View Full Version : 2nd Gen Ram Tech
- 2500 steering linkage - Diesel Vs. Gas
- Headlight cleanup
- The best handheld tuner.
- Crank Pulley/ Harmonic Balancer
- Any interest on a group buy for an e fan set up?
- Torque Converter questions
- best gearing for 1500
- Short Box
- Question for all that DO NOT live in CA
- are these lifters ok?
- Seafoam?
- Hub/Bearing
- I think a transmission shop broke my truck
- Stalling issue
- Engine troubles? Help ASAP please.
- Tonneau Cover
- 97 dana 60 front axle socket size
- What is the best sounding exhaust on a 5.9?
- need a new engine but dont know where from
- Painting Rims need advice
- best way to open up center hole on rims
- truck is at shop
- Intermittent reverse issue
- Stereo causing drain?
- Lower Class Club
- just squeeking along
- 318 to 360 swap in my 96 1500
- Rear bumper on 2001 Sport
- Rims and Tires Question
- V10 what do you think of them?
- Brake line shot, patch possible ?
- i just dont know
- Transmission shifts back and forth
- header bolts
- O2 Sensors keep going bad 96 ram 1500
- electric fan asembly install???
- Overheated (I tried search function I promise)
- Hard to start, can't figure it out ...
- OMG! My Dodge feels like a big slug!
- new and need help
- Brake Squeel.. Any suggestions?
- cel came on yesterday
- engine won't start
- nv3500 tail housings
- Quick Clutch Question
- Engine stumbles when cold...
- How much to have a tonneau cover repainted?
- Hood latch
- Cold start loop?
- !996 AC Compressor for sell.
- need a tranny where do i go?
- Check engine light, but no code
- Gotta give 'em props!
- 1997 Ram 1500 idle goes up and down and sometimes stalls
- Inside blower cuts off
- Couple of Questions
- Got New Rims and Tires !
- New and used parts
- Remote start
- Oh yea I got stuck
- Squealing belt?????
- Dana 40 Fill Plug
- easy upgrades
- Holy Crap tires have gotten expensive!!!
- Need wiring help asap
- Dodge Ram 1500 Warmup??? Sluggish
- Did the 46RE have an outboard filter?
- transmission help plz
- A/C vacuum leak
- Steering Knuckles
- Need More Horse Power!!
- Help diagnosing hesitation
- ABS and brake light on, speedo works
- I can has SCT?
- 2001 Ram 1500 Help
- 440 swap
- line-x rockers/ bumpers
- Need tranny for 2000 5.9l 360 v8 2wd
- Sc 3715
- Sway bar bushing replacements
- "Overdrive Off" Switch Bad
- Truck Wont Start!
- Cruise control not very "balsy"
- Sport or not a Sport? Bumfuzzled!!
- 1996 ram 5.9 cat removal
- need tranny help 97 1500 sport
- ECU has no calibration
- Front Axle Nut Removal 2500 4x4
- new speacker problems
- new speakers
- Custom Bumpers
- Serpentine belt alignment
- CB question
- 2nd gen guys... I need a favor
- 96 ram 2500 cummis , weird trans problem
- How to identify which motor I have
- 94 dodge ram 2500 cummis, not using top gear
- Aftermarket PCMs vs. Programmers
- do i need a starter?
- 2000 V10 loss of power under load
- Help ME OUT!!
- ram vs tacoma???
- muffler for a 2001 ram
- Synthetic Oils
- V10 Flowmaster
- Governor pressure sensor
- Need Help finding an old thread
- Weird hissing noise, can't track it down
- Lil help with muffler >?<
- Clicking while in idle
- any takes on those brite bluish headlights
- any problems common to a 97 ram?
- Looking for a more "happy medium"..opinions wanted
- No X4
- No power after starting
- Unidentified Plug?
- Noise when gas pedal is pushed
- Power Steering Upgrade
- shocks
- Finally!!! A resilution to my sputtering prob
- 94 v10 starting problems
- Instrument cluster failure
- odd starting issue
- Fuel gauge stuck way past Full level and not coming down
- 46RE Issues, advice needed
- P0601 code ecm
- intake gasket help
- Lighting Question...
