PDA
View Full Version : 1995-2000 Dodge Avenger
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12
  1. i need serious help!
  2. 1996 Avenger - Front Brake Rattle
  3. O2 sensor info
  4. Bad vibration.. Transmission maybe?
  5. 1996 parts manual
  6. O2 sensers - HELP
  7. steering issue
  8. PS/CV/brake light info
  9. 98 dodge avenger 6cyl
  10. 96 avenger 2.0 shuts off
  11. Help Finding Motor Mounts
  12. Problem with Transmission :icon_doh:
  13. 2000 Avenger - No Reverse - Error Codes P0700 and P0736
  14. Exhaust System
  15. Strut Bar
  16. Help Needed
  17. New Problem
  18. key dance
  19. Parting out 98 Avenger
  20. Transmission help
  21. Horsepower
  22. 97 doesnt start
  23. Start problem PLEASE HELP 98 avenger
  24. Brakes go to the floor wont get firm
  25. P1495 code
  26. Rattling window on 99 Avenger?
  27. Sunroof help.
  28. Need Electrical Help Please
  29. '98 2.5 es
  30. 97 Avenger ES ride height
  31. 98 avenger almost stalls when coming to a stop
  32. The SRS light in my Avenger -96 ES 2.5 V6 doesnt work when startup?
  33. Engine Swap?
  34. Vote for DF's Ride of the MONTH
  35. 1995 Avenger - reset CEL?
  36. Patch panels!?!?
  37. timing belt
  38. Ball Joint?
  39. Update on my avenger
  40. distributor
  41. Need help identifying a part
  42. Avenger vs Stratus Sedan
  43. 2000 dodge avenger transmission help!!!!!!
  44. 1999 Dodge Avenger esES-V6
  45. 1998 ES Stalls When Stopping Only When Warm and in Gear
  46. where can i get RIMS for 95 Avenger ES???
  47. 98 AUTO AVENGER WONT SHIFT OUT OF 1st
  48. Error code: p1294
  49. Major vibrations on my 96' Avenger ES
  50. 99 Avenger driving my nuts.
  51. This mom needs HELP!!!
  52. looking at buying used avenger-please advise!
  53. I need votes !!! Help an Avenger brother out
  54. Data Link Connector dead?
  55. Inner/Outer Tie Rod replacement
  56. Hvac trim/bezel???
  57. Car pc install
  58. 97 Avenger dies when coming to stop signs
  59. Is there any air-filter inside of dash-board?
  60. 1999 Avenger for first car?
  61. 95 Avenger Front Oil Seal
  62. Rack & pinion - 97 coupe
  63. how to replace dashboard fan / temp light?
  64. Avenger won't start - turn key, nothing happens
  65. 1995 Dodge avenger ES sunroof leak need help!!
  66. what's my 99 avenger worth?
  67. 1996 Avenger won't shift out of 1st gear
  68. intake
  69. Rocker Shaft Springs
  70. FS:Factory 16'' rim center caps, Center console
  71. Body Panels
  72. Need spark plugs replacement. Which one's to choose?
  73. running fog lights without headlights
  74. 96 Avenger keeps stalling/not starting
  75. chrome powder coated 2.5 intake
  76. 1996 Avenger Parts Manual
  77. Heater Core removal question
  78. 1996 Avenger ES hub cab
  79. 1999 key transponder chip
  80. Engine rotates but won't start
  81. ETACS Chime Module Needed
  82. problems aligning timing marks on 96 avenger 2.5
  83. 97 Avenger ES tranny ?
  84. rear spindle bushing
  85. No chime or tone when headlights are on
  86. Really Lose Rear End
  87. Question about dome lights and key Fob
  88. Battery light and very low power while driving
  89. 2000 dodge avenger crank but no start
  90. Transmission Shift Solenoid
  91. Component Speaker System Question
  92. fog light bulb replacement
  93. Dodge Avenger 1997 body color code location?
  94. Idle problems
  95. Rough Idle - No Power - Whistling
  96. Tire Size?
  97. Inexpensive Key Fob?
  98. 1998 Dodge Avenger 6cy Having Problems...NEED HELP PLEASE!!!!!!!
  99. Heater core question
  100. Why are my doors locking automaticaly?
  101. Need a little help, window issue
  102. 97dodge avenger 2.5l
  103. Front Strut Replacement Help
  104. Front Strut question?
  105. Ok.. So I'm addicted to Avengers
  106. blower motor assembly????
  107. Sunroof Diagram
  108. help
  109. 1997 Dodge P1494 and tachometer upto 2000 when starting
  110. ???97 Avenger Key Question???
  111. Drive cycle for 1998 dodge Avenger
  112. 96 avenger miss
  113. why dodge avenger,s and other dodge models stick in second
  114. 95 Avenger ES Oxygen sensor location
  115. 98 dodge avenger es
  116. 1998 Dodge Avenger ES starting issues
  117. need help
  118. Dodge Avenger, 1997 book and / or electrical wiring diagram
  119. oil sending unit
  120. code p0750 2000 avenger
  121. Where are all the Avengers?
  122. wheel lugs
  123. tires size???
