View Full Version : 2nd Gen Ram Tech
- 2000 Ram 1500 Trans Problems
- High beam indicator not turning on.
- Truck Slow to Rev in 2nd Under Load
- 1996 dodge 1500 won't go into gear
- Light misfire may be affected transmission
- 2001 Dodge Grinding at 40-45 light acceleration
- Transmission help
- 1999 dodge ram 2500 2wd
- Complete rebuild no low rpm power
- NP231D shim (bonded) gasket
- Rear gear oil question
- Cool spring advice
- 1994 Fuel Tank Configuration - Pump or no Pump?
- No signal to one coil
- Engine revs with little movement after starting in drive
- Retrofit Overhead Console Computer
- 94 1500 Brake Issues
- Rebuilt transmission brands
- Front Axle Harness vacuum supply location
- Coolant Leak
- 2nd gen engine and tranny swap help
- Suspension hitting hard
- Will not shift out of park on incline
- Shaky and high idle
- high idle problem after alter replacement.
- 2nd gen ram 1500 RWD suspension repair
- Cylinder 8 Misfire
- Need MC adapter/spacer plate
- 360 build with MSD 6AL
- Smart Control Automotive Grade Linux / Android Auto
- Major tuneup
- 98 5.9l 4x4 rebuild kit
- Np241 swap in 1500?
- 98 ram wont move in R, D, 2 or 1st
- Alignment on a ram 2500
- 1996 Ram 1500 Damaged Crossover tube
- 1997 1500 control arms
- Fuel pump psi 97 ram 150”
- Coolant system bleeding problem
- Engine bay cleanup
- Interior upgrade issues
- Brand New Used Dodge Ram (2nd Gen) Introduction
- Installed a new fuel pump and truck is throwing a bunch of codes and won’t crank
- Bad Clockspring?
- Truck stalling with no bus error
- Front wheel issues
- Seemed fine yesterday then no start this morning and 5 codes. 95 obd1
- 2001 Ram 2500 - Hanger bearing fail - dies & won't start
- Fuel Pump will NOT turn on
- Speedo signals
- 1500 Suspension swap
- PCM A/C Clutch Relay Control
- Vehicle stalls
- Dash
- 96 Ram 1500 - Needs new engine
- No Power to ignition switch
- 4x4 swapping 1996 Cummins
- 99-01 Cab swap question
- Voltage regulator
- Vacuum/evap leak, engine sluggish after fresh rebuild.
- Help battery gauge quits working and check gauges pops up
- Headlights
- Fuel injector cleaning and filter question
- I now have a 2500
- Transmission problems
- Help. Cuts off.
- rear drive shaft
- 16k Warn
- 1996 ram 1500 4x4 5.2
- front shocks
- Fuel pump relay hot
- A/c fan stops blowing at highway speeds.
- Trying to fix my 'stock' radio. Do these exist?
- ABS and Brake light on
- 46re trans removal questions
- 98 Ram 1500 remote start alarm and brake controller install
- 98 1500 5.9l gasser knocking only on start up
- Odd steering problems (all new parts)
- Drive train binding 4WD
- Transmission code P0740
- Cold start knock in early morning only
- Brake warning light comes on intermittently - how to troubleshoot?
- Nitrous on 360
- 5.9 tuning/tuner?
- Scanning for Cruise Control Issues
- 1994 Transmission rebuild
- Steering Wheel Stereo Controls Retrofit
- Parasitic battery drain and engine stalling
- Resource for replacement transmission
- Loose steering/ a lot of play in steering wheel
- 1994 Transmission problem?!
- Major tune up.
- Transmission look up Help!
- Overheating.
- Using Chat GPT to trouble shoot
- Oil Dipstick Tube
- Boost Sensor Question
- Rear Main Seal 1999 1500 5.2
- Misfire
- ECM or PCM issue
- Re-use shocks with leveling kit?
- Help with a short
- Any clue where this goes?
- Snorkels? diesel 3500
- 46re 4x4 trans re build
- Throwing Parts At It
- 5 inch long arm lift
- Power steering pump
- Coolant sensors
- 5in lift cab and chassis
- 1999 Dodge Ram 1500 Help please
- Loose fit on air intake box
- 1999 5.9L transmission downshifting
- Dodge ram 2nd gen weird transmission issue!
- Differential clutch packs
- 1996 Ram 1500 with a 2000 engine. Way to make temp gauge work?
- Front end issue(steering)
- 2000 dodge ram no start
- 46RE transmission shift question
- 46re Won't shift
- 1998 dodge ram 2500 4x4 4.9L magnum
- Rear Doors Compatibility
- 1996 12 valve brake lights
- 95’ 2500 instrument cluster not working
- 47re code P0743 no drive or reverse
- Brake shoes rubbing
- 2002 Dodge Ram 1500 SLT issues
- A/C Issues
- 1997 dodge 1500 brake upgrade to 2500
- Need help! No compression on one side of engine
- hot air leaking around heater core, defeating AC
- 1997 dodge Ram 1500 4x4 u joint
- Interior question
- Howling sound when accelerating
- Are wide rims, ~4.75" backspace, as hard on balljoints and wheel bearings as spacers?
