PDA
View Full Version : 1st Gen Durango
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. Do I buy 2WD or 4Wd replacement parts for the D??
  2. 2003 Dodge Durango SLT 4.7l hesitates when accelerating from a stop
  3. 5.9 no crank/ no start
  4. Help solve incline problem
  5. Coolant Problem?
  6. Not gonna throw a fit YET... BUT....
  7. wont start. need help asap
  8. dodge durango
  9. bad hub assembly?
  10. 4wd issues
  11. bad hub assembly?
  12. 2002 Durango HVAC Ducts
  13. max size of tire for stock 03 durango.
  14. Let's Talk Appearance!
  15. Planning on buying first-generation Durango
  16. DodgeForum at Chrysler Nationals!
  17. Steering box problems
  18. cleaning little rust under your truck.
  19. 2001 Durango jumped timing
  20. 2002 durango
  21. transmission filter, gasket and cooler lines
  22. The Rig Is Done... THANK YOU!!
  23. 4WD problem
  24. 8 mpg
  25. Problems Help...
  26. vacuum hoses
  27. 4.7 vs 5.2 V8
  28. shifter cable for 2002 durango...HELP!!!!
  29. thinking of converting a first gen durago to electric
  30. 01 Durango Front Tread Width?
  31. On The Fence
  32. Vehicle quiting
  33. Blend door problem???
  34. Help with transmission
  35. front bump stops
  36. heater in the rear
  37. Is it my battery?!?!
  38. Helper Springs?
  39. Taking My D Back
  40. 2003 R/T Durango 5.9 Waterpump
  41. Spark Plugs and Timing/Idle
  42. Hypertech Power Programer for 1998 Trucks/SUV
  43. 01 Durango transmission trouble
  44. Gas gauge
  45. *sigh* Help with my Problem Child Please
  46. Power lock and blower knob backlight issues
  47. Cant start
  48. 33X11.5 on my wifes durango
  49. custom rear cargo cover/shelf
  50. Which hitch for a Durango 2011 oem?
  51. Abs??
  52. 2000 Dodge Durango misfiring
  53. security beeping
  54. HVAC impossible firewall nut! ideas please!?
  55. Locking hubs?
  56. 1 Gen Durango Heater Flow
  57. Looking for Intermidiate Shaft
  58. Factory Alarm
  59. Catalyst not being read at DEQ
  60. I've HAD it with Midas Brakes!
  61. I NEED HELP!! Please? :)
  62. Dodge Durango Oil Pressure Problem
  63. Side mirror's
  64. Suggestions; Brake parts to use..
  65. Security light flashing on/off rendomly...
  66. Dodge Durango DTCs P1757 And P1762
  67. 4x4 question
  68. IF anyone can
  69. Shifting Issues
  70. Lift Kits
  71. please help
  72. lifting my 99 Durango
  73. A/C Blows Hot, But Barely Blows Out
  74. Bypass the Heater Core
  75. tires
  76. 4 wheel drive lever issue
  77. Got build sheet, very interesting...
  78. What began as a rough idle, now won't start
  79. Disable airbags 2000 Durango?
  80. Rebuild / Head Gasket Fitment - 318
  81. Ashtray bulb replacement
  82. Help on 2Wd Suspension, Wheel & Tire Upgrade
  83. Looking to buy 1st gen Durango...need help and advice please
  84. 00 5.9L Durango P1740
  85. 02 Durango code P0344
  86. Another misisng part?
  87. If anyone can help...
  88. Help solving my durango
  89. intrest in 1998 preunner?
  90. How much can I tow?
  91. Leaking antifreeze
  92. Durango cargo cover
  93. Stumped! Died idling, 100% loss of power.
  94. 4-Lo problem 02Durango
  95. Durango won't start
  96. Transmission removal
  97. Need help with the radio
  98. Help, wont start
  99. Tranny questions
  100. Clutch Fan?
  101. Back hatchdoor Compatability
  102. Another potential problem arises
  103. 2002 front drive shaft
  104. Over sized caliper bolt question
  105. Drone noise in front of 2001 Durango R/T
  106. limited slip/posi
  107. evaporative/emmissions code P0440
  108. Photo ad question
  109. Brush Guard Help
  110. trans/drivetrain rebuild/overhual ideas
  111. 2000 dodge durango (4.7) crank sensor
  112. Very Strange 99 5.9L issue, tranny or ecm?
  113. 01 durango. getting horrible mpg around 6mpg
  114. Awd?
  115. Creaky front suspension?
  116. 87 vs 91
  117. Value Question
  118. 2000 d.dur 4.7 wont start !!! Please help
  119. Replace water pump 2003 Durango 4.7L
  120. Passenger door wont unlock!?
  121. 2001 durango slt 4.7
  122. 99d 46re tranny...down and out..questions
  123. Engine is smoking and overheating!!
  124. Trouble Reading the Engine DATA
  125. 2002 durango engine swap
  126. Suspension roughness
  127. About to buy new brakes.
  128. New Durango, Couple questions
  129. Stumped 02 sensor problem
  130. Oil pressure drops, this is what we found
  131. shifting troubles
  132. Head Gasket Fitment 318 Magnum, 98 Durango
  133. 02 4wd...cv axle
  134. 99 durango power locks keep unlocking
  135. Low gas mileage since engine overhaul
  136. Front wheel problems
  137. Performance upgrade help needed
  138. Help!!! 99'Durango Transmission issue..stranded 3 hours from home!
  139. engine stalling issue
  140. Grinding noise coming from rear end
  141. Code P1889 issue
  142. Wtb window trim for 98 durango
  143. looking for this bull bar..
