View Full Version : 2nd Gen Ram Tech
- Fuel injector service
- Seatbelt Light tied with theft??
- tranny line temp?
- Iac
- Looking for oem running boards...advice on where to get them.
- Firing order
- Failed Inspection!
- 97 5.9 Misfires, backfires when cold, codes P0300, P0301
- Wheel Bearing replacement question
- Transmission swap
- TB/TB Cable question
- 4x4 collar and axle question
- Possibly PCM???
- Exhaust Mods
- seat swap
- 94 Ram 2500 stalling at a complete stop.
- 95 2500 4x4 vacuum problem
- Which Steering Stabilizer
- exhaust size help
- parking lights and tail lights stay on even with switch in off position and ignition.
- Lowering 3/4, wider tires and Wheels Backspacing
- How is everyones Herculiner holding up?
- Time to replace water pump
- torque converter HELP!!
- Need advice on air intake
- Roller rocker madness
- 285's vs 265's
- 95 dodge ram 5.2L how to set the timing?
- Westin bull bar brackets
- my build sheet
- Dreaded Rust
- Washer light driving me crazy!!
- 3500 Dually Rear Fender
- Stuck on defrost
- Tranny maintenance, sonnax sure cure
- Plenum Plate
- can I make my 2wd into a 4wd?
- Really annoying squeal!!
- Real annoying squeal!!!
- I've got to be getting annoying by now... But PLEASE tell me what you think
- exhaust question
- aftermarket instrument cluster
- i figured out what i need!!! help!
- 2001 1500 5.9L missing/backfiring
- Help with 1998 1500 V8
- so anybody whos done the 2500 to 1500.....
- Which suspension lift ???????
- Looking at a '99 RAM 2500 QuadCab
- 6x6 6 (Wheel drive)
- 96 ram 1500 bucking hesitating
- Need help with my truck
- 1998 Ram 1500 Overdrive won't disengage..
- fog lights
- What do y'all think?
- Lift kit help
- Ac/heater fan
- forum search tool not working
- acceleration problems
- 2003 Ram transmission problems (it has the 2nd gen setup)
- 97 ram hard start
- Water Pump or Fan Clutch? Or Neither?
- Brake problem, huge problem! 2001 Ram
- Still Losing Oil After Plenum Fix
- need help ! ram 1500 2008
- Cool PDFs to have on hand
- Hughes Plenum Kit Gasket
- Fuel Line Removal Tool????
- Got my truck started, now it runs rough, stalls.
- intake mainfold
- vin-locked hypertech
- Codes for EGR
- Rear axel movement
- Any Suggestions? 5.2l Oil Pressure Issue
- Burning Oil at Idle
- TRansmission lines. Need help.
- Eshaust and cia
- need help finding long arms
- no start condition
- difference in v10s
- front end issues
- grille guard
- Fake chrome is bubling/flaking off of grille.
- transmission swap will it work?
- biggest size tires on stock 01 Sport Off-Road??
- P0305 code every now and then??
- Front dana 60 question
- air gap + throttle body advice
- Slow pick up.
- tranny problems / shifting problems
- SCT cable question
- 96 ram fail to start
- Seat Belt Retracted and Fuses Blown
- Doetsch Shocks
- c-code list?
- 96 1500 front coil swap
- vibration at highway speed
- 96 wont crank after fuel pump change
- The 2nd Gen Suspension Thread
- Please help me .... Antifreeze leak coming from transmission housing???
- Fuel Gauge not working.
- starter issues
- Home made Steps / Runnin Boards?
- multi spark ignition box.
- high idle problem
- leveling kits
- Trouble shifting after pulling out
- Heat works only on the 2 high positions... Why?
- Vibration/grinding sound from front end at high speeds???
- dumb lug nut question
- Omg my axles
- E fan wiring HELP Im an IDIOT
- which timing chain ?
- Need Advice whether to buy or not
- Few Ques.
- temp gauge help on 97 ram
- engine dies when trying to idle or coming to a stop when still in drive
- What is making this squeal sound?
- Is the electric fan suppose to turn on when you turn the a/c on ?
- how do i do the spark plug defouler trick???
- Possible heater core problem
- electrical problems, charging, computer
- E fan set up
- 97 ram transmission problems?
- Gears.
