View Full Version : Dodge/Ram Diesel Tech
- Any Ca ctd's in here?
- Question about a Dodge Diesel???
- capping off my pyro port
- Where to tap brake controller red wire to?
- CA-40G ?
- 80hp Bully Dog injectors
- Off topic but, need help with Avatar
- Just got back from the meet and greet..
- Pics of new Megacab
- Mag-hytec's in but what is up with this oil
- New Drive Shaft
- Gear oil quandry
- water in fuel light
- Pics and video's of my truck
- edge or quadzilla?
- Upgrade friendly service depts.
- dumb questions on throwing codes
- Which fuel door is best? alu. or steel?
- Do fender flares hit CTD logo on 2004 dodge 2500?
- Repair Manual
- Hey Drew
- Diesel grand national?
- Diesel Nationals
- help please
- One of the best days of my life.
- PHOENIX GUYS, HOW BOUT MANZANITA SAT NIGHT????
- How to speed up Turbo
- u connect
- Center Bezel
- Tommorrow...?
- Happy Memorial Day Weekend !!!
- Really dumb question oil drain plug
- Dyno results
- It hurts to type.........
- BWAHAHAHA!!!
- Blown Fuse? Help!
- I dont want my truck anymore.
- Good old ford... marshmellows anyone?
- Anyone order from Xtreme diesel?
- My truck starts out better in 1st than Drive?
- Who all has a my space?
- New to the forum
- Attitude turbo timer?
- DEath Wobble in 2006 3/4 Ton 4X4
- Sons Graduation
- Engine Surge
- Programmer/Chip traces
- Tranny problem?
- My newly arrived 2007 Ram 2500
- Jacobs exhuast brake concern.
- EGT Probe
- 95 ctd questions
- 2001 axle's
- new wheel question
- How many litres of 75/90 for the diffs?
- GEAR RATTLE
- 2005 5.9L cummins oil change
- 2001 Dodge 3500 diesel
- Thinking about my trade in
- Sharx
- All of this warranty talk has me nervous!
- Pumping diesel out of truck
- Hey Jake...
- Juggling between a Motorcycle or a Cummins
- 1 thing I like about the new Ford
- Hard starting
- Arizona Residents Unofficial Meeting 5/26/07
- Finally decided on the edge/attitude.
- K&N 33-2056 Filter for sale.
- Aero 4040 or 4040XL
- Maintenance log
- I hope your happy Jake...
- Pics of the truck
- TOTM voting
- dyno vid
- Ran into a Quad Cab Dually with stacks
- So, you think you can operate a skidsteer
- Tire update & wheel care...
- A/C problems
- Which truck if money no object
- new wheels / stockers are stuck
- If the white engine tag on engine says 325HP
- Redneck after a DUI???
- Isspro gauges and A-pillar mount
- How to turn on adjustable power pedals?
- Who here uses AMSOIL 3000 HD synthetic ?
- time for mods, what air intake?
- muffler and cat delete
- saw a sick ctd today in NJ
- Waste Gate J hook
- tst mods
- Is it normal for voltmeter gauge to read low at startup?
- Dealer service?
- Predator Stage 3 installed..WOW
- Need a little help/advice
- Anyone notice a "jerk" when holding brake?
- Does any1s 2004 dodge ram have light under hood?
- Cheapest way to 450hp? First diesel, need help
- Segelson
- Towed for first time
- Middle seat storage?
- Back from Greensburg KS with report and pics.
- 2007 3500 dually bigger tires????
- 4" muffler cut out Y pipe
- air intake
- Short Shifter
- Sportman's Double
- Cat Back vs Muffler Elim kit?
- Speaking of Monkey's
- Stuff for sale ...
- Ram "Heavy Duty" not so heavy duty?
- How much OIL in each component?
- Anyone run AMSOIL HDD 3000 synthetic in their 5.9CTD?
- leveling kit help
- 96 CTD INFO WANTED
- 22.5" wheels????
- How dangerous is it to run over full on oil?
- Quadzilla Commander/xzt chip
- Dodge 2500
- SOS! I Need Help Bad!
- steering box
- transmission
- Fuel Filter
- Stacks are in ;-) >>
- How are NAPA filters?
