PDA
View Full Version : 2nd Gen Neon
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. Can I drive my Neon 2005 with the engine light on from a P0344 and P0340 engine code?
  2. Different Crash Bar?
  3. new to this
  4. My 03" SXT neon shut down and won't start.
  5. Please help !!
  6. Problems with manual Tranny
  7. 2004 dodge neon
  8. 2nd Fender flares. Where?
  9. 2000 dodge neon, Rebuild or used motor? What is the best most affordable option?
  10. Top speed on a 2003 neon SXT manual
  11. 2000 dodge neon
  12. What is the top speed on a 2003 dodge neon SXTmanual?
  13. 2005 Dodge Neon Rear Camber Adjustment?
  14. P0522 after Water Pump install No Start!!
  15. Aftermarket automatic shifter install
  16. Neon speedometer intermittently functions
  17. Transmission Issue
  18. 2005 Neon transmission issue
  19. Does anybody know this part
  20. Excessive oil on cam position sensor
  21. insulation cracked/ injectors
  22. 2004 Dodge Neon Engine Light Code 2096
  23. ISO: Injector Cover
  24. back-up lights
  25. 2003 Neon cooling fans always on
  26. Need help with torque specs..
  27. New Mods
  28. 2002 dodge neon fog lights stuck on?
  29. 2003 Dodge Neon 2.0
  30. collector/restorer?
  31. 2005 Dodge Neon SXT Fuel Pump
  32. 2002 neon shuts off while driving
  33. neon cranks but wont start
  34. 2003 Neon SXT drive axle play, clunking
  35. wiper motor questions
  36. Need HELP 2004 Dodge Neon Problem
  37. Receiving 2074 error code
  38. 2.0 sohc dirt track question
  39. Camshaft and Crankshaft timing re-learn procedure
  40. Help with starter
  41. 05 neon won't go over 2000rpm without spurting
  42. 2010 avenger front end
  43. 05 Neon SXT A/T radiator
  44. 2005 Neon SXT, A/T, no start after weird situation
  45. 03 Neon SE- Hard downshift from 2-1 (Auto)
  46. 2005 Neon Died. Help?
  47. 02 dodge neon
  48. 2000 neon
  49. Had clutch changed now drivers side front clunk sound and wheel hop
  50. O4 dodge neon sxt... ticking/scraping noise from engine.
  51. 2003 Dodge Neon Temporary Rough idle on startup
  52. 05 Dodge Neon Vibrates when in idle and in gear
  53. 2000 Plymouth Neon transmission swap
  54. 2005 Dodge Neon
  55. 2003 Dodge Neon - Tips and Tricks for a Newbie
  56. 2003 dodge neon blinking check engine light
  57. low k 98 neon tick tock
  58. check engine light p0522 and p0304
  59. 2001 Neon, Remote fob locks but won't unlock doors
  60. cmshaft sensor torqueshaft position sensor?
  61. need help
  62. Need help with anti-theft lock out
  63. Noise under timing cover
  64. How do I remove the old upper strut mount
  65. To change or not to change
  66. reverse only on level or downhill surface
  67. 2005 Dodge Neon SXT
  68. 2000 dodge neon won't go into gear anymore
  69. 2000 Neon Shaking at start up
  70. '00-'02 Neon front bumper on '03-'05 Neon
  71. How do you test spark plug wires
  72. 2004 Neon won't start
  73. Transmission gone???
  74. Thanks you for help with my 05 neon timimg belt and head replacement
  75. Grinding tranny 5 speed no reverse no move
  76. 02 sensors need help
  77. Timing belt hangs off cam shaft sprocket
  78. 05 dodge neon, not sure the problem.
  79. 3.8L V6/41TE swap into 2002 Neon
  80. i'm lost no crank no start no click
  81. Major Evac issue
  82. 2005 neon 2.0 timing belt keeps walking off.
  83. 2000 Neon catalytic converter
  84. Positive Cable Hot
  85. Need info about motor mount bushing kit
  86. Running 5w20 or 5w30
  87. i have a 2004 dodge neon
  88. Shift Knob Removal
  89. Driveline Vibration When Turning Right
  90. How do you replace power steering belt
  91. Ok I need help troubleshooting my problem with 2000 dodge neon im stumped big time
  92. adjusting timing tensioner
  93. No compression ln cylinder 3 and codes p0300 and p0303
  94. ECU pinout
  95. Headers
  96. A/C Issue
  97. power steering pulley
  98. high idle and stalling
  99. problems with 2005 neon after tranny swap
  100. Squeeling clutch on 2002 5spd manual dodge neon
  101. 05 neon torque spec Automatic Tensioner Assembly 3 Bolts
  102. Ground green strap by starter see pic
  103. Three peice ground wire by ds strut connects where?
  104. Green wire by starter screws where exactly ?
  105. auto trans
  106. 2005 Neon Schematic Help ?
  107. dodge neon manifold actuator
  108. 2004 Neon Rear Bumper Problem
  109. 2003 dodge neon sxt dead
  110. 2003 dodge neon sxt dead
  111. Turn Signal Fuse blows when A/C is turned on
  112. 2003 dodge neon sx 2.0 transponder key programming not working
  113. First gen head swap
  114. I really love my 03 pls help
  115. 2003 Dodge Neon SXT
  116. Vacuum Hose?
  117. 2000 Neon A/C
  118. Can I do a compression test without the wiring connected?
  119. Check spring tang is within specification on tensioner??
  120. Hard Start & Rough Idle
  121. Should new timing belt idler pulley spin freely?
  122. Hs9036pt2 head gasket set parts list
  123. Spark plug Boot will not snap in all the way!
  124. Code P0340, replaced sensor, still wont start.
  125. which gasket to use on a decked head
  126. How to set timing on a new head
  127. head port and polish?
