PDA
View Full Version : Dodge/Ram Diesel Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. Who all uses Lucas Oil Products?
  2. gauge mounting
  3. Where's your favorite...
  4. P1693 issues
  5. Headlights?????
  6. Trailer Towing Package Question
  7. Matte Finish
  8. CTD in my future soon!
  9. Cummins!
  10. going from hemi to cummins...
  11. Stock air intake question
  12. [Fender Flares] I need them, suggestions?
  13. dropped valve with bad head damage.????
  14. Thoughts on Lucas oil products
  15. Thinking about diesel
  16. Maintenance Cost
  17. Oil weeping out of my exhaust
  18. First Cummins!
  19. Computer question...Reset
  20. 1995 47rh tranny shift points
  21. 04 dodge ram 2500 cummings
  22. Check Engine Light Comes on (1999, 5.9 4x4)
  23. 02 3/4 with running problems
  24. 08 6.7
  25. Need Help, 2007 3500 diesel Mega Cab
  26. 2500 running hot
  27. Any comments on a couple of Parts.
  28. Front end conversion
  29. Wipers on my ram3500 borked
  30. Limited Vacuum
  31. U-joint help
  32. Floor Jack?
  33. Auxiliary Leaf Spring
  34. Smoke Switch Yes/No?
  35. Which one?
  36. Alright I need a new brain on this!!!
  37. Need help selecting a programmer for 03
  38. New Mods
  39. Just got a call from quadzilla
  40. banks six gun with speedloader letdown
  41. What rear end do I have?
  42. 12V 2500 wont start! HELP!
  43. Questions about Juice w/ Attitude
  44. 2004-2500 4x4 SLT
  45. want a diesel
  46. Ram Exhaust Boxter style?
  47. Does my cummins have tuning or chip?
  48. question on the new ctd..
  49. trouble with 92 dodge cummins tranny!?`
  50. Oil leaking from Dipstick...and other problems
  51. WIPER Situation
  52. Tough Decision
  53. Rookie looking into buying a diesel.
  54. buying used Cummins tips
  55. A different approach to the Meet and greet.
  56. No Heat
  57. Smarty Jr
  58. Pinion Seal replaced=whining :-(
  59. Bullydog question
  60. I'm Stumped!
  61. trans issue
  62. projector headlights....
  63. exhaust question
  64. gauge/electrical problem help
  65. What size tires?? 35's or 37's?
  66. Shout out for Olee at "Power by Poole"
  67. Need help on new rims
  68. Bully Dog Products
  69. Any tips or pointers?
  70. Front End Wobble
  71. 7-pin trailer plug.
  72. Mopar Parts?
  73. 2500 cummins no start
  74. High beam indicator
  75. intake heater
  76. stereo install in '08 ram
  77. Water pump?
  78. brake pads
  79. turbo lag
  80. code help 1693 and 0234 what excately do they mean
  81. ball joints are here...
  82. i need more power
  83. injectors stolen
  84. exhaust
  85. SRT10 Bumper cover and Dodge Cummins Question
  86. Pros/Cons of 3.73 gears on 07 2500 4x4 w/ 35in tires
  87. bd diesel steering question 01 truck
  88. help wanted
  89. Pros/Cons for 6.7 vs 5.9
  90. 97 cummins power quistion
  91. I'm Screwed HELP
  92. Cst suspension 6 1/2" 2wd lift kit
  93. diesel has no power
  94. Lost milage
  95. best programmer without other mods???
  96. please help!
  97. new HID for the ol'girl
  98. can someone send me 2.4 for bully dog please?
  99. Need thought on Diablo
  100. Ram Down! Looking for parts.
  101. Brakes????
  102. "Dependable Dodge
  103. engine light on and trans not wanting to shift
  104. programer
  105. brought the truck to the dealer today
  106. dodge cummins tps problem
  107. Blower Motor , noise?
  108. Ball Joint time...
  109. A/C noise
  110. Buying a Diesel....
  111. Biggest Tire on Stock 04 Ram3500 4x4 CTD??
  112. Lost in a Dodge
  113. 1995 cummins buying oppinion?
  114. Thoughts on ATS turbo's?
  115. Best 3rd Gen
  116. just installed my bully dog triple dog
  117. Help!! 2500 hub removal!!
  118. a noise
  119. amsoil dealers
  120. 2" gauge mount option
  121. exhaust question
  122. Aluminum transmission temp manifolds?
  123. My exhaust set ups
  124. Engine noise
  125. Have Edge with Attitude can I stack this with the smarty jr?
  126. dodge vs chevy and ford
  127. Straight pipe
  128. Smarty
  129. low budget mods???
