PDA
View Full Version : 1995-2000 Dodge Avenger
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12
  1. Valve cover plug seals
  2. My experience with OBD2 on a Dodge Avenger -96
  3. Wont shift out of 1st!!
  4. Rebuilding my 2.0
  5. Windshield-wipers does'nt work =/
  6. leather seat
  7. Passenger airbag replaced, now SRS light is on…
  8. high idle rpm
  9. 95 starting issue
  10. How to replace EGR-valve?
  11. what to do about a dead short
  12. Many problems, problems starting.
  13. 98 ES 2.5L Engine Swap
  14. Ball Joint Break?
  15. installed alternator 3 weeks ago, now charge sys warning light and no batt power
  16. Problems installing coilovers
  17. Tweeter grille covers
  18. Which battery for a Dodge Avenger -96?
  19. Check engine light has come on =/
  20. Sound when door is opened and key is not in the ignition?
  21. Car gets unstable rpm when stoplight
  22. lifters/valve lash adjusters...removal and replacement
  23. 95 Avenger engine swap
  24. Code P1786 on a 2000 Avenger 2.5 auto
  25. Stalling, cutting out, and rough idle when stopping
  26. Water Leak After Rain
  27. A604 Valve Body
  28. 1997 Avenger in Limp mode
  29. 1997 ES Coilover install tips?
  30. Alternator is bad, and a whining noise
  31. 2000 Avenger ES stalls while driving
  32. squeaking noise when going over bumps and parked.
  33. How do I hook up the factory head unit up to this amp?
  34. 97 automatic transmission problem
  35. Changing the Air Filter
  36. Chippys & Mice Motel
  37. '95 2.5L No Spark
  38. Eclipse front end?
  39. speakers
  40. Sputters when Accelerating
  41. '95 New sound system - Help
  42. Need help with this quick
  43. Blinker Question...
  44. Roll pin for harmonic balancer 95 Aenger ES
  45. High RPM
  46. 2000 Avenger Tranny leak
  47. Gas Level Sensor Problem
  48. 99 Avenger - No Map lights/courtesy lights PLEASE HELP!!!
  49. 98 dodge avenger wont start
  50. FALSE Misfire code in ALL cylinders??
  51. 97 ES Battery/fuse/wiring problem
  52. 2000 avenger stalling
  53. 1996 Avenger ES Comm Problems
  54. more idle
  55. Spuddering problems when taing off and driving
  56. Noisy lifters or Valves
  57. Tranny Issue
  58. Whining sound when turning week slightly and when breaking?
  59. starter won't crank
  60. Cruise control Question
  61. Coolant level problem
  62. Any 6G73 wire tuck tips?
  63. Quick Stereo Speakers Question
  64. trans question
  65. windows don't work
  66. Oil type for a 1997 ES 2.5L with 163,000 miles?
  67. stumble problem thats got me stumbling!
  68. 98 Avenger Keyless Entry
  69. engine fuse keeps blowing
  70. Hi Everyone
  71. '98 ES 2.5l smokes, yet no trouble lights...
  72. fuel problem
  73. 1998 Avenger ES Engine shot??
  74. I Guess This is Goodbye
  75. Got a spare $30K ???
  76. transmission upgrade
  77. nnewbie needs help
  78. Slight squeal and smoke from near p.s. pump on 2.5L V6
  79. breaking transmissions
  80. 2.5L engine noise
  81. 2000 dodge avenger alarm
  82. DIY Post on Replacing Door Handles?!?!
  83. Possible Interior Alteration?????
  84. Accesorry Belt Tensioner Pulley bolt
  85. overheating...
  86. For Sale: 1995 Avenger
  87. 1995 Avenger Computer Interchangable
  88. 98 Venge Question
  89. 1995 Dodge Avenger Just Dies
  90. Wife's avenger is frying throttle cables...
  91. GB: V6 95-00 Avenger/Sebring Leightweight Crank Pulley
  92. 98 dodge avenger.. 2.5 liter fast?
  93. In need of hood & front bumper
  94. P0134 issues after 02 replacement
  95. Tranny swap questions
  96. Overheating issue...
  97. 1997 2.5L transmission wont shift into overdrive.
  98. '96 V6 ES Avenger Engine
  99. 97 es > top end is knocking and ball joint recall no longer good!! ChryCo is crap!
  100. 99 aveneger trans problems
  101. D@mn multiple misfire code !!!
  102. 98 transmission problem
  103. 96 Avenger has a mind of it's own
  104. 95 2.5L and seafoam
  105. possible fuel pump??
  106. 99 avenger 2.5 6g73 NEED HELP!!!
  107. Interesting Tidbit...
  108. first post
  109. car jerking
  110. A604 Transmission Solenoid...
  111. parting out 97 es
  112. fuse box problems
  113. 1997 2.5L idle problem.
  114. Suspected grounding problem?
  115. How to remove black specs on 2.5L intake manifold?
  116. help with noise
  117. 98 Avenger replace tweeters
  118. how much horsepower can a 41TE automatic tranny handle?
