View Full Version : 1st Gen Durango
- intrchangable
- 2002 Durango Rear Washer Line
- Struts or Shocks
- losing hope, stalls, bad gas mileage, power locks and more
- Transmission shift
- durango
- Extremely loud popping noise from under 1998 Durango
- 01 durango no rear heat
- Fix or Parts
- 99 Durango 5.2L will not start
- New cars are sweet!
- Pcm issues
- tranny issue
- New Member Have Question
- hi from ky Steven meek. need 411
- 01 Rango Fill up issue
- towing
- 2000 Durango Help
- engine knocking?
- removing dash panel for radio
- duango Trouble
- caliper bolt size
- Torque converter question.
- Brain picking time
- New Member!!! Need Help...
- Code p0440 is driving me batsh*t crazy!
- towing capabilities
- which transmission?
- What P/S Fluid to refill?
- 2003 Doge Durango rpms up and down
- Parking lights and instrument cluster lights up when I step on brake pedal. Any ideas
- Transfer case help
- fuses keep blowing
- Determining Transmission and Transfer Case
- Please Help!! 2000 durango transfer case 244 to 2003 durango transfer case.
- oil pressure
- Intermittent ABS and brake light issue.
- OBD-II commands
- Source for Rear AC/Heat Vents
- can this be tuned?
- 03 5.9 Thermostat Replacement
- Winsdield Wipers stuck in the up position.
- Use old PCM to Troubleshoot new PCM?
- Muffled Poping
- Water drivers side floorboard
- Durango 01 Remote star install
- Power steering pump replaced but........
- Durango not shifting out of first gear
- stall while driving P0108 and aftermarket brand advice
- gonna buy these shocks.
- 4WD selector switch
- Re-wiring audio - speakers
- 03 durango error code help
- Spar Tire
- 01 Durango 4.7 wont start without gas pedal floored and wont idle
- tcm part #
- 2001 Durango 4.7 Electrical Problem
- p code 1740
- allwheel transfer case
- Rear shafts
- 1999 dodge durango starting problems
- NO POWER STEERING SENSOR 2003 4.7 Durango
- Noise in reverse gear.
- Fuel pump wont work all the time.
- ABS and Brake light Help!!!
- need wiring diagram
- help please with steering question
- HELP!! door locks, dome light, evs11
- stumble at 2000 rpm need some advice
- flowmaster 40 question
- 4 WD issues
- BMW LED Foglights
- 2001 durango 4.7l code p300
- fixing P0480
- Drove through rough weather the other day...now rig is affected.
- Oil analysis results
- dodge durango 2012 services
- question about HID lights.
- error code po 551
- Anyone need a new '01 speedo cluster?
- 2003 durango slt 4.9no reverse lites
- Just got a 99' Durango, Help?!
- No heat
- 01 durango Grill guard bracket
- stalling issue
- Durango Issues - Stumped At This Point
- how much does lifting cost?
- Do they have pocket style fender flares for 2003 Dodge Durango?
- Possible Power Steering issue
- Front end wearable parts replacement
- Shocks and Exhaust recommendations
- turn signal problems.
- Horn stays on when running/headlights are on
- Steering Gear Box
- 1998 Dodge Durango SLT 4X4 5.2L Transfer case blown!
- Tccm.
- Brake fluid disappearing..?
- Spare Tire - Wheel Winch
- I'm gonna pull my hair out with this tranny
- No Drive Condition with P1763 DTC
- 1998 5.2l chugging
- 2001 Durango- replace spark plugs
- Tax Return inspired mods
- [PART-OUT] 1999 Durango - Burgundy
- Will h7 hid conversion kit fit durango
- Is it safe to drive with code P0480
- Front Passenger CV axle 03' XLT 4x4
- Tranny probs?
- Change heater core by cutting the firewall?
- birds&bells living in My5.9
- 4x4 question / issues
- 2003 no spark
- Hi I am new here and i have blinking Headlights
- what trans do I have??
- heat still doesn't work
- alternaotr went bad
- level kit
- New forum sponsor (///MoparAmerica) - Hey guys and gals!
- Help with HEAT please
- transfer case??
- 01 durango shuts off
- PCM harness connectior
- how to remove transfer case motor???
- no reverse lights
- 1st gen parts swap
- Front sway bar torque values?