- Torque converter not locking up.
- Any Body Shop techs here?
- front end 'popping' and mysterious rough idling..
- Code p1391 after 5.9 rebuild
- 97 Ram 1500 4x4 5.2 L automatic delayed shifting
- Swapped a 98 5.9 Mag into my 95 2500 4X4 -- Backfires
- Tow haul button fizzled
- mirror unstable
- 1996 Ram 1500 Fuel Tank Pressurizing While Sitting
- Do I need a new water pump?
- Truck is too loud. Exhaust Suggestions?
- Left front signal light stays on dim in my dash and out front without being turned on
- What's the Wire from fuse box to starter called
- 1998 dodge ram 2500 5.9L V8 4x4
- Up and down wobble in the back end of truck
- 47 re transmission help
- 47re transmission
- Rough Idle issue
- Transmission thumping/sticking/No 4th gear?
- Trouble Code P0133
- Engine running hot but not overheating
- Fuel Pressure Regulator- 1997 5.2L
- Recommendations Needed
- 5.2 heads/ parts on 5.9l block?
- Water swooshing noise on startup
- 1995 Ram 1500 Front Axle Control arm Mounts
- Coil spring pocket.
- 5.9 rebuild question
- 1995 Ram 1500 4x4 ABS & BRAKE LIGHT ON. AND CRUISE CONTROL
- Weird on and off metal scraping noise
- Clunking and Noises
- New transmission 46re needed and installed
- Retaining clip for governor pressure sensor - 46re
- 2002 Dodge Ram 2500 5.9l magnum drivers side headers glowing HELP!!!
- Transmission Pan Torque specs
- New Top End or Long Block?
- Transfer case won't engage 2wd
- brake wear issues
- Transmission swap
- 1998 2wd 1500 - HVAC vacuum supply routing
- Shifter issue
- Suggested stereo replacement for '94?
- Can anyone tell me what these wires are for?
- Pulling my hair out with a brake issue
- Intermittent Growling Noise
- Is there a spot to test oil pressure on the 318?
- 245/75R16 to 275/60R20
- IAT Relocation
- Passenger side hinge bolt Hellpppppp!
- Differential help
- Oil pump Prime?
- Clip, what kind? For cupholder reinstallation.
- No throttle mystery. 99 Cummins 5.9.
- 46RE leak
- Solid roller lifters for 5.9 magnum
- V10 guys I need help
- ECM break down
- o2 Sensor brand question
- Trying to locate Mopar 5015135ABSuspension Knuckle Front Left
- Drivetrain issues?
- Engine is running rich
- No turbo whistle
- Torque converter problems (maybe)
- 2002 Dodge single cab cab mounts supplier?
- Help please 1995 ram 1500 4x4 5.9
- 94' 1500 Intermediate steering shaft seized
- Hey everyone have an issue with a 97 ram 1500
- ABS question 2001 5.9 2500 pick up
- Can you install Gen 4 Grille Guard on Gen 2?
- 2nd gen running right-ish but idle?
- Lifting Engine
- Transmission issues
- Vacuum leak
- Vehicle Signature Please
- Does anyone know if a 3rd gen brake light will fit a 2nd gen truck?
- 99 ram 1500 third tail on cab having issues
- 2001 dodge 1500 4x4 w/ABS question
- AC design question
- 5.2 uogrades
- Crank, No start, No spark, Gets Fuel, No Coms
- Did engine swap from 98 jeep grand Cherokee to Dodge ram 1500
- Need motor help
- Frame rust
- Gatragjerry
- 4wd light/engagement mystery
- NV3500 to NV4500 or Tremec TR4050
- 1994 A518 transmission cavitated and lost all motion
- generic part replacement brands
- New thread trans help
- 99 Ram engine issues
- Dash Illumination No Longer Working After Radio Short-circuit
- Lots of carbon.
- Fuel pump issues 97' 1500 Long Bed
- 2500 Lowering
- Plenum repair parts source
- Overdrive!....
- Injector issues?
- If It's Not 8 Things, It's Another 3
- OD is Slipping/Shuddering
- Headlight switch knob removal
- 96 1500 Clockspring Replacement Recomendations
- 1999 1500 5.9 is dead please help!!!
- Looking for Nice exhaust not to loud but just perfect
- Engine direction advice
- 96 1500 Upstream 02 Sensor Question/Confirmation
- 46re valve body re build need help please
- Misfires after warming up. 2001 Ram 1500 2nd Gen
- 46re help needed
- 01 1500 Sport 5.2L 2WD
- 3rd gen 9.25 disc brake rear swap into a 2nd gen truck?
- Used diff
- Dodge things
- quad cab rear door hinge pins/bushings
- Emergency Brake Cable will not tighten
