View Full Version : 3rd Gen Ram Tech
- Superchip
- Torsion bars
- step bars
- hypertech +jet module?
- Anyone have Pro Comp Series 7028 wheels
- programing duplicate key help
- tires on ram?
- Tuners for a 4.7?
- NEWBEE WITH A RAM 2500 WIRING QUESTION
- Plug Wires?
- Idle Problem
- Confused on CAI!!!
- building a cold air intake
- My 07 failed inspection.
- New Pics
- Back again with a new toy
- RPM Question
- Debating between cold air intakes and exhaust for 4.7l ram
- good comments towards Varsity Chrysler...
- the 3rd generation ram go an award
- which tuner is the best for the money?
- HELP
- air intakes
- FINALLY!!!
- Corsa exhaust
- 09 hemi intake manifold swap..
- going to track...soon
- Got one for you techies...
- transmission light
- is it worth it?
- Squeel when turning the wheel AND when not turning wheel
- Cluster Leds
- overheating / variable temp at vent
- New Hemi!
- best gears???
- Over heating / variable heat at vent!!!
- Urgent help please
- Stainless Rocker Panel questions
- finally got some pics up of the truck
- Oxygen Sensor???
- Flowmaster Update
- Ceramic Headers versus Black Painted Headers
- Battery died Today
- Upgrades for better towing
- Power Wagon ????
- Best $30 EVER!!
- 4.7 chip
- Seat belt chime
- Superchips Programming Questions ram 2006
- Whale Tail Holes, Anyone find a chrome tailgate cover for it.
- Gotta new Ram today!
- Hey another Sub Speaker question
- 02 ram 1500 5.9 gas, hp needed,help
- something broke
- HELP! Brand new tints on 1 window coming off.SHIAT!
- I think I was taken!
- Realy Loud Tick
- Vertical Grill???
- Alignment after installing leveling kit?
- Sub Box 4 qc thats not under the seat?
- driving lights
- hid problem
- PCM / Engine Light ???
- Tail light changes
- Torque converters
- "fresh" door handle
- Overhead Consle Lights
- where to purchase body colored grills,bumpers,roll pans?
- Driving Lights
- 285-70/17's will the fit on stock 02 1500 2wd
- Transmission Interlock- BTSI
- Need wiring diag. for the LED ashtray MOD
- CAI clarification
- IF YOU DONT WANT YOUR TRUCK GET STOLEN BY OTHER IDIOTS!! THEN READ THIS!!!
- Possible rad leak?
- Loose side view mirror
- KEY REMOTE UPGRADE QUESTION
- TAILGATE STOLEN IN TULSA
- 4:10 vs. 4:56? Pro's vs. Con's?
- Would you buy the 3.7 again
- replacing 3.55 with 4.56 gears
- HOW MUCH FOR A TAILGATE
- 2008 Dodge Ram 1500 maintenance ?.
- Hey guys.... been a long time...need some help...fuel pump
- Tire fitment
- Does adding canopy = shi$$y MPG?
- 4.56 gears...WHO ASKED ME A QUESTION VIA PM?
- Lone Star Edition
- question about sound systems
- Power window problems
- TinT ArT SigNs PIMPED MY RIDE!
- Got my 2008 Ram SLT Hemi
- Updated Pics in gallery
- truck sounds horrible with...
- Trouble code p0303 cylinder 3 misfire
- engine upgrade?
- Overdrive in, all the time ? can it be done ?
- Better MPG on Stock Hemi?????
- which one do you like more - NEW or OLD???
- Adding OEM GPS unit?
- Superchip Gas Mileage
- TRX
- Throttle Body Spacer
- Programmer Ideas
- Which CAI should I get?
- Pictures problems
- FLOWMASTER MUFFLER
- New owner, several questions...
- Bad door speakers?
- WOOOOOO FREAKING HOOOO BABY
- water infiltration in differentials
- Performance questions
- Check engine light...no code
- New to Forum
- MOVED: nissan is dodge? vis versa? READ THIS
- BEFORE I GO RIPPING APART MY DASH
- painting headlights
- Bump while stopped??
- Which mod first?
- Ac/Heater not working Fan problem? Help!
- MDS Thoughts and Questions...
- check engine light?
- Suggestions on dropping my truck
- MOVED: off roading
- Satellite antenna templat
- Factory stereo removal??
