PDA
View Full Version : 1st Gen Durango
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. 2003 durango ac problems
  2. A/c prob.
  3. transmission plug
  4. Oil pressure gauge issue
  5. pROBLEM W/ 2002 DURANGO 4.7L
  6. what kind of problems can i expect from a 2001 dodge durange
  7. Will 46RE tranny work out of...
  8. power steering gear box
  9. Coolant Leak
  10. 4x4
  11. Tinted tail lights problem
  12. 01 Durango idle's rough and stalls, Need help.
  13. Does this sound like I need a band adjustment or more?
  14. 2002 Durango Grinding
  15. Whirring noise in reverse?
  16. 2000 Durango Tow Capacity? I think I got taken.
  17. Selling my durango
  18. Introductions and IAC / PCM Question
  19. 5.9L performance input needed
  20. Suspension ideas...
  21. Rust, rust and more rust! (Pics inside!)
  22. electronic brake controller
  23. Bad transmission leak HELP PLZ!!!
  24. led third brake light
  25. Spark Knock?
  26. Transmission torque managment
  27. Help p0700
  28. Swapping Pull Knob for Turn Knob Headlamp Switch
  29. Flushing the Radiator?
  30. Head Gasket.
  31. Which cyl. is #8 on 4.7l??
  32. ***asap****
  33. Stalling Issue
  34. A/C low pressure 25 high pressure 75, belt squealing
  35. Rear End.
  36. Aftermarket Cats
  37. Installing Cold Cathodes
  38. More Power?
  39. Heater Eating Connectors
  40. No head lamps / dome lamps
  41. 1999 Durango SLT
  42. Fuel doctor.?
  43. Its leaking...
  44. Broken Camshaft
  45. oil change time...
  46. Installed CAI kit...now truck runs hot????
  47. Hissing sound, engine dies.
  48. Warning Light Causes. (ABS & BRAKE)
  49. Dodge Durango Power Steering Problems
  50. Passenger side window issue
  51. Superchips tuner
  52. Automatic Gear Shift
  53. Transmission Q's
  54. Heater core
  55. oil pressure gauge maxing out on key on
  56. CAI kit......throttle body connection woes
  57. overhead console
  58. 2000 fan blower motor
  59. Rear Passenger Brake Hose
  60. I want to change my spark plugs.
  61. Rattling Start, Engine Ticking, No Window controll
  62. Engine Vacuum, and Gearing...
  63. I Want a Smoother Ride!
  64. Key Fob.
  65. Break Line leak?
  66. 2000 4.7 rough idle 11.4 city 13.5 highway mpg 104k miles
  67. Durango Seats
  68. Octane conversion based on Altitude
  69. Sudden Drop In Fuel Mileage 2001 Durango
  70. Turn key and nothing
  71. Hughes or m1 intake???
  72. 03' Rear Disc Brakes...
  73. 2001 4.7 4x4 Transmission Question
  74. supercharger help
  75. new plugs champion iruduims ?
  76. Wheel Bearing Investigation
  77. Tour Event
  78. In the market for a new D, Opinions on what to get?
  79. DTC Question
  80. Question about front drve shaft...
  81. Fuel pump ( maybe? )
  82. Having trouble refueling my 2001 Durango
  83. Headlight issues
  84. Trans issue.
  85. AC Doesn't Work At Elevation
  86. Clicking noise and other noise while in 4 wheel drive!!!
  87. Rear Axle - Make and Model?
  88. Yes, I know, ANOTHER balljoint question.
  89. Signal Light Problem
  90. Getting ready for the ALL important EVAP core switch out!!!
  91. Rear Heat.
  92. Hard Shifting Transmission
  93. Transmission Advice!!
  94. Electrical issue with no clue where to start looking
  95. 2000 Durango No Bus code/stalling/Trans not shifting
  96. Annoying wheel stud problem
  97. 98 Durango SLT 5.9 Squealing noise (water pump)
  98. 98 Durango SLT 5.9 Steering play
  99. Blower and 4x4 problems with 2000 4.7L...
  100. strange idling
  101. Engine Code Mania
  102. 2001 4.7 4X4 Need help solving engine vibration!
  103. Check this out....Evap hose kit
  104. transfer case troubles
  105. Brake light and ABS light came on
  106. CTM, PCM, steering
  107. Front Drive shaft Bad
  108. 2001 sport 4x4 troubleshooting
  109. A/C poll
  110. Sarona.com...bodykits for our durangos
  111. 2003 Durango Bank one sensor
  112. Muffler and Mirrors
  113. Possibly mixed antifreezes?
  114. What is best magnum engine in orlando fl?
  115. intermediate steering shaft question.
  116. Durango Stalling.
  117. Custom Wheel
  118. acceleration studder when cold
  119. engine troubles
  120. which exhaust system?
