- dash/stereo wiring diagram
- Avenger Idles but dies when given gas?
- shocks
- Brake balance issue
- Problems with the front suspension...again.
- Hello every1
- General Questions
- crank wont start no compression
- Car Hopping!!!
- Noise while accelerating 1998 avenger
- high idle
- Haqppy Birthday Silvercoupe 97
- My venge stuck in second, tips plz?
- Where is this leak coming from?
- Need New Hood !!!!
- Rack and Pinion
- Turn signal/light switch
- Major Avenger Project
- Aftermarket Oil caps...
- removing headlights?
- right front wheel bearing hub
- TB boring
- Multiple Cylinder Misfire
- Power windows stopped working. PLEASE HELP!!
- Over Heating
- EGR
- throttle body bore
- R&R front bumper
- a couple questions
- EGR Solenoid and EGR System fault
- interior lights not working
- 1995 avenger - CRUISE CONTROL NOT WORKING
- car alarm?
- 1995 Avenger
- 1995 Avenger
- ECLIPSE TALON DSM 4G63 PARTS questions
- Rough Idle
- Ignition coil replacement - 2000 venge ES
- Cruise Control problem
- Performance Chips
- Need Torque Specs FOr.......
- Help on 2.5 timing belt
- spare parts
- Which Decal?
- Blinkers
- Front noise from axle into transmission
- AC Problems
- battery light
- Exhaust question
- Hail Damage
- HID headlight bulbs
- 98 venge speakers
- Lost Serptie Belt
- BAD HAIL
- Rough idle, Stalls, Misfire
- new venge meat
- 1996 Avenger 2.0 Litre Oil Pan Replacement
- front hub [bearing] replacment
- bored throttle body?
- Spark Plugs & Wires
- Wheres the safest place to put jack stands..
- Backup light switch...??
- How the heck and wtf??
- Cv Joint Boot Install
- 96 I4 mtx swap
- Electrical Problems
- HELP! Engine bad idle, keeps dying
- best gas treatment?
- passenger fog light
- wires and plugs?
- glue like substance?
- Side Mirror Writing
- 1997 Avenger ES stock rims
- when do transmissions go out on these?
- AC problems!
- Removing Interior Trim Peices...Need Help!
- i have a question about these cars?
- 1995 Avenger Tranny Questions + Other Questions
- Water in fog light
- Car show Tips??
- Avenger sport low end?
- Windshield Wiper Arm Removal
- Transmission Cross-reference 1995 ES V6 AT
- 1999 Avenger Amp
- Car too low
- 1997 Avenger 2.0 Automatic Tranny Problems
- End of the line July 31st-2008
- touring wing
- HP Gain
- wants to run hot and crapy gas mileage
- 1996 dodge avenger 2.0L DOHC
- 6 speed manual transmission conversion
- fiberglass
- Delete
- Avenger eclipse
- Blinking ac light
- 98 avenger door lock probs
- 98 avenger wheels & tires
- wheel bearing
- Shutting off on highway and then restarting
- CV joint maybe???
- painting the decals of a 96 avenger
- Stock stereo...
- 95 avenger starts only when plugged in/warmed up
- 95 avenger 2.0 no start
- Car Revs Itself
- Tail light covers...
- Avengers back/ balljoints
- car alarm
- Finding after market exhast systems...
- Why my avenger radomly stops.
- oil pressure switch?
- How do i take my tweeters out?
- struts maybe?
- Car blown
- Windshield Washer Fluid light
- 2.4L pistons in 2.0L?
- Losing Gas
- 97+ headlight conversion
- Remote starter for 96 Avenger
- '97 Dodge Avenger ES: radiator fan stopped
- Front passenger side
- How hard is it to change a auto tranny filter?
- Avenger Front End Noise!
- 2.5 mateing to a standard trans
- P1391
- dual battery
- No Manual 6 cylinders?
- About to take a sledge..
- Jumping when pulling away
- avenger won't start
- Oil in my anti-freeze...help!
- 98 2.0L 4 Cyl / Valve Cover & Gasket
- WANTED: 5 speed car
- extending sideskirts
- Cyl 2 misfire p300 p302
- Windows rattling???
- Down pipe...or flex pipe size?
- Paint Code
- Fiberglass.....?
- eclipse/avenger interchangable
- yanckie
- car's dead somebody help figure out why
- My 2.0 97 Avenger is sick, and I need help
- front sound
- PCM question
- Power driver's seat
- Looking For A Few Things
- 95 Avenger, OBD Scan Tools, etc.
- Where can I find some POWER???
- Bumper Issues
- Front Bumper Removal
- Misc Parts
- just a few issues..
- Harmonic Balancer removal
- front wheel bearing hub assembly
- 99 avenger limp mode
- venge intake
- fusible links?
- Aftermarket radio w/ factory amplifier
- Bad Brakes?
- update...Bad Venge please read....
- 95 non turbo rebuild
- Lower Control Arm Bolt Help!
- Rimtalk
- CREDIT WHERE CREDIT IS DUE????
- HELP !! How do I disable my factory alarm?
- 20" wheels on 96 avenger
- fs: iceman intake
- Bad Vibes...
- Cold Air Intakes?
- 1998 Avenger Manual / Maintenance
- Upgrades / Gas Mileage / Performance
- fs: body kit and others
- high beams not working
- Remote locking... parking lights flash? Horn chirp? Mine doesn't.
- tranny question
- Stock Rims
- Broken Seat
- no door handles
- 96 Avenger 2.5 overheating **update**
- 2.4L Stock Turbo Kit
- v6 headers
- Grinding Noise-Maybe my shocks/struts
- Rims
- bleeding PS system
- What is the problem with the car? Any ideas?
- last call for parts from my avenger
- 95 Avenger smoking from timing belt cover
- 95 transmission
- v6 turbo setups
- Fuse Layout
- Lighter Won't Work
- 96 Avenger 2.5...will not turn over
- BAD VENGE PLEASE READ!!
- Still Dying At Idle
- Fan switch
- 99 Avenger door speaker replacement help
- transmission lost?
- Blacking out Tailights
- Help!
- exhaust
- loads up/sputters before shifts
- Dash brake light.... and other problems 97ES
- trans stuck in second, searched but no one is having the same prob as me...
- starting proplem
- MY DODGE WONT START!!!NEED HELP
- Transmission Rebuild
- Trans on a 95 Avenger 2.5
- 95 avenger Door lock
- Overheating 1999 V6
- outter tie rod
- 96 Avenger Tune Up... Can you help me?
- Need to replace 16" rims on 96 Avenger
- eclipse console question
- Acceleration Stall
- 98 eclipse wheels on 98 venge
- Another Stalling Question
- COTM
- Picture request
- NEED ADVICE
- Automatic Trans Lugging
- Transmission issues..
- 2000 venger no spark
- Will new 07 Avenger wheels and tires fit my 97?
- 96 avenger wont turn over starter
- 1997 Dodge Avenger Up For Sale
- 98 5-Speed Trans Question
- will this tranny fit
- window regulator
- ABS Light
- Driver Seat
- Throttle Cable
- Pull to left and grinding noise
- 98' avenger sway bar linkbolts
- 1997 dodge avenger 2.5 v-6 anti-theftMy son just bought this car and the ins. company was asking if
- where to buy trim parts
- Need Body Parts???
- Car Jumping!!
- Rear strut upper support bracket
- noise in right front
- Coolant leak, Knocking sound
- Automatic door locks?
- 1997 avenger 2.5 v-6 will not start
- rim size
- avenger alternator removal 2.5
- HVAC controls
- Gas Milage
