View Full Version : Dodge/Ram Diesel Tech
- Ball joints '05 Diesel
- Diesel guys!
- gasser to diesel
- 98 ram 5.9l quad upper ball joint
- Barry KC
- 55 ford twelve valve cummins
- Dodge changing fuel filter to larger unit on 6.7 CTD?
- F/S Edge Juice w/ Attitude for '06
- will they fit?
- Turbo/Intercooler
- please help with out of park alarm
- drum to rotor swap
- 1995 ram 2500 ctd
- quick noob question
- hello first post lots of question.
- towing- is this right? please help
- Idle?
- Cam Position Sensor / Grounding Trouble - PLEASE HELP!
- Aftermarket Clutch for G56
- Metal clink noise!
- Starting problem...need some insight
- 2005 3500 diesel
- 2004.5 Problems (P0237, P0193, and P0069) - ECM bad?
- 2008 2500 High low pressure on AC Question
- ram 3500
- 99 2500 CTD wont go into park. NEED HELP
- Imput on style changes to my 94
- Newby here
- 99 DODGE CUMMINS 2 speed rear ends \ transmissions
- 99 DODGE CUMMINS 2nd lift pump wiring
- Starting Issue
- Changed fuel filter, now no start?
- wobbling front end...
- 2007 Dodge 2500 6.7 Likes or Dislikes
- Engine not starting
- OverDrive switch weak?
- New from CA-SMOG issues
- 06 Common Rail Mods
- 03 Ram W/5.9 Cummins Running HOT HELP..
- need help. 5.9 cummins
- VE Injection Pump Leak/Problem
- Turbo whistle
- Cetane Question
- 2004 2500 ctd not running
- Smarty or Smarty Jr.
- batteries
- Question - Front end sounds like it's falling apart!
- Help!!! i need your knowledge
- axle type
- new truck
- 5.9L Lack of Power at Start-up
- What happened to the grease fittings on the tie rod ends?
- leveling kit brands
- locking hub change out??
- 2005 ram 3500 overheating
- Transmission issue
- new to forum questions on manual trans
- New Diesel and Thanks!
- 02 lift pump and injector pump issues
- 2004 broke down need info
- 97 5.9L Interminttent won't start
- SRT6 Emblems
- fuel leak
- Towing question
- Replacing electric slider window
- starting issues
- Weird possible tranny issue
- in need of much help or any info!
- vp44 fuel additives?
- Battery Help Please!
- CTD won't drive now?? Bad sensor and Locked up TorqueConverter ?
- My first Diesel..FINALLY!!!
- Info on the new Superchips Cummins racing product
- Replacing Stock Turbo, Best Choices For Aftermarket Turbo?
- Urgent Towing Help
- Prodigy Electric Brake Controller - Always on?
- 02 2500 4x4 Brake Issues
- 2007 2500 diesel help!
- deisel fuel problem
- 94 diesel tranny goin krazy!!
- APPS Adjustment?
- 2004 cummins wont start
- 93 cummins won't stay in OD??
- 6.7 power mods
- What year did Emissions affect Cummins
- smoking diesel
- Early shift into 4th gear
- EGT Spike w/o Muffler
- Diesel EGT Spike w/o Muffler
- fan problem
- 08 6.7 getting new turbo at 52K miles
- 2005 lift pump
- Results of 06 Cummins mods! Thanks Coal Train.
- Rear window/power lock issue
- 06 Dodge Ram 2500 questions...
- Running bad at idle. Any ideas?
- Vin code when ordering parts?
- Rpm's
- Transmission Leaked while hauling
- Looking into a Diesel for next summer
- 2003 Common Problems?
- Signal lights acting up
- New to the diesel.
- Need Help!!!! Dying in S. Texas. No A/C
- '99 Ram 3500 trans shutter
- Towing With 6 Speed
- Steering box adjustment screw leak
- Need help with motor upgrades 5.9 cummins
- 07 2500 SLT 5.9 Diesel Fuse Block
- Unknown Connectors
- Uh Oh...
- Cummins upgrade?? Need Help
- Towing
- Torque & Timing on MADS Smarty Jr
- looking to buy a cummins
- water pump on 6.7L cummins
- 99' ctd 3500
- Losing power up grades
- Royal Purpule
- 2500/3500 MPG with Hemi vs 6.7 CTD? ...
- 2005 transmission
- A 'thunk' sound after I start my Cummins
- What oil ships in the Cummins from the facdtory?
