PDA
View Full Version : 1st Gen Durango
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. 98-D A/C Useless
  2. R/T's engine blew up!?!?! have a few questions?? need help!
  3. Hypertech, or Flashpaq
  4. Calipers sticking ??
  5. turn signal light messed up
  6. 2001 Durango Transmission Issues - Electrical?
  7. New tranny video
  8. wheel bearing
  9. serious knock
  10. 01 Durango no start issue
  11. Air Conditioning Problems
  12. need a front diff!
  13. Resistor Pack Connector
  14. Engine light question
  15. AC Compressor runs on all settings
  16. interesting problem/hopefully easy fix
  17. serpentine belt where is the tensioner
  18. tensioner what one is it?
  19. compressor plz help
  20. Repainting Roof Rack
  21. trouble posting
  22. 2000 r/t
  23. knocking from the compressor need help
  24. Durango wont stay running HELP!!!! asap
  25. front sway bar diamater?
  26. Steel Cowl Induction hoods?
  27. Radiator (need a new one)
  28. Tranny cooler
  29. Caliper bolt 1999 Durango
  30. p0456
  31. sucky acceleration
  32. 2wd lift
  33. Transmission coolers
  34. Upgrading to high performance muffler/exhaust system
  35. 99 Durango Transmission issues
  36. A challenge for you
  37. burnt diff oil
  38. Funky Fuel Gauge Behavior
  39. Durango/Jeep SRT8 trans/transfer case swap
  40. Air Intakes... Closed in or open?
  41. Looking for a part, not sure of correct name or #
  42. windshield wiper problem
  43. AC Compressor Cycling
  44. P0601 engine putts, pops when accelerating
  45. window is off track
  46. 02 2wd upper balljoints durango
  47. Changing to a Airaid or FastMan TB HELP?
  48. shift kit 99 4x4 durango
  49. cant post replies
  50. 98 Durango Broken Exhaust bolt
  51. 2002 Durango AC blows cool not cold
  52. 02 sensors
  53. oil pan change
  54. No power to radio fuse
  55. PLEASE HELP! Power Lock And Window Issue
  56. Durango O2 Sensor
  57. chopping my cat
  58. Towing Questions
  59. What causes the computer to "burn out" or go bad?
  60. How to replace transducer pressure sensor for code P1762
  61. 413 truck motor
  62. Used Hitch question
  63. Gas Mileage Not up To Specs
  64. Function dual Hood Scoop
  65. weak A/C not real cold or blowing hard
  66. water on passenger floor board
  67. FRONT BLOWER MOTOR RESISTOR
  68. reverse light malfunction
  69. Computer location
  70. Radiator replacement
  71. 01 Durango Shifting problem
  72. Electrical diagrams?
  73. Replace both camshaft and crankshaft sensor on 2000 Durango 4.7L?
  74. '99 Durango windshield washer pump
  75. Driver seat issue
  76. P0505 & P0443 On 2000 RT Durango
  77. NV233 AND NV244 ?`
  78. transfer case help again
  79. Rear A/C blower
  80. Overhead Console Love or Hate it
  81. AMP AND CD CHANGER
  82. 99 Durango Kicks & Sputters
  83. Computer problems
  84. Camshaft/Crankshaft position sensor replacement on 2000 (4.7) Durango?
  85. Want to lift my 2000 Durango 4x4
  86. Want to lift my 2000 Durango 4x4
  87. Help With A/C Leak
  88. Radio stops working intermittently
  89. rpm fluctuates??
  90. Blower resistor plug replacement?
  91. Malfunction Indicator Light
  92. Transfer Case Question
  93. 2002 Durango Underbody Refrigerant Lines
  94. power window regulator
  95. Draining '99 Durango radiator
  96. HELP! (2000 Durango) What A/C port to I hook my freon charger to?
  97. 4x4 question, CAN ANYONE HELP ME
  98. Cam positon sensor location on 4.7 Durango
  99. Help locate CTM for 2001 Durango
  100. Why no platinum plugs for the 4.7?
  101. Interchanging doors
  102. will not idle
  103. dead battery/clicking glove box
  104. airbag lite on no horn....
  105. Just Bought a 99 Durango Need Some Tips
  106. 98 Durango dual A/C Help PLEASE
  107. Trouble Starting
  108. P0036 02 Durango 4.7
  109. AC Problem
  110. Tranny or electronics
  111. A/C problems...blower motor
  112. HOW TO FIX STRIPPED CALIPER BOLTS
  113. Rough idle, flatspot in accelerator.
  114. FRONT SEATS
  115. Hot Brakes/Rims
  116. Durango Guys
  117. 2002 2wd Dodge Durango help needed
  118. AC hot and cold?
  119. 17" black powdercoated R/T wheels
  120. 2000 Durango, 4.7 4X4 Tranny Question
  121. UPGRADES
  122. A/C compressor won't stop
  123. model number of transfer case
  124. transfer case crack help
  125. Hauling a boat that's over the towing capacity?
  126. Changing durango spark plugs
  127. Lug Nut Torque?
  128. ABS ??
  129. Front turn signal bulb replacement.
  130. Problems with iradic idling on start up
  131. Reverse Lights not working
  132. Anyone relocate IAT sensor on 4.7L w/ K&N FIPK
  133. Front Brakes Sticking
  134. Code P 0207 + New info
  135. 2000 Dodge Durango towing capacity=2000 lbs on the 4.7 v8 engine?
