View Full Version : 1st Gen Durango
- Best Spark Plugs for 99 5.2 v8
- Climate control fan, only works on high.
- Minor issues with a service manual
- water pump
- Clicking from transfer Case
- Transmission Question
- Bluetooth: '01 Durango
- got another ?
- 99 Durango Still Overheating...HELP!!!
- June Ride of the Month Voting!!!!!!!!!
- turbo kit for the 5.9 durango
- SLT?
- 2000 Dodge D SLT 4.7. Front bumper
- Durango wont drive
- 03 Durango Body Lift
- popping in steering wheel everytime i move it
- TROUBLE CODE P0456
- Where is the Camshaft Position Sensor?
- Vibration under acceleration
- header leak?
- 2000 Durango, windows
- 2003 Durango ball joint recall?
- 2001 Dodge Durango chime wont stop
- Will a 00-02 Body lift fit an 03 ?
- Transmission
- Valve noise and black residue
- weird noise
- Help Please!!!
- Steering Wheel Vibration...and gas at US 12c per litre
- Has anyone preformed a braking system upgrade?
- Viper Brake upgrade...
- 98 durango supercharged
- Durango differential ??
- 1999 Durango - lost top end of 1st gear??
- How to replace starter on 2000 durango??
- Clicking in the front driver side
- Driver side quarter panel (fender)
- Part Numbers for 5.9 Performance Ignition
- 2001 Durango R/T AWD transmission Clunk
- MOVED: Starting Durango
- Transmission
- Steering Wheel Radio Control Problems
- Compounded Electrical Problems! HELP!!!
- my first post HELP..........
- offroadin knocked my muffler loose and it sounds great
- noise consisting on RPM`s
- newb lookin to get faster
- Trailer Towing Wiring Harness
- Infinity Speaker Problems!!
- New MSD Ignition
- brake and abs light, no cruise
- HELP! Can't get Durango into "Park"
- 5.5 in. lift with 33's????
- Squeek Under Dash/Making Us Crazy
- Durango Torsion Key lift... 2-3in $100 ?
- Copper v. platinum spark plugs in 4.7?
- Power Window/Lock electrical Problem - FIXED!
- tools needed for caliper on 1999 durango
- cruise problems
- Replacement Audio amplifier
- gas gauge
- Pitman arm / direction Question
- 10 inch wide rims??
- Conversion to Ethanol / E85 ?
- Spare Tire Theft
- A/C problems??
- Blinkers dont work,HELP!!!4 ways work though
- Help
- PCM Question
- ball joint trouble..I think?
- May Ride of the Month Voting!!!!
- Blowin Fuses
- BLowing FUses
- Tires?
- New Owner
- 2001 4.7 60000 miles using water
- Front or Rear tires wear quicker?
- 1999 Durango Transmission Issues
- Durango 2003 P0601
- Installing Hitch on 2002 SLT 4.7
- Fried Spot Light Relay....
- No front A/C. 02 with rear air.
- information center on 03 wiggin out
- 2000 Durango Question
- Car and Truck of the Month, get involved!!
- 1998 Durango Stalling
- Performance Accessories Body Lift
- Rear passenger, driver side window doesn't power wind down
- power receptacle problem
- Front Axle Pinion Seal Replacement
- exhaust y-pipe?
- becool radiator
- 0-60??
- 2000 Dodge Durango
- lookin at a 99 durango SLT
- Cleaning the Throttle body
- 2000 durango brake problems
- RKE Keyless entry problem after changing CTM
- Could use a little help
- New Steering Wheel ??
- 03 R/T missing bellhousing cover bolt ok?
- belt/engine squeak ?
- plug wire sequence 1998
- New D 2006
- 99 2WD Durango rattle noise
- Cheap 2003 D/S Rotors and EBC pads spotted. Less then 1 day!
- VTSS Security
- Programming a oem keyless entry keypad
- rear disc brakes for 2000 rt
- Another possible RECALL!!!
- New D 2006
- Durango Mods Help
- PASSENGER SIDE LEAK
- Snow in Durango
- MOVED: dash and rear lights. Help!
- exhaust diameter???
- dash and tail lights. Help!
- dash and rear lights. Help!
- MOVED: New owner--Engine light on
- Just boutght a Durango 91K
- Removing Fan/Clutch
- FREE GREG SPRADLIN SRT10 PRINT!!!