- Replaced Mulit-function switch/hdlights alwys on
- Seat cushion swap
- Good Deal?
- Thinking about Swapping 1/2 ton leaf springs with 3/4
- Front Brake Question, Pads scraping rotors
- plastic piece on front bumper
- Brakes! NEED ADVICE PLEASE
- Loss of Power on Acceleration
- ok here the best buy for the longtubes
- plenum not the problem!!!
- My belt fell off, can I fix this easily by myself ?
- auto to manual conversion
- tranny cooler question
- 00 1500 headlight adjustment?
- Lurching at 72-73 mph( I have no clue why
- how throaty
- Dakota of the Month Poll
- Spare tire went bub by today
- Should i upgrade my steering shaft?
- pretty good deal on new superchips 3815 $230
- 1999 Dodge Ram 3500 Dually sport
- start up problem....
- Changed the Plenum and now two injectors are spraying gas
- 01 2500 Gas, Buck on accel for 2-5 min.
- Brake woes
- weird theory
- Start-up idle issues driving me crazy
- A/C compressor clutch noise
- Annoying hiss
- Leaking Master Cylinder
- redneck-ed ride
- gas mileage went way down
- SCT on sale 400$
- Hard to start the first time; ok afterwards. Help?
- Help with Spark Plugs
- Brake bleeder broke
- Overhead Console
- New Member Help With 99' 1500
- Clicking when I turn.
- Advanced Auto Parts Coupon save ya $10
- 318 coverted to 360?
- new to dodges,one of the many transmission threads...
- No Power & Rough Idle
- Groan/Whine/Hum
- help on some issues
- Tire fitment question
- 99 ram 2500 front brakes lock wont release
- Hub Unit Bearing
- Won't start
- Ideas for custom rear "pipe" bumper
- Steam in exhaust 5.2l
- how many 98-01/02 guys have the blue interior???
- Superchips 3815 problems....
- Thinking about a trade opinions needed.
- Leaking gas tank
- rear diff blew, looking into locker
- taking my heads off
- L.S.D./gears
- Hum with wheel and pedal vibation
- 1995 v-10 problem.
- just ordered PLENUM and UNDERDRIVE PULLEY
- A/C Issue
- Fog Lamp Problems
- X or H pipe
- Sagging Headliner
- time for the plenum job!!!
- Fog light mod
- Power steering problem
- Tranny Guru's, I need some help.
- Anyone used the HyperPAC Chip?
- Plenum Gasket Help
- axle u-joint issues
- U joint....input needed please
- Need HELP!!!
- brake caliper paint??
- need pics of engine bay 5.9L...
- How to tell the difference between a 5.2 and a 5.9
- Truck not sitting level or strait..im confused.
- head torque specs
- Egr?
- News on the My Truck With Pics
- shes settin purty now
- Vibration damper to crankshaft bolt, what size?
- How much sand can i put in my box
- converstion u joints
- AC is driving me crazy
- Torque specs for the suspension?
- What are the steps to setting my timing?
- radiator classics ?
- whens it time to upgrade
- power driver's seat
- Horn
- 1500 won't stay started
- the dodge wants attention
- Electrical Bull
- New PCM
- Breaks are really strong at start up?
- need info on plenum parts? and the death flash?
- Chicken coop
- Grille gaurd
- Wild Vents Problem - Questions
- stalling issues
- Transmission service and band adjustment
- engine replacement. headers question?
- bad fuel mileage??
- just got a trouble code????
- No reverse lights?
- Superchips Issue
- Issues after engine overhaul.
- Dodge RAM Projects Complete!!
- Hi everyone Got my Truck Out Finaly
- Hi
- 98 Ram Cruise Control Quit...
- brake booster question
- aaaahhhhh i think my truck wants to be a harley
- Quick seat fix maybe
- Oil Pressure Sending Unit
- Lift question for the guys...
- RAM Upgrades
- Help: Crank pulley
- O' The Tranny Woes (Need help)
- Question about tranny and engine