  121. She's over heating again
  122. Replacing Stock Muffler
  123. Issues with Horn
  124. Broken Shock Bolt
  125. Loss of Air through front vents after heater core replacement
  126. Speedometer not working after heater core replacement
  127. Loss of steering after Pump Replacement
  128. ac not working
  129. Brake System Overhaul
  130. 2001 durango r/t shaking intermittingly
  131. Rpm jumping?????
  132. A/C leak coming from behind the glovebox?
  133. Cross rails on luggage rack
  134. tcc solenoid heeeeeelp
  135. Cinderellas Carraige!
  136. AC Evap Removal
  137. Need to Get Tow Package on my Durango
  138. Info on shelby sp 360 durangos
  139. A/C doesn't seem to be blowing hard
  140. starter
  141. please help 02 durango
  142. Need some parts....
  143. durango bolt patern
  144. Woo-Hoo, new shiny brakes.
  145. Type of Gear Oil for Front Axle Differential
  146. Overheating
  147. Farewell!!
  148. 01 5.9L sputtering/acts like its not getting gas
  149. p0601 internal control module fault any ideas
  150. Need a new Radiator...
  151. Part number needed for these peices. Pics inside.
  152. Trans Pan Gasket
  153. 2001 Dodge Durango 5.9L has no heat
  154. Found This in My Diff
  155. Will a bent rim cause false wheel alignment
  156. Problems with something in electric
  157. Tranny coming out - suggestions?
  158. Cold Air Intakes
  159. 2001 4.7 Rough Idle Need a solution!
  160. CTM problem... With a twist!
  161. Vibration in steering wheel and brake pedal at low speed
  162. High Pressure Pwr Steering Pump Hose ????
  163. 4x4 dodge durango
  164. New O2 sensors?
  165. New Generic China made audio deck for Chrysler
  166. Best Replacement Parts (Brakes)
  167. 99 5.9 no bus?
  168. suv wont start in rain help
  169. Humming/buzz noise from center/rear under carriage
  170. Diagram for Front Differential
  171. Transmission Reaction Shaft Condition
  172. Shake Rattle and Roll!
  173. Low idle Maybe?
  174. Just plain stuck
  175. Fender Trim
  176. OEM or are there better aftermarket options?
  177. sas on a 98 durango
  178. Did some wheeling this weekend...
  179. Speedometer way off
  180. 01 5.9 2WD dies with no acceleration
  181. 99 Durango ABS and Brake lights and oil pressure problems
  182. 2000 Durango electrical towing Problem
  183. Engine light code p0301
  184. Any way to repair frame? ( 56k warning! )
  185. 99 Durango SLT 4x4 Transmission not shifting
  186. throtttle body cable stretched?
  187. Scary
  188. ABS and Brake light
  189. 99 Durango 5.9 PCM - what is the best source
  190. 2k Durango wont start after short drive
  191. Replaced Steering box, now pulls to right
  192. fuel delivery nobus code
  193. change motor from a 4.7 to 318
  194. differential fluid type?
  195. A/C question
  196. pcv rattlle...
  197. Cabin Air Filter?
  198. Front brake lock up AGAIN!
  199. Door Lock Cylinders.. (Intermittent locking and unlocking)
  200. 98 4x4 slt howl
  201. 01 RT Trans has 'Lost' Reverse - Any 'Good' news?
  202. Brake light issues with 02 durango r/t
  203. 02 4.7 Durango noise on exceleration
  204. K&n filter size
  205. 2003 Durango Stereo Installation issues
  206. 46 re
  207. 02 Durango dying while driving
  208. 2002 dodge durango problems
  209. ABS pump problem. (Couldn't find an answer in other threads)
  210. more 4x4 issues
  211. Breaks and Evap Question
  212. Adding an oil cooler to the D
  213. Swapping Guts on a 44re Transmission
  214. Tune up
  215. strange code
  216. 4x4 issues
  217. Under the dash rattle
  218. '98 throwing codes
  219. Spare Tire/Wheel
  220. 01 steeering knuckle on a 99?
  221. 2001 dodge durango 4x4 slt
  222. Air Intake's on 2003 dodge durango 4.7
  223. flooding issue
  224. cowl induction
  225. oil pressure suddenly drops
  226. None Working Speedometer...
  227. Quick Thanks! (RE: Sway Bar Bushings)
  228. 03 Roof rack load limit?
  229. 98 Durango SLT rear hatch lock wont open!!!
  230. Brake Light "Y" location?
  231. headlight assy removal.
  232. Seeking - 98 Durango OD wiring diagram
  233. po500 and no spedo!
  234. PLEASE HELP 99 dodge durango
  235. Power Window stuck in the up position
  236. New member needs expert advice!
  237. Trash can airbox for CAI
  238. 98 Durango Trans Problems - Tried everything!
  239. Windshield swap 99 to 03
  240. 01' dodge durango 4.7lt v8 steering problems
  241. wheel bearing hub problem
  242. rear differential input & level check?
  243. water pump and fan clutch toast
  244. Bore Out 318
  245. Hyper sensitive brakes
  246. Girl + 2000 Durango = Confusion
  247. Bucking, hesitation, and no power! Emissions problem?
  248. 4 wheel drive question.
  249. OT, Trouble searching this forum ?
  250. Do i need a Tune up, fuel filter, fuel pump or what???
