PDA
View Full Version : 1995-2000 Dodge Avenger
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12
  1. Buying 00 Avenger...questions
  2. dodge avengenger YOUR GROUNDED!!!!
  3. new lights
  4. Question For Exhaust
  5. bomz racing spoiler
  6. STILL DYING
  7. electrical parts
  8. strut tower bars
  9. 1995 avenger 2.0 D0Hc wont start
  10. tranny rebuild, need mopar atf3?
  11. speaker set up q's
  12. question for bad venge
  13. MOVED: highway race
  14. car pictures
  15. tranny issue help needed
  16. rattle
  17. exhaust set up
  18. NO More shacking!
  19. ASD question
  20. Owners Manual
  21. trans won shift into 3rd
  22. Whats involved with taking my headlights out?
  23. Coil pack
  24. 'Venger won't start
  25. 95-99 eclipse...or 420a intake on a 2.5?
  26. Lowering my Avenger...
  27. studder problem
  28. Intakes
  29. tranny not shifting
  30. Which is the best bet for my 98?
  31. Where is the IAT sensor plug? and another ?
  32. Hearing this noise from first to second gear...
  33. Where Do I Start?
  34. Grinding noise from rims.
  35. question for bad venge
  36. E85
  37. EVERYBODY
  38. Window off track
  39. 420a vs. SRT-4 engine
  40. Please read my Post in the New member Section
  41. Code P0300 and P0304
  42. Dodge avenger shakes when it is idling.
  43. Any Ideas
  44. fog lights
  45. Panic alarm will not shut off...
  46. broken fender bolts....
  47. Venom 400 module??
  48. high out put atl
  49. Wassabi...New to DF...intellectual sponge
  50. Cold air or ram air....?
  51. Idle seems really low!!!
  52. break lights and ABS
  53. Sun roof question
  54. Avenger race.
  55. OEM 17"x 6.5" avenger wheels for sale
  56. Battery
  57. Timing belt Question?
  58. Interior Question
  59. Adding a second exhaust pipe on a Dodge Avenger.
  60. Tire Question
  61. New Engine
  62. Paint Stock Spoiler
  63. Shacking noise in front
  64. Rust is spreading on the hood of my car - Need some advice
  65. panic horn sounding spontaneously
  66. Same Old Problem With Dying At Idle
  67. Rims
  68. Will this work?
  69. 20 inch wheels on avenger
  70. need nominations for car of the month
  71. indy red???
  72. custom rims
  73. rust hole
  74. help
  75. Exhaust for 2.5
  76. Body Kit
  77. 95 dodge avenger won't start
  78. codes
  79. Painting alloy wheels black.......
  80. Few Questions
  81. Modding Stereo location..
  82. Any others??
  83. power steering
  84. Exile Dead?
  85. transmission / transaxle leak
  86. Door Switch
  87. Underbody neon problem
  88. 95 2.0L questions.
  89. have anything to do with recall
  90. headlight sunfaded...
  91. Brake replacement / Online shop manual
  92. performance chip...
  93. oil pressure gauge
  94. burnout for the ladies
  95. V6 drive belt routing
  96. 96 Es
  97. Weirdd
  98. What tires do you run on your ride?
  99. custom turbo
  100. atf+4
  101. Philladelphia area dodge owners
  102. Random cylinder misfire
  103. fog light wireing
  104. Thank you BV
  105. supercharger
  106. rear seats
  107. cold air intake or short ram
  108. Still Dies At Idle, With Other Problems
  109. Blown tranny
  110. Timing Belt
  111. speedometer light!!!
  112. avenger making a weird noise!!!
  113. 420A manual
  114. Gear indicator bulbs
  115. pulley kits?!
  116. Tech stuff
  117. Gettin sum head
  118. front sway bar
  119. Cigarette Lighter/Accessory Socket Fix
  120. new guy here, if you were me...
