View Full Version : 3rd Gen Ram Tech
- Speedometer calibrate
- Hard shift around 45 to 50mph
- Hemi Cold Air Intake makes truck Sluggish
- Which engine, head, intake combination
- Alternator
- Rear transmission shaft bearing replacement
- wiring issue
- trans cooler
- 2007 Heater Core
- ram heater/AC
- Tranny, Diffs and Plug maintenance.
- 05 Ram 1500 5.7 hard to start.
- 03 Valve spring replacement and brake booster.
- problem with lights
- stumped with p0440 and p0441 plus 2 codes?
- Trailer light issue on '04 1500
- noise from...T-case??
- door alarm
- P0700 and P0841 AAAGH!!
- Play in back wheel.
- 4x4 Rear Diff Question
- Werid new problem... WOT high RPM Misfire
- Lift Question
- Stupid PCV valve
- Best Plugs for Hemi?
- Broken Brakes
- Dodge lean
- 2004 Ram 1500 performance question
- brake line fittings question
- shock question
- 2006 Dodge Ram 1500 Security System problems :(
- Newb here considering a 3rd Gen Ram 1500
- 2ndgen member buying a 3rd gen, help
- '05 1500 - Diff Check, Transmission fluid and Brake Pads
- loud noise under truck
- Winch Question
- speed sensor
- Power wire resistance question
- can not drop oil pan.
- Transmission: Good or Bad
- 2004 Dodge Ram Transmission Problem
- Transmission filter change
- What Diff Oil To Use?
- 2005 Ram 5.7 Check Engine Light
- Rear door locks not working
- Replacement AC Compressor?
- Need Help With a Seat Swap
- Odd Knock In Front End 07 1500MC
- 4.7L check engine light
- Questions - low end torque needed
- Overheating 4.7... At shutoff
- Tire Pressure for 2500HD Quad 4x4
- Long travel suspension
- I need Help, Misfiring
- 2004 Ram 4.7...
- Wrong PCM! Screwed up idle!!
- need help
- Something wrong with truck... slow 0-60times.. calling all pros
- 3rd gen rear axle swap
- New to DF! Also need some help...
- LED Brake light
- "Stuck" on front diff
- Adding USB power ports
- Front Differential taking a crap!!!
- 2006 Dodge Ram 1500 5.7 Hemi check engine light
- Injector Issue
- big thanks to this forum
- strange place for electrical plug
- New Guy
- Tool box and bed cover
- star scan vs DRB III
- Recommendation for heads
- 2006 ram brake warning light
- 4.7L Weird Sound
- You guys will love this
- Fog Light wont turn on
- Air Conditioning 04 Ram - Problems
- 05 tranny problem
- question about new truck
- 2006 ram 1500 mega cab
- failing emissions
- How do I reset my PCM?
- alignment...concentric...huh?
- Speedometer incorrect
- Cam swapped now it won't start...
- Strange wire
- crankshaft position sensor location
- Problem with my Ram 1500
- Trailer Brake Control Wiring
- New member Hemi help !!!
- Ram 2500 HELP!!
- Front diff oil change
- Issue Before Shifting
- torque converter sensor question
- 06 dodge 4.7l wants swap to 5.7l
- Need tire/lift help! Yes...I've searched and read stickys
- will wheels off suburban fit dodge ram
- Daytona Spoiler
- Dodge Ram 2500 Header HELP
- Will 295/70/r17 rub?!
- Bad pulley?
- 04 ram 1500 overheating issues
- 08 hemi qc rpms drop off out of no where
- Lug nut size
- Thinking about Limited Slip
- best programmer for 06 1500 ram?
- Procomp ES9000 owners
- Exhaust difference between 06 and 07
- steering clunk at full turn
- Intermittent "Lamp Out" Light
- Leaking from front passenger side, just inside the tire a few inches.
- gear shop in east tennessee
- Batteries COMPLETELY dead multiple times
- Code P1241? anyone know what this means?
- Heater core by-pass?
- Where to buy gears????
- Hmm. Heatercore being replaced. Dash crumbling apart?
- Tilt Steering Lever Broke
- have a. few questions
- Rusting quarter panels/wheel wells
- Do I have 3.92 or 3.55, 07 Hemi QC?
- 4.7 top end Rebuild Need input on what is best
- 2006 Ram 1500 Hemi PROBLEM with starting and idling
- Rough Ride after sitting forever...
- Drivetrain noise in 2H but not 4H
- Electrical problems
- Overheat issue
- what is this port for?