- MOVED: Exaust
- Durango AC/Console Lights/Airbag failure
- Suspention lift kits
- NO TURN SIGNALS
- Exaust
- 2000 Durango engine swap 4.7 to 5.2
- PCM and Trans module conflict
- April ROTM
- MY D WONT START BATERY CHARGED
- New Member
- Let the MODS begin
- New owner--Engine light on
- Advice for new buyer
- 2000 Durango
- Suspension questions
- 99 Durango that will die going down the road seems like it happens more in hot wheather
- New and Need Help!
- MOVED: New and Need Help!
- 2000 door panels/windows
- 52mm throttle body question?
- Hi and Durango Repair Help
- Suspension lifts
- reverse lights and wiring diagram
- Color of injectors
- Brake light and ABS light are on dash board is lite up
- Good idea?
- Caravan Durango rear shoulder strap don't catch
- Oxygen sensor
- Check engine light
- easiest way to change 'cap & rotor'
- 2000 durango rt question
- Where to get Stainless Brake Lines for '02
- Problems with my baby.
- Engine upgrade
- tranny q's help
- MOVED: intermittent warning bell, 2001 Durango
- intermittent warning bell, 2001 Durango
- MPG Worse after tuneup??
- Can use some A/C help
- 2002 4WD System Info
- Back Bumper issue
- WHICH PLUG WIRES DO YOU USE (SURVEY)
- How tough are these Durango's...??
- New Member
- blinking rear-window defroster
- 1999 Durango w/ 5.2, buy?
- Electrical / Fuse ???? issue
- fuse blowing my mind
- New here, couple of questions
- Help with Radio Control Failure
- Now I've got problems....
- MOVED: newby. needs help dropping 00 D
- newby. needs help dropping 00 D
- MOVED: '03 Durango - Crazy Door Locks
- '03 Durango - Crazy Door Locks
- Front axle Locked in?
- Best place to get parts
- Key Fob...
- Step
- 98 Durango Trailer Help
- WHERE DO YOU GET NEW FOG LAMPS NOT MOPAR
- MOVED: 98 Dodge Durango starts then stalls at idle
- 98 Dodge Durango starts then stalls at idle
- 98 Durango Tune up Procedure???
- speed-o-meter
- Installing Bazooka Tube in 98 Durango?
- Minor Road Traffic Accident
- reverse problems
- whining sound from rear end???
- What is Factory A/C Temp?
- MOVED: Rear Diff Noise
- Rear Diff Noise
- CTM part # 02 durango
- MOVED: CTM part # 02 durango
- MOVED: Multiple Electrical Problems
- 2000 Durango - How to change headlights?
- questions about tire fitment
- 2 Durango issues
- universal garage door opener
- changing tranny fluid an tranfer-case
- How much did you get for your durango?
- Durango Tranny Failure: Chrysler Canada RUDEST CSR's around (rant)
- removing the head unit
- Transmission performance
- CV Joint or Wheel Bearing Noise????
- 88 durango trailer wire harness help
- ABS Clunking upon ignition
- Fiberglass Doors fenders hoods etc
- MOVED: SLT
- SLT
- 2001 Durango
- MOVED: Replacing Drive Axle/CV joints
- Replacing Drive Axle/CV joints
- 5.2 oil weight and capacity
- MOVED: electricians ?
- electricians ?
- MOVED: Removing a Fan
- Front and Rear Bumpers
- MOVED: Durango Performance 5.9
- Durango Performance 5.9
- Only getting hot air
- Removing a Fan
- which brake rotors to get
- Kennesaw Mountain Winch Bumper Group Buy
- 01-03 Durango Owners Possible Danger
- 1997-1999 5.2L / 5.9L Volant Super Sale
- MOVED: Engine control module
- Engine control module
- Coil Pack Clicking???
- Fender flairs??
- Rattling noise when accelating
- Tire question
- CB Antenna Mount?
- Issues with Durangos 100,000+ miles
- 31' tires on a 01 2WD Durango?
- Owners Manual
- Finally adopted a Dodge Truck
- looking for some wide wheels??????????
- Oil Pressure Up and Down
- Wheels???
- Heated seat problem
- tranny shift
- MOVED: how to replace a distributor
