View Full Version : Dodge/Ram Diesel Tech
- Did my Good Deed for the day
- In case you guys haven't seen this ... " Superlift recall "
- intake baffle
- tokyo drift
- New ride
- Big tires
- Shifting woes
- new truck
- alright. . .whose white CTD was this
- Loose Doors HELP!!!
- Brake Pads
- Stereo
- trucks wont shift
- superchips vs bully dog
- 06 auto tranny ,tow haul or O/D,
- now this is COOL!!!
- New ECM
- Diff Fluid Change
- Somthing is BAD wroung!!!!!!!
- predator Programmer
- Boobs or cummins, I lost to the boobs
- is 74,000 miles alot???
- Oil Bypass Filter Recomendations
- 6" exhust
- Ok Who did it?
- Service Manual
- Which should i get
- Which mod first?
- 6.7 re-programmer?
- HOLY CRAP!!!
- Think I mighta sold pop (Ford guy) on a CTD!
- Brew vs. Injector cleaner
- Lets end the Hype
- I laugh my a** off @ dogs who chase turbos...LMAO!!!
- 6-speed versus auto in an '07?
- 3 questions
- Hey Drew, ya want some SNOW!
- Dodge Mechanic Tech Advice
- Things are looking up
- No Hitch 'nads in Maryland!
- Rumble
- Still have an Autometer tranny gauge to get rid of.
- Problems with the 6.4L 2008 Fords
- Walmart ramps ...
- HO diesel
- E17 Recall
- 06 CTD stereo, cant get it to play MP3s
- Waste gate?
- Pics of my tryck & the welding bed I built
- Im new to Dodge Forum... Question on Diesel parts???
- Thats why he got a diesel
- Best for my money
- H.O.
- mileage help
- Need help or info on 2005 CTD asap.
- Sooooo.....Think you know how to melt tires?
- Gear Ratio
- Fuel Pump
- brakes
- I'm back from freezing Iowa
- lookin to buy a cummins, info needed
- RPM's
- For those with mods, and who know how to work a truck...lol.
- Rear Locker on an '05??
- Folsom wheeling pics...
- Who washes their engine?
- Pretty sure this post will get booted.... but
- Front end question??????
- 48re tranny question
- Drilling and Tapping - Test Results
- VIN number
- muffler
- Bad Boys and COPS
- Pics Of My Mega Lifted
- Trans pressure
- 03CTD Smog engine?
- Finally doing it.
- Loon Lake
- OUCH!!! rolled & dumped???
- Loss of Power
- Lubricants??
- window decals
- transmission worries?
- intermittent chime on 2004 ctd engine start
- Stop light will not turn off
- Room for Car Seats???...OH NO!
- Engine Swap
- Tow Rating for CTD
- Performance Goodies
- Just joined the Dead VP club
- stacking ????
- How much will the transmission hold
- P0216 Code, Will I cause more damage driveing it?
- 04 Stock stereo
- ram trannys on other CTDs?
- GM LOOKING TO BUY CHRYSLER
- EGT Probe Location
- What temp does brake fluid freeze?
- Online performance companies
- Mapquest Fuel Price Finder
- Gauge Selection?
- 94 2500 12valve Questions
- windows freezing.............
- Here it is
- lift
- bouncing Front End
- one more add-on
- Overdrive unit for a 4x4?
- MEET THE MAYFAIR TWINS, and I have a question.
- thoughts on a true-flow air filter?
- AFE stock replacement filter
- Good thing she didn't have a real truck
- boost fooler question
- 06 g56 flywheel
- no boost reading
- BioDiesel plunge!
- Overhead
- Will this combination work?
- How do I clean out the engine???
- When did the '07's come out?
- ignition switch delay
- So long Ford....
- Stock rims 315 tire?
- Dodge 1 Ford 0
- boost psi?
- Drew hows the snow?
- One more Question...
- Got me worried
- Snow Packed Intake!
- ROKK tech crank sensor review
- check engine light
- 92 cummins 5.9
- 07 ticking noise
- Hey drew 2007 service schematics
- how to drain the tanks
- P!$$ poor fuel economy
- Found some mud... sort of...
- We should add this
- Cummins for Dummies?????
- Transmission Slip
- Dealers You Just Can't trust
- Intake
- Pictures of drain valve installed
- this is funny
- High EGTs w/ loss of power...whats the deal?
- Charles(DBLR) What in the H%$$ is in the water up here!!!!
- JR gets to drive the CTD...
- Quadzilla Xzillaraider XZT
- changed the fuel filter
- Driveshaft Lube - EASY!
- Check your air bags
- Hey cumminalong
- Wait to start light
- Reasonable Price and Timing for New Buy
- Turbo gasket
- Speed control devices
- No go, but funny
- stack threw hood
- You know you've lived in AL too long when...
- 97 ram 1500 diesel conversion
- MOVED: who wants 50 hp for $125
- aero install
- remote start
- 06' CEL
- Turbo Ring Remove
- Guys, check this vidoe out, it will make your year!
- check engine light p2609
- question?
- Oiling Air Filter
- 06 ATF smell
- YES! It is Friday
- 2004 CTD - Oil Pressure Gauge
- Hey Diesel Demon!
- Safe Exaust Modifications
- torque converter
- Just a Few Questions
- New Truck...
- RUN IT WITH OR WITH OUT THE PLATE?
- no fuel plate in my 96???
- my 96 doesnt have a fuel plate????
- By-pass oil filter installed........
- Check Engine Retunrs no code ???
- Ram Air Hood for Cummins
- Bad Fuel Woes
- diesel woes
- Stacks?
- diesel power mag.
- Welding Bed
- do u know wat this is?
- anyone tried this
- Last of the upgrades
- Trailer Towing
- time to fix the previous owners damage
- Vacuum Fun! 01 Ram 2500
- Winching
- My first time pullin w/ the cummin's
- RoadRelay 4
- just mounted my 35's
- Need Help
- Block Heater with Remote Start
- It Will Run With...?
- Who's runnin 2-stroke oil in cold temps?
- ROKK Adjustable Timing Sensor
- Stalls out
- voltage regulator ??
- Is kore worth it??
- DIABLO PREDATOR ,Bully Dog ,Hypertech
- Cat Back Exhaust. Is it worth the money??
- Block heater
- External Oil Filtering
- Motor noise
- What do ya think?
- Oil drain info
- goofball dog
- 6" Stacks and a question about manual tranny temp and upgrade
- Trany??
- This cold makes my PS pump whine........
- Diesel mileage
- GCW for 91 w/Auto Please Help!
- a good cheap box
- Pac Brake
- Slow warm up and little heat
- Is it cold enough for you yet?
- how long untill i switch to synthetic oil
- 06 Ram Seats revisited
- What to do?
- How Bout Dem Colts!
- Transmission Problem... Need answers FAST
- 06 injectors
- 6- speed
- CTD 1 -Mercedes 0
- 5" MBRP on 06' 3500
- Photos of 2007 3500 Chassis cab
- rear axle
- Cabin Filter
- WHAT SHOULD TOP SPEED BE
- how bad?
- how to power up my truck
- Muffler elimination
- Dash lights...
- truck dies in cold weather
- Aero with Jake brake???
- STEVE, tell me about the sound
- EGT, Tranny Temp, Min'Fuel Pressure
- turbos?
- Diesel for non-heavy duty use?
- fuel pressure
- Hey Sharx... you might enjoy this.....
- Diagnostic on a 47re
- cummins power emblems
