PDA
View Full Version : Dodge/Ram Diesel Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. so, i'm starting to look at diesels....
  2. New Front brakes... having some trouble stopping.
  3. Latest Oil Analysis Report
  4. weird shift
  5. Transmission Housing ???
  6. dumb question...
  7. 1999 5.9 turbo engine speed problem
  8. Weak AC........
  9. 99 2500 axle nut
  10. whats the biggest tire I can get on my stock 2006 4x4 quad cab diesel big horn
  11. Bullydog upgrade scks
  12. Nerf Bar Question???
  13. Variable Cam Timing Overretarded (bank #2)
  14. Fuel pressures/volumes coming out of tank?
  15. what programer should i get?
  16. Losing hope....and patience
  17. Anybody got a bagged/slammed Dually?
  18. tactics when buying a '92 d250 diesel
  19. 2007.5 6.7l issues...need advice
  20. egt questions
  21. How to Choose a Nitto Grappler Light Truck Tire
  22. P2000
  23. edge juice with att.
  24. 08 dash power problem
  25. hard to start cummins
  26. *Unveiled* Pioneer AVIC - U, AVIC - X and AVIC - Z Car Navigation
  27. want to put 22.5 on my truck
  28. incentives for the 2009
  29. AC recharge
  30. Snakes In The Dash!!
  31. right, stop,turn,almost dead
  32. Is this cool, or should I worry?
  33. A/C question
  34. commander/tst
  35. '07 ctd 3500 t/c lockup, any opinions
  36. Chrysler Recall?
  37. 07 ram mods
  38. HWY RPM's/ New Gears. in 99 3500 Manual
  39. HELP!!!!!!!!!Tranny Down Shifting While Driving
  40. Help!! its hott
  41. *uck ats
  42. **** ats
  43. 06 MEGACAB Diesel 3500 4" lift
  44. check this out
  45. question about injectors
  46. Sitting at the dealer waiting for the CEL to be reset!
  47. Should I buy an 04 3500 w/ a 5.9L Cummins?
  48. Auto Transmission fluid changing
  49. Warranty?
  50. 05 intake suggestions
  51. 01 Ram 3500 5.9 auto
  52. Power steering fluid leak - need help diagnosing.
  53. Driveability Issue
  54. chip/programmer
  55. A gas burner needs your guys' help!!
  56. Transmission Help
  57. Not All Fuel Filters Are the Same
  58. power steering pressure fitting leakage
  59. Lost power
  60. New Tires = Sway?
  61. Vacuum line check
  62. Just got 2500 ctd
  63. Checking out an 06 this week, quick q's
  64. tach problem on 3rd gen cummins
  65. fuel injector help
  66. Help help please
  67. 2008 mega or quad cab mpg
  68. EGT question on 02 Cummins
  69. ECM Location
  70. O5 2500 irdog install
  71. Line-X vs. Rhinoliner ?
  72. Will this Tailgate fit a 94 Cummins.
  73. 06 3500 wheel bearings
  74. Question on ball joints
  75. Transmission or Drive Shaft problem??
  76. Edge Juice w/ Attitude vs Banks Six Gun
  77. Dodge "Jake" Brake on 6.7
  78. Fuel Leak
  79. No Power Streeing when not in motion
  80. 1998 Dodge Gas Crusie Control in a 2001 Cummins
  81. Freon Level
  82. Ats screwed or not screwed
  83. Codes
  84. 2006 5.9 Engine HP & Torque specs
  85. PCM location 2007 5.9 3500 dually
  86. Truck Box
  87. oil leak
  88. The Squeak
  89. compression for 06 24v
  90. 97 throttle rod problem
  91. Dusted engine?
  92. Banks high ram air intake or cfm+ ram air intake?
  93. Axle fluid capacity?
  94. noise when i push in the clutch
  95. Help/questions
  96. Diesel engine in my V10 I know i searched!
  97. 05 cummins spins over but will not start
  98. 5.9 Cummins won't start
  99. Decreased fuel mileage after PCM upgrade - help?
  100. Steering Box Seals
  101. EGT Question
  102. New Member with cummins engine questions
  103. Transmission Question
  104. Torque Converter Switch
  105. Fuel Level Sensor?
  106. 35" Tire Recommendations
  107. Looking to increase MPG
  108. OEM Extanable Towing Mirrors (LED)
  109. EGT guage install and use
  110. Air Lift
  111. Tire Load Range???
  112. 09 CTD Auto Shifting Hard
  113. 315/70/17 Tires
  114. Price on Injectors
  115. Towing
  116. EDGE juce w/ attitude
  117. Bully Dog Triple Pup question..
  118. Cummins Fuel question
  119. Canadian Cert. Does a Diesel need a Muffler?
  120. 07 2500 Diesel Ram Leveling kit/ Tire Size
  121. Would a programer cause injection pump failure?
  122. crankcase overfill
  123. Keep my 5.7 Hemi or get a 2500 CTD?
  124. new 37's, whatta ya think?