  121. engine codes
  122. Burning oil
  123. No interior lights!!!
  124. Avenger Spoiler???
  125. Window Vent guards....?
  126. Where is the dinger ? - 95 Avenger
  127. Anyone make louvers for the avenger?
  128. another turbo
  129. Whoa !! what just happened
  130. Blowing Fuses?
  131. venge dies randomly
  132. hole through firewall!
  133. 96 avenger slow death
  134. Vacation
  135. HI !!
  136. Still waiting for answers
  137. Air Filter + check engine light
  138. Fuses and Overdrive
  139. Erratic idle fixed!
  140. window water spots
  141. More eclipse help....just a different guy
  142. Check Engine Codes on a 98
  143. Driver window is stuck
  144. Radio cuts in and out?
  145. Idles Way Too Low
  146. hey silver
  147. Fuel Door Jammed
  148. what is worng with my clutch?
  149. One day it starts, next day it wont. HELP!!
  150. are the 2.0dohc-sohc&2.4dohc block the same.
  151. Alternator capabilities...
  152. Upper Control Arm Squeak
  153. passenger quarter glass
  154. eclipse help
  155. Engine keeps cutting off NEED HELP!!
  156. Can someone please help me:)
  157. firewall holes
  158. Side Moldings Suck
  159. New to the forum...
  160. New Stereo... no sounds coming out :(
  161. hey guys. help me out if u get a few minutes.
  162. 200 hp
  163. 420a-4g63t swap????????
  164. Data Link Connector
  165. Interior light problems
  166. Avenger Clutch
  167. Should I get rid of stock infinity amp....
  168. water gauge
  169. building a 420a
  170. Hesitation and skipping at lower RPM
  171. funny idle
  172. site newbie with questions
  173. keyless entry??
  174. new dude engine swap question
  175. Turboing a 420a?!?!
  176. 4g63 stock internals?????
  177. Exhaust setup
  178. 420a tranny question
  179. 4g63 swap
  180. Cat Converter:part 2
  181. v-6 manual IT CAN BE DONE !!!
  182. Windowwashers Thing??
  183. No Spark, Please help!
  184. Locating the canister purge valve
  185. aggrevating miss
  186. Cat Converter
  187. swap heads sohc dohc SILVERCOUPE97 "help"
  188. i cant belive this happend
  189. It dies!
  190. newbie
  191. 2.0-2.5 turbo ?
  192. Muffler Question
  193. Donations?
  194. auto trany to manual trany question
  195. Oil squirting from oil fill hole while running?
  196. WTB:Trans for 98 2.5liter venger
  197. need help choosing HEADER!!
  198. Need help - I am hearing wearing sounds coming from my front suspension.
  199. Rust is starting to show on my Dodge Avenger's Hood
  200. Work//Tweeter
  201. brake pads/rotars
  202. Will these rims fit?
  203. Blown tweeter on 1998 avenger with infinity sound
  204. nice
  205. got pics? lol
  206. Headlights
  207. shock
  208. hey silver
  209. lighting problems
  210. exhaust
  211. engine test
  212. spoilers
  213. Thanx silver
  214. mor
  215. more pics silver
  216. underglow ? question?
  217. Antenna
  218. its finally over...
  219. gauge cluster
  220. abs light
  221. heres my 250$ ride
  222. 97 dodge avenger 2.5L V6 intake manifold removal problems
  223. location
  224. eclipse center console
  225. where at!
  226. hey guys...
  227. turn signal flasher location???????
  228. Car and truck of the month, vote now!!
  229. 97 Dodge Avenger Wont Start
  230. ???????
  231. oxygen sensor help
  232. Defrost and Radio
  233. Chip when locking
  234. parkinglight/foglight sticky
  235. Transmission swap
  236. what is the govenor on an avenger V6?
  237. out side door handle
  238. The end
  239. Which is faster?
  240. headlight conversion
  241. sttuudder
  242. car wont start.....wahhhhhhh
  243. Are The Dropzone Lowering Springs A Good Way Too Go?
  244. Windows
  245. Headlight replacements Silver:)
  246. upgrades?!?!?! NEED HELP ASAP
  247. speeding
  248. done with the venge
  249. venom control module
  250. new wheels
