View Full Version : 2nd Gen Ram Tech
- They tried to steal my fuggin' truck!
- AC Clutch Not Moving Even After Direct Jumping
- Cab mount break/cargo light
- recommendations for brand of spark plug wires
- Front bumper cover
- 2001 dodge 1500 5.2
- Loud startup noise
- Transmission fluid dipstick
- Transmission going out?
- 99 Ram 1500 starts and dies almost immediately
- Transfer case vacuum line placement?
- 2001 2500 V10 slow to move no power
- 2wd-4wd conversion
- Trans keeps ruining fluid
- 1999 Dodge RAM 2500 5.9l V-8 FI 4x4 - Questions...
- 2001 3500 4wh dr clutch issues
- Unrelenting P0441 code.
- Rebuilt Motor Knock
- Hemi VS Magnum
- Dichotomous key or other to pinpoint/diagnose steering/suspension/drivetrain noise?
- 1994 RAM 1500 5.9L backfire through intake
- 2001 Ram 1500 3.9 Fuel Gauge Issue
- Load sensing prop valve?
- Bellhousing Bolts
- Broken camshaft sensor
- Distributor cap n rotor
- Out of ideas: electrical issues
- 1995 1500 will not start
- Engine ticking noise
- Suicide Doors
- "99" Ram 1500 5.9 46RE tranny govenor kit
- Engine Swap
- cab swap
- Are all 360s the same?
- Tuning on a 2nd gen?
- ongoing stereo issue
- Nv3500 clutch
- ABS light. Emergency light and no cruise control
- Emergency Brake not working
- 2000 to 99
- Need ideas for stock truck
- Coolant leaking in the center of the water pump
- Rear pinion seal
- A possible project.
- Fog light wiring
- Dana 44 axel seal question
- Resistance of New Spark Plugs?
- Hemi swap because cool
- 2001 Ram 1500 Electrical issue
- Camshaft Upgrade
- After Market fuel regulator and fuel rails
- Ac control for efan.
- Rear main seal
- P1756 code I think
- How to tell 42 from 46 RH transmission
- 1997 Dodge Ram 1500 Low Pressure Service port
- Copper Heater Core
- I have a 1998 1500 4x4 with a 318 the other day out of the blue my transmission just
- Shaking and noise above 2nd gear
- AC Evaporator
- Please help… Steering column mounting
- Trans/T Case Clunk
- Towing with 1997 5.2 extended cab
- Acceleration Issues
- 97 Dodge Ram 1500 laramie 5.2l magnum
- LED Headlights
- AC Accumulators
- Electric water pump
- Factory tow hooks
- Need help
- Adding Oil to AC System
- 1995 ram 1500 stays in drive till turned off
- Has anyone pulled the bumper cover off the metal skeleton on a Sport?
- Transmission is a pain
- Interior Parts Questions
- 5 lug ifs to 8 lug ifs
- Ram shifting issues
- P0753 3-4 shift solenoid
- Trans Cooler Line Lower Radiator Fitting
- What trans comes in a 1998 dodge ram 1500
- 3-4 accumulator piston and spring
- 95 Ram v10 running rough
- 2000 r46re forward direct cluch problems
- 46RE o/d and trans temp
- Is this brake crossover important?
- Speed shifting for 1000 miles?
- Brake proportioning valve 2001 Ram
- 44RE 4WD to 2WD
- 98 dodge ram 1500 5.2 liter crank no start
- 99 1500 5.2L - Pulled wrong bolt removing PS, now won’t reseat
- Front brake nipples.
- What is to the left of the Distributor
- Rear end swap
- Help with dash replacement - Plug Identification
- 96 ram 5.2 won't switch from ac to heater
- Strange chirp Noise
- 96 V10 Fuel Pressures
- Will a 99 46re work in 2000 ram1500
- Failed rear bed side support
- Stock track bar replacement
- What's this supposed to connect to??
- 46RE late shift after overhaul
- Rats ate my 2001 Dodge Ram wiring
- New clutch and transmission
- Another 46re crap show thread....
- Tranny rebuild that'll actually last?
- Parts for my old reliable? 2000 5.2 1500 4x4
- No odometer
- 46RE - possible electrical issue - I give up
- Air conditioner year ranges
- Mopar performance PCM p5249516
- Cutting out while driving
- !!!!!Help please!! Rough idle
- Can't Trust Parking Brake
- .25 Amp Draw
- Fuel injector connector issues
- V-10 to Cummins swap
- New transmission but still leaks
- Tranny and diff upgrades
- Nv3500 downshifting hard
- Magnum 360 Rocker Install
- If I'm using an air gap intake why do I need to keep my computer
- Ecm flash no communication
- 1998 Ram 2500 2wd
- Truck rarely starts fine and mostly starts really bad
- 1997 Ram stalls when going from Reverse to Drive
- ABS Light has come on (With odd effects accompanied)
- Tail lights
- Radio Not Working
- Operating temperature after 180 thermostat
- clicking from front passenger side axle
- 2001 Coolant Leak
- Are these acceptable temperatures for the A/C vents?