  125. thank you
  126. First Diesel.
  127. Where is everyone?
  128. No muffler
  129. Codes?????????
  130. Diesel, Hard to start...
  131. New exhaust system
  132. Does a Diesel Pickup need a Muffler?
  133. abs light code 65?
  134. 2009 2500 Mega Air horns
  135. 96 Cummings idling problem
  136. trailer tow wiring problems
  137. Newbie: Another Throttle Positioning Sensor Problem?
  138. Transmission and Diff Oil Specs
  139. 2500 5th Wheel Towing Capacity
  140. 94 jumps at 45-48 mph
  141. Problem with Cummins idle, help please
  142. 5.9 Cummins wont idle normally
  143. marine grade oils
  144. Red dually
  145. Dashboard Removal
  146. Lift pump or Injectors???
  147. 07 stalling
  148. 07 mega ram stalling
  149. Speaker sizes?
  150. H34 dash panel recall
  151. Newer Cummins Spool up and Power Brake
  152. Help diagnose my smoking truck w/ Video
  153. abs and brake warning light
  154. Laugh is on me - VP44? - K.I.S.S.
  155. Steering box on '04 2500
  156. 6" lift with 35's photos needed, please!
  157. help code P2149
  158. bad gas mileage, possible tranny or tc problem?
  159. onboard air
  160. Tow mirrors
  161. Blue Smoke and P code
  162. p1693
  163. Do i need i leveling kit?
  164. bhaf
  165. Re Intro and questions
  166. 08 charging problem wits end
  167. 93 Diesel charging problems.
  168. Slow to Go tranny
  169. Dodge 2500 Mega 4x4 Cab 6.7 Turbo Diesel Purchase
  170. whast up guys im back
  171. what leveling kit for 08 6.7?
  172. Balance your drive shaft
  173. real bad rattle
  174. Need help asap
  175. DIY Ball Joint Replacement
  176. Project truck what do you guys think
  177. power steering update... carnage
  178. manual transmission hard shifting
  179. 01 question bout brakes
  180. 96 Dodge brake pedal to floor
  181. Beeps w/ Right Blinker and when Braking
  182. Time for some replacement parts
  183. loss of power steering
  184. Recall problems
  185. 2003 Tow Hitch wiring connector problem
  186. Dong/Beep When Braking
  187. Yip I'm a new guy
  188. 2001 Dodge Ram 2500
  189. new to me truck
  190. Steering wheel
  191. Cummins Club In Connecticut
  192. 93, 2500, 5.9, speedo intermit, no o/d, voltage low
  193. Ball Joint day!
  194. Hub Assembly/ABS tone wheel
  195. Basket Ball front end
  196. 07 2500 Exhaust Q's
  197. 2001 dodge 3500 in-tank fuel pump
  198. Brake pad ?'s
  199. Breather bottle relocation
  200. dodge ram 2500 diesel diablosport predator tuner
  201. Aux. Oil Cooler
  202. 2006 3500 check engine light on
  203. 2006 2500 Rearend
  204. Stuck Seat Belt
  205. High idle
  206. Warranty on 68RFE 6-speed transmission?
  207. FSMs
  208. Anyone have this installed
  209. 1998 12valve Longevity (a good buy)?
  210. Diesel running hot
  211. Ram brakes, too much rear.
  212. bluish grey haze on start up
  213. buyer
  214. Overcharging and slow turning over
  215. increase boost cheap and easy
  216. Grinding Front Right of truck
  217. 300,000 & no power...
  218. New to me an 03 CTD
  219. 2000 5.9 wont start
  220. need help fast!!!
  221. Exhausted???????
  222. V8 to 12V Cummins Swap
  223. ,07 4wd query
  224. Looking to buy a diesel - which one?
  225. 4x4 conversion
  226. 47rh 2nd gear slip
  227. 2" gauge mount option
  228. Dash Swap
  229. Replacement Rotors
  230. gear ratio question
  231. i got small mirrors.....
  232. Wiper motor getting weak?
  233. 6.7 w/aisin trans reliable in ram4500??
  234. 6.7 w/aisin trans reliable in ram4500??
  235. 2000 dodge 2500 diesel suspension
  236. whats this issue?
  237. CTD Won't start, starter motor bust?
  238. v10 to 12valve-v10 is out
  239. 12 valve cummins leaking oil
  240. turbo charger , holset hx35
  241. fass install issues
  242. fuel delivery problem.
  243. pre load
  244. want a 2500
  245. Vacuume pump on a 01 2nd gen
  246. dash pad removal
  247. no overdrive dodge 12 valve cummins
  248. Mileage Max from Edge
  249. New to the diesel thing...need help
  250. Oil pressure problem