- Driver side headlight
- Hard to start after sitting for a couple hours
- Cracked Head (possibly both)
- swapped 360
- do they make a chip for my truck?
- Front Bumper
- cooling fan question.
- Engine miss/tune up
- Plenum Gasket years?
- belt Squealing
- Starting problems...stumped
- Please help!! Heat wont work!!
- Alternator going, going...gone?
- BONDO and PAINT!?
- Hubs!!
- e-fan install
- steering gear woes... wrong pitman arm on my truck?
- got new fork shoes
- Bad PCM???????????
- Transmission year of manufacture?
- hmmm
- what would these be off of???
- 14x3 ?
- Cold start problems!!
- Water on the floor board!!!
- Voltage regulator?
- remove lift or change gears for improved milage
- what transmission do i have?
- sport or off-road
- I'm stumped - coolant leak
- Who makes the best front hub bearings?
- Quick trip back to Square 1: Engine oil loss, smell of oil burning, oil in exhaust?
- coolant Drips
- Weird cooling issue, what do you guys think?
- Purchasing Ball Joints
- Heavier duty coils for plowing
- Anyone have a pic of the firing order for the dist. cap
- Randomly shutsoff?
- When adjusting the tv cable how do you know if the tv body is closed ?
- Random Stalling
- replace the rocker arms
- Heater/Ac/Radio/Power Window Problems
- weird vibration in 4X4
- how do i know if my transfer case is bad
- Major truck problems!
- 4th gen rims ?
- Problems on a 95.... And stumped....
- still burning oil after plenum fix
- who has the cheapest posi-lok
- Anyone know of compatible suspention lifts for "offroad" model rams?
- V 10 oil pressure
- Fuel Pressure Gauge
- Motor wont start if Temp is below 40F°
- Truck misfires after snowstorm???
- Fuel sync tool.
- Pricing is Irrational- be sure to price things out!
- Random Shifting and Stalling
- Wipers Stopped Working
- 4WD Cuts Out While Driving!!!! HELP!!
- Black smoke
- Window sticker for 1996 Indy Truck
- just ordered a few things
- Deep snow + 4WD = SCARY NOISE!!!!!
- someone with 33s on stock wheels?
- PLEASE HELP! Unique Transfer Case Problem!
- power seat
- 4wd fixed..... kinda
- Truck almost stalled in 4WD in a harder right turn???
- Help seat stuck
- i hate my 4wd i give up!!!!!!!!!
- Gas Mileage Help
- Lighting..
- Cracked Dashboard..HELP
- 97 5.9 cam suggestions?
- 2001 Starts sometimes
- whats under 4wd shifter boot
- Lift question....
- What all should I replace when doing plenum / timing set?
- Abs/ Brake Light
- HID Kit MOD Dodge Ram
- 2000 dodge ram cummins Question
- help
- Axle seal name
- 1500 Ram Lift Question! HELP!
- 01 brake fluid gushing from above axle looking for part list
- Help..radio info
- Transmission and Door Hinge Pins HELP!
- Need help with cab lights
- help with 96 1500 transmission woes!
- Would you guys downgrade to upgrade?
- Rattle/Ping at high RPM's
- Misfiring Problem
- Beefing up spring load capacity of 1/2 ton springs
- 3/4 ton d70 drum to disk
- Stall and no shifting
- Parts List
- Door will not open GRR
- o2 sensor issues
- engine code p1756
- The Dreaded knock
- tired of scrapping ice off your window
- Speaker Ohm's ?
- Transmission adjustment?
- i dont think i have check valve
- 1999 dodge ram 1500 Sport 50,000miles
- New Mirrors
- Being Realistic
- New Doors
- Budget Lift
- No CEL when I turn on key/other issues
- Leaking Metering Valve (Brake System)
- ram . fuel ,spark, but will not fire
- Fastman & other mods..now no power..help
- 96 v8 cylinder 3 misfire
- 8.0L V10 Performance Parts
- Reflections on a 408 build.
- 97 5.9 360 - Power Steering Gear box - Adjuster Screw Leak
- Diff gear oil trend and question
- transmission part # questions.
- A 2008 SRT Hemi out of a Charger
- brights problem
- Any way to check?
- washer fluid
- 2500 2wd v10 oil seepage
- P0308 (Cylnder 8 Misfire Detected)
