View Full Version : Dodge/Ram Diesel Tech
- Caster information
- Nitto Trail Grappler M/T *New Sizes Released*
- Code P0088
- Fuel gauge
- Ram diesel Engine/Cabin heater
- Joining the CEL Brotherhood!!!!!!
- Strange overhead console problem
- Pull rotor without pulling wheel bearing???
- 2004 2004.5 question
- weird question
- MileageHowToIncrease?
- won't start by itself
- Noob w few q's
- Check Engine Light blinks 10 times, three others lights not illuminating
- Wierd problem. Tranny, diff, or computer?
- 04 CTD won't start
- just bought a 2008, mega cab, cummings
- Strange 6.7 problem
- transfer case needs rebuilt!!...help?
- Front end problems
- Fuel Sending Unit problem
- transmission problems
- My first Black smoke, boy is that addictive...
- 35" rims and tires forsale
- Valve Lash
- 6.7 08 Ram CTD 2500-Lost instant power & wont spin tyres anymore .Help?
- no oil pressure
- Runs sluggish til warm
- changing rear brakes/wheel cyl
- Recomend 35" tires that are good in the snow
- Diesel for 1500 Ram
- AFE Stage II question
- injectors
- HELP: my Injectors are Destroyed I NEED NEW INJECTORS!
- new lights tell me what you think
- Looking for less black smoke!
- 33" Tire Recommendation
- best warranty?
- buying advice
- Fuel filter questions
- 99 Straight Pipe?
- 3 different diesel engines in 2004?
- Let her smoke
- O7 3500 ram with 200k miles on it
- anyone ever change spark plugs and wires on their 5.9???
- injector crossover tubes
- 03' Dodge Ram 3500 CumminsTD, Max Tire Size (stock), and lift questions?
- lifted truck and towing questions...
- Has anyone had to hire an attorney to fight Chrysler
- injectors?
- Truck doing weird things....
- Head gasket leaking
- cr vs mechanical injection
- new place to hang my hat
- Wastegate/actuator failing?
- Rumor or true??
- motor measurements
- just got loud
- Vacuum pump oil leak!!!!!!!!
- Help!!! Got a problem withmy tranny
- Transmission Troubles
- 19.5 or 20.5 inch wheels
- NEW 6.7 Powerstroke!!!
- Programmer?
- looking at my first CTD, what to look for?
- Nitto Tire Launches a New Interactive Site for Trail Grappler M/T (check it out.)
- RPM jumping between 40 and 50 mph HELP
- Towing Weight
- 2007 6.7 exhaust question
- Dyno & Racing at Silver Dollar Raceway
- Time for Tires
- fuel sending unit issue
- Poor Acceleration
- first generation injectors
- Was there a SLT Laramie Reg Cab 2500?
- Transmission help needed
- Leaking Tranny Cooler Lines
- 2500 4X4 rough ride
- gauges vs. digital dash displays
- 02 cummins exhaust
- A/C compressor clutch problem??? Need help ASAP
- Weird squeak
- Alternate method for front U-joint lubrication?
- Sluggishness fixed!!!!
- Injector pump / fuel pump
- How many fuel filters on 06' 5.9 Cummins
- 98 Dodge Turbo Hose Blows Off!!
- Differential & Tranny fluid
- 5.9 front u joints
- 99 dodge 3500 died while driving...
- HI-RES Nitto Dodge Ram Desktop Wallpaper [free download]
- engine block cracked
- my ram
- What is the real cost to drive?
- It just shut down help !!!!!
- a/c stopped working
- fuel problem
- truck wont start
- 2010 Dodge Ram Diesel
- Transmission Problemmo
- "chipped" engines - good, bad, ugly???
- Looking to buy - have some Qs about the 2006 vs older models
- Fuel MPG of stock 5.9 vs 6.7
- P 2850
- No power to sending unit/lift pump?
- 6.7 fuel in oil
- Which is the better early Cummins
- 2006 Dodge 3500 Diesel mega cab trans probs
- HO????
- remote oil filter
- 2004 1/2 HO Diesel help!
- 2005 Dodge Ram Transmission Shifting funny
- Hard to start, can't figure it out ...
- 99 RAM Diesel Help?
- new to site and question please??????
- How do you tell if a cummins is common rail?
- remote oil filter system
- looking for a friend
- Smarty Programmer
- Additives
- tranny mistake
- info on dodge tranny band adjustment
- 3 waterpump replcemnts on 03 dodge dsl
- What would you guys do?
