View Full Version : 4th Gen Ram Tech
- Dodge Reveals CNG Ram from Factory
- Drag N' Wagon on Gearz
- Towing Power with Camper???
- Belltech lowering lifting strut TRX4 opinions
- back to the dealer
- More Power!!!
- Weird vacuum or whistle noise at 1300rpms
- front end noise
- CHR550 lockpick, day 1 review
- Annoying front end squeak..ugh
- Raptor Side Steps install: hardware warning
- New to Dodge
- Dirty Brake Fluid
- Valve stem tops mushroomed - #2 Misfire continued
- Tow Rating
- 2012 RAM 1500 Splash Guards Mopar or?
- 2012 RAM Integrated Brake Controller
- Dumb question about front diff
- 99% sure but... (headlamps)
- 2012 (and 11) SC Flashpaq flash....
- High Speed (220 km/h) will damage axle or transmission??
- Recon lighting help
- 2011 Laramie Center Console Swap to 40/20/40
- TPMS Valve Heads Up
- Air bags on lifted applications
- New brakes to be on soon
- In need of opinions and knowledge!!! PLEASE
- Name that Dashtop Doodad! RAM 1500
- TRX shocks on a ST
- Need Help to install remote Starter RAM 2009
- Misfire #2 cylinder, 8 days and counting
- oil capacity
- 2009 Ram 4.7L Spark plug torque spec?
- Anyone add power locks to an ST?
- More problems
- 22 inch xds 4 inch zone lift
- 2012 warranty
- 2009 dodge ram 4x4 hemi Automatic transmision SWEATING
- Resetting "oil change due" warning on EVIC
- How do you tell if MDS is working
- Where does this part go?
- 2011 5.7 1500 sport tuner
- HID's for 2009 Ram
- Tire fitting question
- Busted grille
- 2010 ram 1500
- Shocks on 09 Ram 2500 4x4
- RHR+Iphone question
- Installing aftermarket backup camera
- Failed inspections-Not ready
- Check egine light at 27k just an injector phew!
- Mopar backup camera install question
- Security light and TPMS light stays on.
- TPMS Compatibility
- synthitic oil
- Can you install a 2011 MyGig into a 2010?
- superchips tune and state emissions test
- Hid projector headlights
- Good set of tools for regular maintenance...
- Poor aerodynamic design?
- Wheels from 2002 - 2009?
- Projector headlight high beam problem
- How Do I ?
- Separate Spark Plug Thread for the 4.7's
- New 2012 Gas Pedal Weirdness
- airbags on lift 4inch lifted 4x4
- Anybody here use a dash cam?
- Monroe Sensa-Trac Load Adjusting Shock Absorber
- Automatic Transmission Fluid Change/Check Question
- Mtce Schedule: Mileage vs. Time (why)?
- Cargo Lights Tap?!?
- Power Train Control Module TSB
- bedliner?
- Passenger Door Heated Mirror Not Working
- 2011 1500 rear coil upgrade?
- Please Help!!!!!!
- 2012 Ram SXT Trailer Brake option?
- Is There A Cabin Air Filter or Not?
- 2nd to 4th gen leap: Have they fixed the AC vents?:)
- Fuel Injection Service
- Under Hood light (work light)?
- 2009 Dodge Ram 1500 ESP/BAS, Airbag Light, Automatic Locks...
- 4 radios later....
- Ethanol Mode? Ethanol Learn Mode? WTH?
- Shift problem fixed. Front end "clunk" fixed. Pleased with dealer.
- How to remove seat cover
- Rear Chrome Bumper starting to rust!!!
- Can I add backup camera and/or nav to my factory touchscreen?
- 5100's tire combo question
- HELP, rams gone crazy, lights, gauges, wipers everything!
- Badge logos on door
- Horn..wipers..turn signals..high beams..NOTHING!
- Shift lever sticking periodically going into Park then Drive...
- bumper discolouring
- puddle light issue
- Limited Slip Differential and ESP
- New part # for tailer brake controller?
- Best way to optimize for cruise control/highway driving? Lockout OD?
- Transmission trouble
- RHR Nav Unit Update 2.120 (untested)
- Loud 2012
- Wheels chrome clad!?
- 2011 Dodge Ram Laramie - Rims
- Not going to bragg anymore
- How do you buy a brake controller? What do I need?
- Give me the lowdown on the different diffs and what i could do.
- 1500 vs 2500
- Key Trick for 4th Gens???
- rear end alignment after 4 inch lift?
- Risk of Front End Vibration with Levelling Kit
- Webasto Preheater for Diesel
- Need Torque Settings Cab/Frame bolts
- Evic alternative
- has anybody in 4th Gen grounded their TB?