- 2006 545 RFE Auto Trans service
- 2002 Ram 1500 - 46RE Failure
- Transfer case position sensor switch
- Back Up Cam 08 Ram ? ?
- Reverse Lights Turning On By Themselves
- Misfire cylinder 3 help!
- '07 Hemi Ram....MDS possibly on during acceleration????
- Yoke Question - Dana 70
- no a/c at idle
- Help!!! Keyless, Am I in the right area??
- Valve Spring Tool ?
- abs and brake light stay on
- Another abs and brake light issue,speedo bouncing some
- Replacement steel brake lines
- 2006 mega cab dies or won't start
- alarm issue
- Needing CV joint replacement soon
- all good now
- Does RP 75w92 need the LSD additive?
- exhaust manifold bolts on 06 hemi ram
- p302
- Tachometer
- Hood compatibility
- 4th Bad PCM
- Intermittant Cruise Control Problem
- Need Help Either O2 sensors or bad cat
- Exhaust noise???
- 4x4 Indicator Light Issue
- Tip Start
- 4.7 engine swap
- Front Shocks Replacement
- no power when i accelerate???
- 2006 5.7 Hemi Transmission fluid & filter
- 4 cylinder high idle
- $4 DIY to fix that pesky 02 Sensor light!!
- Suggestions on New bucket seats
- 02 4.7 falling idle. Ideas?
- Weird Vibration...Please Help!
- How to get out of lockout after using wrong transponder key?
- Code P0748?
- Lose brakes at full lock
- quick differential gasket question..
- Intermittent ABS light on 2007 Ram 1500
- power steering cooler leak
- A/C problem
- Lookin for a radiator
- Replacement front bucket seats
- 4wd lamp indicator switch. Dealer only?
- Door locks
- transmission
- Heated Mirrors
- Looking for power/heated tow mirrors....will trade with OEM 6x9 mirror or purchase.
- Aig bag install - Broken bump stop bolts - any tips?
- Another 06 Ram (possible) Tranny problem
- ABS/Brake like issues
- doing something with our 4.7 single cab 2wd ram
- new rims with 5 inch backspacing
- new here..fan control knob problem?
- 2005 ram rear end
- help with rough idle
- 4.7 cooling questions.
- Reprogramming Computer for gears
- Interior/Cargo Lights
- HELP 08 Ram 1500 5.7 Hemi NOT STARTING
- What kind of differential fluid???
- fuel sending unit replaced, but not registering to my fuel guage? please help..
- 2004 Rear end rebuild, need help
- 4.7 to 5.7 swap apps problems
- Starting Problem
- cv axle not locking
- no sound from speakers
- electric fan
- 2004 dodge ram 2500 5.7 hemi programmer questions
- Struts and shocks
- Tire Size
- 2003 Ram Hemi Doggy!
- Broken DISTRIBUTOR screw
- question on 1500 lift
- dual relay wiring
- 20A 12V Fuse - Where'd they hide it?
- steering and heating issues
- Will not start/Red light on in the instrument cluster
- Another vibraton mystery
- 2004 Dodge Ram aftermarket Stereo issues
- 2002 e fan mod
- Ebay SS (overstockaccessories) OEM Style Nerf Bars - Bad
- Something that's just been bothering me
- 2003 dodge ram alarm/ battery
- OK, my turn to ask for help...
- 2008 ram 1500 qc 5.7L Hemi electronic throttle controle light
- 2008 ram 1500, leaning to the passenger's side...
- Isolated starter battery. Second dual battery
- My transfer case was THIRSTY!
- what trans does a 06 1500 have?
- 35" Tires on stock rims?
- 1500 megacab stick shift
- newbie questions
- Something wrong with tranny in my 6spd! HeLP!
- 4x4 engages by itself
- check engine code p0179
- p0132 and p0300 after exhaust
- need help p0132/p0152
- Coolant leak, maybe water pump.
- tire size?
- Tail Lamp and Marker Light Issue
- RPM needles not accurate!
- Switching out factory radio with factory sat radio
- Something Feels Broken
- 03 Hemi Misfiring
- Swaping OPEN diff with LSD diff on ram ?
- 2005 Quad Cab, 4x4, 5.7 Hemi fuel tank leak / issue...Not sure what it is
- Lights issue
- Need help to identify part
- Leveling Kit
- Air cond. blows weak
- Does it sound like my IAC is bad
- 06 Ram 5.7 trouble codes - key trick doesn't work
- Sister's 03 1500 Ram throwing codes 0585, 2175, and 2106?
- Struts/Shocks from hell
- DIY Powerwire install
- 2002 4.7L Oil Pan Removal
- Weird vibration