- GREAT ..... gun violence again in MY neighborhood !!!
- What Guages
- emergency!!!
- Need for an EGT Gauge.
- Anyone else have trouble brake torquing?
- Whats a good Descent oil to use ?
- Where do you install the EGT sensor?
- Wheels and Tires??
- Powersteering growl.
- Is a lil black smoke normal on a newer CTD?
- Dead Kitty?
- First Gear Shifting
- Will TOW/HAUL button on a '04 let you in overdrive?
- When should a guy expect a bearing roll to be done?
- in the tradition of Steve's posts......
- Need Rear Axle Help ASAP
- Keyless entry unlock/honk settings
- Went into the mtns yesterday...
- Transmission Question
- Autometer Gauges
- Loss of power when I first took off
- Need Help with Plate Ideas
- Build Sheet/Carfax Report
- I try it again
- OK how come you can't delete a post here
- valve body bad again!!!!!!!!!!!
- I'm 2 strokin now ...
- How do i turn up my stock turbo 02 cummins
- Is there a benefit by changing to K and N filter?
- Whats that hole?
- Does any1 add additives to their tank?
- CAT c6.6L
- I'd say this guy has some serious power in his truck ...
- Can you say lawsuit?
- Long arm lift
- upgrades for 1st gen
- Do all rams have the anti slip diff?
- Anyone have a pitman arm for 4-6" lift?
- 06 2500 CTD MegaCab Questions
- Advice on purchase 03 3500 4dr cummins
- Guys, I got a quick question about the ram...
- Driving/Fog lights!?
- strike update
- Manual tranny fluid change
- just took off silencer ring and muffler..
- I want turbine sound through exhaust.
- engine speed sensor fault.
- Are manuals available for 04's ???
- EGT's...
- Sharx
- Can someone plz send pics of band adjustment
- I have a 2004 ram 2500 SLT 4X4 Cummins and...
- I was ripped off plz help
- Mag-Hytech Transmission Pan
- Another Transmission question??
- How to drain fluid from Torque Converter?
- Recon Lights
- Transmission Fluid Question
- How tuff is your Dodge?
- Stupid stealership
- Mag-Hytec Diff cover
- What the Ford guys are saying about the CTD!!
- Spare Tire Information
- Transfer Case Question
- Fuel Mileage with a ctd
- Brakes sticking
- MOVED: CHRYSLER SOLD!!!!!!
- Question regarding the FS2500
- super chips programmer
- New Cooper stt's pics
- Trailer Brakes
- Cummins into Ford
- 03 24v hard start
- Burnt tranny up in the MT's (56k warning)
- Drive line squeak
- A/C out again
- problem with a/c clutch, i believe
- p0336
- 2005 CTD Pickup
- Tiny rust spots...anyone got 'em?
- 2002 excelleration
- Programmer and Lift/Suspension
- where to buy Block heater cord online?
- Question for the guru's
- my turbo froze up
- biodiesel setup...
- Pop's puttin the Mag covers on today ... gotta question ...
- Question for Triton...
- Hey Mr. RamIt... and others, check these out......
- diagnostic code help
- Anyone seen these?
- whats it worth 2000 dodge ram
- bank seizure of dealership
- wiper blades chattering
- tranny shifting at 12 psi boost
- Wastegate
- Hot juice
- Where's my cut
- Damn, my truck has a Hemorroid!!!
- DAMN!!!
- Hood insulation
- how bout this for a birth day
- Got my Juice back today...
- Truck Vibrates and shakes a little?
- Pyrometer probe question
- What Incentives Are Available?
- BIODIESEL?COOKING OIL? DIESEL SECTREST?
- '94 w/ ABS and Brake Light Starting To Come On
- AC problems .... anybody know what this is ??
- What did your tax return buy?
- Trailer Plug Wiring
- tow haul/ overdrive
- Do any of you guy's use this "nano" filter ??
- A dogs life...
- GRANATELLI Big G Milage Miser
- edge w/additude
- Horsepower
- Brake Box
- global warming
- Mayfair, you like bubblewrap?
- I'm in the dog house!
- 6.7L engine photos now online
- Immigration ... you've GOTTA see this !!
- anyone want to go stacks? cheap?
- Another mod this weekend ...
