View Full Version : Dodge/Ram Diesel Tech
- Opinion: 20" Wheels vs. Fuel Mileage
- SOS - 911, need a call
- Lift Pump?
- Broken wheel stud (front) 2010
- 98 cummins diesel, what size are the intake clamps
- Towing in Cali
- Need help with door locks
- tranny gremlin
- Idler Pulley
- Transmisson Coolers
- Can't find vibration source......
- Front bumper replacement & Tick coming from Engine
- Sounds like predetination
- Rollin' Thunder - '93 Dodge Ram
- 2500 vs 3500?
- Fuel Lift Pump Power Problems
- July 3rd Gen Ram TOTM - Go Vote
- 4" Exhaust Worth it?
- Hard to start Cummins, when fuel is low.
- cheap good power ideas help.
- oil change light
- Blow by, turbo related
- before I buy
- Uphill RPM
- 2010 hd
- 2006 ram 2500 diesel will not shift
- Personal Invitation for 2nd gen TOTM voting!
- Is diesel the right way to go?
- front 4x4 axle with 373
- Dodge Tech Please
- Power Loss When Turning Left
- '03 Dodge Cummins Charging issue
- 2004.5 Truck with Error Code and other "issues"
- Loud buzz when I turn on the key
- Need HELP FAST
- unsure about 6.7L cummins
- ac trouble
- Fass customer service, or lack thereof
- How long does it take before the MPGs improve
- Cruise Control Accelerates
- looking for my first Diesel!
- southbend DD shifting ?
- Finally... I can almost taste my first diesel...
- don't want to join a chevy forum
- rear pinion seal
- NEED HELP no air??
- Heavy vibration/shaking at low speeds and stops
- P0243 help
- New to me 97 CTD ... suggestions?
- check it out!
- Running Rough
- 97 CTD auto stalls in reverse under load
- looking for chip of 06 cummins
- 2004 5.9 Engine Codes and CEL
- New Too diesel
- buy a programmer or not
- The tow/haul button on the 2010 409 CI Cummings diesel with AT
- tachometer hook up
- Dana 60 Portal Conversion
- Here's how to get rid of the straight pipe drone with 4" exhaust
- wheels and tires for sale
- The Stealth BOMB'r is under the knife
- P0480 Cooling fan
- Tranny Help
- 2010 cummins
- 95 diesel auto trans help
- NADM event at National Trail Raceway
- 2001 24V 5.9 HO Lift pump?
- Have a couple questions
- 2002 fuel pump problems
- Rims and Tires
- New to Cummins section of DF
- Upgrades
- 01 Data Link Plug
- Looking at putting 22.5's on my dually
- Which Chip For MPG?
- Engin bogging out
- Exhaust Question Again
- crazy larry
- Cooling Problem
- Changing fog lights
- have a 2001 dodge 2500 with defrost probs
- 2001 cummins defrost problems
- Vacuum problem? 2500 5.9 turbo diesel
- code 336 , will shorted injector set this code
- 2003 dodge cummins, code and no power
- Bully dog programmers
- AC problem
- buying 2004 cummins and need suggestions!!
- Help!!
- accelerating without the pedal
- Driving me crazy!!!!!!
- Lost fuel pressure then came back
- my 2000 cummins surges
- 2004.5 Starting problems
- Looking at a cummins
- 2003 dodge cummins , no power
- 03 Dodge 2500
- Personal choice, but i'd really like your input...
- 04 Modified Dodge, Reliable?
- Need stock muffler...anyone?
- please come vote....
- Help!!!
- Econo fuel programmer
- Trans OD and electrical problem?
- need help with van aaken commander.
- What are the dealer secrets to buying a new Dodge?
- Good level kit?
- Should I buy this truck?
- Anti-Freeze question
- Damper & Speed sensor OPINION??
- Daily driving
- Fan Clutch -- Need help
- rear leaf spring question... factory blocks???
- 2nd gen TOTM, come vote
- 3500 front rotors????
- Towing
- want to install wheel masters extenders
- 6.7L emissions recall J35
- 2nd gen poll, come vote
- 2004 dodge 3500 with code p0251
- 2500/3500 Towing/Payload
- Unexplained chime??
- Aftermarket stereo pics
- Strange squeak?
