View Full Version : 2nd Gen Ram Tech
- which o2 senser is 0132
- 1996 Ram 5.2 injector question
- PCM and code P0601
- motor goes into high idle once placed in park
- fuel pump...
- Bad Gas?
- Got a problem......
- Whats wrong with my radio?
- motor swap
- O2 Sensor Removal
- No Blinkers or Hazards
- truck wont start after its wormed up or stay running
- Rear differential confusion- and how much and what type of oil?
- tired of 1 wheel burnouts
- Serious Hesitation??
- Help would be appreciated.
- did anyone watch muscle car today?
- 2.02 eq heads
- Strange 'dimp dimp dimp' noise
- Replacement Mopar Tonneau Cover?
- Selling truck...needed paperwork?
- Running hot
- alternator
- P1756 Error Code
- Check Engine Light
- Intake manifold torque & idle/low rpm misfire/shudder?
- More cooling fun
- In need of an axle stub shaft
- Brake lines
- 86ing the Ram Air Hat
- Anyone seen these? clear diff covers
- 1995 Dodge ram 1500 5.2L needs more power.
- Dudes new problems
- OBD conversion
- Oxygen sensor troubles
- 2001 Dodge 2500 truck Ball Joints
- Completely removing Charcoal cansiter(evap system)
- No fire and coil is good, now what ?
- Front Tires going bald on the insides??
- Got a new radio installed....
- CEL - question - P0455 and P0442
- Battery cables
- I think I can I think I can
- Power steering pulley
- which coil is best
- Just ordered a boatload of parts
- replace plenum?
- Hard start when cold
- fog lights????
- What size is our tranny cooler line? 1/2 or 5/8
- Son of a ....gun
- trading to get a dodge ram
- Rearend Noise
- '99 Ram 2500 Wont start
- THANK YOU 6lb 8oz SWEET BABY JESUS!
- 0-5 Ohm Wideband AFR Gauge?
- Transmission questions
- Need help with vacuum leak after plenum repair
- Front Passenger side axle noise
- blow by or am i hearing things?
- New to the forum, just stopping in to say hello
- radio illumination bulbs?
- Transmission Question
- ac/heat vents
- probably computer or cps help??
- transmission ?'s
- 3rd gen 20's on '99 2wd
- oil presser gauge goes up and down
- front axle noise
- Cleaning agents for rims.
- engine hp and dress up
- Long cranking, need advise
- New to Dodge, need help with a P0138!
- Where is DIY thread?
- Transmission is Toast **advice**
- few questions about performance upgrades
- Quick O2 Sensor Question...
- Stuff going in the truck
- What is the wear point between the driveshaft and slip yoke? what needs replaced?
- Transmission ?
- steering / track bar home build update
- Am i the only one with a rattling brake pedal?
- 318 to 360 swap
- New Distributor, Now Truck Won't Start
- Ignition Upgrades
- Center console stuck up, seriously stuck
- remove cat? emissions
- quiet exhaust - suggestions needed
- single vs dual
- will a 5.9l cummins fit in a 00 dodge ram 1500 and how much work wuld it be
- Compression Ratio.
- EGR Delete
- Leveling kit confusion
- Plenum Update
- Mopar M1 Intake
- 2WD Front Spindle/Hub Grease Caps
- Has anyone replaced the fabric on your door panel?
- got a starting issue my haynes manual couldn't solve..,??
- Problem
- Trans question
- programmer suggestions
- engine question.
- A/C question
- wheel bearings
- Which engine do I have from engine castings
- Pitman arm snapped at gearbox.
- 4" lift spacer?
- speedometer and overdrive not workin
- 408 heeeeelp!!!
- ( Water in Transmission ) Please Help
- need vacuum line help
- 1996 dodge ram 1500 problem
- Aftermarket instrument clusters
- Updated nut for Pinion
- Clunk in my Chunk
- Keyless Entry
- Anyone try getting exhaust in GA?!?!
- Breaks lost pressure, but still stop the vehicle
- Trying to sell ram- Swap 35x17.5 MT Baja Belteds for 35 on fac- hurt or help?
- How to determine if Ujoint is inside lock ring or outside lock ring?
- anybody buy heads from clearwater?
- Timing Chains
- ABS data link connector?
- A/C Issues.