- Cummins Club
- She laid down on me!
- Ideas on how to hook stacks up.
- Dodge Ram diesel
- improved suspension ?
- I have 2 smarty S06s
- fram oil filter leaking
- CTD bluetec motor ????
- What did you pay?
- K&N air intake install and fuel mileage loss
- 2004 Ram 3500 CTD auto tranny shifting wierd
- 04 AC question
- idle speed
- Diesel problems
- Quick tire question please!
- need help with engine block heater
- What is done to your Cummins Turbo Diesel
- New UK member needs advice please
- 6.7 silencer Ring
- 6.7L Turbo replacement
- First tank of fuel in my new/used truck
- What size tire on stock rims without lift
- anyone interested in a 3rd gen adrenaline?
- help with p1668
- Low power at take-off
- Transmission issues, please help
- Dodge 6.7L mechanics and turbo replacement
- Has anyone heard of???
- DIY steering box install
- ABS and (!) Brake light in cahoots
- I want to swap a DRW to a SRW 3500 AXLE
- Squeaky belt on engine cut-off
- Pull the trigger on 2009 or wait for 2010?
- Steering Pulse
- Changing/Checking injectors on '01 Cummins?
- 99 dodge diesel ABS Light
- tranny problems?
- cruise control questions
- 35's and the speedo
- cold air/warm air
- Thoughts on TST PowermaxCR
- new dodge owner with questions
- sluggish 01 ctd... need help!!
- fuel mileage?
- overdrive jumping in and out
- Auto Tranny Problem
- Locker ?'s
- Jet Hot coating on Ex. Manifold
- oil level problems
- dpf filter question
- Tool Box in 3500 Mega Cab with 5th Wheel
- Please help, please!!!
- Model Year Changes 04-08
- Bd Steering Box Stabilizer
- Anyone else had these issues?
- looking to get a cummins
- Loud Humming 99 Cummings 2500
- Help. Had to get a tow. Fuel Pump? VP44?
- slow start huge amounts of smoke very sluggish
- Transfer of warranty question
- A/C question. Help it was 115 degrees today!
- Installing Flex-a-lite 264 Monster ELectric Fan
- Jey Hot coating on manifold?
- EGR quick questions please help!!!!!
- Join the TX Truck Club!
- Axle nut fell off....
- Looking into a Dodge 2500 98-2002
- valve lash ?
- new to this but i need a exhaust
- Power steering pump - internal spring and valve
- Exhaust Manifold and Turbo Gasket Recommendation
- Leveling kit
- Jacobs Exhaust Brake
- Engine Overheating
- Anyone know?
- 04 thru 06 axles
- Ordered an Edge Mileage Max...
- Van Aaken box ID help
- '04 FSM (limited time)
- Attention 2006 3500 owners...
- 5 speed conversion
- 2500 versus 3500 (confirming something)
- Aftermarket intake manifold
- 37's on my truck?
- Cummins Outlet?
- Contol arm bushings
- HELP Brake Problems
- Shopping for a Ram - Diff between 2500 and 3500?
- 2007 5.9 Diesel with SRT10 Hood
- best intake, exhaust, and programmer for 6.7L?
- washer in timming cover
- V6 to CTD swap?
- wont start
- ATS Exhaust Manifold and Pyro
- 89 with 5.9L died idle and won't start again
- Thinking of buying diesel
- 2009 6.7 Question
- Cummins swap...help
- Abs and Brake light on
- Dodge fuel problems
- Glow Shift Gauges??
- Blown rear diff '98 2500--which years fit??
- ECU programming question, quick response appreciated.
- looking at buying a cummins
- Silencer Ring?
- air intake kits
- Stock Muffler and Resonator vs. Straight Pipe
- Jerky shifting
- Injector pump pressure?
- Belt Screach
- Stopping the odometer???
- *Just Announced* New Nitto Trail Grappler M/T [PICS]
- Truck in the shop
- I Need a Fuel Pressure Tester
- Hard starting when engine is warm.
- Extreme Power Loss
- Black Beauty
- Chasis lubrication
- 6.7 exhaust change
- death wobble 6" lift = HELP
- Flywheel in the 07 5.9's
- Any advice on buying??
- Exhaust and Intake
- How to find the 5.9L H.O.
- Strange Throttle Problem
- 05 Cummins powersteering leek
