View Full Version : 3rd Gen Ram Tech
- Combining lift kits?
- Techs are stumped by my issue....
- Sway bar link issues
- 2004 ram slt sluggish on highway????
- 16-18 mpg down to 10-11 in 2 days !
- 2008 Ram 5.7 HEMI Whine (NOT Belt-related)
- What circuit to use when running halo's
- Any Ideas on How setup with sound.
- Can someone explain pressure wire and tranny line booster
- Sway bar link Broke
- 12 volt power outlets
- p0452 code
- lift question help
- Axle nut size 06 Mega Cab 4x4
- Low air out put from vents
- 06 2500 mega cab rear end rebuild kit help
- Bed not level any more
- 4 Mechanics stumped Im at wits end!
- disable start-up chimes???
- New member needs lift help!
- Anybody ever remove this bumper?
- Hesitation when accelerating P1038
- Front right tire wearing on the outside
- ring and pinion gear help for lift
- Ball joint issues
- 05 Dodge Ram with upgrade but hard start
- Maggy Y-Pipe Question
- 05 Dodge Ram uogrades but hard start
- '05 doors same for 1500 & 2500?
- R&R catalytic converter
- Overhead Brake light problem.
- 2004 Ram 4.7 Engine Knocking
- Quick question.....
- need alittle help
- condensation, build up under oil cap and fill tube
- K&N Air Intake For my 1500?
- Rattling/clicking noise 2004 Ram 1500 2WD SLT
- Only 3rd Brake Light works
- Exhaust Questions for my 2008 4.7 6SPD
- Can someone help me find a pdf repair manual for a 2004 dodge ram 4x4
- Please help. Codes P0700 P1765 P0743
- changing fluids question...
- New Wheels
- Overcab Camper For a 1500???
- replacing catalytic converter
- Intermittent rattling/clicking noise 2004 Ram 1500
- spark plugs
- what yall think
- 2008 1500 blower motor question
- Driveshaft CV failure/solution
- Need some Help!!!
- Lug Nut Free Spins?!
- Rear end rebuild shops around Charlotte, NC
- Heavy Duty Front Coilovers
- Upgrading cam soon, need advice...
- 03 Ram 4.7 Rough Idle
- After Market Head Unit
- Fog Lights will not come on
- Headliner removal in a 02 single cab
- Chunk, chunk or squeak, squeak in the front end
- 1500 Mega Cab Limited Slip Additive Needed?
- new brakes squeal
- EGR valve bad within 1 year?
- Found under Ford: Dodge Ram Fuel and EVAP Line Fastening Clips
- Brake upgrade after lift?
- I'm new here, but i have a question about my Custom Ram!
- lights turn after I stop the car
- 2004 Dodge Ram Fuel and EVAP Line Fastening Clips
- Brake Recommendation
- Please help p0420 and p0357
- which engine
- 2007 1500 warning chime keeps going off
- Had to level insted of lift.
- Power steering rack bushing looks.. weird.
- Loud metal knocking sound from front drivers side of engine...
- Tire Size with lift
- U1418
- Belltech Street Performance Shock Question
- 2004 Ram 1500 4x4 fast overheat, died and wont start
- 2004 Dodge Ram 1500 4.7 check engine stutter shifting
- 07 ram 1500 2wd front springs/shocks swap with a 2500 2wd
- repacing oil pump
- A couple issues after engine swap
- 08 battery dies when it wants to so confused
- P0483 Fan Speed
- hose on the EVAP Duty Cycle Purge Solenoid is busted
- Overheating in 4x4
- Ball Joints on a budget
- Fixing wind noise
- How To:Real Automatic Headlight Switch
- 4.56 gears with posi?
- 2003 Ram 1/2T quad cab alignment issue
- Brake Pad ?
- 2007 dodge ram 1500 quad cab SLT 4x2 conversion to 4x4
- random "dings" and abs/brake/airbag light flash
- torque converter clutch solenoid circuit
- Oil cooler location?
- 2004 dodge ram 1500 5.7 L Hemi Regular Cab Speakers and Speaker Sizes?
- How to change/replace struts inside coil spring?
- WOT shifting issues
- Engine noise in Rebuilt 4.7l?
- spare tire wouldn't release
- Question on Gears
- coil codes - little help
- AC not blowing any air at all (Neither cold nor hot)
- Electrical Gremlin - Airbag Light / Brake Lights / Speedometer / AC
- 2004 Dodge Ram ST Seat cover
- P0155 2004 Ram 1500 5.7l
- ac compressor knock
- Info for those with transmission hesitation/slipping on startup
- Radio mutes itself at random
- vin number parts help.
- Some wiring i assume....
- 2013 ram 1500
- brake controller
- 6in Skyjacker Lift Front Driveshaft Angle
- P1389
- No power to drivers side back seat window
- cheapest way to lift a truck?
- horrible steering wander
- Regearing 9 1/4
- Scantool selection & Trans Temp PID?
