View Full Version : 3rd Gen Ram Tech
- Unplug amp wires
- LED lights (HyperFlash)
- 2004 5.7 Hemi Vacuum Problem
- Adding a Winters Shifter to a 545RFE, anyone done it?
- 5.7 Hemi, 06' car engine into 04' Ram
- Need some wire colors
- 03 ram pcm question
- Has anyone put a charger searchlight on their pickup?
- Wheel bearing questions
- I'm new to the forum. 04 Ram frontend rebuild.
- Cruise control doesn’t work past 85
- 06 1500 trans stuck in limp wiring
- Leaf Spring Shackle Help
- Grinding noise when letting off accelerator
- 2006 Dodge Ram 1500 ignition switch problem
- Death Wobble Question
- leaky oil pan
- Clicking Noise Under The Dash
- Release back of backseats?
- Replaced transfer case linkage. Won’t lock into 4HI
- Engine seems like its bogging down
- Check engine light not working
- Heat issues 06 2500
- Fluid capacities
- Rear leaf springs second opinion and advice with a link.
- Cold Start Issues, Have to feather acceleration pedal
- Shift cable/transmission problem
- Power loss and Exhaust Manifold leak 07 Ram 3500
- Rear end locked up
- Rear end
- Help!!!
- Best bang for the buck upgrades
- Tapping when accelerating
- Cam for torque?
- Noise at start-up driving me crazy!
- What is this under my dash?
- Upgrade Axle Ratio
- 2006 ram 5.7l hemi random misfire code dont know what else to do
- Hemi down
- New Guy Here Need Some Help
- 08 5.7 getting 7mpg?!?!
- Occasionally feels like truck can’t decide to shift
- 04 Dodge Ram codes please help!
- 2005 Dodge Ram 1500 4.7 liter shifting problems
- 2004 4.7 codes P0871 and P0700
- Oil leak from oil filter sealing screw port area. 2 questions.
- 4.7 top end rebuild issue
- 4.7 4x4 rear end knock
- New guy on the Forum needs some help
- Almost giving up on hemi
- No low beams and random right high
- Moisture in Oil Filler Cap 5.7 2008 Dodge Ram 1500
- 2002 Dodge Ram 1500 v6 3.7 water pump problem
- axle u-joint c-clip fitment
- 2008 4.7 stalling
- Quarter panel fitment
- Dodge Ram 1500 Stalling when Stopped
- Rear Suspension, leafsprings, front suspension and steering problems pics.
- Jumpstart another truck got me in trouble :(
- 2005 Ram 1500 hemi - correct Ratio programming
- Loose Pinion Nut and Flange 2005 Ram 1500 4.7L
- Leaking coolant between oil pan and bell housing
- Manual to Auto 3rd GEN
- 07 ram 1500 - brake controller and hot wire
- 46re unusual problem, need help
- 2004 1500 Oil Consumption 4.7L
- Window swith not work
- p0335/p0336/p2509 codes after start with low battery
- S
- Swapping transmissions
- 2003 545rfe problems
- 2004 Dodge Ram 1500 4wd ignition issue
- 03 5.9l cummins trany cooler
- Truck wont start
- Losing brake fluid
- EGR Valve Tube rerouting.
- Nv3500 02 ram 4.7L other people with nv3500. Start in first or second gear empty?
- 5spd 4x4 hurt tranny with a sad 4.7
- 04 1500 Gauges Issues
- 03 Ram 2500 5.7Hemi having shifting problems.
- 3rd Gen Ram surge problems
- Simple question, yes or no.
- What kind of metal are these valve covers made of ? I want too paint them. DIY Style
- P0132 & misfire
- motor sawp
- 07 3500 Won't Start - Request for how to vids?
- Help w/mysterious 07 issue? Pretty please
- Mobil 1™ High Mileage 5W-20 Helps extend engine life in vehicles with over 75,000 mil
- Need Some Opinions! Lifting or Leveling and Tires Please and Thank you
- 2008 Dodge Ram motor swap
- ABS/traction control problem
- 2004 1500 defrost not working
- Mystery - Battery? Alternator? or?
- Battery overcharging
- 2003 ram 2500 right brake light does not work any suggestions?
- Ram HID Lowbeam flashing
- Towing capacity
- No Heater Blower
- What happens if I plug the vaccum line from the Evap pump to the purge solenoid?
- Tailgate
- 05 5.7 Ticking Noise
- 07 Electrical and Idle Problem
- Nv3500 02 ram changing clutch hydraulic assembly as preventative maintenance
- Headlight issues
- Looking for Shift Solenoid Block Pack
- Mobil 1 Delvac gear oil 75W 90 a good choice for the front Differential ?
- '07 1500 4.7L feels underpowered
- Ect 3000 short finder help
- rear flat plug 4 Pin round unknown
- Towing and EGT question...
- 09 cummins
- 2007 Ram ST cruise control install
- 4wd light flashing... can’t find help
- Rear Differential Fluid question
- 2003 Ram 1500 V6 02 sensor issues!
- Rear end swap
- 2-4 pressure Switch Solenoid Block
- Engine revving while in park
- Truck dies over 2000 RPM
- Short circuit
- PLEASE HELP 2004 Ram 1500 5.7L Wont Idle
- 4wd actuator?
- 2006 4.7L upgrades
- Lifter noise after rebuilt motor.
- Spark plug inspection and antisieze ?
