View Full Version : Dodge/Ram Diesel Tech
- Even with New Injectors
- Help 06 Dodge 3500 bad transfer case
- fuel pump.
- 2006 Ram diesel 3500 "limp home mode?
- 35 or 55 watt hids
- 07 3500 6.7 NO BUS code
- 2004 cummins electric fan clutch problem
- Dead Pedal, skipping, on 24V
- Starting Problem HELP please
- 2003 Dodge P/U A/C cold drivers side, warm pass side
- 2005 RAM 2500 Door Locks do not auto lock
- Dual Mass flywheel help
- Horsepower
- Oil Venting Problem
- rim&tire size
- Bout time to step it up a notch
- Engine cutting off while driving...
- Best CAT BACK system for 2006 cummins
- dodge ram intercooler upgrade help
- I broke it. Now, what is it?
- Transmission problems
- steering
- Fan clutch
- Well.. I just bought a new built cummins..
- gear help needed
- Too many small issues. Help please!
- Dodge Ram 07 Diesel 5.9
- AC Pressure
- 6.7l diesel bucks at slight acceleratio
- ATV and the RamBox
- 2006 injectors question
- shortbedguy tread
- Is it time to buy a new truck?
- Electrical Problems
- '13 Lift
- 2013 Factory 20's ?
- Air conditioning.
- wont start all the time
- Got my wheel & key locked when parked, & it killed the battery???
- Air Conditioning Just Stopped Working
- New Be Needs Some Answers!!!!
- how can I make my truck really loud?
- Replacing tv cable on a 12valve
- ECM Help?! 2006 5.9 HO 1 Ton
- Code P0868
- Oil usage 2013 Ram 2500
- Dpf and egr deletes
- 2012 3500 stalled in high water.
- 5.9 Cummins 53
- 5.9 head swap
- 06 5.9 Batterys over charging
- Swapping Programmers Smarty -> H&S
- idle is running 3-600 over what it should
- Fuel pressure gauge
- twins question
- Need help!
- speedometer
- 2003 cummins wont start
- Kelderman 8"-10" Air Suspension Lift For Sale
- dullie conversion
- 2005 dodge 3500 bullydog diagnostic codes...HELP PLEASE
- 2005 Dodge 3500 Bullydog diagnostic codes..HELP!
- 2nd gen auto durability.
- Fuel system losing prime on 98 24 valve
- air dog 2 problems
- No Power Steering or brakes.
- Aux Switch bank
- 2002 dodge ram 2500 deisel has dead pedal
- Door Molding
- o2 dodge heater trouble
- conferting
- break in a new 5.9 cummins
- replacement oil pan for my Dodge Ram 2500 cummins diesel
- 6 speed straight shift
- antifreeze
- oil prime a 5.9 24 valve
- 2008 2500.....?
- Cheap Lift Kit?
- Big power steering issues with 2011 ram on gravel road
- performance programmer's for cummin's
- New Guy: Electrical Ghosts on my 2007 5.9 24V Cummins
- code 0123
- Cummins wants to "pull" when in gear
- Please help me with my ram! Stuck in outback australia!!!
- Questions on 2013 Cummins fuel mileage
- New - questions on possible purchase (long)
- New to this board just saying hi.
- trade in, gas for cummins
- What Injectors Should I Buy?
- 2005 dodge ram 3500 cummins turning off while driving
- Gas to Cummins engine change?
- 2005 Dodge Ram CTD wont start
- 12 valve cummins stalls out when startin or idling
- Keep the noise down
- 08 6.7 check engine light/scan tool
- BULLY DOG tuner
- Is this turbo going to be giving me problems?
- Idle problem
- 08`Cummins 3500 - Should/Shouldn't Buy?
- Black Fridays: 10 second CTD 2nd Gen Destroys a Duramax Chevy
- airdog
- 01 24 vavle turbo problem
- Clearance lights
- 2006 Dodge Ram 6.7 Diesel Turns off while driving
- Best sounding exhaust?
- Intermittent Windows
- '06 won't start without ether??
- Black Fridays: Cummins beats everything.
- Truckin' Fast Wednesdays: Cummins Destroys PowerStroke
- 03 3500 sputtering
- Heeeeelllppppp!!!!!!
- Help locating an alternator part
- How much does the fan have with mpg
- strange oil leak.
- Brake Lights remain ON
- Exterior and Interior colors
- looking for a programer/chip
- Help identifing oil(fuel?) leak
- truck not starting?!?!
- New to the CTD but not to the forum
- Looking at an 06' 5.9
- Fuel pressure
- Dynatrac FreeSpin Kit.
- Vp44injectionpump.com
- Oil leak, is it the head gasket?
- Transmission not shifting properly!!
- Black Fridays: 2001 CTD Ram provides 2 minutes of a smokin good time.