- 7 inch lift help needed!
- towing weight
- A/C Condenser Fan running?
- 2wd v6 and i can't seem to find any lift kits
- Misfire and p0138
- Should driveshaft have any play at the transmission extension housing?
- Trimming upper control arm mount
- heater problems... 2003 Ram
- Ram 1500 2004 5.7l 4x4 odometer & ABS
- Double Din in a 02 Sport 1500 w/ Infinity
- new to the forums, a few performance based questions
- Throttle body or Transmission or something else??
- 2004 5.7 Hemi Fuel Pump Pressure Test Port Location
- Part number for recirc. door 2002 Ram
- Can the solenoid pack fix itself??
- Rear end clunk
- New to forum and have a few serpentine belt questions (Squealing)
- Looking to lift 06 1500 long bed
- Another blower motor issue
- Helping determine heater core, blend door(s) or HVAC switch?
- SLT interior
- Help Electrical Issue
- persistent P0058 code 2004 Hemi
- Help please; '03 Hemi valve spring failure & foibles.
- 2004 5.7 Hemi P0300 Multiple Misfire
- 04 1500 no cruise control?
- HVAC Help
- New to forum and have a few suspension questions
- 2005 1500 4x4 problems
- 4.7 Cylinder Head compatibly
- 2004 1500 Ram Brake light issues
- OD & TCC solenoid
- 05 5.7 Quad cab. Running her to death??????
- Steering knuckle and hub/bearign assembly help
- Fuse vs Fusable Link?
- security problem
- 2007 Big Horn Keys
- New Hemi Motor, $2400 Shipped...
- Speaker problems
- Ball joint questions...
- New member from the UK
- no heat out driver side vents
- 2006 tranny issues
- Plowing with an 03 2500
- engine changeover 02 4.7-06 4.7
- 2004 Ram SLT electrical trouble
- 85w90 or 85w140 for motive 4.56 and eaton tru trac?
- Mad battery drain
- what leveling kits are you guys running
- Transmission 2002 Ram 1500
- Issue with Interior Lights
- Change oil
- Pacesetter Headers on my 04 ram 2500 hemi?
- New Member 2005 Dodge Ram 1500 regular cab 4x4 Hemi
- Violent shaking
- MDS v8 to 4cyl
- Help with install of Yukon Dura grip
- 2003 Manual Gear Selector slop/play
- '04 front bumper woes
- Electric Fan Install ???
- 06 1500 3.7 misfire problem. Please help
- %@$#&&% brakes!!!
- Are These Powerstop Rotors Correct
- exhaust leak at the manifold
- Fuel pump reliability?
- PS Leak
- Oil guage going down?
- Connecting rod bolts
- Penetrating Oil (Thread Unlocker)
- Parking brake system rebuild?
- Help deciding on new tires
- "Random" Electrical Issues
- abs light flashing
- Tube on rear axle brake tee
- need a battery, for cheap
- Changing seats! Need advice
- 4x2 2006 axle flip question
- suspension qustion specific to 06 - 08 1500 4X4
- 06 to 08 1500 4X4 specific suspension lift qustions
- 2007 5.7L 1500 Vibration issue / bad tire wear.
- OBD Code Reader
- Lifting A 08' 6.7 2500?
- Rack and Tonneau Cover?
- Ebay electric superchargers
- 3500 Truck turned off in drive. DANGER!!!
- CAI K&N Model #'s for 08 1500
- Rhythmic squeal at higher speed
- DDM Tuning 35w 9006 Fog light install on 03 Dodge Ram help
- Truck leans/lower on right/passenger side
- Transmission Issues
- help!! new to the maintnace world.
- 2007 3500 differential
- Rear LSD Issues (PICS)
- 87 or 89 for my 04 2500 Hemi?
- Need some help
- Bought my first truck, Oil question :)
- 06 Ram 1500 4x4 light issue
- Misfire #6 igniter
- PLEASE HELP...06 Ram 4.7
- Replacing ball joints
- A little tranny fluid on garage floor
- 08 Ram using oil
- Broken spider gears - nothing else
- 03 Dodge Ram Quad Cab - LED Dome/Map Help
- Quality kits
- Hemi smokes alittle on starting
- instrument cluster weird problem
- SOLVED P/S Power Steering Pump Whine
- Hemi Tick? Help please!
- 4.56 motives and eaton tru trac are in!!
- Front Carrier replacement questions
- 260 Camshaft in a 2003 Hemi?
- 08 Ram cummins Engine Light
- Aftermarket Ignition Coils?
- Cheapest bed/tail gate cap.
- If you have lowering shackles read this
- Front end leveling
- 2008 Ram Factory Radio
- New (to me) '05 Cummins
- shuddering upon acceleration in 4wd need help
- HID foglights?
- New Plugs/Motorcraft Platnum
- Throwing code p0174 and p0171
- P0303 ram 1500 2007
- Do i need shocks or struts front
- 03 hemi getting hot
