View Full Version : Dodge/Ram Diesel Tech
- WTH is this?
- 2001 transmission help
- 2008 Dodge Ram 3500 6.7L Performance Advice Needed
- affordable 47RE diesel converter
- New from a 1500
- Fuel Pressure Gauges
- 2010 cummins help!
- 2008 Diesel Trouble
- Lift Pump problem? Truck cutting out at idle. Nobody can figure it out!
- had a power steering leak today
- Cummins guys!!!
- 2008 BlueTec Diesel
- New Dodge Questions
- engine temp
- Dealer?
- 4bt
- Help. My 5.9 won't idle in Gear.
- New photo
- California Diesel Question
- trouble code P2000
- Electronic throttle controll
- putting an exhaust brake on a stock 2004.5 48re truck
- Need help Installing an A/C pump in 04 2500
- Solar Powered Trickle Charger
- Rear end 3.73 or 4.10
- Headlight Switch Connector
- Differential Additive / chatters when making tight turns
- 2012 Ram 3500 Check Engine Light ON
- Actuator Issues on 06, 3500 diesel
- truck issues help
- Help! My 1999 3500 idles fine, but try to give it fuel and got no power.
- Which repair manual?
- Another few Questions...brakes - Manual
- 5.9 6 speed programmer?
- Dirty Turbo????????
- Help buying first truck!
- NV5600 middle synchro ring
- 2013
- New to the diesel section! Few questions...
- still learning
- Newb checking in!
- I need HELP!!!!
- 5.9 cummins upgrades
- 2000 Cummins?
- 02 5.9 Cummins turbo deisel Lift pump issues
- Is my steering box going bad?
- upgraded from '05 2500 to '12 3500 DRW looking for info
- 2001 Electronic Tuners?
- Lower engine gaskets
- 12v wiring
- New to the Cummins world. Mod suggestions?
- black smoke need help
- Duramax diesels .
- hard start when warm
- P7100 problem
- 2007 2500 cummins no power to ac
- Need help with diagnosing a problem!!
- Urgent help with p1757!!!
- ABS and Brake light Stay On
- Click ..Starter will not engage!! help!!
- Turbo replacement
- New Injectors now Turbo???????
- Rough first start?? Lots of cranking.
- Built transmission problems please help!!
- 1999 2500 4x4 Crusie Control problems Cummins
- 03 1 ton diesel iIN OUT OF LOCK UP
- Very low mpg's after injector replacement
- pilot bearing
- Looking at switching to a Cummins
- Juice Questions
- Cummins shifting
- Ac showing overfull compressor cycling off and on HELP!!!
- Dodge injectors
- front cabs mounts rusted out... how to approach
- New to the world of Dodge Diesels
- 05 5.9 HO Hard to start, white smoke, rough idle, and more soot than usual
- Putting power install mirros on
- 06 tuner
- common rail wont start
- Mishimoto Intercooler
- summit racing dodge towing mirrors?
- 2001 24V Cummins- Turbo Lag, Overheat
- 2001 24V Cummins
- diesel tensioner pulley
- Tensioner pulley on diesel
- Parts for 2011 Dodge Ram wanted
- superchips info?
- fuel mileage
- No oil preasure
- what to look for on a 1994 12V
- New to the Forum Just got a new to me 2001 2500 4x4 Cummins Diesel
- Clutch advice
- fass vs. air dog
- nv 241 dld transfer case ?
- killer dowel pin?
- Edge EVO HT for Diesel
- What Trans Do I have?
- Clutch kit
- Which Engine Brake?
- oil pressure gauge
- Brake light and abs light come on
- 2000 Dodge Transmission
- Turbo Question.
- Going to look at a 2001 3500 cummins (PICS!!)
- 12v crank pulley orientation
- need tranny help asap..
- Finialy I own one!
- Help, heater grid light.
- Boost leak
- 01 Fuel Mileage Dropped to 14 MPG??
- Erratic throttle at steady cruise
- Looking into getting a 02 cummins
- Trans Problem
- 24v swap
- Help! I put gas in my Diesel Truck!
- transmission
- 2004 5.9 oil smell
- how do i fix fan belt pulley
- Installing LED lights
- 03 Cummins Electrical Problem
- New guy here
- code po148
- New style mounting bracket for remote fuel filter!
