View Full Version : Dodge/Ram Diesel Tech
- Mods For Better MPG??
- Question
- Voltage output?
- Newbie needs help with tires & wheels
- dodge ram diesel truck bed
- front wheel bearings
- 94 12v cummins
- Looking for a Diesel
- turbo housing
- Cummins pulls out Durmax
- rear driveshaft problems
- transmission overload?
- 2500 or 3500
- Washer sprayer
- Problem
- new cummings
- turbo upgrade!!
- Lift questions
- looking to buy a cummins
- any ideas?
- 92' Ram 250
- "No cars allowed car show" in Tennessee
- 1990 dodge cummins....help!!!
- Transmission Shifting Problems
- What to look for when buying a Diesel
- New truck just wanted to show it off
- Fuel Pump Question
- 24V cummins in limp-in mode
- Lost 5th gear
- 99 trans question
- transmission problems
- differinatial and pinon question
- HEY GUYS remember me?
- Transgo SK 48RE shift kit
- dead cummins
- I want a little more
- I need some clutch advice from experience wanting to upgrade
- help please
- HELP!!! rear brakes!!
- hard to start after gauge install
- Removing gov sensor & solenoid
- Good deal on a 92 diesel 350?
- First ??? in this section
- Opinions needed: Exhaust manifold!
- Snow Plow
- How much would you pay for a 94 2500?
- 03 3500 cummins fuel pump prob?
- Potential Purchase
- Transmission being weird!!
- Lease is up
- tie rod /pitman boot or bushing
- uncontrolable shake
- Shell Rotella T Synthetic Meets CI-4 Requirement
- Hard powertrain vibration!!
- Sending unit
- Used diesel engine price
- Before i switch.
- Re: 1990 DODGE RAM 250 CUMMINS DIESEL 4X4 MINT !! - $5900 (MORA)
- SWAP Question
- Is this a series 600 Cummins?
- FIXED, ECU, problem.
- Help Identifying loose Plug.
- Bad ECM or PCM?
- Bad Head :(
- Brakes Locking While Driving
- Bad pump or electrical issue?
- 2007 ram starting problems
- Replacing Batteries
- '96 dually tire size
- G-56 6-Speed Fluid Change! Help!!
- 07 5.9 leaking fuel in the fuel filter area.
- NC get together
- BullyDog Gt Just Installed
- I'm cold
- Looking for a clutch that will hold my Edge Hot Unlock
- 2008 6.7 Jerks/bucks at 40mph
- Tranny stays in 3rd gear
- will not start when cold
- pod question
- Need help! Bad Vibration
- 03 3500 dieing
- help again
- Mpg
- help an diesel techs? no start posible ECM
- Clutch position switch
- nv4500 stuck in 5th gear
- Exhaust Manifolds
- test drove 2010 2500 Cummins
- Fluidampr
- Dual feed CP3
- In frame rebuild??
- need input on buying a CTD
- 2003 3500 Running rought and stalling ??
- Egt high???
- Intercooler difference?
- mega cab
- Turbo Help!
- Ramilla still going strong
- need new engine ?
- 2003 3500 codes 2121 & 2122
- Need advice! Buying an 2005 2500 4X4 diesel
- What happened?
- programmer questions on early 3rd gen
- 2002 Ram 2500 CTD looses power
- idle and fuel
- any help for an xford guy
- ainti freeze leak???
- differental noise
- might be geting a 1st gen cummins
- headache rack?
- losing power then dies
- differential cover replacement
- measured vs, rated CCA on batteries
- Possible turbo trouble around the corner
- CTD buying help requested
- Rear Back Up Camera Problems...help?
- Oil in radiator
- 92 ram 250 diesel won't start
- Leveling kit
- Just bought an '06 Mega CTD
- Nitto Trail Grappler M/T Review [Four Wheeler Magazine]
- p0004 fuel volume regulator control circuit high
- Arp head stub torque spec.
- EGR Leak???
- Clanking noise!
- 2004 dodge ram 3500
- Looking for a new pickup
- 08 2500 Ram 4X4
- cold smoker
- New, Used Dodge ram questions...
- lost tachometer,
- 47re lost 2nd gear
- High Mileage All Terrain Tire Suggestions?
