View Full Version : 2nd Gen Ram Tech
- Truck dies but no codes found
- How to reprogram the ECU for true dual exhaust
- the burning rom
- Shock Question?
- SMOKIN NEED HELP
- Catalytic Converter – Inlet/Outlet Temperatures
- Front hubs
- New noises upon startup.......FIXED!!
- 1998 Ram Exhaust Question
- Trouble with my 2001 Ram truck
- well crap.
- Fuel Injectors
- Fog/ Driving light switch location
- OEM cd radio am works ----fm not a bit
- transmission went out on my 96 3500 deisel
- '96 2500 V-10
- 98 Ram 1500 5.2 V8 Gas Mileage?
- Should have got Gibsons…
- Wipers...again
- Cutting 2500 Rotors/hub bearing
- pics of side exhaust
- truck tool box suggestions
- ? about 99-02 cab lights
- steering box wo's
- think im sellin my truck
- Where Can i Find..
- Overheating when towing
- New owner, saying hey and two questions
- What the????
- Congrads SHOTT'S!!!!!!!!!!
- What size engine do the new fords have?
- Pinion shaft lock size
- Leveling kits
- what, $7900 isnt a STEAL?
- What size pipe for CAI?
- MOVED: Banks PowerPack TLC System 5.9L Diesel
- Magnaflow Catalytic Converter
- MOVED: MANY QUESTIONS NEED ANSWERS
- A/C help- Montgomery, AL
- Brake System Flush
- MSD, Accel, Jacobs, or Taylor
- amp and subs installed.
- Fram Boost vs. K&N FIPK Gen II
- additives/cleaners
- PROBLEM RAM!!!!!!
- Throttle Bodies
- squishy brake pedal
- Leaks...
- spark plug heat ranges
- ODD AC Question.
- MANY QUESTIONS NEED ANSWERS
- [ebay] - 1999 5.9L Mopar Performance PCM - CHEAP!
- 2500 & 3500 Owners, Brake Upgrade Info!
- Best Performance
- Burnt it up
- Hi all Newbie to the site
- 4wd indication light
- looky what i got
- Cat
- 97 360 engine missing issues!
- Body lifts?
- Ram overhead console wire harness (home link)
- engine Temp
- re: Brake Booster
- Help With Weedeater
- Possible Tranny Problem - Hi from a New Guy
- tonno cover
- quad door not working
- have a 94 ram 2500 V10 with no seat belt dinger...............
- Funny noise - brake cable??
- Dodge Ram 4x4 v10 need help please!
- Weird exhaust note
- 360 engine swap
- Traded the truck so I guess it's goodbye
- tires?????
- electricized rear windows..
- 1994 2500 5.9l 360 trouble
- steering wheel radio controls, has anyone ever...
- Leakage
- 4X4 Shifting Operation - Need some basic info!
- tailgate plastic
- A/C and check engine light
- Stock Intake Manifold... what years will work?
- Part Number for Truck Plugs
- Best Mods for your buck
- bubbles on auto tranny dipstick ?
- Battery
- noobie needing help with ideas...
- New Light Strip
- Blinkers turn on but dont blink, why?
- Wiper arm removal
- at a loss guys?????
- ebay lift
- wide tires
- Light Bulb
- water in axle?..
- BREAKS
- headlight switch diagram (headlight wire color)
- Front end noise..
- Wheelbase
- Opinions...1994 Ram
- Re-gearing
- Idle sensor and Headlights
- A/C not working right
- I bought a Ram!
- Nerf Bars for Club Cab...
- rear diff and front diff
- tires and wheels
- Need Exhaust Advice
- PLEASE PLEASE HELP
- Well it wet out todat Tranny
- Tranny question-weird shifting?
- Might really leave...
- '01 Ram Speedo
- another torque converter
- can any body help
- Fogged up headlights?
- Tires
- suspension ideas/questions
- Wheel Size
- Trans Go good or bad
- Wrecked!!!
- DIY window tint
- Installing Balancer on the 5.9
- Tranny synthetic oil
- Try and figure this one out....(Tranny)
- noise problem
- Noobie Questions...