- help asap
- Auto Dimming Rear View mirror
- 2011 5.7 Hemi Blown Head Gasket
- rear sensor wire
- Pics of your 4G UCA's
- 2012 ram 1500 rear suspension upgrade?
- Motor dies when MDS goes off
- Adding dual zone climate control
- Tonneau cover for RamBox
- Grill Guard!!!
- Rear seat cover recomendations
- Normal / Max Oil & Trans temp?
- Select shift 2012 1500
- What size tires on a 2012 1500?
- Missing Key FOB (options?)
- Hardwire your Radar Detector?
- Break In and octane?
- Fuel Octane Question and Break In
- ipod on 2012 Laramie 730/735(REW) in UK
- annoyed
- How to take apart transmission line connectors?
- Power loss?!!
- LED out in mirror
- What are you guys using for spark plugs?
- need info on tightening front axle nuts on 4x4.
- broken windshield=(
- Bluetooth
- Warning Lights!!
- 5.7 HEMI and towing
- Help!
- 1st problem
- Help!! ST Locking
- electrical issues
- iPod 4th gen
- Need quick opinion - permatex or not on gasket
- Question about my new 2500 Hemi??
- mobil 1 or valvoline? valvoline
- to everyone with a cold air intake!
- Mopar remote start
- Rear Spacer Alignment?
- 04 dakota 4.7 whining noise
- noise in front when turning, anyone have??
- Magnaflow getting louder???
- Relocate backup camera
- Fobik prog.Anyone done this on 2010 RAM?
- Clunk when in Eco Mode
- New Truck Inspection
- MyGig 430 - Is there a way to delete single song?
- reverse camera wire ?
- Mystified By My Engine
- Rancho Quick Lift?
- Identify these bolts...
- Dealer Visit- Cab Mounts
- Where to mount concealed detectors? (Radar Laser Jammer escort 9500ci)
- True Towing capacities???
- My 4.56 gears and super chip
- Paging wiring gurus - HID with DRL idea
- Will these shocks work??
- How to know if the autodimming exterior mirrors are working?
- Yes another HID Quesstion
- whats the screen size on the 430 unit?
- I pod touch 4th gen 8g issue
- Oil Catch Can...different this time..?
- What is important at 30k miles on truck
- Fog Lights
- Electronic 4WD Shifter
- Air Noise
- Column to Console Shifter Conversion
- 3500 leaf springs on a 2500?
- waiting 5 weeks already for tie rods
- HID cause problem to TIPM/Fusebox?
- Cracked CV Boot **Pics**
- how big of a tire can you run with a 2.5 leveling kit
- Snow Commander / Snow Chief
- 2012 brake controller dash panel
- 100k Spark Plugs
- 09 ram crew rear power sliding window question
- Tons of electrical issues
- Fording question.
- 65RFE question
- Speed Limiter
- Will they fit stock 2009 TRX4 Off-Road
- Wheel and tire size help!!
- 2012 Ram 2500 Crew Floor Mats?????
- can i tow this?
- Help changing fluids, (diffs, etc)
- Horn Specs
- 2012 Ram brake controller
- Ordering hid lights. A little help please
- New to the Ram side of dodge
- Service Manual for MAC?!
- temperature on heater stuck
- Media Formats
- Wax for Chrome clad wheels?
- headlamp replacement
- 2010 Duals Bumper
- Terra or trail grappler? and what size
- How to install rear amber turn signal
- sunroof switch light up at night?
- 2011 Ram 5.7L stalling at stops.
- getting a new engine from chrysler
- New guy with wheel question
- Anyone have problems with HIDs in fog lights?
- Are changing spark plugs really worth it?
- Bug Deflector hood protection?
- Keyfob/door unlock problems
- Soon to be new Ram Owner!
- 11 1500 4.7L making weird noises
- Pace Edwards Bedlocker question
- Anyone thinking bout N-fab nerf bars ??
- Anyone got a good shop in Austin for gear swap?
- Flat tire advice
- Felt like truck falling apart!
- Knock Some Sense In Me
- Will airbags fit in my truck???
- tri fold tonneau
- Superchips! What do I need to know about updates?
- New 1500 Sport QC Owner. True Blue Pearl
- Lowered 2012 1500 and can still carry the load and haul….
- evic light on
- proper oil pressure?
- Serious "Dash" of trouble
- Frost on inside interior windshield with condensation on Sunny Cold Days - fogging
- SPYDER LED Tail Light Install Dilemma
- Billet Grille Help
- Why two rows of spark plugs?
- Wanting Bilstein 5100s. I know, I know!
- Good Reading about the hemi
- any new ford or chevy race outcomes to tell
- encounters of the ford and chevy kind
- Not running right after recent Hemi tuneup
- TL retrofit in duals done
- How to run wire from bed to cab ?
- Why am I seeing this?
- Thinking about buying a 2500. Price question
- HP numbers
