View Full Version : Dodge/Ram Diesel Tech
- battery issue's
- xdp fuel sump
- 07 3500 5.9L rough idle and slow fan speed
- Cummins builds the 2,000,000th CTD for Chrysler
- 6.7L update questions
- New Cummins...now a predicament...
- 03 diesel in and out of lock up
- 2001 Dodge "SURGES"
- Camshaft, the same on all 1989-98 12V?
- Factory Remote Start And Alarm Options?
- Recommendations on shocks
- Injector Or Worse?
- Truck shopping: 2nd or 3rd gen Cummins?
- Issue With My Cummins
- Trade Hemi for Cummins
- 01 cummins just bought?
- subtle bucking, do I need new injectors?
- hanging in gear
- Is the diesel truck worth it?
- New batteries
- Level kit question
- 6BT Injector thread size?
- Need some honest first-time-Cummins help!
- 07 3500 mega cab 5.9L vibration while on throttle
- I need some smoke!!!!!
- Poor fuel economy, Loss of power, Smokes
- New to this forum
- help - 2007 secondary air injection sensor
- Bull Bar/ Tow Hooks
- Thinking about buying this truck
- odd truck problems. NEED HELP!!
- 07 3500 5.9L throwing codes after a really cold night on the highway
- 99 dodge 2500 stalls and fuel injectors keep pumping
- Are you near Bossier LA? Let’s Meetup
- Shifting in and out of overdrive
- Need Advice Tuner/Towing
- Fan clutch wires
- 5.9 vs 6.7 MPG automatic trans
- Noise
- Ram won't lock in park HELP
- charging query
- Why Cummin' Never Felt So Good
- Body Parts for a 1998-2002 Cummins???
- anti freeze question
- 90 dodge blower motor fail
- changing fuel filter 98 24 valve.
- serious black smoke
- 22.5 tires and rims on a 02 2500 24 Valve
- 400,000 mile tune up
- New member with a problem
- Ram long hauler
- Anyone know this truck?
- Really starting to HATE my truck
- ECM question
- 5.9 wont start! 2005 ram 2500
- 98.5 deisel wouldn't start
- 2005 Cummins No start ?
- Exhaust Kit for 5.9L Cummins
- In search of complete 6.7 engine or totaled truck
- tranny warning
- 98 dodge dully transmission
- Exhaust / Engine brakes and RAM problems
- 2006 Dodge Ram 2500 Laramie 4x4 Diesel - need advice by 11/3
- flashing dash lights at start up???
- P0500, U0121, and P2509 help?
- 5.9 cummins battery boiling
- 04.5 5.9 cummins 2.4 valve 4x4
- Transfer lockout switch
- 03 cummins hard start
- 12v burns oil to add mark but never gets lower?
- trans problem
- 2001 Cummins Knocking!!!
- 2005 cummins will not stop!
- edge cts with attitude questions
- 2010 Cummins Question
- Hi-lift base
- a/c and heat problems
- first to second upshift to quick
- 2007 6.7 electrical problems
- shifting rpm while wot 2012 6.7ho auto
- 07 5.9 cummins accelerator issues
- Changed out stock air filter...Now problems
- 04 cummins problem
- Solid 5.9
- Fuel economy problem.
- What is the best fuel additive ?
- 5.9 48re or nv4600
- 04.5 2500 14.5 mpg highway?
- bought an 07 cummins 5.9L
- KC lights
- Cummins cyclinder #2 isn't firing should I buy it?
- Intermittent Cruise Control ?
- egt guage problems!!! please help
- Cummins revving problem
- No power on kickdown to pass: code P0148
- Air intake horn
- 2001 Ram 2500 5.9 diesel 4x4 brake problem
- new to diesel...buying 04.5 6 speed...thoughts
- diesel vacum pump oil leak
- Will this turbo fit my ram?
- Beamed Prerunner cummins
- Building a 94 cummins for truck pull competitions
- advise needed!!!!! all you Cummings tricksters
- Is my Turbo broken? How to tell?
- Stalling when taking off in 2nd
- hey ny guys
- Looking to buy a cummins
- nv4500 4X4 with electric shift?
- 1990 w250 5spd rear driveshaft length?
- oil pressure gauge install
- Hey Guys, I really need some help
- need help with airbag light cot in high water
- 2007 Ram 3500 6.7 Cummins Will Not Start
- New Diesel Owner
- 2001 5.9L Cummins Bucking/Jerking under acceleration
- Frame comparison
- 2002 dodge cummins 24valve questions
- changing exhaust pipe
- Instument Cluster
- DPF delete programer
- Any Smarty S-03 Owners? Looking for fuel economy feedback
- MPG trick for ALL CUMMINS
- morn....morn,morn
- Night Fellers
- Dodge cummins purchase advice
- What mods should I get? 07 6.7L
- New Here
- need some specs asap please
- POST-DIY Ball Joint Problem!!!