- please help!!
- Can't shift from Park!!
- Turn signals
- Loose steering
- Power seat id and wiring
- power loss......Clueless....PLZ Help
- Dash and Firewall Diagram?
- help
- any 03 durangos with a PA 3" body lift?
- Starting Issue
- Need help
- muffler choice?
- How Sturdy Are Caliper Pins?
- how hard is it to flush heater core
- overdrive circuit
- alternaor
- gas miles and 4.7
- dodge transmission guru's i need you
- 390 stroker build trans questions
- no bus error
- Opinions Needed on Purchase Attempt!
- Problem with changed tie rod passenger side
- Brakes Locking
- 2000 46re question
- flood waters caused P0480
- Bored Out Throttle Body
- changing oil and filter
- whit brand tire is everyone running?
- Low Voltage on Startup
- P0480 and P2530
- 2003 4.7L Starting Problem
- Lifting my 01 rango
- What would you do
- '03 4x4 Front wheel bearings
- 98 Dodge Durango Fan Clutch
- Rear wheel cylinder
- Anybody running a Dynomax Ultra Flo muffer?
- rear view mirror
- durango 4x4 saved my ass
- truck dead. Won't take a jump, not making any sort of clicking sounds.
- Left Signal & Hazrds Dead When Headlights are on.
- Transfer case shifter
- Heater core replaced now no lights and air bag light
- Shock advice for 2" T/S lift
- 4.7 HP mods and discussion
- Front diff is blown...
- ABS light on dash board, No ABS on wheels
- 2003 durango
- 2002 Durango start issue
- 2000 4.7 loud power steering
- 01 durango, no front heat
- where to find a hvac box? and how much?
- 2000 Durango SLT 4.7 Ltr 4x4 - Intake Plenum Gasket
- Front differential help
- 2002 4.7 to 5.7 hemi durango
- NEW DURANGO OWNER!!! with a heating issue...
- Add Towing after build?
- Need Help: Another car shuts off question (while turning)
- The BS Thread
- 2000 4.7 Not Starting Issue
- 4x4 actually engaging but noisy, and dash indicator light not lighting up.
- New Membet
- clicking noise while in 4wheel drive
- Code P1281 ???
- My '03 Dodge Durango SXT 4.7L
- 2003 durango problem
- Lost heat
- type of oil and changes
- Durango won't move..
- Alarm system
- 2001 Durango SLT Starts then Dies after 2-3 seconds
- ELM 327 OBDII troubles
- R/T out the Gate...
- tranny swap. finally!
- 2 new issues under my Durango.
- How to disconnect the body wiring hareness in a 1999 durango
- No rear running lights with headlights
- Radiator Replacement Question
- HVAC Vacuum line location through firewall?
- Did the homebrew intake mod today...now another question...
- New member- Question about coolant consumption
- Motor mounts 4.7 to 5.7
- I could use some "Whats Next?" advice.
- Fitting 24 inch rims?
- Wilwood caliper conversion
- 1999 dodge durango 5.2
- Swap
- After Market Cargo Rack?
- Intermediate drive shaft replacement
- Failed State Inspection cuz of a few little things.
- Polished turd?
- Is this the right Flowmaster for my '03 4'7 liter?
- Cigarette Lighter & 12V AC plugs out.
- 99 Durango doing crazy stuff...help!
- Wheel toed out
- my 01 durango 5.9 R/T
- 2002 Dodge Durango won't downshift.
- Door lock electrical issues
- I.a.c, abs, possible vacuum leak
- Rig stalls while running...
- 98 Durango 5.2 timing gears
- vent issue
- Exhaust could clear Wal-mart parking lot!
- Rear heater core question
- Wolverine Heaters vs. Engine Block Heater vs. Remote Start
- So, I put a new ABS rear speed sensor in...
- All new power steering, now doesn't work
- Power steering... or not
- Question
- Cutting off
- To Do List on the Durango...
- Tire Rub
- Replacement Headlights
- Temperature Control Knob
- Tinted my Windshield
- 4.7L Oil Pressure issue
- Front wheel hub issues???
- 2001 Durango won't start
- Coil packs
- new to to the Durango family
- 2003 SLT 4.7 engine rebuild
- 2003 Durango 4.7L No Oil Pressure