- attn habeba86, speaker question
- lookie what is waiting for me back home!
- bottom rust on door
- weird bumping under passenger floor board
- New Guy
- Spark plugs.
- Exhaust Tips
- Distributor Cap
- Quick question: re: tune up
- upgrades
- I Need Some Ideas!
- 2004 dodge ram 20" wheels on a 1998 dodge ram
- Tranny noise
- U joints
- '01 Ram Headlight Switch dash light
- Header "tick".... normal or leak?
- Front Crank Oil Seal
- rearend problems
- New stickied thread
- 46re tranny ?
- Towing Torque
- suspension advice(please)
- Goodbye Dodge Ram!!!
- Transgo
- looking for black simple rims..
- Tranny - Grinding
- ignition/transmission problem
- July Ride of the Month Voting!!!
- i got a good one for everyone
- time to vote for shotts *** VOTE NOW***
- Camshaft and intake manifold ?
- where'd my tires go?
- Deal for Steelers & bike fans
- '96 5.9 waterpump
- newbie!
- pastfast125 - R U still around?
- posted it on ebay.... ad look ok??
- 2500 V10 cat back exhaust help!!!
- 1997 cummins electrical problem
- removing "ram 1500" emblems from doors...
- performance intake manifolds
- just bought my first dodge
- Stumped on engine performance
- What the...?
- Got an idea and wanted to see what you guys think...
- Werid starting question
- pics of the truck
- mismatched years, your thoughts
- last 8 of the vin
- suspension lift question any Ideas
- 96 Ram 1500.Pulled codes,PO711 and 783 Trans Codes??
- Tire Ideas
- Automatic transmission swap
- very strange thing happened today
- Wheel rubbing on lower control arm? Please Help!
- [EBAY] 1996 Mopar Performance PCM 5.9 AUTO
- Dumb Alternator Question
- Torque Converter ?????
- Pulling at straws?
- Help with A/C problem
- Cracked Instrument Panel Cover
- Rear speaker?
- weid buzzing
- Intake manifold
- Lack of Power???
- MOVED: "95 Cummins won't start hot
- Dual Steering Stabilizer Dodge Ram 1500
- Aftermarket Stereo Help!
- Timing Chain Replacement
- Oil Consumption
- Noise from under Tcase shifter boot?Common??
- Voltage going into crank sensor (dim light)
- Urgent Help!!!
- Replace rusted rear bumper or roll pan???
- [ebay] 94-95 Mopar Performance PCM 5.9 *CHEAP*
- Bull bar installed
- my baby is sold...
- sloppy steering
- headlight switch...
- Tire size?
- autometer gauges and a piller pod
- New DT trackbar/ steering wheel issues
- Wondering??? New 3 gen Gauges on 2nd gen truck???
- Best Mods for a 99 RAM
- stupid question...i know
- seafoam usage
- Rear Window Graphics
- Purge Flow Fault ----Please advise
- Dually tires with 4.5" spacer lift
- K&N CAI or TOP MOUNT ELEMENT?
- Frame Bolts replaced for Running Boards
- 4.56 gears installed
- Tread peeling on running bars???
- Surging/Bucking while driving
- New Owner Need Advice
- to hell with mud i say bring on the POLLEN!!!
- damage to clear coat
- Fog Lights?
- I found my Roll Bar/Light Bar!
- Electrical problem !!
- Thought I had a big problem with the Ram
- new step bars check em' out
- Overhead Console
- Getting high flow cat with Hypertech
- HEMI HEADS FOR MY 360 MAGNUM
- 1/2 to 3/4 ton question
- TV cable
- Tie rods
- Old school needs help
- Engine Mods For 95 ram?
- vacumm lines on t-case pics inside
- Help me diagnose my problem (possibly plenum)
- i got a question
- redoing exhaust
- MOTOR RATTLES WHILE TOWING UP HILL AROUND 2800 RPM?
- Tranny Compatability?
- need rebuilt transmission
- Misfire on #5
- Call for help - cruise control not shifting down
- air gate
- Who's making a good front brake pad
