View Full Version : 3rd Gen Ram Tech
- Oxygen Sensor location
- 2007 RAM 2500 5.7L HEMI: Bad PCM/WCM? No Start No Crank / Will not program new keys
- Transfer case tries shifting while driving
- Vibration when turning on the highway
- Bumper spacers
- 2WD 35x11.50
- Trackbar bracket eggd holes fix
- Body Mount Bolt Broke!!! Help
- P0132 P0152 and P0038 2008 Dodge Ram 1500
- Inverter setup?
- 08 ram 1500 4.7L actuator spindle won't move.
- Looking at a 2006 1500 ST 4 door
- Surges in cruise control
- 46re shifting issues
- Clunk in front end
- New guy
- Led help
- Code PO300 Solved
- 04 Ram 5.7 dead miss on #7
- Gauge Cluster Acting Strange
- 2004 Dodge Ram
- Cant't make my cruise control working - what to try next?
- truck bed compatability
- 06 ram hemi starts hard
- '05, 5.9 auto. Fuel pump injector problem.
- Seats
- How to replace front dust shields?
- 07 Ram 1500 4x4 hemi no gears at all suddenly this morning
- Electrical Issues
- CODE U0155-Instrument Cluster
- Moog Suspension Parts/Serviceable VS Non Sericeable/ Vehicle Resale Qs?
- brake line fittings dont fit?
- Front lower balljoints - what diameters press tools?!
- How about E fan upgrade? Flex A Lite or what...
- rear axle problems
- 2008 dodge ram 1500. 4.7L V8
- dies on the road
- Loose change sound
- No Starting issue
- Stock height measurement?! How to find out?!
- 46re problematic shifting delayed shift
- 2004 Dodge Ram 1500 4.7L
- Need to disable skim
- Output shaft speed sensor
- Power steering pressure switch wiring.
- Mis-guided plug
- 2004 Rear Differential Tag Says 3.9 is that 3.92?
- AC leak? Or something else?
- My 2002 dodge ram 1500 46RE rebuild questions and build thread
- Sway Bar Issues? Bent Front End?
- 2003 Dodge Ram Cracked Dash Cover
- $7E8 and $7E9 Codes
- 3rd Gen performance tuner info
- 5.9 Engine noise tick 02 ram 1500 sport
- fuel supply wire harnes 2004 Dodge Ram 1500 5.7L Hemi
- 2008 3.7 Engine Swap
- throttle body adapter
- Custom 3rd gen ball joint/ control arms for camber on 5/7 drop 07 dodge ram
- Temp gauge
- engine oil with antifreeze "weeding"
- Recommended Shock Absorbers
- Best diesels.
- Pcm Part number
- Gas Tank Replacement?
- Engine knocking
- Tail lights not working
- Coolant tank grommet, $4
- 46re dodge ram 5.9
- Two part question - Used intake manifold has metal chips inside!
- Cummins ticking noise
- Brake switch cold wire for brake controller
- 08 Ram power,no crank!
- P0706 no start
- What is my wheel Bolt Pattern?
- Coolant and timing cover.
- 08 ram random misfire at idle only
- 2008 Ram 3500 radio fuse
- 05 4.7l 1500
- 07 Ram 1500 4.7l AC compressor not engaging
- Engine heat and cooling issues
- Wipers, taillights, running lights and fog lights, Oh my!
- A pillar grab handle
- ⚠️ Driver Seat Stuck Forward ⚠️
- Electrical issues 2004 Ram 1500
- Fuel Pump Size/Model
- 05 2500 5.9 Cummins engine mods
- no A/C and boy it sure is hot out there...
- NFG introduction!!!!
- Ugh, another Crankshaft Position Sensor Issue; possible wiring problem?
- NFG has a few ?????
- Parking brake issues? This fix can help you.
- Overheating asd relay/fuel pump relay
- Downsides of torsion bar key lift in AWD RAM 1500?
- Dodge ram stalls at light and runs rough
- front shocks
- Hvac module or mode door?
- 03 No Bus still running just fine
- Trans gauge light
- Stalling in high ambiant temps
- 45RFE question
- Cooling issues
- 03 transmission swap
- 04 Hemi, Taylor Shorty wires 8.2 or 10.4 MM ? Thundervolt or? and Plugs 06 Conversion
- 07 1500 4.7 Rear Shock Mount Issue
- Air Bag code set
- Looking for feedback on 03 1500 4.7
- key chime stays on
- Longhorn 3rd gen
- 2008 5.7 Engine swap question
- No power to fuses
- Starts but shuts off numerous times
- 2006 Ram 4.7 2WD Motor Mounts
- 03-05 PCM swap ideas
- Replacement Bumper
- Evap hoses melted on top of exhaust
- Fuel tank
- Fuel pump lock ring and gasket replacement
- How to check fan clutch being stuck?
- 3rd Gen PCM Programming
- Rear bumpers
- Need Help old Dodge Ram hemi
- Throttle position sensor
- Stuttering at 2500 rpm can’t accelerate.