- melted next to blower unit
- 1500 ram charging issues
- 1996 2500 headlamps (high and low) not working
- Suspension Guru's needed !
- 1996 dodge ram 1500 4x4 crank no start
- Help. Transfer case.
- 2nd Gen gas tank conversion
- 99 46re won’t move
- Cold idle and sticky pedal
- head light relay issue
- T Case leaks onto drive shaft
- NP241DLD carnage
- Need Diagnosis Help, Or Even A Good Guess!
- My Ram wont stay running.
- Can loose rear bands cause line pressure issue?
- Rebuild suspension/steering question
- cranks - no spark - no codes - engine trouble lite on
- Biggest difference made with steering upgrades
- High idle after replacing IAC, will not reset
- Replacing the tie rods and ball joints
- Cold air door 1998 Ram 2500
- Trans fluid in overflow, AND engine compartment?
- 5th wheel towing with 360
- Running Tail lights not working
- 5.9 harmonic balancers
- Passenger brake light out
- Cowl Seals Part Search - Stumped!
- Are all magnum 5.9 oil pumps compatible
- Trans lever shift linkage
- Help !!! No heat.
- Heat pete!!!
- 97 ram 1500 fuel line leak at plastic fuel rail connection
- 5.9 gas thermostat housing
- Weird Temp fluctuation issue, need help
- Transmission slips
- Dumb q about 5.9 timing cover and wp
- No crank & 2 Possible Missing relays
- A/C charge pressures?
- 96 Dodge Ram 1500 won't stay running
- 98 1500 5.9l auto brake pedal stuck down
- 1997 Ram No Heat
- 97 Dodge Ram 1500 paint job cost
- 360 or 318 for High Horsepower build
- V10 Transmission
- 97 Ram 1500 gear indicator/shift lever won’t go into park fully
- Grounding problem?
- Can't find 98 ram, 5.9, 360 intake manifold
- Slightly bigger cam in a 1995 with OBD1
- 94 1500 4spd auto stuck in first
- Trans codes trigger BRAKE and ABS lights?
- Air Bag Suspension
- STILL no heat. Please HELP
- 2001 dodge ram p0735
- 5.2L magnum 318 in my 99 Ram 1500 4x4 rear main seal leaking
- How much PAG oil do I add to a new compressor, and system?
- 5.7 Hemi in a 99 Ram 4x4
- Turning trouble
- egr valve
- 2001 dodge ram v6
- 5.9 magnum too cold
- Windshield wiper issues
- 97 dodge ram 1500 5.9L STALLS
- Engine not getting up to temp, but heat in cab works
- Death Flash
- Are the kegger intake manifolds the same for a 5.2 and 5.9 motor?
- 94 5.9 motor and trans swap to 02 ram help
- Injector recommendations?
- No 1st gear
- What are the odds?
- Magnum Heads
- CEL After High RPM due to not shifting correctly
- Idle air controller?
- Bucking on highway 40mph, CEL always illuminated pulled codes p300 through p308
- Clunking noise while driving in 4wd hi
- Throttle linkage stuck WOT?
- Only front brakes are working
- 2001 Ram 2500 Rear End Brakes
- No heat blowing when on the road?
- 2nd gen headlights
- So done:
- Truck turns over but wont fire.
- exhaust hangers?
- Engine Bearing Type
- 2nd gen 24v swap into 3rd gen hemi ( both 1 tons )
- 2001 Dodge 5.2 crankshaft front oil seal
- 5.9L Magnum 360 with 5.2L Cam
- 46re still not shifting quite right
- Tone ring sensor retention, 9.25
- Rain Guards for Quad Cabs??
- Charging issue
- Aftermarket Gauges for my V10 Swap
- Need some help fellas(5.9 V8)
- 1997 Dodge Ram 3500 front differential CAB problems
- 97' Ram 5.9 Laramie Slipping Transmission
- Leveling a 2wd
- Lights
- Flashed Computers and SMOG
- 1500 to 2500 t-case swap
- Too much oil?
- Too much oil?
- 1999 Ram 1500 Help P1391
- Alternator/wiring problem?
- Keyless entry and remote start
- 5.2 L motor swap
- Technical Service Bulletins ??
- using laptop as OBD-II
- Dome Lights and Door Sensors
- 46re oil pressure PSI
- Water coolant gauge / coolant tempature
- V10 cooling
- Shorty Headerrs
- 1999 Ram 1500 electrical problems
- Dumb question
- Trans Replacement/Upgrade 1997 Cummings
- Wild idle issue
- 46RE shift problems