  124. 96 Avenger ES with intermittent stumbling problem
  125. 96 2.0 DOHC 5spd avenger
  126. Window(s) leaking. Sealent?
  127. 98 Avenger wire harness mutilated
  128. Can't Turn Key
  129. Help: 96 Avenger V-6 that won't start
  130. What is the normal RPM when driving av 37 MPH?
  131. 1995 dodge avenger nightmare multiple bugs!!!
  132. engine dies 98 avenger 2.5 v6
  133. '95 Headlights vs '97+ Headlights?
  134. Inner Tire wear 95 Avenger w/coil overs
  135. 95 dodge avenger 2.0 rolls over but won't start
  136. i need plug wire help
  137. Engine stalling within the 1st mile
  138. CPS Testing procedure
  139. Replacing Stereo
  140. fuel pressure regulator?
  141. curved or straight control arm
  142. Need a ETACS ECU for 98 Avenger
  143. Misfire Multiple Cylinders and Blue Rich Exhause
  144. PLZ help .. Power window problems
  145. Help Plz.. Power window problems
  146. Which front brake discs will fit my 1996 Dodge Avenger V6?
  147. 98 2.0L idle problems
  148. Guide "how to change intake plenum" with pictures?
  149. Does Ford Mustang -05 GT Rims fit on my Dodge Avenger -96?
  150. Car was in a wreck but driveable....now dead
  151. Key dance issue and no idle
  152. valve cover gasket, wow took an hour to get out
  153. Weird sound from engine following RPM.
  154. Check engine light flashes
  155. Door Alarm Sensor / Keyless Entry
  156. Fuel Pump Relay Schematic
  157. New alternator, no start
  158. V6 Automatic Tranny Drive Shift/Stick
  159. Replacing Shocks on 99 avenger
  160. bearing thrown
  161. avenger just died and wont start
  162. need help, hubby asked me to check on this for him
  163. timeing
  164. how do i change the back 3 plugs and wires
  165. Performing the "Big 3" Upgrade
  166. Hard to replace lower control arms?
  167. Help my car wont stop smoking
  168. Iam new to the Dogde Forum
  169. Tapping comming from motor
  170. voom voom
  171. Just got Avenger, trans won't go in R or D
  172. Hi from Concord NC
  173. HUGE problem with drivers door
  174. Codes p1784 & p0703...I need help??
  175. autocross
  176. '98 ES cruise control issues
  177. Interior lights won't come on when door open
  178. 1997 Avenger, just picked it up..Tranny Issue..
  179. Tricked out Avenger?
  180. 2000 venge, no spark
  181. front end squeaking bad
  182. interior door paneling
  183. Slight RPM increase?
  184. 1997 Dodge Avenger Distributor rebuild?????
  185. I sure hope tps fixes it...
  186. What is SRS
  187. Please look at the pictures I put on and reply,, hole in manifold
  188. 99 Avenger Cruise Control Question
  189. No Spark after Distributor Replacement
  190. oil around spark plugs and wires
  191. 96 avenger es sputters when given gas
  192. help please,,, heater panel lights????
  193. New To Forum
  194. multi misfire 00 Avenger
  195. fuses on firewall under hood drivers side???
  196. avenger wants to die and miss when giving gas in drive and revers
  197. Oil pressure gauge sending unit location?
  198. Alternator Questions...
  199. Heater core and tranny question.
  200. 00 Dodge Avenger what battery
  201. Avenger Squealing Noise (Video Inside)
  202. Fuse box diagram needed!
  203. o2-sensor positions? (picture)
  204. 97 advenger won't shift out of first. whats wrong
  205. Check engine light on cold starts
  206. Mavman is back with more tranny probs......
  207. Misbehaving Avenger
  208. "Rubber against metal"-sound when turning!
  209. 96 Avenger wiper switch ?
  210. 98 avenger es... OBD II says" no signal from VSS "
  211. 96 avenger hub assembly trouble
  212. R/R CV axles 97 Avenger
  213. 98 avenger 2.5 skiping/stumbling
  214. New here!!!
  215. Viper tcm
  216. Jeep tb on an avenger
  217. 99 avenger es wing
  218. Speedometer
  219. Transmission Issues
  220. what brand plugs and wires for 1997 avenger
  221. No spark.
  222. 2009 Avenger Door Panel Removal
  223. timing belt troubles.
  224. Downpipe/california/federal/exhaust/etc
  225. 98 Avanger ES issues
  226. My first post! Need some help...
  227. 96 Dodge Avenger EGR Solenoid?
  228. axel half shaft 1996 avenger
  229. Transmission slip at stoplight / "low rpm"
  230. Will this Hayden oil-cooler work on my transmission?
  231. Low compression
  232. Rebuilding my 2.0L 420a Plz help!!!
  233. Upgrade firmware 41TE from model year -96 to -99?
  234. 1999 Dodge Avenger Weird Shifting Issue
  235. 97 2.5, two codes, won't start.
  236. blitz body kit
  237. my 1996 avenger wont start! help please!
  238. new to the forum.
  239. 2000 Avenger constant wine/moan
  240. rims
  241. looking at buying a 2000 avenger
  242. 1997 avenger sport
  243. Can I use this oil-chaning-pump for the tranny?
  244. Rearend bounce?
  245. mtx swap parts
  246. 2.5L engine upper knocking need help asap
  247. A few questions
  248. When PS/AC belt not on car overheats.
  249. Dodge Avenger 1995!! dervech
  250. 97 6cyl codes check engine light
