PDA
View Full Version : 1995-2000 Dodge Avenger
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12
  1. quick question..
  2. Transmission Trouble
  3. Silver Coupe?
  4. New to the forum
  5. parting out my 96 avenger
  6. Need new bumper for my '97
  7. High idle
  8. please help me 420a auto/manual swap!!!!!
  9. I'm losing Antifreeze and my water temp. is rising!!!!
  10. PCM or injector harness?
  11. Regional Sections!!
  12. dying venger
  13. Body kit
  14. Car of the year voting...
  15. rear discs??
  16. Front driver brake?
  17. Infinity Amp?
  18. 97 avenger?
  19. Trouble Codes
  20. Vibration back, and need suggestions
  21. NEED HELP TECHINCAL Q
  22. new sticky
  23. Sale Springs, bumper cover, some stock parts
  24. Rear end rides rough and noisy.
  25. motor trade for car
  26. Creaking Noise
  27. Pics of engine rebuild.
  28. Cylinder head gasket replacement
  29. Manual Tranny Fluid Capicity
  30. Pistons
  31. Oily intake, throttle body, and poor idle
  32. Water Damage
  33. leaking head gasket
  34. Rev's high when starting
  35. Headers For the 2.5
  36. 95 Avenger Parts for sale!
  37. NEED SOME HELP Racing Dodge Avenger
  38. Avenger/Eclipse suspension compatability
  39. electrical problem
  40. right upper control arm
  41. body kits
  42. New Belt: V6 2.5 Alternator and PS Belt
  43. 96 venge for sale
  44. Sound system PT2
  45. 96 Dodge Avenger questions..
  46. strut selection...
  47. front brake locked up.
  48. Bad Idling
  49. Drain plug!
  50. Engine Swaps?
  51. turbo kit
  52. 1998 Avenger
  53. 95 avenger transmission
  54. 3.0 lifters make noise
  55. Look!
  56. 97 for sale
  57. What tires would you recommend?
  58. HELP!!!!!!!!
  59. remote start install
  60. cam gears
  61. grinding noise
  62. heater issue
  63. the new exile?
  64. Oil pressure guage problem
  65. Does this really work?
  66. Same problem, diff Avenger!
  67. Exhaste
  68. 95 avenger has bad gas mileage, clicks, and rear speakers dont work...
  69. smoking avenger
  70. Oil light keeps coming on!!!
  71. how many dead avengers must there be
  72. transmission issues please help!!
  73. 2.4L Headers?
  74. fog lights
  75. 3.0 Swap
  76. Factory Rims
  77. swap or bore
  78. Ring Gears
  79. Tranny leak - need help!
  80. Bulb Type?
  81. 97 venge motor swap to a stealth motor
  82. Instrument panel/dashboard/bezel/whateverr
  83. another dead avenger
  84. wheel spacers
  85. Turbo???????????
  86. studdering/check engine light?
  87. 96 DOHC Camshafts
  88. Dash speakers
  89. 96 avenger
  90. tranny noise
  91. transmission
  92. Mysterious Battery Drainage
  93. another keyless entry ?
  94. Need a CAI
  95. 2.0l Rebuild
  96. Avenger Issue
  97. 96' Avenger Multiple Misfires
  98. swap cam sensor
  99. Sound System
  100. Keyless Entry??
  101. Dead Avenger
  102. BV this a good tranny
  103. 96 for sale/ parts
  104. Real Reason Why Misfire With Avenger
  105. misfire
  106. Vertical Doors
  107. 98 avenger 2.5 es
  108. Possible Head Gasket Issue (coolant in the oil)
  109. power lock
  110. well
  111. engine knock in passanger fender
  112. body kits
  113. Free screwdrivers
  114. how to change crankshaft sprocket?
  115. Bad Ebay Vendor: carpartswholesale
  116. Governor
  117. installing new speakers
  118. Fuel Mileage ??
  119. WOW another tranny issue????
  120. Nite Shades
  121. Gear Oil for a 1997 Dodge Avenger
  122. 99 Avenger -- Minor problems/questions, please help!