- Front brake problems
- AC issues
- 02 Ram 1500 3.7L to 5.9L
- No AC
- 2005 ram 1500 hemi NAME THIS PART???
- issues after headgasket replacement
- P0601 Pcm code
- Enhancing Your Dodge Ram's Style and Performance with a New Grille
- 08 1500 Laramie 5.7 4x4 Headlight Intermittent Failure
- 2002 dodge ram help with headlights
- HELP! need help finding tranny parts for my rebuild.
- 2005 Dodge 2500 Ram
- 07 ram 1500 4.7L radio/ speakers not working
- 07 ram 1500 4.7L new AC not working
- Paint restoration and FCM for a 2004 Dodge Ram 2500 2wd Cummins Turbo Diesel
- 6.7 Cummins ECM help
- Need help with hydro booster or master cylinder
- issues starting 08 1500 5.7
- Various Codes
- Driveshaft vibrations
- Looking for a VIN
- Radio help
- Front end clunk
- 2007 Ram 3500 Air Bag Light
- Gauge cluster replacement
- Pegged temp gauge
- 2003 1500 5.7 York 210 Onboard Air
- Passenger Side ABS Sensor
- 2005 1500 4.7 power to half of fuses
- Temperature gauge needle
- Chain Noise
- Turning over
- loud humming sound when let off gas!!!
- Longhorn 3rd gen 6.7
- Help! I can't figure out what this noise is and it's driving me NUTS!
- 2007 Ram Hemi fuel pump voltage issue
- New blend door actuators clicking
- My First 4x4: 4WD Stopped working
- Toggle Switch on Positive or Negative?
- Best spark plugs
- 2004 Dodge ram 1500
- Piece of rtv fell into rear end
- 2003 1500 3.7 2wd manual transmission (STARTER PROBLEM)
- Using impact on torsion bar adjustment bolts?
- Leaf spring swap complete, now onto the torsion bars
- Question about upper control arms.
- New shocks needed
- Random plug behind where radio is in 2002 ram?
- SKIM delete/PCM/ Keys... Truck won't run
- Hooked the battery up backwards…
- 08 ram 2500 AC control
- 2003 Ram 1500 - Interior lights won't shut off..
- high performance transmission any advise
- 2006 Ram 2500 Dim LED Radio display
- 2008 Ram 1500 trans mount problems
- Wiring issue? Tipm? 2006 Cummins
- Timing advance
- 2004 dodge ram 1500 transmission comes out of overdrive in high gear.
- Rusty shackle woes. Wtf!
- 2005 ram 1500 rear shocks w/lift blocks
- Transmission swap info needed
- 5,7 HEMI exhaust manifold, gasket and what screws goes where?
- 2002 ram automatiic with 4WD in limp mode
- Occasional hard start/sputter
- ignition.
- How to identify rear axle and what oil (+ additive?) to use?
- 2003 Ram 1500 dash parts left over after recirc door replacement
- Rear Diff Cover - Aftermarket or Not
- Crank no start 2002 ram 1500 5.9 magnum
- Flatbed from a 4th gen on a 3rd gen
- Replacing my 4.7
- Trim I've never seen before
- Brakes
- Replacing leaf springs on an '05 1500 5.7 4x4
- Should I replace 13 year old gear oil?
- Dome, Map, Glovebox, Vanity Mirror What Bulbs?
- Overheating Problems on 04 3500 5.9
- Milky transmission
- 2005 Ram 5.7 ready to stroke, need advice
- Jack slipped on front now rear wheels lock when wheel is turned?
- Tune questions
- Lift kit question (HELP)
- Whining Noise that changes with speed.
- 08 ram 2500 intermittent ac mode control
- early third gen headlight housing question
- Pcm 5.9 l
- Valves ?
- 2004 dodge ram 1500 brake line question
- 04 ram 1500 transfer case
- Park lamps stay on
- I have a 2003 dodge 2500 5.9 Cummins diesel
- 2005 dodge ram rear shock
- testing fuel pump power
- High idle
- 2004 dodge ram 2500. W/5.7 hemi
- 4x4 shift linkage
- Crankshaft Position Sensor Oil Leak
- Persistent Code !! P0480 ??
- Accelerator is more sensitive than triggered news anchor
- Build Sheet Customer Preferred Packages
- Bad fuel, rough idle, better scanner? Idk?
- Brake Pedal to the Floor
- Dodge Ram 1500 2003 4.7 246000 mi
- error code P2181
- 04 ram 1500
- 06 Ram 1500 5.7
- 2007 ram 1500 Open differential swap
- Front Diff issue?
- Stereo upgrade...
- rear end sway 05 3500 dually
- Codes and over charging problem
- Newbie with tranny problems
- Main bearings
- Key Fob only works when Truck is running
- Intermittent Shudder
- Exhaust Y pipe
- 02 Ram 1500 ABS light and Chime
- Problem installing lower control arms.
- sometimes won’t crank/ clicking behind guages
- Small problem with transmission (545RFE, reverse and 2nd gear)
- JTEC engine in a NGC truck?
- rear camera for 2005
- Need help!!!
- Dually swap
- Motor mounts
- Bent pushrods