- Metering/proportioning valve question
- O5 overheating in pull
- exchange dually rear axle
- info needed
- Mods to 96 2500
- 2001 24v voltage problem
- 24v veggie oil conversion
- Check Engine light
- swapping a gas over to diesel?
- more of a truck question then a diesel one
- Lots of black smoke no power
- New guy here!
- P0603C gen low voltage sence???? What is it??
- high tranny temp
- Parts manual download
- Master Mech. Question
- 98 cummins
- Fuse on Drivers side battery
- 2500 questions for the CTD owners.
- new to diesels
- Engine Light?
- Is possible to disable/delete DENOXTRONIC 2.2 ?
- cheap bosch injectors?
- Warn and Sunny
- Most Common fuel leak? 06
- 24v leaking from unknown source
- Stopped up air conditioner drain
- Transfer Case Help!
- Cummins 700HP Engine swap...for the real piston heads on here ;)
- Transmission not shifting
- T4 exhaust housing for HX40?
- tach wires
- I have a 95 CTD and need help
- Edge EZ Question
- Whats your MPG when towing?
- zerts on '02 ram 2500
- 2000 cummins 2500 4x4 with a lot of little problems... please help!
- should i take some more fuel away???
- power/torque????
- safe egt's?????
- 2002 Cummings Ram 2500 won't start, codes 1691 and 0230
- Transmission type???
- Funny noise coming from auto trans (48re)
- Power door locks acting weird
- stumped?
- Security light flashes , no start
- Buying new cummins need help.
- new cummins?
- Smarty
- First time diesel owner questions
- My new Baby! 07 Megacab
- need help with a vacuume line
- Surging Problem
- Trailer connector on all 3500's?
- tuner help?
- Diesel quitting
- weird problem...
- time for new brakes
- Big Head Wastegate
- Exhause System
- Little to No Smoke w/Edge Juice w/Attitude CS
- tranny rebuild parts?
- engine quit
- DEF Fluid question
- Common things to examine when buying a '98.5 24V
- RFI on the 12's
- turbo
- Fuel Additive for 2011 Ram Diesel
- Low End Vibration and White Smoke
- Ready to pull the trigger
- Ground connections at Block
- oxygen sensor
- FASS Lift Pump - Your Results?
- 1996 12v engine knocking?
- 95 Ram 2500 won't stay in overdrive ..??
- 2006 Dodge Cummins 5.9L - Manual Fuel
- weird sounds at cold idle
- Long bed or short bed
- 2006 2500 Dodge Ram 5.9 Cummins Tranny Issues
- fuel
- power steering pump question
- What is a low cost fuel pressure gauge?
- Dodge ram 2006 5.9 cummins power increase
- Engine Fan Free Play
- Noise, air filter box area
- dodge encourages us to brake the law, check engine light related
- 2003 v10 to cummins swap
- 2007 Dodge Ram 5.9 3500 Mega Cab Service
- Rear Main Seal ?
- oh, I love Cali.. catalytic converter story
- engine fault codes
- Fuel Gauge Problems
- Cummins Noise Issue- with video
- Cummins Conversion?
- poor fuel mileage
- headlights and defroster issues
- 2011 2500 idling with door lock control?
- Finding gear ratio
- off topic questions about buying
- killer dowl pin
- girl that doesnt want to be taken advantage of...
- 2011 Laramie 2500 Electrical Problem?
- Oil Analysis report on '04 5.9 Cummins
- Oil leak 1996 diesel
- 6.7 problems! Please help!
- Tires
- Programmer/Tuner for '95 5.9L?
- Normal Engine sound?
- No Power steeriing firm brakes 2011 Ram 2500
- Vibration while towing
- 4x4 not engaging
- What Mods on 6.7 at 100k miles?
- Impossible Front End on my truck
- ABS light and Brake light came on and stayed on for a few miles
- injector size
- no OD or speedometer- 95 diesel
- 08 250 Ram4x4 $1,000 on diff seals & oil
- What A Friggin Nightmare
- What coolant do you use?
- Looking at a cummins.
- what are some common problems with the 06 model year
- air intake
- Turbo silencer ring removed and still doesnt sound like i expected
- hydraulic clutch issues could use some advice
- Power Outlets?
- Tow haul adjustment
- Rear Main Seal