- Spark plugs for my truck...
- Is it true???
- new motor with cam, does it need a tune?
- msd offroad box thought?
- Engine mount heat shields
- transmission problem
- trailer light hook up
- What would you do with a brand new set of Nittos?
- 1998 RAM making noise during acceleration
- New 2 me 94 1500 w/ 5.2 steering wobble
- Timing chain stretch and gas mileage
- Need electric fans soon, looking for a good setup
- New Plugs for 2000 Ram 1500 318
- Edelbrock Intake Manifold
- Air Bag Light is on
- help 318 knocks when cold
- some newER rims on my truck
- A/C issue is killing me!!!!
- Overheating
- T-case tail housing leak?
- 318 engine rebuilt
- Battery/starting/stalling problem
- Screwed the pooch (AIM airhat)
- Now, on to the 4X4
- Tranny wont shift out of 1st
- RPM gauge wrong...
- I need help on lifting my truck please
- Underhood light
- dayum! i need help
- Removed my cat! Oxygen sensor question
- 1.7rr's mpgs
- 1999 ram shutters coming out of lock-up
- 01 5.2l starting issues
- Marine battery
- Questions regarding TB Mod
- runs rough cold/after startup
- New piston rings wont go on
- exhaust
- hughes air gap
- Where do you find engines?
- Gears for '98 Ram 1500
- Front and rear end ( CHANGE )
- craigslist find
- another crash!
- why are y'all so down on WD-40?
- No overdrive
- headlights dont work!!!
- difference between 5.2 and 5.9 converter
- this overkill?
- Leveling kit questions
- thinking of changing the cam...
- Autostart problems
- How do I clean a Throttle Body?
- A little Help with a 2001 Dodge Ram 1500
- I think I have a running problem? MGP, Catalytic converter, ??? Please help
- code question
- 1995 1500
- 01 Ram Infinity System, Tweeter Question
- Meguiar's Headlight restoration
- fuel pump
- Tracking Bar?
- E-Fans Installed (Small Problem ) Pictures
- Flowmaster Super 44 Extreme Question
- Ford step side bed on our Rams?
- lighting question??
- How to run fog lights with brights on??
- 5.9 gas grade?
- leveling kit ?????
- Buh-Bye Paycheck...
- Engine swap 5.2 to 5.9
- heater hose bypass
- cornucopia of confusing codes
- Identify This Line Please
- tranny problem?
- fog lights
- E85 Conversion Kits
- sluggish after warm up ? wtf ?
- Coil spacers vs lift coils
- Why cant I use 4wd leveling spacers on a 2wd?
- much needed info on my 97 360
- How did you learn so much?
- Wideband AF Gauge on a CA truck (After precats)
- 2k ram 1500 . Dies . no bus , then restarts
- help identify transmission please
- Time for a new motor?
- parking lamp 15amp fuse keeps blowing!
- Slipping transmission
- harbor frieght tow hook
- paint darkening wax
- how do you fix a p1398 code
- Axle types, just making sure...
- Turn Signal Malfunction
- Shaking when accelerating
- ebay Transmissions
- Couple questions for my '96
- preview of beefnut steering / track bar build
- Best website for aftermarket performance parts?
- probably a stupid question..
- new wheels
- FINALY going to fix that great detroit No-spin locker in the rear of my truck.
- Help re-installing transmission
- Won't start
- 1998 Dodge Ram 1500 Shaking when I stop
- 99 ram surging at idle
- ram headlights no workey
- Rear brake issue
- Will 05 Nerf bars fit an 01?
- 1997 5.2 wont start
- superchips help
- Modifications to do to my truck
- Whats the point of NOS on a truck?
- I need help finding Mopar Cold Air Intake
- 2001 1500 Sport 4x4 tires question
- Trying to figure out what's wrong
- Profile/Garage
- Anybody Remove the Rear Lift Blocks on Their 4x4?
- Truck on TV
- What cause that "bulge" in the radiator's top row. see pictures.
- gas guage just stopped working
- How to tell if you have abs
- Need some big time help..........
- Just bought my first Dodge. Time to swap the V6 to a V8
- Oil and Lucas injector cleaner question
- Rough Idle
- Gov press solenoid sludge
- 7? 10? 12? 14? how many quarts of fluid does 46rh hold??