  144. Antifreeze leaking on the carpet!
  145. My irritating ultra slow fueling issues
  146. Another Blinker Malfunction Thread
  147. To Service or not.....
  148. 00 Durango Single Click, No Start
  149. fuel pump
  150. Idling Issue and while driving too...Pls Help
  151. Hey new here few problems
  152. Hankook Tires Ventus ST RH06 Tires
  153. 2001durango code p0420 & p 0700
  154. New to the Forum
  155. Tansfer case broke
  156. 98' Dodge Durango Not Starting!! HELP!!
  157. Replaced Turn Signal Flasher, Now Brakes Stay On Permanently
  158. 2002 durango 4x4 needs new tires
  159. need help asap with 99 dodge durango 5.2L V8 318
  160. Crazy blinker
  161. rear wing?
  162. Trans Problems.
  163. Weird Bass issues from kicker box
  164. Blower motor resistor?
  165. Please help this is bad
  166. trying to decide which timing kit
  167. Superchips AND Sct
  168. Do horsepower mods kill torque?
  169. Left Front Noise Hub Bearing??
  170. loss of power
  171. Rear Caliper Conversion
  172. 2003 Durango 5.9L RPM fluctuation help
  173. 2000 durango 4.7lL 4x4 slt
  174. where could i find transmission relays and such components?
  175. Trying not to beat a dead horse...
  176. tips on changing my differential fluid
  177. trailer wiring question
  178. rear end swap, and superchips
  179. overheating!!!
  180. Lifting a '99 Durango.
  181. Plz help 2001 durango 4.7l
  182. 2000 Durango tranny issue
  183. 01 durango aftermarket front driveshaft question
  184. 98' Durango 5.2 speedomiter problem
  185. New muffler affects mpgs¿????
  186. Plenium gasket
  187. February ROTM
  188. p1765 check engine light!!! someone please help!
  189. my overdrive is off, my buttont work, please help!!!
  190. Lookn for 4x4 trails in NH
  191. Chattering gremlins need to die !
  192. Chatter in the Rear on slow sharp turns
  193. engine rebuild, mild performance incease, lots of questions?
  194. Fu·$T·ck!!! A/C blower out!
  195. Durango Buying Questions
  196. Water in valve cover
  197. resonant cabin drone?
  198. 2000 durango
  199. Upgrade
  200. Another problem
  201. need help....replaced evaporator and durango will not go in gear
  202. PCM troubles
  203. 2000 Durango SLT Air bag light keeps coming on
  204. Body part swap
  205. RPM during moderate acceleration?
  206. Stumped on tranny issues!
  207. will not start
  208. 2WD 99 d front bump stops..pics
  209. heater issues...
  210. Rebuilt PCM
  211. Still no heat!! HELP PLEASE!!!
  212. Fuel Pump???
  213. Looking to buy...
  214. Steering wheel audio controls
  215. 4x4 clicking bad/clinking when engaged
  216. Tps issue?
  217. 5.2 most efficient differential?
  218. Head Gasket's an Head Question
  219. Lifting the D and setting up for off road fun NJ
  220. Anyone upgraded to touch screen stereo/gps/etc
  221. Fog Light Question
  222. 01 durango getting 6mpg plz help!!
  223. What the heck does this go to?
  224. Long Crank causes engine code P0302
  225. The big surprise my trans had for me...
  226. 03 Durango Blower/Resister and connecter shorts.
  227. please help, my Durango automatically shuts down, and I get a check engine light!!!
  228. Need help my dodge Durango keeps shutting off and I get a check engine light!!!
  229. 110,000 miles. Replace oxygen sensors?
  230. P0700, p0734, p1790
  231. Strange Motor Problem
  232. 2wd d suspension question
  233. Found this under my car
  234. Noticed variance in heater/warm air get cooler
  235. 98 Durango With Magnum V8 5.7?
  236. PCM Part Number Question..
  237. 99 Durango 5.9 slt (pcm is in limp mode)
  238. rack and pinion replacement
  239. Transmission 44RE for Durango
  240. Help!!! Back window about to fall!
  241. Coolant Flush should I or should I not????
  242. 2000 dodge durango 4.7 please help
  243. Left Turn Signal blinks too fast......
  244. Battle of Rare Colors
  245. Brakes squealing after all pads replaced
  246. ?? replace oil pan gasket
  247. SpeedO on 99 D
  248. Possible Duragno Purchase
  249. Does CAI really work?
  250. 2001 Durango SLT 4.7 4WD Heater blower motor questions