  128. Overheating issues
  129. installing a new head, do I need to add more oil ?
  130. 2005 Dodge Neon SXT
  131. timing belt whine
  132. Won't start again
  133. Dead cylinder
  134. 2000 dodge neon #3 cylinder misfire , engine hissing at tailpipe
  135. Help with High Idle - Motor swap
  136. 40TE Transmission Reliability?
  137. 2004 Neon SXT
  138. Dodge Neon 2000 138+miles oil light on at idle
  139. Neon will not idle
  140. neon wont start it only cranks
  141. need a fender motor mount
  142. 2005 NEON recently TOWED need help
  143. Found burnt exhaust valve, get a used head?
  144. Help with part identification please.
  145. 05 neon whats missing in my head gasket set?
  146. 05 neon striped timing tensioner allen wrench hole
  147. raditor fan ds not coming on. only redlines when ac is turned on
  148. 05 SXT Idle/Accel/Decel Issue
  149. 03 SXT missfire
  150. Wheel Stud Help!!
  151. '05 SXT Issues
  152. 05 neon limp mode when warm
  153. 2004 neon head valve cover!
  154. 2.0 SOHC Rocker Arms Noise
  155. 01 plymouth neon gas tank strap replacement question
  156. To buy or not to buy a 2003 Neon low miles with issue
  157. 2004 dodge neon srt-4 swap
  158. I'm new here an having problems with my 05 neon 2.0 Se
  159. 01 rt intake questions!!
  160. Release Cylinder vs Slave Cylinder
  161. Help! '05 neon bogging down. Cranks fine.
  162. 03 Neon Se strange problems
  163. Replace 02' Neon instrument cluster
  164. P0420 Code
  165. 2004 Neon SXT race worthy?
  166. 2005 Dodge Neon 2.0
  167. Bad Gas Mileage / Low RPM idle
  168. 2003 neon r/t transmission help
  169. R/T trans parts
  170. Bad pcm? Help
  171. Tire Tutoral By RMA
  172. Backfiring and loss of power
  173. Horn not working
  174. 2004 Dodge Neon SXT Clutch Pop/Snap
  175. 02 SXT Limp mode
  176. Rusty muffler clamp bolt removal
  177. ´95 Neon doesn´t start
  178. 2005 dodge neon Sxt
  179. Auto Tranny problem
  180. 05 Neon throttle "sticking"
  181. 2001 Dodge Neon
  182. Need help identifying
  183. 2002 neon R/T eating tires
  184. O4 neon st needs better mpg
  185. Motor dies when I remove the gas cap
  186. Anyone turbo the 2.0? Or any other performance mods
  187. i installed a pcm for my 03 dodge neon now it doesn't start
  188. Clicking from power steering pump.
  189. AC problem...quit working
  190. Car dies when brakes applied
  191. Steering pulling issues
  192. Starter bolt
  193. 05 neon
  194. strange hissing noise from passenger side airvent accompanied by stuttering and stall
  195. neon will not start
  196. Oil light/Check Engine light on, Crank won't turn manually, Oil Pressure problem?
  197. The Why For Molybdenum In Our Lubricants
  198. A Why For Boron In Our Engine Oil
  199. Loud buzzing noise-driver's side dash area
  200. 2003 dodge neon sxt odometer reads NO BUS
  201. Crazy question
  202. Dodge neon 2005sxt not moving on drive but engine is running.
  203. Changed transmission cooler lines and now there is a weird vacuum noise
  204. rough idle
  205. Crank no start problem!! Desperate need for help
  206. transmission is not going into higher gear when speed is higher mph
  207. Car RPM fluctuates and doesn’t go over 2000 when it’s on the freeway and. . .
  208. 2004 SX2.0 Sport Fuel problems , bad ground? help please.
  209. Need Help Please
  210. aftermarket exhaust
  211. Yet another issue with drivetrain
  212. How Water Affects Synthetic Lubricants
  213. 2000 neon Ignition key stuck
  214. How To Evaluate Oil Filters
  215. Automatic transmission solenoid pack gasket leak
  216. IAC screws worn and will not go back in tight
  217. 04 neon, idled rough, made loud pop sound
  218. idle dropping in traffic and spluttering and stalling
  219. CD player
  220. oil spill
  221. The Poor Mans Oil Analysis
  222. 2000 dodge neon engine light on
  223. 02 5peed Neon P0456
  224. 2000 neon no heat
  225. Vacuum leak
  226. HELP!! Dodge neon 05 sputtering when accelerating
  227. 2005 SXT Engine Interchange
  228. 2005 tranny cooling line problem
  229. 05 neon sxt rear drum to rotor swap
  230. Looking For Help
  231. 2000 Dodge Neon 2.0 L giving off 8 codes Please Help
  232. Clunking in rear passenger. (suspension or drum brake assembly?
  233. Vehicle Vibration Analysis Flow Chart
  234. How to read codes without a reader
  235. Battery Tutorial
  236. Dohc 1st gen to sohc 2nd gen.
  237. Timing belt and water pump replacement
  238. Serpentine belt tensioner problem
  239. Signal switch buzzing
  240. Coolant flush?
  241. Ugrading rims
  242. Gasoline White Paper
  243. Hood switch??
  244. Neutral without key
  245. 2005 sx 2.0 - 2k RPM limp mode occasionally..
  246. 2003 Neon parking light bulb replacement
  247. 2002 dodge neon turns over but wont start
  248. 2002 dodge neon fusebox diagram
  249. Spark Plug Mini Tutorial
  250. AAA Tests Top Tier & LAC Gasoline Engine Deposits