  119. Radio Problem
  120. Where is the output speed sensor.....
  121. 96 Avenger won't start
  122. Multiple problems.....
  123. Recommended Tire pressure for 98 avenger?
  124. Dodge Stratus r/t 3.0L intake manifold on 2.5L?
  125. Dont think my 97 avenger shifts into overdrive
  126. 97 avenger makes clicking noise?
  127. Disturbing Motorsport CAUTION!!!!
  128. What the f#%@!!!
  129. Factory Fogs on with parking lights? How?
  130. Rear Speed Sensor?
  131. Brake Rotors removal help
  132. 98 dodge avenger wont start
  133. 99 avenger No Power locks? Only 2 speakers work?
  134. Crank sensor removal '97
  135. Help wont pass e_check
  136. A/C Bypass pulley...?
  137. New to Manual
  138. 98 Avenger - Please help?
  139. top middle dash(defrost,hazards,etc)
  140. '97 2.5L - oil in spark plug tubes?
  141. where to find complete axle for pass side
  142. PLEASE help I'm so frustrated...
  143. '97 avenger 6 cyl no power
  144. 3.5L manifold on 2.5L and cost of DMsports 5 speed?
  145. trans wont shift
  146. what sensor is this?
  147. 96 venger 2.0 alternator
  148. 1996 Avenger Brakes
  149. Aftermarket ECM...or Reprogramming?
  150. supercharge/turbo 2.5L v6
  151. what seats fit in a 99 venge? weather strip
  152. That darn P0740 code....!!
  153. Condom
  154. Need a drive belt Idler Pulley!
  155. Front Brake locks up
  156. A turbo 97 Avenger
  157. Need your vote ...
  158. Hello and Good Day
  159. 97 v6 venge horn prob
  160. idle problems
  161. Car shakes and vibrates
  162. White smoke/burning oil
  163. Major issues, please help!!!
  164. 96 Venge Revving Low at stops?
  165. Heater panel lights
  166. 1998 dodge avenger ES spker
  167. transmission surge-jerk-slip
  168. Someone help.. Oil Pan
  169. Cruise Control
  170. 99avenger check engine light/misfire?
  171. New Avenger: love it or hate it?
  172. Driver window sealing problem
  173. engine trouble......
  174. New wheels......
  175. Rough Idle and difficult to start on humid,moist, or wet mornings and when it rains.
  176. '95 ecm issues
  177. Radiator Prob......
  178. trans fluid pan bolts stripped
  179. 95 ES, TireAir lbs/Alarm
  180. Turbo ready 420A...What all do I need?
  181. Help Need a new Bumper
  182. Avenger transmission fluid
  183. Idler Pully tensioner bolt
  184. 97 avenger runs like crap and ticking after new trans!
  185. Smells like burnin...
  186. Locking up in reverse only?
  187. Passenger airbag cover peeling
  188. '98 Avenger Front End Shaking
  189. srt-4 motor
  190. '96 Avenger 2.0 won't start, help!
  191. 98 Avenger Electrical Issues
  192. 41TE transmission help
  193. 98 Avenger P0304
  194. 1995 Avenger 2.0
  195. Help with Avenger Starting Issues.
  196. Bad Venge OR Silver...I need your help!
  197. 98 Avenger stalling
  198. Smash Bang Crash
  199. 1996 avenger ES High oil pressure issue?
  200. Reliability/Repairs Questions
  201. Engine stumbles then turns off
  202. Exhaust Manifold
  203. squealing
  204. Need help!!
  205. Spoiler bolts?
  206. Overheating with ac
  207. Turning Noise
  208. V6 To I4
  209. Black tar coming from behind door panel...
  210. a/c belt help
  211. 97 2.5 ES throttle lag issue...
  212. Idler Pully Issue
  213. aftermarket crank pulley question
  214. Gauging Intrest Racing seats ready to bolt in
  215. What is pictured here???
  216. V6 timing belt question.
  217. O2 sensor question...
  218. convertion
  219. Removing back deck on 96 venge
  220. 98 ES 2.5 V6 Idle Surging Code P0122 Low TPS Voltage
  221. 95 Venge 2.5l Stalling issue....
  222. Over Charging???
  223. Fuel Rail Bushings/Spacers?
  224. I keep blowing a fuse
  225. lock/unlock door 1997 es 2.5
  226. car shutting off
  227. Tranny Issues?!?!
  228. p0300 code yet running fine..HELP....
  229. Starter on 2.5
  230. A604 Trans Valve Body
  231. A few questions about the sound system.
  232. Need help with o2 sensor location...p0134
  233. 97 Dodge Avenger whine
  234. 97 Avenger is leaking.
  235. Help!! Tranny!!
  236. Going to possibly purchase another venge.....
  237. cherry bomb glasspack
  238. Trunk and license plate lghts not working
  239. Avenger/Sebring ECM
  240. sticky e-brake on '95 avenger sport
  241. Photobucket pics of my Avenger
  242. replacing alternator plz help
  243. 1998 2.5 Avenger ES
  244. Simple question
  245. 98 venge door lock problem
  246. no spark 97 avenger
  247. Help with 98 Avenger
  248. A/C Not working
  249. K CEL acting.....weird
  250. What Now?
