View Full Version : 2nd Gen Ram Tech
- NewSpeakers
- 4wd indicator on, 4wd not working
- Fog Kit?
- Fan fixed but not fixed Really?
- Rear Axle Tag = 1885
- Front Shock Install with Pics
- throttle body spacer! pro's vs con's
- possible specialty tool loaner program
- Engine to cold fault
- Cruise control problems
- Gauges for Truck
- Exhaust man compatibility - LA 318 to 5.2 Magnum
- '96 PCM wiring - what is a trans output shaft speed sensor?
- 318 to a 360 computer swap
- Engine or Tranny pull
- hub assembly?
- knocking,pinging sound???
- Recall for hood latch?
- can i use a computer from a 97 dodge b2500 in my 01 ram 1500
- Repairing doors
- Exhaust upgrade, but not loud?
- Resale Value?
- '97 ram rearend
- 1997 steering case wandering.
- 97 Ram Transmission
- Anyone have h.i.d's here
- idle air speed p0505
- help....
- Weird noise
- Aftermarket Sport Headlight Housings?
- Help me troubleshoot - loose right front???
- Headlights
- Iron Ram Heads
- Does any one have this???
- In-dash touch-navigation for 2001 Ram 1500?
- Tires
- Power loss problem solved
- 01 ram computer monitors
- 1998 dodge ram 1500 van heat issues..
- Rear Block Question
- Temperature Questions..
- Starter Contact and Plunger Fixed.
- Trans fittment questions
- 318 vs 360 engine balance question
- 5.2L engine swap - regulated fuel rail?
- Tow mirrors
- PCV Valve Help ?????
- No build sheet for me.
- Fuel filler tube and pocket
- 8-10 mpg, REALLY????
- Burning OIL smell when driving with heat on, valve cover gasket?
- Sticking 4wd light
- 4X4 car wash
- tranny swap on a 95 now wont run
- changed oil. Gauges go nuts (vid attached)
- 2001 Ram 1500 with air and heater blend control issues.
- Carbon/charcoal in vaccum lines
- HELP!! Bogging issue when accelerating
- Cooling system leaks on 1997 Ram 2500
- Front Axle help
- 47RH Growling noise!! Cant figure it out after full rebuild!
- Pinion and Ring gear change
- Excited about a CEL!!!
- 318 to 360 swap..ideas please
- biggest tire on 3in lift
- ByeBye Dodge...Hello GMC!
- DIY Modified Throttle Body?
- no overdrive in 95 ram
- Grill Inserts
- OBD Software
- Thinking about buying 2002 RAM 2500 - thoughts?
- 4 wheel drive wont work
- Transmission fitment issues 46re
- Found this ad, Need help
- super dim headlights
- 1998 360 fuel pump, crank sensor?
- tranny wont shift right - vacuum problem?
- 2001 Ram 1500 5.2L 318 lifter noise / knocking / ticking?
- Please help!! 360 with lots of problems
- Rotor Button Help ASAP!!!!
- 46re?
- Need Help 96 ram 1500
- Steering wheel
- t-stat
- loss of spark after tranny swap
- Coolant!!
- Headlight Restoration
- transmission help
- Putting in my pulleys
- Oil Pressure Oddities.
- Idle all over the board
- Reverse issue
- idle air control motor ?
- Replacement sunvisors?
- seal kits?
- Clicking sound
- Please Help me with my electrical issues
- How to "draw vacuum" for a/c system
- P0455-evap !!!!
- Blower fan works when wants too!
- dodge diesel fuel gauge not accurate
- Idler Arm Crap-Fest
- '94 with a Rough Idle
- 94 ram steering
- transfer case options
- front end noise and vibration
- Missing coolant?
- When truck gets warm won't idle
- E15 Gas
- Grinding noise?
- diagnosing my fuel guage (help me out)
- How to fix my low idle
- harland sharp 1.7 any dyno chart
- SCT question
- Did the plenum finally
- vacuum hoses
- Truck Dies every 300 miles Help!!!
- Projector headlights without HIDs?
- stuck key
- Back Up Lights
- Noise in the rear
- Super bright blue head lights. Any suggestions?
