PDA
View Full Version : 1995-2000 Dodge Avenger
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12
  1. \door Speakers
  2. 1998 dodge avenger
  3. To anyone who knows alot about the 2.5
  4. Tweeters
  5. Typical Problems
  6. Headlight Bulbs, Winsheild Wipers, and Speakers
  7. NEED HELP!
  8. Bumper Parts
  9. Condenser and Radiator Questions
  10. Do stock headlights on the Avengers suck?
  11. I need help And Info On the infinity stereo system
  12. Engine missing
  13. Engine + Wet = No Start
  14. kool kit advice
  15. need headlights and bumpers
  16. New Clutch?
  17. Brake Help Please!!!
  18. 95 Map Sensor
  19. Hood needed, red one or carbon fiber.
  20. getting rid of the venge
  21. im lookin for a new hood
  22. 96 avenger OPINIONS DESPERATLY NEED
  23. which set up?
  24. throttle body
  25. oil pressure
  26. ALL EXPERTS NEEDED!!!
  27. Lower control arm recall info
  28. i found it
  29. SURGING PROBLEM
  30. Electric Supercharger
  31. wierd
  32. heads up on ball joints
  33. Tune-up Qusetions
  34. I need new rims, please help!
  35. cold air intake
  36. mystery switch
  37. Foglights
  38. Looking for Custom Avenger Eyelids
  39. Front Right Lower Control Arm
  40. Idle Air Control Issue
  41. oxygen sensor
  42. NEED SOME MORE HELP
  43. AVENGERS SUCK!!!!
  44. Dumb Question..
  45. P0715 code
  46. another turbo question
  47. front tweeters
  48. Eagle Talon TSI Swap?
  49. WARNING! DUMB QUESTION ALERT
  50. balljoint recall pics
  51. battory light
  52. recalled balljoint broke!!!!!
  53. New Exhaust
  54. Brake question
  55. Spolier
  56. touch-up paint
  57. need help before I buy parts
  58. turbo set up
  59. Need a PCM
  60. strut help immediatly
  61. Alarms
  62. How-To: Dash Removal
  63. Cruise Control Does Not Work!
  64. Center Console lights went out.
  65. Sunroof wiring
  66. inrieror swap
  67. Belt problem?
  68. Alarms and remotes
  69. 1996 es jump time
  70. Transmission Rebuild Pictures Online for A604
  71. Two problems?
  72. 2.5L V6 to manual conversion
  73. Where did it GO!
  74. pcm
  75. tire rubb on the rear A arm
  76. Car Stalling
  77. ITS FIXED SILVER!!!!!!
  78. idk
  79. Any Ideas
  80. 99 avenger
  81. TRANSMISSION TOTALLY BLOWN
  82. engine probs
  83. Silvercoupe97 is a V-6 TT AWD possible
  84. Parking Break Light Malfunction
  85. tranny fluid change question 2.5L ES
  86. 95 dodge avenger es stalls!
  87. 99 avenger dies everytime i stop.
  88. Driving noise
  89. Horn issue.
  90. Silvercoupe97 Siggy!
  91. 95 Dodge Avenger ES is stuck in second gear!
  92. 4g63t swap
  93. All Avenger Ideas
  94. belt noise plse help!!
  95. fog lights + parking lights
  96. first time at the track
  97. tuning parts
  98. Stuck in 2nd gear...
  99. serpentine belt
  100. COTM
  101. upper ball joints
  102. Help for front brake pads&rotors
  103. 97 venge trunk problem help
  104. HEAD GASKET LEAK?!?!
  105. Headlight replacement
  106. Vibration
  107. Official 2007 Dodge Avenger Pictures Released!
  108. alternator
  109. 95 Avenger 2.5L Stalling Problem/TPS Info needed.
  110. eclipse woofers
  111. Cabin water leak.
  112. TC1 Body Kit Question
  113. 96 Dodge Avenger 2.0 needs to be sold.
  114. Transmission Solenoid
  115. suspension
  116. 2yes2 ATA Italia Doubleface Wheels/Kumho Tires for sale
  117. knock on passenger side
  118. Weird Check Engine Light
  119. Fast idle help!!!!!!!!!!!!
  120. Oil on the spark plugs
  121. Air intake opinion
  122. How-To: 3.0 Swap
  123. GETTING WHEELS OFF
  124. pillar pod
  125. '98 2.5 w/#1 & #5 misfire; replaced all plugs & wires, now idle is worse!