- 2500 deisel vs. Hemi ?'s
- new 08 5500
- Sagging Driver Seat
- Loss of power going up hills 93
- Fuel Problem?? '05 3500 Dodge Cummins 5.9L Diesel
- Temperature Guage ?? 98.5 24v
- Rear wheels wobble
- What to look for?
- Annoying Exhaust Rattle at Idle
- thinking about buying a dodge
- quadzilla custom tunes?
- Help needed asap urgent
- 06 Wiring issues
- New 2010 Mirrors on '07
- Haunted Dodge
- Looking for a new air intake
- clutch not working need help
- 6.7 with 19K+ in fuel damage, please help!
- AC Noise
- Erractic Torque Convertor Lockup HELP PLEASE...
- smoke switch
- steering issue
- diesel do diesel don't
- rear end/front end temp.
- Transmission/driveshaft problem? need help
- not shifting the same
- Roar & more
- Oil change question please.......
- Hit the track with the truck
- high idle and NO throttle, randomly???????
- PCV or somthing like it on a 12v?
- 07 Ram 3500 CTD Steering Clunk / Pop
- straight pipe
- Help! I put gas in my diesel truck
- my new 00 CTD!
- Problems after ball joint replacement
- im new to the cummins
- '01 front end gears
- Strange clunking noise????
- Strange ISB issue.
- Rev Limits and Cruise Control.
- Emergency Flashers
- leveling kit question for 08 2500 4x4
- Bouncing
- Ford F250 What's Happened
- Fuel pump relay location
- Tranny question (that just sounds wrong...)
- a sad day...
- rear door panel removal
- Newbie with questions please......
- Kdp got me
- Need a little advice, new to cummings
- Anyone live in the Florida panhandle area?
- Looking for a new Tranny......AGAIN
- 1st Time Deisel Man... HELP me!!!!
- Looking For Information
- Newly installed Edge Juice w/attitude kills my batteries [06 cummins]
- Anyone interested in Diablosport programmer?
- rims and tires
- 04 CTD Steering wheel vibration...looking for suggestions
- 6 inch lift parts
- Hey, everyone.
- Need a fuel pump core
- Strutmasters.com Warning
- help removing timing gears
- Need help...purchasing a Diesel
- question about a 2001 dodge ram diesel
- Help! DTT Shift Kit Problems
- need a gear housing
- 1999, 3500 dodge diesel six speed 4x4
- Looking at Diesels
- abs and brake light on?
- control arms
- Banks six gun for sale!!!!!
- help removing 5.9 12v inj pump
- Thinking...
- Little Help On Leak
- engine swap from hemi to cummins
- truck vibrates at lower speed.
- brake light????
- Will they fit?
- Limp Mode
- Cubby Gauge Pod
- help please stuckk at 2000rmps
- could use some support from the other big units on DF
- ISSPRO boost guage
- problems with 06 trucks ?
- smoke switch for edege
- How can i make my blow off valve louder
- Just put a new Southbend Clutch in my truck
- quadzilla smoke switch??
- Brake replacement
- 2500 losing power
- Diesel MPGs for 3500 2008
- fuel filter/ 2004 cummins.
- Belt tensioner
- 2500 seat covers
- transmission shift problems
- Dodge/Ford mileage
- 2004 transmission questio
- DPF Delete Installed
- Unknown Problem
- Which Dodge (Year) should I buy, dually diesel?
- 88 d150 body swap onto 91 350 cummins (problems)
- 47re transmission lube,band adjustment
- 03 cummins 5.9 4x4 won't start...HELP
- 03 cummins 4x4 wont start????? Help
- dual exhaust on cummins?
- Radio Dies on Start
- Whats the best brake pads????
- door molding removal
- Possible commins switch
- 2007 3500 Steering Problem-AGAIN!!!
- Lift pump transfer pump failed
- Need some advice...Tierod ends and tires
- 2003 5.9L with overdrive problem
- Thermometer sensor?
- need to know fuel pressure specs for an 04 dodge
- Rebuilding Injectors
- 1500/2500 parts compatability ?
- bad little truck
- 6 codes by the dealer
- Simple tranny question
- Engine wouldn't turn off
- Electrical door lock problems
