diesel burn?
- battery Problem
- Commercial Cummins computer upgrade
- tie rod recall
- block heater
- Lots of Codes - Temporary Loss of Power
- FASS DRP Pump
- Block heaters and turbo leak
- 2004 NV5600 Front Seal
- 2006 electrical ghosts
- 2004 Ram 2500 CTD, Most common causes of fuel leakage.
- Fleetguard Stratapore Filter #
- no heat / overheating
- Where can I buy injectors for a good price?
- 2003 5.9l cummins cranks but no start
- New Truck
- Has been awhile
- Block Heater
- Blower and Power Windows not working - HELP
- single clunk at 19mph
- a picture is worth a thoulsand words
- what are the best delete kits out there?
- H&S xrt pro tuner price????
- 99 3500 4x4 cum5.9 5spd tranny popping?
- Looking to trade in 06 2500 CTD
- Blown Tachometer
- Fuel additives
- No Power to the Fuel System PreHeater
- yes or no
- 2004 dodge ram 4x4 SLT Injector issues
- Issues with my alternator/voltage regulator
- Fass/Airdog Installation
- 01 2500 lift pump bypass
- desperatly need a bluetooth dongle, pulse V2 for quadzilla
- 04 steering shaft question
- 2nd Gear issues!
- 99 Dodge diesel was running won't start dead
- 2012 ram 2500 front end issues again and again and again and again...
- 2012 6.7 Ram
- R & R Differential Fluid
- Q: Cummins + Tip-tronic?
- error code on my 2005 ram 3500
- Fuel pump not priming up 2003 ram 5.9 diesel
- Np205 yoke mated to front output shaft on np241DHD
- More fuel used in the cold?
- 2007 2500 tranny fluid leaking?
- 1997 Dodge Ram 3500 Diesel 4x4 dually
- DW says MBRP too loud
- Chip Recommendations for 2005 5.9
- 2005 with mods, value question
- Bypass pulley on 96 cummins
- New 2013 Cummins Ram replacing 08
- best snow tires rated for HD truck
- New guy to diesel
- Adjustable seat repair
- Vibration/grinding when in reverse
- 6 speed Cummins clutch problm
- a618 and 47re valvebodies
- APPS/TPS in '04 3500 Ram problems...
- 06 oil pan bolt torque?
- Here is a question that all diesel owners should consider
- What is the oil to gas ratio to make diesel
- Diesel Fuel Filter 2001 Ram 2500
- Turbo is shot? Or can I fix it? Or just upgrade?
- Parked
- 08 Ram 2500 Cummins manual trans question?
- Should I buy this 2006 Dodge Ram 3500 5.9?
- 3500 cumins idles fine but stumbles upon acceleration
- Diesel Newbie / 2010 Ram3500 Laramie
- Spark Plug Change HELP PLEASE
- needing new balljoints what to go with?
- 03 3500 White smoke
- 92 Dodge W250 cummins air conditioner needs part
- traction bars?
- Turbo Question?
- headlight upgrade
- P0148 but only at 1/2 tank of fuel?
- Oil in exhaust system
- Ugh!
- 18 inch rims and 342 rear diff ??
- Please help!!!
- tow mirrors
- First Time Diesel Owner, Have Some ?s
- 2010 2500 Megacab 4x4 with Cummins
- Fuel filter
- Dodge 3500 dually need help
- Won't start - any thoughts
- the 2500HD should be revised to a very light duty truck
- Cruise control fix
- Loosing FP on 2001 24V
- 1997 diesel
- In-tank fuel pump on 2001 3500
- no throttle response
- Online Tutorials/Video On Replacing AC Compressor
- What are the symptoms of a cracked injector tip?
- Dealership Oil Change Price
- Buying used disel , what yr to stay away from
- ABS light and brake light??
- diesel power loss
- 1994 2500 Diesel wiring diagram
- Dodge diesel cooling
- Auburn, WA Dyno Day Aug 10th
- obd codes pertaining to fuel problems
- 2001 quad cab 3500 Diesel
