View Full Version : Dodge Caravan
- engine noise
- could hardly believe the gas mileage on 2013
- Do 2013 Caravans come with rear leveling for towing
- No horn. Help
- Rust on the Hood
- Spark plug threading...
- Blacktop edition interior pictures
- plastic "Y" behind the engine
- 2000 Grand Caravan Blowing Air (STUCK) Only On Windshield
- brakes and brake pedal
- change your air filter, change your life
- Got the two front doors and the rear windows tinted
- New water pump with wobbly pulley - 07 caravan
- code
- Rear Drivers Side Door has no Power
- Need HELP!!!! an won't start driving me crazy
- intermittent wipers
- tune up supplies
- Bad ignition coil?
- PLEASE help. 2005 grand carvan no brake lights or rear turn signals
- Aiming Headlights on a 1996 HippieVan
- How Do 2008 and newer front wiper arms remove?
- 2013 Dodge Caravan -- poor performance
- 2010 Grand Caravan - Ticking from transmission plug every 10 seconds
- 97 caravan
- 1997 Dodge Caravan 3.0 Wont stay running
- klunk in front
- getting EGR codes on engine without EGR
- Engine cutting out and smoking underhood
- Rad/Con Fans not working 98 Voyager
- Help identifying part : hose
- brake job on the road?!?
- Monday Puzzle (pix)
- 2001 Carvan Sport problems
- 2008 Caravan Struts
- Steering Knuckle Part #
- Sunday Puzzle: What is this part? (pix)
- Extra seat in 2010 Caravan required
- Tranny troubles?
- 2013 Grand Caravan Crew w/ Misaligned Parkview Camera
- 1995 Dodge Caravan Wiring Issue
- Can A bad SKIM be bypassed
- new headlights to replace the old fogged OEM units
- more power! (additional aux power outlets/usb ports)
- Passenger air bag replacement
- 1997 31TH leaking fluid...
- 09 Caravan shifter question
- Nobody can program a new fob key to my 2008 Grand Caravan Sxt
- 2006 Grand Caravan Stalls after getting gas
- Common issues to look for
- Noise from Belt/Pulley Area
- 1989 Caravan Right rear axle
- 2005 Grand Caravan Engine Noise Help
- The Sludge about Oils
- 2002 3.3 top end noise
- 02 3.3l non flex grand caravan se, milky oil after head gasket replaced
- Is this an engine knock?
- The Banshee Van
- rear heat/air only works on high
- Dodge Caravan,rear tow hitch
- 2000 3.8L Timing Cover Leak
- 2003 Dodge Grand Caravan Radiator Replacement - Video
- Rear Brakes. - Suggestions??
- anyone install additional power supply in back of van?
- 96 GC Valve Clatter At High Rpm, Is It A Knock Sensor ???
- 2004 Grand Caravan SXT bumper cover
- High idle after head gasket replaced
- 2000 Dodge Grand Caravan possessed! Flashing lights.
- 2011 Dodge Caravan Pentastar Engine noise with video link
- Air bag replacement
- 2001 Grand caravan Sport Antenna/radio
- 2013 Dodge Grand Caravan with 16" wheels Front Brakes Pics
- 1999 Dodge Caravan Sport 180K
- 2002 GC 3.3 transmission gasket
- 2005 Grand Caravan sluggish and poor mileage
- 2013 SXT plus 17" Alloys
- I did it
- 2011 Dodge Caravan Steering Wheel Controls Problem
- 2007 Grand Caravan inner door lip rust
- Can I program a 2012 Grand Caravan 6-button Fobik key fob myself
- help- 2006 grand carav. sxt misfire & power loss
- 2012 Grand Caravan Parking Brake Wire
- 06 caravan annoying vibration
- What's The Procedure For Replacing Water Pump Housing Seals?
- Transmission probs 2001
- 2010 Grand Caravan Corrosion (Rust) on Driver's Door-Inside
- 08 Gnd Caravan Rear Hub
- Wanting to buy a 2013 caravan
- 2002 Transmission interchange
- 97 Grand Caravan Brake Bleed Issue,,, Please Help
- 98 31th transmission
- Where is this mount located?
- 08 caravan - very perplexing issue
- 2002 Grand Caravan Transmission Jerking
- Starting & electronic issue
- 2005 Dodge Grand Caravan Passenger Side Power Window Woes
- Output Sensor or Trans axle Problem?
- At around 1500 rpms lurching feel!?
- issue with driver side power window
- Radiator fans turn on by themselves with van off and no key insterted
- Where to buy trans and shop REFUSES to flush trans?!?!
- 2001 Dodge Caravan SE ...Fan won't turn on at all Help!!?
- Looking for replacement spare tire winch cover
- 2011 Front brake ?'s
- Transmission Solenoid Leaking
- auto climate control delay....
- Oil pump replacement
- 1996 Caravan "re-settable" fuses or circuit breaker for power windows
- 1997 Grand Caravan
- 03 Caravan Coolant leak or trans oil leak or?
- '99 tranny slow to shift into drive
- Looking for help with 08 Grand Caravan SXT
- 2005 grand caravan oxygen sensor removal
- 2005 Caravan Oxtgen Sensor- Removal ???