- wont crank help
- Something unplugged
- Cam into a 97 360
- Instrument cluster
- 46re troubles
- 5.9 z vin ignition/ missing
- 1997 Dodge Ram 1500 Transmission Shift Problems!!!
- Starter Mods
- remote start
- New guy 1999 Dodge Ram 1500
- 1996 dodge ram problems
- idle and cruising rpm
- won't start code P1389
- A/C sense Circuit or PCM issue
- Service Dept Pricing
- Getting starter Armature inside brushes trick??
- Put in heater core now my headlights don't work.
- New to me Ram and I'm pretty happy
- Tow Mirror Mounting
- Checked the light code.....
- Leaf springs broke
- New tires, can I fit a 35 on?
- back up lights don't work
- '99' 1500 billowing white smoke
- Installing chip
- blower motor stays on when ignition is off!
- Possible Air In the Steering gear lines
- Do all 94-01 (2nd gen) Rams have the same fenders 100%?
- Intake replacement
- rear tire/wheel play....
- Pistons with HS 1.7's?
- intake mod Kegger
- Stupid Q's but can you sell tuners
- who has had success with e3's
- Couple water pump questions...
- 1997 Dodge Ram 1500 - Need Help
- Oil Sending Unit Replacement
- ABS issues (rear hub??)
- I need help on what to do please!
- plenum and intake build questions???
- Ok need help lol brake lights
- 5.9 rebuild installing oil pump D shaft
- Cold Weather Operations
- 1998 dodge ram 1500 v8 wont stay running
- 94 ram loss of power
- 98 Re-badge
- towed a 3500 ford four door dually 4x4 this morning
- 4x4 vacuum lines
- Rear Speaker ?
- Electrical guys...ambient outside air temp. sensor electrical question...
- HELP 4X4 axle problems
- posi lok
- 94 Ram 1500 Crankcase fills up
- 47rh trans problem
- How strong is the glass in our trucks?
- Jerky Front End
- I can't leave well enough alone..
- B&G flash suggestions based on my specs. need help
- Select Trac 4x4 Ram?
- *Just Released* New Tire Sizes for Nitto Trail Grappler® M/T
- 5.2 that doesnt warm up
- Caliper Locked up
- transfer case whine
- 8" lift questions
- Different Intakes.. question for 'yall...
- 98 Ram questions
- Do you know why....
- 94 1500 trans swap rh to re?
- loud high pitch hum/whine coming from under the hood
- Where are the head light relays
- Cab air temp control
- I need a real dodge guru PCM TWEAKING ?
- Engine stalling at speed
- Hello Guys - Newbie here with questions....
- '98 Ram wont idle
- Low end power ?
- how to remove transmission cooling lines?
- Check eng light/ABS
- Transmission issues?
- 95 1500 power loss
- Exhaust, X pipe possible?
- '94 Ram 5.2 Not Starting
- abs light
- Differential Noise...Maybe?
- Volt gauge reading high
- hop hop hop
- I broke the PRNDL gear selector cable adjuster...
- rearend
- CB antenna mounting ideas
- Heat problems
- Quick question
- need help
- Please help! No heat
- ball joint size
- 4 cracked heads WTF
- help help...truck wont start in the cold weather
- The beast is TOO LOUD!!
- '97 Ram Overdrive turned off by itself???
- Need help finding this !!
- Still Having Battery/Charging Issues
- very high idle when cooler or cold outside??
- Finished my Dana 60 Swap
- Illegal Intake, Trying to smog, have stock parts but ?? (+pics)
- Ram Air Intake requires tuning?
- cruise control light........
- 4x4 Problems
- Hughes Air Gap FI/California smog question
- Intake torque? Use spacer?
- 4WD drive goes on and off when in 2WD
- cold weather and door latches
- wheel sizing
- 4wd not staying engaged
- click click , tick tick.
- Steering Column Lock Washer
- programmer tuner chip anything?
- driving problems? please help few question
- Should I use 87, 89 or 93 octane on my 5.9l?
- will a motor from a 99 1500 fit an 01 directly?
- My ram
- Transmission line
- Aftermarket headlights
- New pads/rotors, new noise
- 4x4 transfer case tranny ???
- drum brake advice
- intake ?
- Post your gas savers addons
- brake question?
- transmission stuck in first