  130. Online Service Manual ?s
  131. New injector search?
  132. Help with Wheels &??
  133. Front/Rear bumper replacements
  134. Help P0516 Batt temp sensor
  135. Transmission band adjustment
  136. Problems
  137. 2003 5.9 noise
  138. Lucas Oil Stabilizer in 6.7?
  139. K&N Filter in a 6.7?
  140. first mod??
  141. Oil Analysis Report
  142. Turbo Squeal
  143. tranny
  144. fuel pump
  145. Cat 2-Micron mounted with APPS..It can be done!
  146. calibrating bigger tires
  147. Truck tool box condensation problem
  148. found a good deal on a 6.7 I THINK????
  149. Voltage During Warm Up
  150. Expected longevity on 96,000K CTD
  151. new CTD owner
  152. Block Heater
  153. 03 3500 dually Cummings fan clutch
  154. Passing Inspection ?, Without DPF. BIO D ?s
  155. intake pre-heater quit, alternator wont charge
  156. 3/4 ton and 1 ton
  157. Diesel reliabilty
  158. key trick
  159. oil
  160. turn me on
  161. Turbo Swap
  162. cummins dpf and fuel milage questions
  163. ctd plug
  164. Jump starting?????
  165. The Honking Truck
  166. 2008 6.7 Check Engine Light
  167. Ball Joint Replacement
  168. Muffler Question
  169. downloaded crazy lary and now its mest up please help!
  170. What's my horsepower?
  171. Crank / Cam sensor
  172. Like everyone else, lift pump problem
  173. Muffler?
  174. 2008 speedo stoped working
  175. What's wrong w/ my truck
  176. Truck of the Year
  177. 2006 2500 4X4 Vibration
  178. cummins and smallblock
  179. Valve adjustment?
  180. 1996 47re rebuild questions
  181. Killer Dowel Pin
  182. rear diff
  183. low sulfer diesel
  184. A Stupid Question
  185. ran out of diesel
  186. Headach rack with stacks?
  187. What's with fords
  188. Dead battery?
  189. NADM @ Rockingham April 11th ( flyer )
  190. HELP!, Broken Spring!
  191. new take off Dodge Grille
  192. Surging, Injector Knocking , puff of black Smoke??
  193. Canister between fan and radiator?
  194. FASS pressure
  195. low fuel milage
  196. oil
  197. Dodge FTMFW
  198. what can I expect?
  199. Question for the Diesel guys
  200. Some questions about 6.7 Mega cab
  201. I've got camber?
  202. Broken Tensioner Pulley Thread
  203. brush guard/bull bar ??'s
  204. Selective Catalytic Reduction (SCR)
  205. Slave cylinder/ clutch master cylinder
  206. Banks 6 gun
  207. ATS warning EPA about DPF dlete kits.
  208. Ball joint replacement
  209. transmission service ? (60,000 miles AT)
  210. 06 trany noise
  211. Water in fuel? Something else?
  212. Good deal???
  213. sat radio query
  214. Need some steering help.
  215. Are you using Geno's Muffler Elimination Kit?
  216. 2006 Ram Cummins TurboDiesel---new member
  217. Transmission Pan
  218. Best deal on Pro Comps?
  219. P2149
  220. RAM 3500 rear axle gear ratio and speed
  221. Fire Ringed
  222. Ram 3500 mega cab diesel for 5th wheel
  223. what other transmissions
  224. IS this an alternator problem or something else?
  225. Vibration in neutral
  226. Trailer battery
  227. few things
  228. temp gauge
  229. Elevated Boron in oil analysis
  230. 6.7 black smoke
  231. trans ?
  232. Aftermarket U Joints/Carrier Bearing?
  233. turbo wheel upgrade
  234. Kore 3" coils going in soon...
  235. Poor MPG
  236. Is there a 2008 5.9 CTD?
  237. sign of a bad injector
  238. Oil Shortage - WTF
  239. failed lift pump, won't start now?
  240. '05, 2wd, Quad, 2500 Excessive EXHAUST noise
  241. Good deal on 3500 cummins.. or not
  242. Transmission leak, help needed
  243. Programmers
  244. new here
  245. Dodge Ram Diesel Power Loss at Start Up/No Spool or RPM increase
  246. Will Jet-A fuel run in the new blue-tec diesels?
  247. Turbo
  248. 11 1/2 AAM rear axle exploded diagram?
  249. location of transfercase module
  250. simple wiring question on 00 ram