- hemi chip flash
- Tires on 20" clad wheels??
- SQUEAK IN REAREND..PLEASE HELP!!!
- Radio wiring question
- installing mudflaps/ splashguards
- Air vents
- 07-08 OEM Taillights/Covers
- stripped screws
- front axle U joints - 2004 2500 diesel 4wd
- rear end lowering clamps
- You guys need to check this out my cousins online auto shop (HSAUTOSHOP.COM) just opened up.
- Bedliner to line-x
- Body Lift $$$ and Where to buy
- Tires void warranty?
- Funny Noise?
- New found problem w/ truck
- tried a new car wash product and....
- 2002 1500 Leaking antifreeze
- Thoughts
- Best place to run a wire from engine bay to cab?
- Hemi question
- 160k Miles Too Much??
- add a leaf
- WTF, my BFF rose... My door lock doesnt work???
- Billet or Vertical Grill???
- Cruise control question
- SHAKY!!!!
- Driver door weatherstripping -
- broken clips in LSD rearend Ram1500
- Wheels sittin kinda funny...
- Posted for user Chris S
- Tail Light Mod
- Wheel Well Liner Kit
- Electrical gremlins!!
- P0700
- What Do I do First?
- what are those "flat" rear bumpers called?
- lets hear the gas prices
- air around glovebox??
- Your thoughts please
- window lock button
- BDS vs. FabTech
- Blue smoke
- tow mirrors
- Getting an '08 QC 4wd 4.7 6spd...
- exhaust pipe question
- Selling Cap for 04+ dodge rams
- Gibbson vs Flowmaster
- Rear end shaking real hard???
- I need your help on how to trailer my truck
- Evap purge flow monitor failure or evap solenoid circuit
- 2006 Hemi Upgrades
- How do I adjust the door?
- 2004 ram w/hemi
- Turning your own brakes?
- Anyone have Dual Exhaust Headers on a 2007?
- Button broke on my Tonneau Cover!
- Tow mirror install
- couple questions
- MY RIDE RITE AIRBAG FILL UP SPOT...
- Rollin on New MEATS!
- SINCE THE 3"BL AND 36'S..........
- Ultra Goliath Wheels ON RAM
- Towing the Ram (wiring questions)
- Front-end window tinting
- CENTER CONSOULE SWAP
- Probably getting a 2008 Hemi - question
- O2 sensor low voltage?
- 4x4 leaking Need Help Please!
- Wheres your odometer??
- Replacement Dash...where to buy?
- Auto Headlight mod questions
- WOW... My ram sounds like a GM
- lightbar, lights and a little more PICS
- ball joint vibrate?
- 6.1 hemi exhaust manifolds..
- installing aftermarket headlights
- Front axle diagram
- New Thrush 2 chamber mufflers
- plugged cat, o2 sensor, or fuel injector pls help
- DeBadge
- MOVED: Watch out ! 2008 Mitsu. Lancer's !!!
- O.K., so I spent....
- Front Floor Tunnel Convienence Tray
- Question about the cross over plug wires..
- Did you lift your truck for off-road use or looks?
- Off Road in you Ram
- Shift points with superchips
- which gears do i have
- Mudding Tire Wear
- swapping an 05 4.7 into a 02
- how to know if your tie rods are bad
- 5.7 L Vs. 6.0L
- Working the PowerWagon
- I love my friends at the Internal Revenue Service :D
- Love the RAM but Trucks are Godawful Slow! (Be careful)
- Flowmaster Muffler?
- MOVED: Feeler Thread 04 ram part out
- Axles and Gears
- Torque converter before or after headers?
- Stock Rims Big Tires??
- I'm Confused
- Stupid Alarm
- 1500 rear axle fluid
- new stereo
- Steering issues - post front end work
- Headlights doing a dance
- Anyone have a DualLiner
- Airaid Jr
- Ready Lift?
- MOVED: pic signature maker
- Test Tone?
- Got New Bumper Put On
- Another Wheel ?...Anyone have these?
- Sub enclosure box
- diff covers/gears
- Tranny stuck in 2nd
- Drastic Driving Change
- speakers
- HELP! Stranded in Mexico...Dodge Ram 1500 2003 Stalling after engine warms up...
- Ball joint grease
- EXHAUST????
- Whos towing a camper or sumtin ?