- aux fuel pump
- Widest Tire for a 2500.
- Stock ride height
- Thuren heavy duty steering kit question
- Bob from BC
- Dies during Idle
- need help 02 dodge cummins computers
- Turbo squealing
- Turbo ring
- Cant get rear drum off
- HELP ME ! Alaska Dodge and Corporate telling me NO on new warranty engine
- CP3 leak HELP!!!!!!!!!!!
- A/C Question
- seats
- need tuning advice...
- ctd test drive.
- Tirick for removing Front wheel bearings
- 2500 5spd manual.
- Air filter cross over #
- 2006 Ram 5.9 Cummins injector problem?
- 4rth gen ctd
- Hard to shift out of Park
- Water/meth injection
- 48r transmisson problem
- Strange sputtering/shaking at idle (750 RPM)
- 4x4 problems
- ok i have a question for the 2nd gen cummins guys,
- P0121 CEL need help
- Gas pedal problem
- Gas pedal problem
- Too much rear brakes, how to fix?
- Potential purchase ... need advice
- Seat Belt Alarm
- Dual battery question.?
- 06 3500 CTD - Thermostat problem?
- monster diesel
- injector problems
- Wheel Search.... Brand, size, and back spacing
- Wont start and loves to stall
- smarty jr.
- 06-3500 misfire at idle
- What else to look for?
- Governor Solenoid/ Valve Body recommendation
- fuel filter change
- Brand New Bullydog PMT in an '03 Dodge 2500!!!!!
- Mystery vibration..
- dash speakers
- Atf in the fuel?????
- Buying a Mega 07 6.7 Tomorrow
- Injector cleaning tool?
- k&n air filter
- front drive shaft recomendations
- Intercooler
- CRAZY LARRY for the BULLYDOG PMT...????
- Need Advice - Another Tranny noise question
- Need Help with OBD-II Connector - No data
- 01 2500 Cummins won't start after fuel filter change
- '03 2500 Ram 2 major issues.....help!
- Propane Injection??
- Throwing code P1693 and getting no fuel help
- stupid question
- New to Diesels, Electrical question.
- Fuel Issues
- 05 5.9 ram problems!
- Just Released: New 16" - 24" sizes of the Nitto Trail Grappler M/T
- 6.7L CTD power adders question
- New with fuel leak problem
- 04 Cummins 2500 engs dies while driving
- Pretty Cool Cummins
- Rough Idle?
- marvel mtstery with lucas??
- rokktech crank sensor
- Injector part #?
- transmission fluid??
- 2010 brake contol system
- Overheating in four wheel drive
- 05 cummins engine kit?
- 2010 3500 4x4 Max Rim Tire Size ?
- 2010 Ram Heavy Duty Steering Problem
- 2005 Dodge Dually exhaust
- Truck Life
- chipping a 2000 ram with 5.9 cummins
- Anyone in Birmingham, AL?
- Hey everyone, soon to be Cummins owner got a few ?'s
- Need Help ? Fass System? injection pump?
- 95 2500 question
- 92 Dodge 250 Ram diesel
- 92 dodge cummings spark in fuse box will not start
- 3rd gen intake plate...
- windshield wipers cutting in and out
- Straight Kerosene?
- 2005 dodge diesel head gasket
- Looking for 2010 Diesel Fuel Ratings
- Pricing advice needed
- Air flow selector knob in dash malfunctioning
- trouble codes 07 5.9 cummins
- i've hit 3 years and 60,000 k's, do i go for more warranty
- 2006 fuel door
- Help with CTD newbie please.
- 02 Ram diesel no power at first
- lucas fuel treatment
- New lady with an older 2500 Diesel problem
- 2wd vs 4wd
- Would this setup work?
- Bad Rings 2006 Cummins 5.9
- 2002 engine heater
- loosing brakes
- Gear oil smell in and around cab
- Gasser with Oil question
- reasonable repair time?
- Bad tank of Diesel...FML
- Dangerously close...
- 09 shift issues when cold
- No power under load, bad lift pump?
- Wire diagrams for 07 ram 2500 diesel 4x4
- 07 ram diesel 2500 4x4 HID lts