  126. Body Kit Options
  127. HELP engine codes have me confussed
  128. Front brake rotors
  129. lowering springs
  130. HELP WITH POWER MIRRORS PLZ
  131. '07 Dodge Avenger!?
  132. Firewall relay info
  133. timing belt
  134. Speed Sensor
  135. Loss of power - curse of the TPS?
  136. 98 es 2.5 more trans problems
  137. whistling noise from firewall area
  138. Brake Squeak problem
  139. stalling out
  140. pixs of trunk mod
  141. stalling out
  142. grinding noise?
  143. 96 avenger won't start
  144. Whats the diff. between a highline V6 and a regular V6
  145. new used car problems HELP!!!!
  146. I'm stupid...
  147. need help asap
  148. Tires and Rims
  149. Help please!
  150. I have several problems that are bugging me...
  151. i dunno anymore
  152. A few Quick Questions
  153. Which is faster
  154. SuperAvenger!?
  155. How to rewire fog lights!?
  156. I don't know what's wrong...
  157. aftermarket gauges
  158. Air Ride
  159. Small problem with thermostat housing
  160. What speakers have worked with you?
  161. What is the diff. between a avenger sport and a ES
  162. oil and plugs
  163. 1999 Dodge Avenger
  164. coilovers
  165. Cylinder Misfire/ Spark Plug replacement
  166. suspension question
  167. Couple of questions about the 96 2.0 DOHC motor.
  168. 97 Avenger acting really weird!
  169. I need help with my 99 2.5 running problem
  170. 97 avenger pcm tcm up for sale
  171. 99 Dodge Avenger Question
  172. Misfire V-6 P0123, P0113
  173. Hey Yo Silver
  174. Hi there.
  175. Tranny Question and some parts needed!!!
  176. Viper 530T module + break issues
  177. wierd
  178. How-to: Remote key fob programming
  179. air condition at idle
  180. magnaflow
  181. trouble codes
  182. 98 Dodge Avenger ES HELP PLEASE !!!
  183. Which is Better
  184. cobolt lt vs avenger
  185. 1995 Chrysler Sebring (looks like my 96 venge.)
  186. replacement catalytic converter
  187. rear wheel drive
  188. High Oil Pressure
  189. PLEASE HELP!!!
  190. Headlight Question
  191. The PCM
  192. overheat....
  193. 98 Sport intake noise
  194. Whinning noise while accelerating
  195. engine block restoration
  196. oil spewing everywhere
  197. Lookin' to buy
  198. 2.0 pulled, what now? Mods?
  199. Severe coolant leak...and more?
  200. Cruise Control does not work
  201. 1997 Dodge Avenger, trans limp mode, please help
  202. How-To: Horn Button Fix
  203. Horn switch
  204. 1995 Dodge Avenger Stalls
  205. Changing the Alternator on a 96 2.0 standard.
  206. 1995 Avenger..
  207. 1999 Dodge Avenger Help
  208. 5 speed to auto
  209. 1998 axle shaft
  210. Any idea what would cause this engine studdering?
  211. stock fuel injector size
  212. sensor ???
  213. Program keyless transmitter
  214. different motor for my avenger....
  215. Avenger Stalls and Overheats
  216. August Car & Truck of the Month!!!!!
  217. New to this
  218. What have you beat with your 98 Avenger 2.5?
  219. remote wire quetion pleae HELP!
  220. Sounds Like Tie Rod Probs
  221. Starting trouble
  222. Starting to have problems
  223. valve and tranny problems
  224. What Needs 2B Done?
  225. A/C diagnostic test, anyone have a procedure?
  226. Hi and Help
  227. Euro Headlights
  228. need help abs
  229. brake sensor?
  230. fuel level question
  231. after market sport mulffer
  232. 95 Avenger 2.0 DOHC not starting.. we changed the crankshaft sensor
  233. door jamb switch problem
  234. back seat
  235. 96 Dodge avenger 2.0 new battery odd non start
  236. 95 Avenger
  237. Performance upgrades?
  238. changing antifreeze
  239. starting problem
  240. 1998 Avenger 2.5
  241. CAN ANYONE HELP
  242. check engine light
  243. Car over heating
  244. Help! Check light, tranny stays in 2nd, oil pressure = 0
  245. custom it
  246. Need Info
  247. How-To: AGX/coilover install
  248. Is it really worth it
  249. HELP ME!!!
  250. check engine light ????