- 02 ram 4.7 any way to figure out what type of anti freeze is in truck
- Whomp noise
- Np243D replacement or repair??
- rear bumper info
- 2004 1500 strange brake light issues
- No pedal response
- Electrical issues or???
- Exhaust manifold gasket
- Shopping List for Lifter/cam Swap
- Headlights flash off and on after warmed up
- I believe my baby is posited
- Headlights Are Criss-Crossed
- wiring needed for fuse 25 power outlet IP dodge ram 2500 2003
- 04 2500 4x4 Cummins Trans comms issue
- 06 ram 4x4
- 3.7 v6 swap from dakota to ram 1500
- Need help 07 ram 5.7
- Pcm help please
- Crank but no start. Help please!
- Wiper intermitting
- Shifter stuck in park unless a heavy weight person is sitting in the drivers seat
- 2005 Dodge ram 5.7 P0404
- Serial offender 2204 Ram 1500 4.7
- Truck shut off on highway, lost oil pressure wouldn't turn back on but turns over
- Defrost issue
- overheating with ac engaged
- Shop manuals??
- 2002 4.7 what battery strength do I need? I can’t seem to find this anywhere
- I’m ashamed to ask this, but new pcv valve will not screw into the oil filler neck
- Weird heavy vibration when decelerating from 50 mph
- Help! Timing chain
- Lower a/c housing replacement - with or without dash
- INSTRUMENT CLUSTER SWAP, KPH too MPH ?
- Squealing Noise At Idle - Please Help
- What kind of coolant does a 2002 take?
- Theoretically what would the computer do if I unplugged the Evap canister?
- Codes!!
- gas cap warning
- 2005 ram 1500 4.7
- Help please
- Horn doesn't work
- Various Electrical Issues
- 4x4 shifter
- Exhaust brakes
- 2003 Ram 2500 hemi throttle body won’t work
- LED Upgrade
- 04 ram1500 torsion bar crossmember bushing #52113134aa
- Serpentine belt broke, now Truck hesitates
- Broken Exhaust Manifold Bolts - 4.7L Extraction & Replacement
- Dodge ram speedometer fault helpp
- Problems with hvac controls
- Wheel/Rim problem
- Power steering flush question
- Check gages! light on COLD morning starts -- oil pressure gauge
- Truck won't start
- Introductions
- No high beams
- Nv3500 first and second gear sound like I’m turning at 7,000 rpm when I’m going 2,000
- New clutch but now my nv3500 is making noise from under the shifter at high rpms
- Oil pressure Drops to 0
- Engaging Cruise Control Creates Bog? - 4.7L
- Front end noise
- Red Lighting Bolt... AGAIN
- Intermittent crank no start - then cranks and starts on second attempt. 3rd Gen 5.7
- Long travel high articulation CV axles
- Pacesetter long tube headers
- Electrical glitch
- 2002 Dodge Ram 4.7 nv3500 will a flywheel for a 5.9 engine same trans work in my truc
- About to do a clutch/input shaft bearing change 2002 Ram 4.7 any tips?
- ABS light
- Hood Supports and Struts ?
- Key won’t turn in old dodge Dakota
- Air bags on rear
- verifying if my truck has a leveling kit.
- Suspension nightmare
- Help ! Rpms not working
- Help with 4.7L head replacement
- 2005 Ram 1500
- Disable ignition key release ?
- 3.7v6 melting coil
- 2005 ram 1500 electrical problems
- Throttle body issues.
- 2005 hemi ram , po300 , I'm out of ideas
- 2006 1500 will not go into gear.
- Check Engine Light and Inspection
- Reset Computer
- 2005 dodge ram 1500 SpareTire Crossmember Unit
- 2005 Dodge 1500 5.7 hemi help!!!
- 2002 Ram 1500 manual trans nv3500 what are the gear ratios?
- Level Floor in Rear of Crew Cab
- Weird gremlins, won't always start
- 2002 dodge ram wont crank after motor swap
- 2-Piece Rear Brake backing plate?
- Leveling kit or lift kit?
- Not just another auto to man trans conversion
- Please help p0121 tps
- Need to replace clutch and bearings in nv3500 2002 Dodge Ram 4.7 what size clutch
- Newly purchased 2002 ram 4.7 nv3500 trans. Makes a whining/growling noise when moving
- 2003 1500 5.7 cooling question
- LED headlights
- Blower motor
- Swap a 2nd gen engine into a 3rd gen truck?
- Aluminum or Steel Upper Control Arms
- Egr valve keeps going bad
- Windshield washer fluid not spraying
- 2004 ram 1500
- Crankshaft sensor? Shuts off when warm
- Intermittent "Lamp Out" Warning Light/Chime
- Complete Switch From HOAT to OAT Coolant.
- Where is the flasher?!
- What's needed to swap an ECU into my 2005 2500 5.7L?
- Speedometer issues
- Bent pushrod?
- Backup cam advice
- Radiator Replacement, Cooling System Flush, Thermostat replacement ?s...
- 2008 Ram Knocking Sound
- Accelerator rattle
- No heat on drivers side 2007 dodge ram 1500 - flush heater core
- LEDs resistors
- 2006 4.7L Dodge Ram 1500
- Head Gasket Repair Question for Ram 1500 2006
- 2004 Dodge Ram 2500 hemi cam
- The best oil
- **Long crank time and no overdrive when cold** Works when warmed up and restarted