  123. Body Kits
  124. towing with an avenger
  125. how to fix fog light?
  126. Fuel filter help
  127. Wheel bearing
  128. One problem after another
  129. About the ball joint recall
  130. INTAKES
  131. Ball joint recall info
  132. 2.0-3.0
  133. crankshaft position sensor
  134. hydrolic timing tensioner
  135. Oil Pressure
  136. NOISE
  137. PARTS
  138. bad venge plz help
  139. camshaft removal
  140. 96 dodge avenger
  141. painting plastic
  142. Tie Rod End and Control Arms
  143. bent rim lip
  144. Power locks problem, remote starting
  145. headlight question
  146. wheel and tire sizes
  147. front bumper material
  148. transmission problems
  149. Interior Dome Light
  150. WTB ~trunk lid~
  151. eratic idling
  152. alternator
  153. Fuse?
  154. 2.0 dies
  155. Computer??
  156. Low end
  157. please help..trans is acting up =[
  158. 02 sensor removal
  159. factory alarm to ic dynamics alarm
  160. What are the pros and cons on adding a second exhaust pipe?
  161. Does anybody have instructions on how to install the bulbs for the fog lights?
  162. ENGINE?
  163. Wont Shift Past 2nd Gear
  164. neon install help
  165. !Lo Jack!
  166. Alarm?
  167. Blinker
  168. HIGHLY ANNOYED!
  169. performance parts?
  170. Tried EVERYTHING!!! Won't Idle
  171. Speaker
  172. Thought it was an exhaust leak......
  173. Kind of a dumb question, '97 avenger
  174. mitsubishi eclipse SRI
  175. overheating
  176. Leaky Tranny (v6 stylezz)
  177. 1st gen eclipse turbo
  178. Wanted: Stock intake duct
  179. climate control button question
  180. silvercoupe97
  181. lebaron trans in avenger
  182. exhaust question
  183. tps
  184. halfshaft removal
  185. Something Fried
  186. Just dropping in to say whats up
  187. Ugh..
  188. Looky here :)
  189. Being Cheap
  190. wiper wash motor?
  191. Alternator/battery issues
  192. 95 avenger surge
  193. 95 avenger surge
  194. BAD TPS PLZ HELP
  195. curved ball joint
  196. Engine Noise
  197. crankshaft timing belt gear
  198. crankshaft timing belt gear
  199. There maybe hope!
  200. 98 2.5 V6
  201. Eclipse 2.0 NA Intake
  202. Tranny Work
  203. A/C Compressor
  204. lower ball joint recall
  205. 95 AVENGER 2.5
  206. turbo kit from 6g72 (stealth/3000gt) on 6g73 (2.5l v6)?
  207. Performance tips
  208. glow gauges power wire
  209. MOVED: avenger heads for sale
  210. Strange problem with the venge
  211. wat do you think about this turbo kit?
  212. tune up time
  213. chaning gauges and ac lights red???
  214. Transmission Question
  215. 97 avenger tranny problem
  216. Timing belt problem!
  217. CPS (Details)
  218. Finaly have the time and money to work on my car..need advice! !
  219. key won't turn
  220. steering hub
  221. More Close Knit Avenger Community
  222. Swap parts question!
  223. speaker covers??
  224. engine in my venge
  225. front speakers
  226. e-brake questions
  227. $125 carbon fiber hoods
  228. brake pads and rotors
  229. 4g63-t swap
  230. 3.0 swap Question
  231. venge buring oil
  232. Codes and a question....
  233. front suspention
  234. 97 avenger
  235. msd ignition question
  236. question on PLenium 2.5L
  237. Busted Fuel door.
  238. door handles
  239. Floor Mats
  240. Headlight Bulbs
  241. 4g63-t EVO 5
  242. Headlight Adjustments
  243. Siphoning Gas
  244. What size are my tweeters up front
  245. wiring harness diagram
  246. scanning warning light
  247. 95 Avenger Power Windows
  248. 95 Avenger Thermastat V6
  249. headers?
  250. Which O2 sensors effect mileage?