- Maybe getting a cummins.. And have some questions..
- TMB/TIMBO APPS sensor, have you tried them, and what are the results?
- Lack of power up hills....
- '99 2500 Ram Diesel Lift Pump Problems?
- Any recomedations for a programer?
- Steering Problem
- Drive indicator blinks and lose throttle
- p-pump govenor spring adjustment
- ‘06 vs. ‘07/08 Diesel
- hey guys
- Brake issue
- 3,750 mile service for Diesel?
- A question about the diff system on a 2005 5.9 Cummings
- A/C Compressor
- It is TIME.... Need help Please
- Tach
- fuel pressure
- 93 250 2wd 1st gen manual trans loses 3rd
- A/C Problems
- Any difference in mpg?
- ctd vers duramax ...
- Power seat
- not building proper boost
- 6.7 pros/cons?
- 1991 2500 Diesel has clacking noise when hauling
- radio glitch dodge cummins td 2005
- Horsepower/Torque curve for a 12V 5.9 CTD?
- Serious problem
- I come to you with a question
- 1998 3500 ram 5.9....oil pressure switch
- 2010 Ram 3500 Radio question
- Info on late 07 compared to 08
- How to change out fuel injectors on a 2006
- black residue on truck above exhaust
- 06 2500 5.9 AC Problem, already replaced Compressor
- Power Steering Problem
- Turbo is not boosting.....
- Bad injectors or seals?
- 05 cummins white smoke at start up.
- 01 5.9 cummins cranking problems
- Is it normal for on 06 to be smoking when accelerate from idle?
- Exhaust!!!!
- Extended Warranty... Worth it?
- Dependable
- Sterling grille on an '07 2500??
- 2008 problems
- Bullydog Extended Functionality..
- fan clutch hardwiring?
- Airdog II ?
- 99 ram 2500 code po121
- 3500 2x4 versus 3500 4x4
- compound help
- Fuel Press.(02 Ram 3500 dually)
- Fuel solenoid wire
- Truck popped codes, got them but don't know what they mean.
- military spec hummer wheels and tires???
- Prospective Ram owner
- Lack of Powersteering
- 98 2500 Fuel injection pump code 1688
- Wastegate solenoid?
- Help-Reported water in brake fluid
- Automatic Tranmission Shift Cable
- Another Fuel Mileage question
- clutch/tranny
- Transmission and mpg indicator
- Info needed for novice '05 CTD buyer
- new owner?
- 04 2500 Cummins 4x4 - Trailer Issue
- loose throttle linkage 98 ram
- Transmission problem
- Torque Converter- Lock, unlock...again and again
- wouldnt start
- Water Temp. Gauge Problems
- Drive shaft grease fitting
- MPG Question
- Suspension noise... PLEASE help???
- Noise from ac/heater blower
- Auto Trans
- Nitto Launches New Interactive Tire Finder
- Transmission Temp
- 1997 5.9L Diesel Bogs down and dies...please help
- Fuel Problem Could use help!! 2002 5.9
- perform service on overhead?????
- Ball Joints
- AC has 2 high ports.
- VP44 death code???
- 04 Ram 2500- Stuck Rear Caliper- need input
- DIY spyntec hub conversion
- Banjo Fitting Gaskets?
- Check out the general discussion subsection!
- Air intake manifold
- OBD code p0191
- idel speed
- Got cracked up dash?
- vibration/moan at 1100-1200 rpm oil filter?
- 01 smoking and gutless
- turbo spooling up
- Serpentine Belt and pulley trouble
- Loss of fuel pressure
- Best truck for millage
- Front Hub Assembly 2001 3500 2WD
- 99 ram with an ac problem...
- 07 2500 shift lever won't engage transmission.
- More power towing
- 318 to 24 valve 5.9 swap
- Towing RPM question
- No Horn
- just wanna make sure I got this right
- Help with modules locations
- no ac replacement threads? please advise
- A/C only works on one side???
- newbie question
- 2 questions-poor fuel milage/throttle hangs
- 2000 Dodge Ram fuel leak from tank
- Right Front U-Joing
- HELLPPPP!!! I need truck advise
- Brake Problems
- A/c issues
- Losing Prime
- fuel pressure regulator control code
- Transmission Shifting Problem
- 06 Dodge Ram 3500 ignition buzzing
- Trans cooler lines leaking
- 07' 6.7 worth it?
- Tires for Ram 2500 with Cummins Diesel
- Loss of power assist when doing parking lot manuvers