- New guy on the block needs some sound advice. Plz help
- 1998.5 won't take throttle
- Intermittent P2509, P0071 & power loss
- Used 07 2500 6.7 Cummins
- 08 cummins at 102K miles
- New ride what can I do with it?
- 6.7L Crankcase Ventilation System
- 2008 cummins
- Trading for a cummins, is this diesel worth it?
- Faulty Tranny Servo?
- Cylinder head orings
- No Error Codes?
- 07 cummins mega cab o2 sensors
- 07 5.9 engine rattle
- Getting a Cummins: Require help with persuasion
- 3.73 and 4.10 gears not available with SRW Ram HD in 2013
- relay
- U-joints under warranty
- 98 ram 5.9 brake problems
- Electric mirrors
- Abuse from easy driving on 6.7L during break in
- Exhaust opinions
- PLEASE help fuel problems
- Is a 56045537ac fog light switch enough?
- security and chimes
- Troutmaster
- heater blend mode acting screwy
- speedo calibrated to tire size result in decrease mpg
- DEF issues on 2012 6.7l
- 6.7 diesel from good to bad fuel mileage
- Dodge Ram 2500 transmission cooling diagram
- Turbo running constantly
- Looking at getting my first CTD
- Truck Jerks
- 4000 RPM 24v (How to??)
- p2509
- 01 tcd surging when tunner is on
- Can a transmission cause bad fuel mileage
- Go to Sleep...Tranny Fine--Wake up....Tranny bad? WTF
- 3 quick questions
- H&S Custom tune...
- valve adjustment
- Superspring or air bags
- 5.9 gas to 5.9 Cummins Swap
- Might be in the market for a Dodge Cummins 5-Speed?
- 03 cummins vibrates at high rpm.
- 2012 Ram 2500 HELP
- Anyone selling HX35/40 Hybrid?
- Poor mpg
- Having Issues..
- 2002 5.9 Cummins Fuel pressure issue
- 1997 rebuilt P Pump 5.9
- New to diesel questions
- Which Lift Pump Are you guys recomending?
- 2009 Ram 2500 5.9L Battery Drain
- 03 Transmission problems
- What should I be looking for
- Need help! 04 3500 ram, turns off while driving? Fuel problems ? No idea!
- 01 5.9 diesel 5 spd problem
- 6.7 EGR Problems
- Trucked stalled, engine reved, check engine light comes on with no codes
- heater problems
- factery order 2013 Ram 2500
- Buying a 2005 Cummins Dually
- 2006 Dodge Ram Fuse panel Issue
- DPF delete, what to buy?what is the difference?
- snow bound
- EGT Gauges
- help with purchase of transmission 48RE 650 HP
- best program/tunner
- white smoke at idle
- Wtf ! ?
- 97 5.9 starting/idling issues
- Viper Auto Start 5704
- Wondering about injectors 04 Dodge Diesel 3500
- 2002 Dodge Ram 2500 Heating Grid Problem??
- price for h&s full deletes supply and install
- 1997 Ram2500 Diesel - stall problem
- Acceleration on it's own (I think my truck is haunted)
- Throttle position sensor or apps
- Ram 3500 dually 2wd
- Just ordered the EGR & DPF delete & the Smarty JR.
- 2004 5.9L Engine improvements???
- 2002 ram 2500 Diesel
- Rough idle and white smoke
- question about when starting my 06 dodge 2500
- Electrical Problem with my 2008 Ram 2500
- Hard starting... again.
- 1995 3500 Cruise Control Switch Problem
- Wtf are you doing truck?!
- 05 dodge cummins, please help
- Which Clutch?
- Does going up one tire size really lower MPG?
- Stock or Chip it?
- Cold Question?
- 2006 DIESEL 3/5 RAM pu
- Diesel grill cover, need it?
- Trouble Code P0113
- help with my 2006 dodge 2500 diesel pickup
- Drivers Park Lamp Issue
- Cooling fan replacement
- merry christmas
- Oil leak!
- 2008 3500 6.7 auto wont shift into overdrive
- 1100 engine vibration
- cruise ???
- 02 cummins vib/humming noise
- 2001 2500 4WD 5.9L Cummins Mods/Upgrades
- New owner of an 09 2500 question about modifications
- 1998 Cumming 5.9 24 v Ram2500 no fuel
- Replaced all injectors..Still having problems
- going backwards
- Probably a newbie p pump question
- how to tell if you have 24v h.o. motor
- NV5600... how many qts are you running?
- 2005 2500 Cummins Engine Rebuild Wont Start
- Diesel fuel additives/conditioner
- Cummins 6BT power and mods?
- 2002 Diesel Runs Rough and Quits
- cab lights
- 1st gen 12 valve tach
- 12v '92 cummins
- New Ride