- leak after motor cools down
- Knocking from engine.
- looking into an exhaust brake
- what mpg do i get and i have a brake question to
- catwngs
- Fuel transfer pump
- gauges which ones?
- VP44 and banjo fittings ?
- 1999 2500 Intermittent Startting Problems
- 2001 5.9L Cummings "Best Practices" for a Minnesota Winter
- Camshaft Position sensor; what else could cause it...
- Edge EZ?
- 99 ram 2500 diesel bouncing on highway problem
- Hopefully buying '06-'07 cummins...need help
- 05 2500 won't start
- not starting
- 2nd A/C compressor?
- More power
- Bad injection pump? Help
- Doomsday/SHTF fuel
- Doing my homework
- Tranny parts
- Suggestions on fuel additives
- No turbo boost
- Fuel injector cleaning
- 2004 RAM 2500 diesel - 200,000 mile service?
- 02 Turbo in 05??
- Easy DFP Delete
- Need DPF EGR Advice
- Tuner Time
- New Truck Need Ideas
- Wanting a new toy, can't decide
- 2003 cummins 3500 overheating
- circuit diagrams
- is urea better than DPF?
- Shifter Rattle
- glassman
- PO217 overheat dtc code on 2004 Dodge Ram 3500
- Ram 2500 rear shock bolts
- 12v low idle/stall
- 07 5.9L Diesel loss of horsepower
- Insight needed!!dtc code p0217 showed on my BD programmer
- Motor swap
- 03 diesel 3500
- New 99' 2500 4x4 SB QC
- 6.7 hard starting?
- 2012 6.7 Upgrades
- Turbo won't go past 10psi?!?
- battery/voltage.... a little bit of a read sorry
- DRW to SRW parts trade in So Cal
- 2003 Ram not shifting into overdirve
- Increase fuel mileage and better performance
- NV4500 to NV5600 swap/ please help!
- error codes
- help ive got bad vibes
- Predictive Maintenance
- bad TPS or PCM causes fast idling?
- 5.9 diesel surging when starting....sometimes
- Injector upgrade
- Accidently put gas in my tank
- tail lights won't turn off, 2002 Dodge diesel
- need help on rebuilt engine
- mega dually w/8' bed
- smarty s67 tuner advice?
- voltage spikes when ac running???
- Warning light at 90000 miles 08 6.7 Cummins 2500
- cummins fuel pressure with fass factory replacement lift pump
- 2012 gooseneck questions please
- Dick Hannah dodge service center
- Can't manualy shift automatic trans from drive to 2nd or 1st
- recall ....
- Going to look at a 01 2500. Advice?
- Towing mirrors ???
- Turbo upgrade recommendations, please help!
- CTD parked for extended periods of time
- Transmission question
- new cummins exhaust system
- 6.7 ltr cummins problems
- Diesel Fuel Mileage
- might need a turbo
- Ready to throw in the towel on my front end
- 2009 Ram need help please!!
- 06 has no power above 1800rpm
- cummins transplant
- Poor man's FASS or AIRDOG
- Engine hesitation???
- Black Diesel.... Burning used motor oil?
- Cummins Conversion
- A/C problem on 2000 cummins
- 2001 Cummins won't reliably start and run
- questions?
- Weird thing happened today
- Best 6.7L boost?
- Lost 5th Gear!
- 2005 Dodge Diesel 5.9
- 1995 5.9 Cummins, WONT START
- Hemi VS Cummins
- 6.9 quit going down road
- battery overheating??
- half breed 2001 cummin into 1997chevy
- Transmission hunts gears when A/C on
- At Wits End
- 1994 dodge cummins timing issue
- 5.9l overheating
- 2003 dodge cummins truck won't start lift pump relay clicks constantly.
- 2008 Transmission Issues
- 05 cummins keeps cracking injectors
- Looking to buy a Cummins?
- Cel code help.
- Upgrading from a 2011 1500 to a 2012 2500
- Old Marine/Dodge Diesel/Needs Help
- offer on a eaton 5spd
- Newby here
- importing new 2012 Ram 2500 into canada.
- Dead pedal
- Dodge Ram 2500 shifting problems
- New South Bend Clutch, noise?
- HELP!!! Cummins codes PO513,PO480,PO243
- 2007 cummins 6.7 vibration when stopping
- 6.7 Cummins / How to modify?
- Blowing cold...thunk...blowing hot