  136. Towing with my D
  137. New guy just checkin in!!!!
  138. 1998 Durango
  139. overheating
  140. It won't start...0 RPMS while cranking. Help!
  141. xylene added to gas
  142. transmission problems ? over Drive
  143. test
  144. front end problems
  145. Tranny leaks
  146. Tranny won't shift into fourth
  147. Durango Caliper Question
  148. 98 Durango won't start
  149. Fuel Pump????
  150. Upper Dash Pad Removal
  151. Front bumper replacement: DIY job?
  152. 01 D SLT rpm issue, stays at 2000 rpms...along with a new whinning noise thats always there
  153. BODY LIFT HELPPPP!!!!!
  154. Towing Package - Always Includes Transmission Cooler??
  155. No Electrical
  156. Power Steering pressure switch available????
  157. Muffler or catback
  158. How do you tell if it is time to change you cat
  159. Roof paint chipping & cracking
  160. Purge Valve 99 durango
  161. Help with 4.7L Serpentine belt!!
  162. Upper control arm bushings
  163. 1999 Durango won't start
  164. possible transmission problems
  165. Where can I buy taillight tint?
  166. What is the operating temp of a 5.2L
  167. durango for sale???
  168. power windows and locks stopped working
  169. Having network problems - HELP!
  170. shocks
  171. Lincoln Mark Viii electric fan install
  172. Pic's of the trailer!
  173. Why engine miss, 2 damp mornings(related?)
  174. Can this be done?
  175. A/C pressure switches
  176. 4wd low light
  177. Air conditioning, blower, hissing
  178. 99 4X4 Control Arm Bushings
  179. ABS/Brake - Code 65 Internal Relay
  180. Problems wth my 98 Slt plus 5.9L 4x4
  181. TIRES- R/T owners and others looking for replacement tires -see inside
  182. HELP... Rear brakes dragging
  183. Transmission Question...
  184. 99 starts itself-remote start issue?
  185. rear door panel
  186. Small Vibration on the Highway
  187. P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
  188. ?'s bout my '98 big red dingo
  189. Water leaking into passanger side
  190. questions
  191. headers on stock system?
  192. maf/iat sensor
  193. axle noise
  194. Alt,Batt,Elec?
  195. AC/Heat Fan Only Works On HIGH
  196. towing question
  197. Sound when pressing on gas pedal
  198. thanks for the info
  199. part throttle miss & stumble
  200. Anyone try HHO?????
  201. oem cd changer location???
  202. 5.2 Serp Belt Routing
  203. In a pinch.. help please?
  204. Idle issues
  205. Yesterdays Trip
  206. Cooling Issues
  207. A?C FREON help for 5.9L
  208. My new mod
  209. Parking lights won't turn off
  210. conversion?
  211. I need to locate an engine, any sources?
  212. Durango parts
  213. durango r/t
  214. How many cans of freon? V6.
  215. Spark Plug
  216. MOVED: Outer Tie Rod for 2005 Durango
  217. Outer Tie Rod for 2005 Durango
  218. Speaker Wires
  219. Hot water on the passenger floor....
  220. PCM Woes
  221. 1998 Durango SLT front end noise
  222. Electrical GONE CRAZY!
  223. speaker replacements
  224. 01'dodge durango needing help!
  225. Brake Problems
  226. P0505 idle sys. malfunction, any others w/ this problem?
  227. 98 D stalls in reverse
  228. Finally got to detail the Durango
  229. Possible 03 Durango SLT Purchase
  230. Gen1 memorabilia
  231. Muffler installed backwards?
  232. Hey guys
  233. 01 Durango 545RFE flash available
  234. 18" SILVER ALUMINUM WHEELS FOR SALE
  235. 98 Durango trans over heating problem
  236. RMP's jumping up not down
  237. Running boards dodge durango
  238. Is there a way to tighten the Side mirrors?
  239. rectifier bridge?
  240. Codes.
  241. 1999 durango back hatch won't open
  242. I need Help
  243. o.e air intake question HELP!!!!
  244. Computer Tune
  245. replacing shocks
  246. Thinking about an exhaust setup, looking for advice
  247. possible tranny issue???
  248. HELP! engine noise
  249. How to improve MPG
  250. Getting ready to add to the D