- Cracking sound in the left
- Leaving key in "on" position
- 09 oil leaks and warranty
- 1999 Dodge Caravan 3.0 Transmisson & Vibrating
- Current software version of radio
- Uconnect and ipod titles
- Foglights problem
- Help My Headlights wont turn on 2008 Dodge Caravan
- AC/Heater
- 02 question about chugging an such.
- How to replace 2000 Dodge Grand Caravan Gas Flap?
- 1994 dodge caravan CUTS OFF WHEN MAKING RIGHT HAND TURNS
- Speed Related Humming Front End Noise?
- oil grades
- 1996 transmission control module replacement
- 2002 Grand Carvan - tranny bucking
- Alternators
- rented '13 to chk it out
- cold start whine noise, what is it? 2012 crew
- 07 Caravan heating issue
- Question regarding the FCM
- 2012 - Eco Mode Comparison
- Availability of side window shades?
- Ball Joints and stuff
- 2013 Towing Capacity / Tow Package
- Looking for easy upgrade projects for '00 GC
- 2001 grand caravan tire help
- 2002 Dodge Caravan Sport Transmission issue
- Aftermarket Switch Location
- Chrysler switch to OAT Antifreeze for 2013 GC
- 2001 caravan courtesy lights fade to black after only five seconds
- replacing catlytic converter
- installing an trans oil cooler - Need advice on oil lines
- 2004 Dodge Grand Caravan sliding door locking issue
- premium console.
- Blower motor replacement 2000 grand caravan
- clunking noise under rear of chassis in 2010 grand caravan with 33k miles
- LED Instrument Light Replacements for 05 Grand Caravan
- trouble removing front rotors on an 09 Caravan
- 08 - Help with an issue
- 03 caravan rack n pinion leaking?
- trouble code p0562
- remote start cost question
- 99 Caravan Engine Hestitation p0505 code
- Code 34, 1995 Grand Caravan
- 2002 Grand Caravan Fuel Mileage / Boat Anchor
- 2010 Caravan will not accept new key fob
- 1996 caravan 3.0
- dash lights
- headlamp switch warranty
- 2002 caravan Headlight issues and airbag light
- transmission finished high wineing when step on gas
- motor oil
- steering wheel aligned
- Headlight SHORTAGE! '06 SWB & Steering Grinding Noise?
- Current Draw on Grand Caravan 2007
- 2010 Grand Caravan S.E.
- 2000 Dodge Caravan Turn signal Problem
- is this a good deal on a 2005 ?
- Does a CAI exist?
- 2011 GC Crew 3.6 Pentastart - Misfire MIL, heads need replacing?
- Aftermarket Backup/Parking Sensors
- Repair Cost leaking trans seal - 1996 SE
- Intermittent ip with a no start
- 99 grand caravan light problems
- engine removal without trans
- Learning the Hard Way...
- O2 Sensor and Check Engine Light
- 97 town and country van
- Dodgecaravan
- 1990 Caravan headlights out
- 2000 GC Fuel Door R&R
- Prematurely Locking Van
- 2002 Dodge Caravan Poor Fuel Economy
- Hard downshift and almost stall out OD after trans fluid change
- Monroe rear shock any good?
- Coolant leaking onto top of engine block: 2006 GC 3.8L
- 108K Mile Service
- 97 grand caravan OBD code P1768
- Scratching head - No start after swap?
- sliding door
- Potential Brake Problem Fix?
- Looking for a Part Number
- Broken Wiper arm for 08 Grand Caravan
- 2008 GC SXT Heater/AC problems
- 2010 dodge GC side door no power??
- 2001 Power Steering Presure Problems
- 1998 Brake failure after rotor pad replacement
- Six Bells at ignition?
- 2010 caravan wipers dont work
- 97 GC 3.8L belt squeal
- 2012 caravan radio question
- Aftermarket AV Navigation System
- 06 caravan, extended crank, fuel smell, engine code
- 2008 4.0 efi
- Screeching/squealing when van first starts
- New Owner: Transmission Fluid & Manual Question
- Alternate tire sizes for an 09 Caravan?
- Traction Control Symbole in the dash display
- 2003 GC Battery Drain
- Haywire TCM
- No instrument cluster lighting cause
- Copying from usb
- CV Shaft Removal
- Loud Thud Shifting Into Drive 2013
- Fog Lights
- Totalled 08 Caravan / Looking at 08 T&C
- New Member seeking advice
- wacky front wiper arm configuration on 2011
- rear passenger heat
- key fob
- How to turn off the hadlights "ON" at unlock
- 2008 Caravan
- Head Gasket Replacement
- Grand Caravan towing a trailer question
- parking brake issue, 2005 GC
- 2010 transmission cooler lines and dipstick...
- Courtesy Lights
- How do I know spare is in place?
- '96 Caravan 3.3
- Ceramic Pad FIX!
- flash 05 caravan pcm
- 2001 Caravan Has Steam Coming From Under Hood
- Oil Light
- 96 caravan wipers stop halfway-grinding noise
- Should I upgrade to a newer van? Weighing my options.
- 2012 Caravan - Questions on the 430 Unit
- 03 dodge grand caravan problem need advice !!
- Another Alternator Noise.
- Caravan value
- Need Driver Side Front Door Lock Actuator / Selenoid
- Windshield noise?
- Brake pedal goes to floor at first brake action
- Mopar Questions
- 06 Grand Caravan suddenly making horrible engine noise
